YACS::ENGINE::OutputPort Class Referenceabstract
#include <OutputPort.hxx>
Inheritance diagram for YACS::ENGINE::OutputPort:
Collaboration diagram for YACS::ENGINE::OutputPort:
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual std::string dump ()
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
Static Public Attributes
static const char NAME [] ="OutputPort"
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
Friends
class CollectorSwOutputPort
class ElementaryNode
class OptimizerLoop
class InputPort
class Runtime
class ForLoop
static int _total = 0
Definition at line 42 of file OutputPort.hxx.
◆ ~OutputPort()
OutputPort::~OutputPort ( )
Definition at line 153 of file OutputPort.cxx.
154{
155 set<InputPort *>::iterator iter;
156 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
157 {
158 delete (*iter);
159 }
160}
Definition: OutputPort.hxx:77
References _setOfInputPort.
◆ OutputPort() [1/2]
OutputPort::OutputPort ( const OutputPort &  other,
Node *  newHelder
Definition at line 38 of file OutputPort.cxx.
38 :DataFlowPort(other,newHelder),OutPort(other,newHelder),
39 DataPort(other,newHelder),Port(other,newHelder)
40{
41}
DataFlowPort(const DataFlowPort &other, Node *newHelder)
Definition: DataPort.cxx:41
OutPort(const OutPort &other, Node *newHelder)
Definition: OutPort.cxx:29
Port(Node *node)
Definition: Port.cxx:34
◆ OutputPort() [2/2]
OutputPort::OutputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 43 of file OutputPort.cxx.
43 :DataFlowPort(name,node,type),OutPort(name,node,type),
44 DataPort(name,node,type),Port(node)
45{
46}
◆ addInPort()
bool OutputPort::addInPort ( InPort *  inPort)
check compatibility of port class ( an inputPort ) before trying to create the link.
Implements YACS::ENGINE::OutPort.
Definition at line 205 of file OutputPort.cxx.
206{
207 DEBTRACE("OutputPort::addInPort");
210 {
211 string what="not compatible type of port requested during building of link FROM ";
212 what+=NAME; what+=" TO "; what+=inPort->getNameOfTypeOfCurrentInstance();
213 throw Exception(what);
214 }
216 {
217 return edAddInputPort(static_cast<InputPort*>(inPort));
218 }
219 else
220 {
221 return edAddInPropertyPort(static_cast<InPropertyPort*>(inPort));
222 }
223}
Definition: DataPort.cxx:56
class for Input Property Ports
Base class for Input Ports.
Definition: InputPort.hxx:44
static const char NAME[]
Definition: InputPort.hxx:48
virtual bool edAddInPropertyPort(InPropertyPort *phyPort)
Definition: OutputPort.cxx:92
virtual bool edAddInputPort(InputPort *phyPort)
Definition: OutputPort.cxx:75
Definition: OutputPort.hxx:79
References DEBTRACE, edAddInPropertyPort(), edAddInputPort(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::InPropertyPort::NAME, YACS::ENGINE::InputPort::NAME, and NAME.
Referenced by YACS::ENGINE::AnySplitOutputPort::addInPort().
◆ checkBasicConsistency()
void OutputPort::checkBasicConsistency ( ) const
Reimplemented in YACS::ENGINE::OutputPresetPort.
Definition at line 261 of file OutputPort.cxx.
262{
263}
◆ clone()
◆ dump()
std::string OutputPort::dump ( )
Reimplemented in YACS::ENGINE::OutputCorbaPort, YACS::ENGINE::OutputCppPort, YACS::ENGINE::OutputPresetPort, YACS::ENGINE::OutputPyPort, YACS::ENGINE::OutputStudyPort, and YACS::ENGINE::OutputXmlPort.
Definition at line 247 of file OutputPort.cxx.
248{
249 string xmldump = "<value><error> NO_SERIALISATION_AVAILABLE </error></value>";
250 return xmldump;
251}
◆ edAddInPropertyPort()
bool OutputPort::edAddInPropertyPort ( InPropertyPort *  phyPort)
Definition at line 92 of file OutputPort.cxx.
93{
94 DEBTRACE("OutputPort::edAddInPropertyPort");
95 if(!isAlreadyInSet(phyPort))
96 {
97 InputPort *pwrap = getRuntime()->adapt(phyPort,
99 this->edGetType());
100 _setOfInputPort.insert(pwrap);
101 modified();
102 phyPort->modified();
103 return true;
104 }
105 else
106 return false;
107}
std::string getImplementation() const
Definition: Node.cxx:350
bool isAlreadyInSet(InputPort *inputPort) const
Definition: OutputPort.cxx:182
void modified()
Definition: Port.cxx:53
Node * _node
Definition: Port.hxx:55
virtual InputPort * adapt(InputPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
Definition: Runtime.cxx:61
References YACS::ENGINE::Port::_node, _setOfInputPort, YACS::ENGINE::Runtime::adapt(), DEBTRACE, YACS::ENGINE::Node::getImplementation(), YACS::ENGINE::getRuntime(), isAlreadyInSet(), and YACS::ENGINE::Port::modified().
