YACS::ENGINE::OutputPyPort Class Reference
#include <PythonPorts.hxx>
Inheritance diagram for YACS::ENGINE::OutputPyPort:
Collaboration diagram for YACS::ENGINE::OutputPyPort:
 OutputPyPort (const std::string &name, Node *node, TypeCode *type)
 OutputPyPort (const OutputPyPort &other, Node *newHelder)
 ~OutputPyPort ()
void putWithoutForward (PyObject *data)
void put (PyObject *data)
OutputPort * clone (Node *newHelder) const
virtual PyObject * get () const
virtual PyObj * getPyObj () const
virtual std::string dump ()
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
PyObject * _data
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 105 of file PythonPorts.hxx.
◆ OutputPyPort() [1/2]
OutputPyPort::OutputPyPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 266 of file PythonPorts.cxx.
267 : OutputPort(name, node, type), DataPort(name, node, type), Port(node)
268{
269 _data = Py_None;
270 Py_INCREF(_data);
271}
Definition: DataPort.cxx:41
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
References _data.
Referenced by clone().
◆ OutputPyPort() [2/2]
OutputPyPort::OutputPyPort ( const OutputPyPort &  other,
Node *  newHelder
Definition at line 282 of file PythonPorts.cxx.
282 :OutputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder),
283 _data(Py_None)
284{
285 Py_INCREF(_data);
286}
References _data.
◆ ~OutputPyPort()
OutputPyPort::~OutputPyPort ( )
Definition at line 272 of file PythonPorts.cxx.
273{
274 PyGILState_STATE gstate = PyGILState_Ensure();
275 DEBTRACE( "_data refcnt: " << _data->ob_refcnt );
276 // Release or not release : all GenericObj are deleted when the output port is deleted
278 Py_XDECREF(_data);
279 PyGILState_Release(gstate);
280}
void releasePyObj(PyObject *data)
Definition: PythonPorts.cxx:74
References _data, DEBTRACE, and releasePyObj().
◆ clone()
OutputPort * OutputPyPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 314 of file PythonPorts.cxx.
315{
316 return new OutputPyPort(*this,newHelder);
317}
OutputPyPort(const std::string &name, Node *node, TypeCode *type)
References OutputPyPort().
◆ dump()
std::string OutputPyPort::dump ( )
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 340 of file PythonPorts.cxx.
341{
343 string xmldump = convertPyObjectXml(edGetType(), _data);
344 return xmldump;
345}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string convertPyObjectXml(const TypeCode *t, PyObject *data)
References _data, YACS::ENGINE::convertPyObjectXml(), YACS::ENGINE::DataPort::edGetType(), and testCppPluginInvokation::l.
◆ get()
PyObject * OutputPyPort::get ( ) const
Definition at line 319 of file PythonPorts.cxx.
320{
321 return _data;
322}
References _data.
◆ getAsString()
std::string OutputPyPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 329 of file PythonPorts.cxx.
330{
331 std::string ret;
332 //protect _data against modification or delete in another thread
333 PyObject* data=_data;
334 Py_INCREF(data);
335 ret = convertPyObjectToString(data);
336 Py_XDECREF(data);
337 return ret;
338}
std::string convertPyObjectToString(PyObject *ob)
References _data, and YACS::ENGINE::convertPyObjectToString().
◆ getPyObj()
PyObject * OutputPyPort::getPyObj ( ) const
Definition at line 324 of file PythonPorts.cxx.
325{
326 return _data;
327}
References _data.
Referenced by valToStr().
◆ put() [1/2]
void OutputPyPort::put ( const void *  data)
Definition at line 288 of file PythonPorts.cxx.
289{
290 put((PyObject *)data);
291}
References put().
Referenced by put().
◆ put() [2/2]
void OutputPyPort::put ( PyObject *  data)
Definition at line 307 of file PythonPorts.cxx.
308{
309 putWithoutForward(data);
310 DEBTRACE( "OutputPyPort::put.ob refcnt: " << data->ob_refcnt );
311 OutputPort::put(data);
312}
Definition: OutputPort.cxx:66
void putWithoutForward(PyObject *data)
References DEBTRACE, YACS::ENGINE::OutputPort::put(), and putWithoutForward().
◆ putWithoutForward()
void OutputPyPort::putWithoutForward ( PyObject *  data)
Definition at line 293 of file PythonPorts.cxx.
294{
295 DEBTRACE( "OutputPyPort::put.ob refcnt: " << data->ob_refcnt );
296#ifdef _DEVDEBUG_
297 PyObject_Print(data,stderr,Py_PRINT_RAW);
298 cerr << endl;
299#endif
301 Py_XDECREF(_data);
302 _data = data;
303 Py_INCREF(_data);
304 //no registerPyObj : we steal the output reference of the node
305}
Referenced by put(), YACS::ENGINE::PythonNode::squeezeMemory(), and YACS::ENGINE::PythonNode::squeezeMemoryRemote().
◆ typeName()
virtual std::string YACS::ENGINE::OutputPyPort::typeName ( )
Definition at line 120 of file PythonPorts.hxx.
120{return "YACS__ENGINE__OutputPyPort";}
◆ valFromStr()
void OutputPyPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 355 of file PythonPorts.cxx.
356{
357}
◆ valToStr()
std::string OutputPyPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 347 of file PythonPorts.cxx.
348{
349 PyObject *strPyObj = PyObject_Str(getPyObj());
350 string val = PyBytes_AsString(strPyObj);
351 Py_DECREF(strPyObj);
352 return val;
353}
virtual PyObj * getPyObj() const
References getPyObj().
◆ _data
PyObject* YACS::ENGINE::OutputPyPort::_data
