PythonNode.cxx
20#include "RuntimeSALOME.hxx"
21#include "PythonNode.hxx"
22#include "PythonPorts.hxx"
23#include "TypeCode.hxx"
24#include "PythonCppUtils.hxx"
25#include "Container.hxx"
26#include "SalomeContainer.hxx"
27#include "SalomeHPContainer.hxx"
30#include "ReceiverFactory.hxx"
31#include "SenderByteImpl.hxx"
32
33#include "PyStdout.hxx"
34#include <iostream>
35#include <memory>
36#include <sstream>
37#include <fstream>
38
39#ifdef WIN32
40#include <process.h>
41#define getpid _getpid
42#endif
43
44#if PY_VERSION_HEX < 0x02050000
45typedef int Py_ssize_t;
46#endif
47
48//#define _DEVDEBUG_
49#include "YacsTrace.hxx"
50
51using namespace YACS::ENGINE;
52using namespace std;
53
54const char PythonEntry::SCRIPT_FOR_SIMPLE_SERIALIZATION[]="import pickle\n"
55 "def pickleForVarSimplePyth2009(val):\n"
56 " return pickle.dumps(val,-1)\n"
57 "\n";
58
59PyObject *PythonEntry::_pyClsBigObject = nullptr;
60
61const char PythonNode::IMPL_NAME[]="Python";
62const char PythonNode::KIND[]="Python";
63
64const char PythonNode::SCRIPT_FOR_SERIALIZATION[]="import pickle\n"
65 "def pickleForDistPyth2009(kws):\n"
66 " return pickle.dumps(((),kws),-1)\n"
67 "\n"
68 "def unPickleForDistPyth2009(st):\n"
69 " args=pickle.loads(st)\n"
70 " return args\n";
71
72const char PythonNode::REMOTE_NAME[]="remote";
73
74const char PythonNode::DPL_INFO_NAME[]="my_dpl_localization";
75
76const char PyFuncNode::SCRIPT_FOR_SERIALIZATION[]="import pickle\n"
77 "def pickleForDistPyth2009(*args,**kws):\n"
78 " return pickle.dumps((args,kws),-1)\n"
79 "\n"
80 "def unPickleForDistPyth2009(st):\n"
81 " args=pickle.loads(st)\n"
82 " return args\n";
83
84static char SCRIPT_FOR_BIGOBJECT[]="import SALOME_PyNode\n"
85 "BigObjectOnDiskBase = SALOME_PyNode.BigObjectOnDiskBase\n";
86
87// pickle.load concurrency issue : see https://bugs.python.org/issue12680
88#if PY_VERSION_HEX < 0x03070000
89#include <mutex>
90static std::mutex data_mutex;
91#endif
92
93PythonEntry::PythonEntry():_context(0),_pyfuncSer(0),_pyfuncUnser(0),_pyfuncSimpleSer(0)
94{
95}
96
98{
99 AutoGIL agil;
100 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
101 // not Py_XDECREF of _pyfuncUnser because it is returned by PyDict_GetItem -> borrowed
102 // not Py_XDECREF of _pyfuncSer because it is returned by PyDict_GetItem -> borrowed
103 Py_XDECREF(_context);
104}
105
107{
108 DEBTRACE( "---------------PythonEntry::CommonRemoteLoad function---------------" );
109 Container *container(reqNode->getContainer());
110 bool isContAlreadyStarted(false);
111 if(container)
112 {
113 try
114 {
116 container->start(reqNode, _imposedResource, _imposedContainer);
117 else
118 {
119 isContAlreadyStarted=container->isAlreadyStarted(reqNode);
120 if(!isContAlreadyStarted)
121 container->start(reqNode);
122 }
123 }
124 catch(Exception& e)
125 {
126 reqNode->setErrorDetails(e.what());
127 throw e;
128 }
129 }
130 else
131 {
132 std::string what("PythonEntry::CommonRemoteLoad : a load operation requested on \"");
133 what+=reqNode->getName(); what+="\" with no container specified.";
134 reqNode->setErrorDetails(what);
135 throw Exception(what);
136 }
137}
138
139Engines::Container_var GetContainerObj(InlineNode *reqNode, bool& isStandardCont)
140{
141 isStandardCont = false;
142 Container *container(reqNode->getContainer());
143 Engines::Container_var objContainer(Engines::Container::_nil());
144 if(!container)
145 throw YACS::Exception("No container specified !");
146 SalomeContainer *containerCast0(dynamic_cast<SalomeContainer *>(container));
147 SalomeHPContainer *containerCast1(dynamic_cast<SalomeHPContainer *>(container));
148 if(containerCast0)
149 {
150 isStandardCont = true;
151 objContainer=containerCast0->getContainerPtr(reqNode);
152 }
153 else if(containerCast1)
154 {
156 objContainer=tmpCont->getContainerPtr(reqNode);
157 }
158 else
