YACS::ENGINE::AnyOutputPort Class Reference
#include <AnyOutputPort.hxx>
Inheritance diagram for YACS::ENGINE::AnyOutputPort:
Collaboration diagram for YACS::ENGINE::AnyOutputPort:
 AnyOutputPort (const std::string &name, Node *node, TypeCode *type)
 AnyOutputPort (const AnyOutputPort &other, Node *newHelder)
virtual ~AnyOutputPort ()
virtual void setValue (Any *data)
 store the current dispatched value More...
void put (Any *data)
Any * getValue () const
 get the current dispatched value for update port value More...
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual std::string dump ()
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
Any * _data
YACS::BASES::Mutex _mutex
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 33 of file AnyOutputPort.hxx.
◆ AnyOutputPort() [1/2]
AnyOutputPort::AnyOutputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 31 of file AnyOutputPort.cxx.
31 :OutputPort(name,node,type),
32 DataPort(name,node,type),Port(node),_data(0)
33{
34}
Definition: DataPort.cxx:41
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ AnyOutputPort() [2/2]
AnyOutputPort::AnyOutputPort ( const AnyOutputPort &  other,
Node *  newHelder
Definition at line 36 of file AnyOutputPort.cxx.
36 :OutputPort(other,newHelder),
37 DataPort(other,newHelder),
38 Port(other,newHelder),_data(0)
39{
40}
◆ ~AnyOutputPort()
AnyOutputPort::~AnyOutputPort ( )
Definition at line 42 of file AnyOutputPort.cxx.
43{
44 if(_data)
45 _data->decrRef();
46}
References _data, and YACS::ENGINE::RefCounter::decrRef().
◆ clone()
OutputPort * AnyOutputPort::clone ( Node *  newHelder) const
privatevirtual
Implements YACS::ENGINE::OutputPort.
Definition at line 59 of file AnyOutputPort.cxx.
60{
61 return new AnyOutputPort(*this,newHelder);
62}
AnyOutputPort(const std::string &name, Node *node, TypeCode *type)
References AnyOutputPort().
◆ getAsString()
std::string AnyOutputPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 75 of file AnyOutputPort.cxx.
76{
79}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual std::string convertNeutralAsString(TypeCode *type, Any *data)
Convert a YACS::ENGINE::Any object to a string to be used in GUI for example.
Definition: Runtime.cxx:369
Definition: Runtime.cxx:61
References _data, _mutex, YACS::ENGINE::Runtime::convertNeutralAsString(), YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::getRuntime().
◆ getValue()
Any * YACS::ENGINE::AnyOutputPort::getValue ( ) const
Definition at line 43 of file AnyOutputPort.hxx.
43{ return _data; }
◆ put() [1/2]
void AnyOutputPort::put ( Any *  data)
Definition at line 69 of file AnyOutputPort.cxx.
70{
71 setValue(data);
72 OutputPort::put(data);
73}
virtual void setValue(Any *data)
Definition: OutputPort.cxx:66
References YACS::ENGINE::OutputPort::put(), and setValue().
◆ put() [2/2]
void AnyOutputPort::put ( const void *  data)
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 64 of file AnyOutputPort.cxx.
65{
66 put((YACS::ENGINE::Any *)data);
67}
Definition: Any.hxx:79
References put().
Referenced by YACS::ENGINE::FakeNodeForOptimizerLoop::execute(), YACS::ENGINE::OptimizerLoop::finalize(), YACS::ENGINE::ForLoop::init(), put(), and YACS::ENGINE::ForLoop::updateStateOnFinishedEventFrom().
◆ setValue()
void AnyOutputPort::setValue ( Any *  data)
Definition at line 49 of file AnyOutputPort.cxx.
50{
52 if(_data)
53 _data->decrRef();
54 _data = data;
55 if(_data)
56 _data->incrRef();
57}
References _data, _mutex, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::RefCounter::incrRef().
Referenced by put(), and YACS::ENGINE::DynParaLoop::putValueOnBranch().
◆ typeName()
virtual std::string YACS::ENGINE::AnyOutputPort::typeName ( )
Definition at line 45 of file AnyOutputPort.hxx.
45{return "YACS__ENGINE__AnyOutputPort";}
◆ _data
Any* YACS::ENGINE::AnyOutputPort::_data
Definition at line 47 of file AnyOutputPort.hxx.
Referenced by getAsString(), setValue(), and ~AnyOutputPort().
◆ _mutex
YACS::BASES::Mutex YACS::ENGINE::AnyOutputPort::_mutex
Definition at line 50 of file AnyOutputPort.hxx.
Referenced by getAsString(), and setValue().
