YACS::ENGINE::FakeNodeForOptimizerLoop Class Reference
#include <OptimizerLoop.hxx>
Inheritance diagram for YACS::ENGINE::FakeNodeForOptimizerLoop:
Collaboration diagram for YACS::ENGINE::FakeNodeForOptimizerLoop:
 FakeNodeForOptimizerLoop (OptimizerLoop *loop, bool normal, std::string message)
 FakeNodeForOptimizerLoop (const FakeNodeForOptimizerLoop &other)
Node * simpleClone (ComposedNode *father, bool editionOnly) const
void exForwardFailed ()
void exForwardFinished ()
void execute ()
void aborted ()
void finished ()
OptimizerLoop * _loop
std::string _message
bool _normal
Static Private Attributes
static const char NAME [] ="thisIsAFakeNode"
Friends
class OptimizerLoop
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
YACS::Colour _colour
template<class PORT >
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 36 of file OptimizerLoop.hxx.
◆ FakeNodeForOptimizerLoop() [1/2]
FakeNodeForOptimizerLoop::FakeNodeForOptimizerLoop ( OptimizerLoop *  loop,
bool  normal,
std::string  message
◆ FakeNodeForOptimizerLoop() [2/2]
FakeNodeForOptimizerLoop::FakeNodeForOptimizerLoop ( const FakeNodeForOptimizerLoop &  other)
Definition at line 49 of file OptimizerLoop.cxx.
50 : ElementaryNode(other), _loop(0), _normal(other._normal), _message(other._message)
51{
52}
◆ aborted()
void FakeNodeForOptimizerLoop::aborted ( )
privatevirtual
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 82 of file OptimizerLoop.cxx.
83{
85}
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
@ ERROR
Definition: define.hxx:52
References _loop, YACS::ERROR, and YACS::ENGINE::Node::setState().
◆ execute()
void FakeNodeForOptimizerLoop::execute ( )
privatevirtual
◆ exForwardFailed()
void FakeNodeForOptimizerLoop::exForwardFailed ( )
privatevirtual
Called typically by Bloc to notify failure on potentially next nodes on the same scope of 'this'
Reimplemented from YACS::ENGINE::Node.
Definition at line 59 of file OptimizerLoop.cxx.
60{
62}
virtual void exForwardFailed()
Definition: Node.cxx:378
References _loop, and YACS::ENGINE::Node::exForwardFailed().
◆ exForwardFinished()
void FakeNodeForOptimizerLoop::exForwardFinished ( )
privatevirtual
Called typically by Bloc to activate potentially next nodes on the same scope of 'this'
Definition at line 64 of file OptimizerLoop.cxx.
65{
67}
virtual void exForwardFinished()
Definition: Node.cxx:386
References _loop, and YACS::ENGINE::Node::exForwardFinished().
◆ finished()
void FakeNodeForOptimizerLoop::finished ( )
privatevirtual
Definition at line 87 of file OptimizerLoop.cxx.
88{
90}
@ DONE
Definition: define.hxx:43
References _loop, YACS::DONE, and YACS::ENGINE::Node::setState().
◆ simpleClone()
Node * FakeNodeForOptimizerLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly
privatevirtual
Definition at line 54 of file OptimizerLoop.cxx.
55{
56 return new FakeNodeForOptimizerLoop(*this);
57}
FakeNodeForOptimizerLoop(OptimizerLoop *loop, bool normal, std::string message)
References FakeNodeForOptimizerLoop().
◆ OptimizerLoop
friend class OptimizerLoop
friend
Definition at line 38 of file OptimizerLoop.hxx.
◆ _loop
OptimizerLoop* YACS::ENGINE::FakeNodeForOptimizerLoop::_loop
◆ _message
std::string YACS::ENGINE::FakeNodeForOptimizerLoop::_message
Definition at line 41 of file OptimizerLoop.hxx.
Referenced by execute().
◆ _normal
bool YACS::ENGINE::FakeNodeForOptimizerLoop::_normal
Definition at line 42 of file OptimizerLoop.hxx.
◆ NAME
const char FakeNodeForOptimizerLoop::NAME ="thisIsAFakeNode"
staticprivate
Definition at line 53 of file OptimizerLoop.hxx.