159 throw YACS::Exception("Unrecognized type of container ! Salome one is expected for PythonNode/PyFuncNode !");
160 if(CORBA::is_nil(objContainer))
161 throw YACS::Exception("Container corba pointer is NULL for PythonNode !");
162 return objContainer;
163}
164
165Engines::Container_var PythonEntry::loadPythonAdapter(InlineNode *reqNode, bool& isInitializeRequested)
166{
167 bool isStandardCont(true);
168 Engines::Container_var objContainer(GetContainerObj(reqNode,isStandardCont));
169 isInitializeRequested=false;
170 try
171 {
172 Engines::PyNodeBase_var dftPyScript(retrieveDftRemotePyInterpretorIfAny(objContainer));
173 if(CORBA::is_nil(dftPyScript))
174 {
175 isInitializeRequested=!isStandardCont;
177 }
178 else
179 assignRemotePyInterpretor(dftPyScript);
180 }
181 catch( const SALOME::SALOME_Exception& ex )
182 {
183 std::string msg="Exception on remote python node creation ";
184 msg += '\n';
185 msg += ex.details.text.in();
186 reqNode->setErrorDetails(msg);
187 throw Exception(msg);
188 }
189 Engines::PyNodeBase_var pynode(getRemoteInterpreterHandle());
190 if(CORBA::is_nil(pynode))
191 throw Exception("In PythonNode the ref in NULL ! ");
192 return objContainer;
193}
194
195void PythonEntry::loadRemoteContext(InlineNode *reqNode, Engines::Container_ptr objContainer, bool isInitializeRequested)
196{
197 Container *container(reqNode->getContainer());
198 Engines::PyNodeBase_var pynode(getRemoteInterpreterHandle());
200 {
201#if PY_VERSION_HEX < 0x03070000
202 std::unique_lock<std::mutex> lock(data_mutex);
203#endif
204 AutoGIL agil;
205 const char *picklizeScript(getSerializationScript());
206 PyObject *res=PyRun_String(picklizeScript,Py_file_input,_context,_context);
207 PyObject *res2(PyRun_String(SCRIPT_FOR_SIMPLE_SERIALIZATION,Py_file_input,_context,_context));
208 if(res == NULL || res2==NULL)
209 {
210 std::string errorDetails;
211 PyObject* new_stderr = newPyStdOut(errorDetails);
212 reqNode->setErrorDetails(errorDetails);
213 PySys_SetObject((char*)"stderr", new_stderr);
214 PyErr_Print();
215 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
216 Py_DECREF(new_stderr);
217 throw Exception("Error during load");
218 }
219 Py_DECREF(res); Py_DECREF(res2);
220 AutoPyRef res3(PyRun_String(SCRIPT_FOR_BIGOBJECT,Py_file_input,_context,_context));
221 _pyfuncSer=PyDict_GetItemString(_context,"pickleForDistPyth2009");
222 _pyfuncUnser=PyDict_GetItemString(_context,"unPickleForDistPyth2009");
223 _pyfuncSimpleSer=PyDict_GetItemString(_context,"pickleForVarSimplePyth2009");
224 if(! _pyClsBigObject )
225 {
226 _pyClsBigObject=PyDict_GetItemString(_context,"BigObjectOnDiskBase");
227 Py_INCREF(_pyClsBigObject);
228 }
229 if(_pyfuncSer == NULL)
230 {
231 std::string errorDetails;
232 PyObject *new_stderr(newPyStdOut(errorDetails));
233 reqNode->setErrorDetails(errorDetails);
234 PySys_SetObject((char*)"stderr", new_stderr);
235 PyErr_Print();
236 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
237 Py_DECREF(new_stderr);
238 throw Exception("Error during load");
239 }
240 if(_pyfuncUnser == NULL)
241 {
242 std::string errorDetails;
243 PyObject *new_stderr(newPyStdOut(errorDetails));
244 reqNode->setErrorDetails(errorDetails);
245 PySys_SetObject((char*)"stderr", new_stderr);
246 PyErr_Print();
247 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
248 Py_DECREF(new_stderr);
249 throw Exception("Error during load");
250 }
251 if(_pyfuncSimpleSer == NULL)
252 {
253 std::string errorDetails;
254 PyObject *new_stderr(newPyStdOut(errorDetails));
255 reqNode->setErrorDetails(errorDetails);
256 PySys_SetObject((char*)"stderr", new_stderr);
257 PyErr_Print();
258 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
259 Py_DECREF(new_stderr);
260 throw Exception("Error during load");
261 }
262 }
263 if(isInitializeRequested)
264 {//This one is called only once at initialization in the container if an init-script is specified.