Referenced by addInPort().
◆ edAddInputPort()
bool OutputPort::edAddInputPort ( InputPort *  phyPort)
check if output type is an input type and if a data converter exists before link
Definition at line 75 of file OutputPort.cxx.
76{
77 DEBTRACE("OutputPort::edAddInputPort");
78 if(!isAlreadyInSet(phyPort))
79 {
80 InputPort *pwrap = getRuntime()->adapt(phyPort,
82 this->edGetType());
83 _setOfInputPort.insert(pwrap);
84 modified();
85 phyPort->modified();
86 return true;
87 }
88 else
89 return false;
90}
Referenced by addInPort(), and YACS::ENGINE::OptimizerLoop::initInterceptors().
◆ edRemoveAllLinksLinkedWithMe()
void OutputPort::edRemoveAllLinksLinkedWithMe ( )
Implements YACS::ENGINE::DataPort.
Definition at line 53 of file OutputPort.cxx.
54{
56 set<InputPort *> vec(_setOfInputPort);
57 for( set<InputPort *>::iterator iter2=vec.begin();iter2!=vec.end();iter2++)
58 edRemoveInputPort(*iter2,true);
59 _setOfInputPort.clear();
60}
virtual int edRemoveInputPort(InputPort *inputPort, bool forward)
Definition: OutputPort.cxx:114
References _setOfInputPort, and edRemoveInputPort().
◆ edRemoveInputPort()
int OutputPort::edRemoveInputPort ( InputPort *  inputPort,
bool  forward
Remove a link by performing not only the deletion in _setOfInputPort but also dereference to the target inputPort. If 'forward' == true the forward deletion If 'forward' == false no forward deletion performed, oneway deletion without update 'inputPort' side.
Definition at line 114 of file OutputPort.cxx.
115{
116 if(forward)
117 {
118 set<InPort *> s;
119 inputPort->getAllRepresentants(s);
120 DEBTRACE("+++");
121 for(set<InPort *>::iterator iter=s.begin();iter!=s.end();iter++)
122 {
123 DEBTRACE("---");
124 _node->getRootNode()->edRemoveLink(this,*iter);
125 }
126 return -1;
127 }
128 else
129 {
130#ifdef NOCOVARIANT
131 InPort *publicRepr=inputPort->getPublicRepresentant();
132#else
133 InputPort *publicRepr=inputPort->getPublicRepresentant();
134#endif
135 set<InputPort *>::iterator iter;
136 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
137 if((*iter)->getPublicRepresentant()==publicRepr)
138 break;
139 if(iter!=_setOfInputPort.end())
140 {
141 (*iter)->modified();
142 if((*iter)->isIntermediate())
143 delete (*iter);
144 _setOfInputPort.erase(iter);
145 modified();
146 return edGetNumberOfOutLinks();
147 }
148 else
149 throw Exception("OutputPort::edRemoveInputPort : link does not exist, unable to remove it");
150 }
151}
void edRemoveLink(OutPort *start, InPort *end)
Remove a dataflow link.
virtual void getAllRepresentants(std::set< InPort * > &repr) const
Definition: InPort.cxx:110
virtual InputPort * getPublicRepresentant()
returns the final physical port behind 'this'.
Definition: InputPort.hxx:57
virtual ComposedNode * getRootNode() const
Definition: Node.cxx:431
virtual int edGetNumberOfOutLinks() const
Definition: OutPort.cxx:50
References YACS::ENGINE::Port::_node, _setOfInputPort, DEBTRACE, YACS::ENGINE::OutPort::edGetNumberOfOutLinks(), YACS::ENGINE::ComposedNode::edRemoveLink(), YACS::ENGINE::InPort::getAllRepresentants(), YACS::ENGINE::InputPort::getPublicRepresentant(), YACS::ENGINE::Node::getRootNode(), and YACS::ENGINE::Port::modified().
Referenced by edRemoveAllLinksLinkedWithMe(), and removeInPort().
◆ edSetInPort()
std::set< InPort * > OutputPort::edSetInPort ( ) const
Definition at line 239 of file OutputPort.cxx.
