20#ifndef __OPTIMIZERLOOP_HXX__
21#define __OPTIMIZERLOOP_HXX__
77 OptimizerLoop(
const std::string& name,
const std::string& algLibWthOutExt,
78 const std::string& symbolNameToOptimizerAlgBaseInstanceFactory,
79 bool algInitOnFile,
bool initAlgo=
true,
Proc * procForTypes = NULL);
82 void init(
bool start=
true);
84 int getNumberOfInputPorts()
const;
88 InputPort *getInputPort(
const std::string& name)
const ;
89 std::list<InputPort *> getSetOfInputPort()
const;
90 std::list<InputPort *> getLocalInputPorts()
const;
91 void selectRunnableTasks(std::vector<Task *>& tasks);
92 void getReadyTasks(std::vector<Task *>& tasks);
94 void checkNoCyclePassingThrough(
Node *node) ;
95 virtual void accept(
Visitor *visitor);
96 virtual std::string
getSymbol()
const {
return _symbol; }
97 virtual std::string getAlgLib()
const ;
98 virtual void setAlgorithm(
const std::string& alglib,
const std::string& symbol,
99 bool checkLinks=
true,
100 virtual void checkBasicConsistency()
const ;
101 virtual std::string
typeName() {
return "YACS__ENGINE__OptimizerLoop";}
102 int getNumberOfOutputPorts()
const;
103 std::list<OutputPort *> getSetOfOutputPort()
const;
104 std::list<OutputPort *> getLocalOutputPorts()
const;
105 OutPort *getOutPort(
const ;
106 OutputPort *getOutputPort(
const ;
110 void buildDelegateOf(
InPort * & port,
OutPort *initialStart,
const std::list<ComposedNode *>& pointsOfView);
111 void buildDelegateOf(std::pair<OutPort *, OutPort *>& port,
InPort *finalTarget,
112 void checkControlDependancy(
OutPort *start,
InPort *end,
bool cross,
113 std::map <
ComposedNode *, std::list < OutPort * >, SortHierarc >& fw,
114 std::vector<OutPort *>& fwCross,
115 std::map<
ComposedNode *, std::list < OutPort *>, SortHierarc >& bw,
117 void checkCFLinks(
const std::list<OutPort *>& starts,
InputPort *end,
unsigned char& alreadyFed,
bool direction,
LinkInfo& info)
const;
118 void checkLinkPossibility(
OutPort *start,
const std::list<ComposedNode *>& pointsOfViewStart,
119 InPort *end,
const std::list<ComposedNode *>& pointsOfViewEnd) ;
121 void cleanInterceptors();
122 void launchMaxOfSamples(
bool first);
123 bool isFullyLazy()
const;
124 bool isFullyBusy(
unsigned& branchId)
const;
125 void initInterceptors(
unsigned nbOfBr);
126 void pushValueOutOfScopeForCase(
unsigned branchId);
128 virtual void loadAlgorithm();
136 static const char NAME_OF_ALGO_INIT_PORT[];
137 static const char NAME_OF_OUT_POOL_INPUT[];
138 static const char NAME_OF_ALGO_RESULT_PORT[];
#define YACSLIBENGINE_EXPORT
Base class for dynamically (fully or semifully) built graphs.
Node * simpleClone(ComposedNode *father, bool editionOnly) const
FakeNodeForOptimizerLoop(OptimizerLoop *loop, bool normal, std::string message)
Class that deal with list of semantics links for high level analysis.
Base class for all nodes.
Base class factorizing common methods for all algorithms interfaces.
InputPort * edGetAlgoInitPort()
OutputPort * edGetAlgoResultPort()
virtual std::string getSymbol() const
virtual std::string typeName()
std::map< InputPort *, std::vector< InputPort * > > _interceptors
outputports interceptors leaving current scope.
AnyInputPort _algoInitPort
AnyOutputPort _algoResultPort
bool _convergenceReachedWithOtherCalc
AnyInputPort _retPortForOutPool
static const int NOT_RUNNING_BRANCH_ID
FakeNodeForOptimizerLoop * _nodeForSpecialCases
static const int NOT_INITIALIZED_BRANCH_ID
::YACS::BASES::DynLibLoader * _loader
std::vector< AnyInputPort * > _interceptorsForOutPool
InputPort * edGetPortForOutPool()
std::vector< bool > _initNodeUpdated
Pool used to manage the samples of the optimizer loop plugin.