265 try
266 {
267 std::string zeInitScriptKey(container->getProperty(HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY));
268 if(!zeInitScriptKey.empty())
269 pynode->executeAnotherPieceOfCode(zeInitScriptKey.c_str());
270 }
271 catch( const SALOME::SALOME_Exception& ex )
272 {
273 std::string msg="Exception on PythonNode::loadRemote python invocation of initializisation py script !";
274 msg += '\n';
275 msg += ex.details.text.in();
276 reqNode->setErrorDetails(msg);
277 throw Exception(msg);
278 }
279 DEBTRACE( "---------------End PyNode::loadRemote function---------------" );
280 }
281}
282
283std::string PythonEntry::GetContainerLog(const std::string& mode, Container *container, const Task *askingTask)
284{
285 if(mode=="local")
286 return "";
287
288 std::string msg;
289 try
290 {
291 SalomeContainer *containerCast(dynamic_cast<SalomeContainer *>(container));
292 SalomeHPContainer *objContainer2(dynamic_cast<SalomeHPContainer *>(container));
293 if(containerCast)
294 {
295 Engines::Container_var objContainer(containerCast->getContainerPtr(askingTask));
296 CORBA::String_var logname = objContainer->logfilename();
297 DEBTRACE(logname);
298 msg=logname;
299 std::string::size_type pos = msg.find(":");
300 msg=msg.substr(pos+1);
301 }
302 else if(objContainer2)
303 {
304 msg="Remote PythonNode is on HP Container : no log because no info of the location by definition of HP Container !";
305 }
306 else
307 {
308 msg="Not implemented yet for container log for that type of container !";
309 }
310 }
311 catch(...)
312 {
313 msg = "Container no longer reachable";
314 }
315 return msg;
316}
317
319{
320 loadRemoteContainer(reqNode);
321 bool isInitializeRequested;
322 Engines::Container_var objContainer(loadPythonAdapter(reqNode,isInitializeRequested));
323 loadRemoteContext(reqNode,objContainer,isInitializeRequested);
324}
325
327{
328 return !_imposedResource.empty() && !_imposedContainer.empty();
329}
330
331bool PythonEntry::IsProxy( PyObject *ob )
332{
333 if(!_pyClsBigObject)
334 return false;
335 if( PyObject_IsInstance( ob, _pyClsBigObject) == 1 )
336 {
337 return true;
338 }
339 else
340 {
341 if( PyList_Check( ob ) )
342 {
343 auto sz = PyList_Size( ob );
344 for( auto i = 0 ; i < sz ; ++i )
345 {
346 PyObject *elt = PyList_GetItem( ob, i );
347 if( PythonEntry::IsProxy(elt) )
348 return true;
349 }
350 }
351 }
352 return false;
353}
354
356{
357 if(!_pyClsBigObject)
358 return false;
359 if( PyObject_IsInstance( ob, _pyClsBigObject) == 1 )
360 {
361 AutoPyRef unlinkOnDestructor = PyObject_GetAttrString(ob,"getDestroyStatus");
362 AutoPyRef tmp = PyObject_CallFunctionObjArgs(unlinkOnDestructor,nullptr);
363 if( PyBool_Check(tmp.get()) )
364 {
365 return tmp.get() == Py_True;
366 }
367 return false;
368 }
369 else
370 {
371 if( PyList_Check( ob ) )
372 {
373 auto sz = PyList_Size( ob );
374 for( auto i = 0 ; i < sz ; ++i )
375 {
376 PyObject *elt = PyList_GetItem( ob, i );
378 return true;
379 }
380 }
381 }
382 return false;
383}
384
385void PythonEntry::IfProxyDoSomething( PyObject *ob, const char *meth )
386{
387 if(!_pyClsBigObject)
388 return ;
389 if( PyObject_IsInstance( ob, _pyClsBigObject) == 1 )
390 {
391 AutoPyRef unlinkOnDestructor = PyObject_GetAttrString(ob,meth);
392 AutoPyRef tmp = PyObject_CallFunctionObjArgs(unlinkOnDestructor,nullptr);
393 }
394 else
395 {
396 if( PyList_Check( ob ) )
397 {
398 auto sz = PyList_Size( ob );
399 for( auto i = 0 ; i < sz ; ++i )
400 {
401 PyObject *elt = PyList_GetItem( ob, i );
403 }
404 }
405 }
406}
407
409{
410 IfProxyDoSomething(ob,"doNotTouchFile");
411}
412
414{
415 IfProxyDoSomething(ob,"unlinkOnDestructor");
416}
417
419InlineNode(other,father),_autoSqueeze(other._autoSqueeze),_nonSqueezableOutputNodes(other._nonSqueezableOutputNodes)
420{
421 _pynode = Engines::PyScriptNode::_nil();
423 {
424 AutoGIL agil;
425 _context=PyDict_New();
426 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
427 {
428 stringstream msg;
429 msg << "Impossible to set builtins" << __FILE__ << ":" << __LINE__;
430 _errorDetails=msg.str();
431 throw Exception(msg.str());
432 }
433 }
434}
435
436PythonNode::PythonNode(const std::string& name):InlineNode(name)
437{