240{
241 set<InPort *> s;
242 for(set<InputPort *>::const_iterator iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
243 (*iter)->getAllRepresentants(s);
244 return s;
245}
Referenced by YACS::ENGINE::DynParaLoop::DynParaLoop(), YACS::ENGINE::InterceptorInputPort::getAllRepresentants(), YACS::ENGINE::InputDataStreamPort4DS2DF::getAllRepresentants(), YACS::ENGINE::DynParaLoop::putValueOnBranch(), and YACS::ENGINE::VisitorSaveSchema::writeSimpleDataLinks().
◆ exInit()
void OutputPort::exInit ( )
string OutputPort::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 48 of file OutputPort.cxx.
49{
50 return NAME;
51}
References NAME.
◆ getSetOfPhyLinks()
const std::set< InputPort * > & OutputPort::getSetOfPhyLinks ( ) const
Definition at line 255 of file OutputPort.cxx.
256{
257 return _setOfInputPort;
258}
Referenced by YACS::ENGINE::OptimizerLoop::initInterceptors().
◆ isAlreadyInSet()
bool OutputPort::isAlreadyInSet ( InputPort *  inputPort) const
Definition at line 182 of file OutputPort.cxx.
183{
184#ifdef NOCOVARIANT
185 InPort *publicRepr=inputPort->getPublicRepresentant();
186#else
187 InputPort *publicRepr=inputPort->getPublicRepresentant();
188#endif
189 for(set<InputPort *>::const_iterator iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
190 if((*iter)->getPublicRepresentant()==publicRepr)
191 return true;
192 return false;
193}
References _setOfInputPort, and YACS::ENGINE::InputPort::getPublicRepresentant().
Referenced by edAddInPropertyPort(), and edAddInputPort().
◆ isAlreadyLinkedWith()
bool OutputPort::isAlreadyLinkedWith ( InPort *  withp) const
Definition at line 162 of file OutputPort.cxx.
163{
164 InPort *publicRepr=with->getPublicRepresentant();
165 set<InPort *> s;
166 set<InputPort *>::const_iterator iter;
167 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
168 {
169 if((*iter)->getPublicRepresentant() == publicRepr)
170 return true;
171 }
172 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
173 (*iter)->getAllRepresentants(s);
174 for(set<InPort *>::iterator iter2=s.begin();iter2!=s.end();iter2++)
175 {
176 if((*iter2)->getPublicRepresentant() == publicRepr)
177 return true;
178 }
179 return false;
180}
virtual InPort * getPublicRepresentant()
Definition: InPort.hxx:63
References _setOfInputPort, YACS::ENGINE::InPort::getAllRepresentants(), and YACS::ENGINE::InPort::getPublicRepresentant().
◆ isConnected()
bool OutputPort::isConnected ( ) const
Definition at line 196 of file OutputPort.cxx.
197{
198 return !_setOfInputPort.empty();
199}
◆ put()
◆ removeInPort()
int OutputPort::removeInPort ( InPort *  inPort,
bool  forward
check compatibility of port class ( an inputPort ) before trying to remove link WITHOUT forward.
Definition at line 228 of file OutputPort.cxx.
229{
230 if(inPort->getNameOfTypeOfCurrentInstance()!=InputPort::NAME && !forward)
231 {
232 string what="not compatible type of port requested during destruction of for link FROM ";
233 what+=NAME; what+=" TO "; what+=inPort->getNameOfTypeOfCurrentInstance();
234 throw Exception(what);
235 }
236 return edRemoveInputPort(static_cast<InputPort*>(inPort),forward);
237}
References edRemoveInputPort(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::InputPort::NAME, and NAME.
Referenced by YACS::ENGINE::AnySplitOutputPort::removeInPort().
◆ typeName()
virtual std::string YACS::ENGINE::OutputPort::typeName ( )
Reimplemented in YACS::ENGINE::AnyOutputPort, YACS::ENGINE::OutputCorbaPort, YACS::ENGINE::OutputPresetPort, YACS::ENGINE::OutputPyPort, and YACS::ENGINE::OutputStudyPort.
Definition at line 69 of file OutputPort.hxx.
69{return "YACS__ENGINE__OutputPort";}
◆ CollectorSwOutputPort
friend class CollectorSwOutputPort
friend
Definition at line 44 of file OutputPort.hxx.
◆ ElementaryNode
friend class ElementaryNode
friend
Definition at line 45 of file OutputPort.hxx.
◆ ForLoop
friend class ForLoop
friend
Definition at line 49 of file OutputPort.hxx.
◆ InputPort
friend class InputPort
friend
Definition at line 47 of file OutputPort.hxx.
◆ OptimizerLoop
friend class OptimizerLoop
friend
Definition at line 46 of file OutputPort.hxx.
◆ Runtime
friend class Runtime
friend
Definition at line 48 of file OutputPort.hxx.
◆ _setOfInputPort
◆ NAME