438 _pynode = Engines::PyScriptNode::_nil();
440 {
441 AutoGIL agil;
442 _context=PyDict_New();
443 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
444 {
445 stringstream msg;
446 msg << "Impossible to set builtins" << __FILE__ << ":" << __LINE__;
447 _errorDetails=msg.str();
448 throw Exception(msg.str());
449 }
450 }
451}
452
454{
456}
457
459{
460 DEBTRACE("checkBasicConsistency");
462 {
463 AutoGIL agil;
464 PyObject* res;
465 res=Py_CompileString(_script.c_str(),getName().c_str(),Py_file_input);
466 if(res == NULL)
467 {
468 std::string error="";
469 PyObject* new_stderr = newPyStdOut(error);
470 PySys_SetObject((char*)"stderr", new_stderr);
471 PyErr_Print();
472 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
473 Py_DECREF(new_stderr);
474 throw Exception(error);
475 }
476 else
477 Py_XDECREF(res);
478 }
479}
480
482{
483 DEBTRACE( "---------------PyNode::load function---------------" );
485 loadRemote();
486 else
487 loadLocal();
488}
489
491{
492 DEBTRACE( "---------------PyNode::loadLocal function---------------" );
493 // do nothing
494}
495
497{
498 commonRemoteLoad(this);
499}
500
502{
505 else
506 executeLocal();
507}
508
510{
511 DEBTRACE( "++++++++++++++ PyNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
512 if(!_pyfuncSer)
513 throw Exception("PythonNode badly loaded");
514 //
515 if(dynamic_cast<HomogeneousPoolContainer *>(getContainer()))
516 {
517 bool dummy;
518 loadPythonAdapter(this,dummy);
519 _pynode->assignNewCompiledCode(getScript().c_str());
520 }
521 // not managed by unique_ptr here because destructed by the order of client.
522 SenderByteImpl *serializationInputCorba = nullptr;
523 AutoPyRef serializationInput;
524 {
525#if PY_VERSION_HEX < 0x03070000
526 std::unique_lock<std::mutex> lock(data_mutex);
527#endif
528 AutoGIL agil;
529 PyObject *args(0),*ob(0);
530 //===========================================================================
531 // Get inputs in input ports, build a Python dict and pickle it
532 //===========================================================================
533 args = PyDict_New();
534 std::list<InputPort *>::iterator iter2;
535 int pos(0);
536 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); ++iter2)
537 {
538 InputPyPort *p=(InputPyPort *)*iter2;
539 ob=p->getPyObj();
540 PyDict_SetItemString(args,p->getName().c_str(),ob);
541 pos++;
542 }
543#ifdef _DEVDEBUG_
544 PyObject_Print(args,stderr,Py_PRINT_RAW);
545 std::cerr << endl;
546#endif
547 serializationInput.set(PyObject_CallFunctionObjArgs(_pyfuncSer,args,nullptr));
548 Py_DECREF(args);
549 //The pickled string may contain NULL characters so use PyString_AsStringAndSize
550 char *serializationInputC(nullptr);
551 Py_ssize_t len;
552 if (PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len))
553 throw Exception("DistributedPythonNode problem in python pickle");
554 // no copy here. The C byte array of Python is taken as this into CORBA sequence to avoid copy
555 serializationInputCorba = new SenderByteImpl(serializationInputC,len);
556 }
557
558 //get the list of output argument names
559 std::list<OutputPort *>::iterator iter;
560 Engines::listofstring myseq;
561 myseq.length(getNumberOfOutputPorts());
562 int pos=0;
563 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); ++iter)
564 {
565 OutputPyPort *p=(OutputPyPort *)*iter;
566 myseq[pos]=p->getName().c_str();
567 DEBTRACE( "port name: " << p->getName() );
568 DEBTRACE( "port kind: " << p->edGetType()->kind() );
569 DEBTRACE( "port pos : " << pos );
570 pos++;
571 }
572 //===========================================================================
573 // Execute in remote Python node
574 //===========================================================================
575 DEBTRACE( "-----------------starting remote python invocation-----------------" );
576 std::unique_ptr<SALOME::SenderByteSeq> resultCorba;
577 try
578 {
579 //pass outargsname and dict serialized
580 SALOME::SenderByte_var serializationInputRef = serializationInputCorba->_this();
581 DEBUG_YACSTRACE("Before execute first of " << getId());
582 _pynode->executeFirst(serializationInputRef);
583 //serializationInput and serializationInputCorba are no more needed for server. Release it.
584 {
585 AutoGIL agil;
586 serializationInput.set(nullptr);
587 }
588 resultCorba.reset( _pynode->executeSecond(myseq) );
589 DEBUG_YACSTRACE("After execute second of " << getId());
590 }
591 catch( const SALOME::SALOME_Exception& ex )
592 {
593 std::ostringstream msg; msg << "Exception on remote python invocation" << std::endl << ex.details.text.in() << std::endl;
594 msg << "PyScriptNode CORBA ref : ";
595 {
596 CORBA::ORB_ptr orb(getSALOMERuntime()->getOrb());
597 if(!CORBA::is_nil(orb))
598 {
599 CORBA::String_var IOR(orb->object_to_string(_pynode));
600 msg << IOR;
601 }
602 }
603 msg << std::endl;
604 _errorDetails=msg.str();
605 throw Exception(msg.str());
606 }
607 catch(CORBA::COMM_FAILURE& ex)
608 {
609 std::ostringstream msg;
610 msg << "Exception on remote python invocation." << std::endl ;
611 msg << "Caught system exception COMM_FAILURE -- unable to contact the "
612 << "object." << std::endl;
613 _errorDetails=msg.str();
614 throw Exception(msg.str());
615 }
616 catch(CORBA::SystemException& ex)
617 {
618 std::ostringstream msg;
619 msg << "Exception on remote python invocation." << std::endl ;
620 msg << "Caught a CORBA::SystemException." ;
621 CORBA::Any tmp;
622 tmp <<= ex;
623 CORBA::TypeCode_var tc = tmp.type();
624 const char *p = tc->name();
625 if ( *p != '\0' )
626 msg <<p;
627 else
628 msg << tc->id();
629 msg << std::endl;
630 _errorDetails=msg.str();
631 throw Exception(msg.str());
632 }
633 catch(CORBA::Exception& ex)
634 {
635 std::ostringstream msg;
636 msg << "Exception on remote python invocation." << std::endl ;
637 msg << "Caught CORBA::Exception. " ;
638 CORBA::Any tmp;
639 tmp <<= ex;
640 CORBA::TypeCode_var tc = tmp.type();
641 const char *p = tc->name();
642 if ( *p != '\0' )
643 msg <<p;
644 else
645 msg << tc->id();
646 msg << std::endl;
647 _errorDetails=msg.str();
648 throw Exception(msg.str());
649 }
650 catch(omniORB::fatalException& fe)
651 {
652 std::ostringstream msg;
653 msg << "Exception on remote python invocation." << std::endl ;
654 msg << "Caught omniORB::fatalException:" << std::endl;
655 msg << " file: " << fe.file() << std::endl;
656 msg << " line: " << fe.line() << std::endl;
657 msg << " mesg: " << fe.errmsg() << std::endl;
658 _errorDetails=msg.str();
659 throw Exception(msg.str());
660 }
661 DEBTRACE( "-----------------end of remote python invocation-----------------" );
662 //===========================================================================
663 // Get results, unpickle and put them in output ports
664 //===========================================================================
665 {
666#if PY_VERSION_HEX < 0x03070000
667 std::unique_lock<std::mutex> lock(data_mutex);
668#endif
669 AutoGIL agil;
670 DEBTRACE( "-----------------PythonNode::outputs-----------------" );
671 int nres( resultCorba->length() );
672
673 if(getNumberOfOutputPorts() != nres)
674 {
675 std::string msg="Number of output arguments : Mismatch between definition and execution";
676 _errorDetails=msg;
677 throw Exception(msg);
678 }
679 pos=0;
680 try
681 {
682 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); ++iter)
683 {
684 OutputPyPort *p=(OutputPyPort *)*iter;
685 DEBUG_YACSTRACE("Start of dealing with output " << p->getName() << " of "<< getId());
686 DEBTRACE( "port name: " << p->getName() );
687 DEBTRACE( "port kind: " << p->edGetType()->kind() );
688 DEBTRACE( "port pos : " << pos );
689 SALOME::SenderByte_var elt = (*resultCorba)[pos];
690 SeqByteReceiver recv(elt);
691 unsigned long length = 0;
692 char *resultCorbaC = recv.data(length);
693 {
694 AutoPyRef resultPython=PyMemoryView_FromMemory(resultCorbaC,length,PyBUF_READ);
695 AutoPyRef args = PyTuple_New(1);
696 PyTuple_SetItem(args,0,resultPython.retn());
697 AutoPyRef ob = PyObject_CallObject(_pyfuncUnser,args);
698 if (!ob)
699 {
700 std::stringstream msg;
701 msg << "Conversion with pickle of output ports failed !";
702 msg << " : " << __FILE__ << ":" << __LINE__;
703 _errorDetails=msg.str();
704 throw YACS::ENGINE::ConversionException(msg.str());
705 }
707 DEBUG_YACSTRACE("Assign PyObj output " << p->getName() << " of "<< getId());
708 p->put( ob );
709 DEBUG_YACSTRACE("End of assign PyObj output " << p->getName() << " of "<< getId());
710 }
711 pos++;
712 }
713 }
714 catch(ConversionException& ex)
715 {
716 _errorDetails=ex.what();
717 throw;
718 }
719 if(_autoSqueeze)
721 }
722 //
723 if(!isUsingPythonCache())
724 {
726 bool dummy;
727 Engines::Container_var cont(GetContainerObj(this,dummy));
728 cont->removePyScriptNode(getId().c_str());
729 }
730 DEBTRACE( "++++++++++++++ ENDOF PyNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
731}
732
733void PythonNode::ExecuteLocalInternal(const std::string& codeStr, PyObject *context, std::string& errorDetails)
734{
735 DEBTRACE( code );
736 DEBTRACE( "context refcnt: " << context->ob_refcnt );
737 std::ostringstream stream;
738 stream << "/tmp/PythonNode_";
739 stream << getpid();
740 AutoPyRef code=Py_CompileString(codeStr.c_str(), stream.str().c_str(), Py_file_input);
741 if(code == NULL)
742 {
743 errorDetails="";
744 AutoPyRef new_stderr = newPyStdOut(errorDetails);
745 PySys_SetObject((char*)"stderr", new_stderr);
746 PyErr_Print();
747 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
748 throw YACS::Exception("Error during execution");
749 }
750 {
751 AutoPyRef res = PyEval_EvalCode( code, context, context);
752 }
753 DEBTRACE( "context refcnt: " << context->ob_refcnt );
754 fflush(stdout);
755 fflush(stderr);
756 if(PyErr_Occurred ())
757 {
758 errorDetails="";
759 AutoPyRef new_stderr = newPyStdOut(errorDetails);
760 PySys_SetObject((char*)"stderr", new_stderr);
761 ofstream errorfile(stream.str().c_str());
762 if (errorfile.is_open())
763 {
764 errorfile << codeStr;
765 errorfile.close();
766 }
767 PyErr_Print();
768 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
769 throw YACS::Exception("Error during execution");
770 }
771}
772
773void PythonNode::executeLocalInternal(const std::string& codeStr)
774{
776}
777
779{
780 DEBTRACE( "++++++++++++++ PyNode::executeLocal: " << getName() << " ++++++++++++++++++++" );
781 {
782 AutoGIL agil;
783 std::ostringstream unpxy; unpxy << "from SALOME_PyNode import UnProxyObjectSimpleLocal" << std::endl;
784 DEBTRACE( "---------------PyNode::inputs---------------" );
785 list<InputPort *>::iterator iter2;
786 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
787 {
788 InputPyPort *p=(InputPyPort *)*iter2;
789 DEBTRACE( "port name: " << p->getName() );
790 DEBTRACE( "port kind: " << p->edGetType()->kind() );
791 PyObject* ob=p->getPyObj();
792 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
793 unpxy << p->getName() << " = UnProxyObjectSimpleLocal( " << p->getName() << " )" << std::endl;
794#ifdef _DEVDEBUG_
795 PyObject_Print(ob,stderr,Py_PRINT_RAW);
796 cerr << endl;
797#endif
798 int ier=PyDict_SetItemString(_context,p->getName().c_str(),ob);
799 DEBTRACE( "after PyDict_SetItemString:ob refcnt: " << ob->ob_refcnt );
800 }
801
802 DEBTRACE( "---------------End PyNode::inputs---------------" );
803
804 //calculation
805 DEBTRACE( "----------------PyNode::calculation---------------" );
806
807 if( ! getSqueezeStatus() )
808 executeLocalInternal( unpxy.str() );
809
811
812 DEBTRACE( "-----------------PyNode::outputs-----------------" );
813 list<OutputPort *>::iterator iter;
814 try
815 {
816 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
817 {
818 OutputPyPort *p=(OutputPyPort *)*iter;
819 DEBTRACE( "port name: " << p->getName() );
820 DEBTRACE( "port kind: " << p->edGetType()->kind() );
821 PyObject *ob=PyDict_GetItemString(_context,p->getName().c_str());
822 if(ob==NULL)
823 {
824 std::string msg="Error during execution: there is no variable ";
825 msg=msg+p->getName()+" in node context";
826 _errorDetails=msg;
827 throw Exception(msg);
828 }
829 DEBTRACE( "PyNode::outputs::ob refcnt: " << ob->ob_refcnt );
830#ifdef _DEVDEBUG_
831 PyObject_Print(ob,stderr,Py_PRINT_RAW);
832 cerr << endl;
833#endif
834 p->put(ob);
835 if(!isUsingPythonCache())
836 PyDict_DelItemString(_context,p->getName().c_str());
837 }
838 }
839 catch(ConversionException& ex)
840 {
841 _errorDetails=ex.what();
842 throw;
843 }
844 if(_autoSqueeze)
846 DEBTRACE( "-----------------End PyNode::outputs-----------------" );
847 if(!isUsingPythonCache())
848 {
849 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
850 {
851 AutoPyRef pStr = PyUnicode_FromString( (*iter2)->getName().c_str() );
852 if( PyDict_Contains(_context,pStr) == 1 )
853 { PyDict_DelItem(_context,pStr); }
854 }
855 }
856 }
857 DEBTRACE( "++++++++++++++ End PyNode::execute: " << getName() << " ++++++++++++++++++++" );
858}
859
864void PythonNode::setSqueezeStatusWithExceptions(bool sqStatus, const std::vector<std::string>& squeezeExceptions)
865{
866 this->setSqueezeStatus(sqStatus);
867 this->_nonSqueezableOutputNodes = std::set<std::string>(squeezeExceptions.begin(), squeezeExceptions.end());
868}
869
871{
872 AutoGIL agil;
874 this->squeezeMemoryRemote();
875 else
876 this->squeezeMemory();
877}
878
880{
881 for(auto p : _setOfInputPort)
882 {
883 PyDict_DelItemString(_context,p->getName().c_str());
884 InputPyPort *p2(static_cast<InputPyPort *>(p));
885 if(p2->canSafelySqueezeMemory())
886 p2->put(Py_None);
887 }
888 for(auto p : _setOfOutputPort)
889 {
890 if (!this->_nonSqueezableOutputNodes.empty() && this->_nonSqueezableOutputNodes.find(p->getName()) != this->_nonSqueezableOutputNodes.end())
891 continue;
892 PyDict_DelItemString(_context,p->getName().c_str());
893 OutputPyPort *p2(static_cast<OutputPyPort *>(p));
894 p2->putWithoutForward(Py_None);
895 }
896}
897
899{
900 for(auto p : _setOfInputPort)
901 {
902 InputPyPort *p2(static_cast<InputPyPort *>(p));
903 if(p2->canSafelySqueezeMemory())
904 p2->put(Py_None);
905 }
906 for(auto p : _setOfOutputPort)
907 {
908 if (!this->_nonSqueezableOutputNodes.empty() && this->_nonSqueezableOutputNodes.find(p->getName()) != this->_nonSqueezableOutputNodes.end())
909 continue;
910 OutputPyPort *p2(static_cast<OutputPyPort *>(p));
911 p2->putWithoutForward(Py_None);
912 }
913}
914
916{
918}
919
920void PythonNode::shutdown(int level)
921{
922 DEBTRACE("PythonNode::shutdown " << level);
923 if(_mode=="local")return;
924 if(_container)
925 {
927 _container->shutdown(level);
928 }
929}
930
931void PythonNode::imposeResource(const std::string& resource_name,
932 const std::string& container_name)
933{
934 if(!resource_name.empty() && !container_name.empty())
935 {
936 _imposedResource = resource_name;
937 _imposedContainer = container_name;
938 }
939}
940
942{
943 return _container != nullptr && _container->canAcceptImposedResource();
944}
945
947{
949}
950
952{
954 return "DEFAULT_NAME_FOR_UNIQUE_PYTHON_NODE_ENTRY";
955 else
956 return getId();
957}
958
960{
961 bool found = false;
962 if(_container)
964 return found;
965}
966
968{
969 if(!CORBA::is_nil(_pynode))
970 {
971 try
972 {
973 _pynode->UnRegister();
974 }
975 catch(...)
976 {
977 DEBTRACE("Trouble when pynode->UnRegister!")
978 }
979 _pynode = Engines::PyScriptNode::_nil();
980 }
981}
982
983Node *PythonNode::simpleClone(ComposedNode *father, bool editionOnly) const
984{
985 return new PythonNode(*this,father);
986}
987
988void PythonNode::createRemoteAdaptedPyInterpretor(Engines::Container_ptr objContainer)
989{
991 _pynode=objContainer->createPyScriptNode(pythonEntryName().c_str(),getScript().c_str());
992 _pynode->Register();
993}
994
995Engines::PyNodeBase_var PythonNode::retrieveDftRemotePyInterpretorIfAny(Engines::Container_ptr objContainer) const
996{
997 Engines::PyScriptNode_var ret(objContainer->getDefaultPyScriptNode(pythonEntryName().c_str()));
998 if(!CORBA::is_nil(ret))
999 {
1000 ret->Register();
1001 }
1002 return Engines::PyNodeBase::_narrow(ret);
1003}
1004
1005void PythonNode::assignRemotePyInterpretor(Engines::PyNodeBase_var remoteInterp)
1006{
1007 if(CORBA::is_nil(_pynode))
1008 _pynode=Engines::PyScriptNode::_narrow(remoteInterp);
1009 else
1010 {
1011 Engines::PyScriptNode_var tmpp(Engines::PyScriptNode::_narrow(remoteInterp));
1012 if(!_pynode->_is_equivalent(tmpp))
1013 {
1015 _pynode=Engines::PyScriptNode::_narrow(remoteInterp);
1016 }
1017 }
1018 _pynode->assignNewCompiledCode(getScript().c_str());
1019}
1020
1022{
1023 return Engines::PyNodeBase::_narrow(_pynode);
1024}
1025
1027PythonNode* PythonNode::cloneNode(const std::string& name)
1028{
1029 PythonNode* n=new PythonNode(name);
1030 n->setScript(_script);
1031 list<InputPort *>::iterator iter;
1032 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
1033 {
1034 InputPyPort *p=(InputPyPort *)*iter;
1035 DEBTRACE( "port name: " << p->getName() );
1036 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1037 n->edAddInputPort(p->getName(),p->edGetType());
1038 }
1039 list<OutputPort *>::iterator iter2;
1040 for(iter2 = _setOfOutputPort.begin(); iter2 != _setOfOutputPort.end(); iter2++)
1041 {
1042 OutputPyPort *p=(OutputPyPort *)*iter2;
1043 DEBTRACE( "port name: " << p->getName() );
1044 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1045 n->edAddOutputPort(p->getName(),p->edGetType());
1046 }
1047 return n;
1048}
1049
1051{
1052 std::vector< std::pair<std::string,int> > ret(getDPLScopeInfo(gfn));
1053 if(ret.empty())
1054 return ;
1055 //
1056 PyObject *ob(0);
1057 {
1058 AutoGIL agil;
1059 std::size_t sz(ret.size());
1060 ob=PyList_New(sz);
1061 for(std::size_t i=0;i<sz;i++)
1062 {
1063 const std::pair<std::string,int>& p(ret[i]);
1064 PyObject *elt(PyTuple_New(2));
1065 PyTuple_SetItem(elt,0,PyUnicode_FromString(p.first.c_str()));
1066 PyTuple_SetItem(elt,1,PyLong_FromLong(p.second));
1067 PyList_SetItem(ob,i,elt);
1068 }
1069 }
1070 if(_mode==REMOTE_NAME)
1071 {
1072 Engines::pickledArgs_var serializationInputCorba(new Engines::pickledArgs);
1073 {
1074 AutoGIL agil;
1075 PyObject *serializationInput(PyObject_CallFunctionObjArgs(_pyfuncSimpleSer,ob,NULL));
1076 Py_XDECREF(ob);
1077 char *serializationInputC(0);
1078 Py_ssize_t len;
1079 if (PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len))
1080 throw Exception("DistributedPythonNode problem in python pickle");
1081 serializationInputCorba->length(len);
1082 for(int i=0; i < len ; i++)
1083 serializationInputCorba[i]=serializationInputC[i];
1084 Py_XDECREF(serializationInput);
1085 }
1086 _pynode->defineNewCustomVar(DPL_INFO_NAME,serializationInputCorba);
1087 }
1088 else
1089 {
1090 AutoGIL agil;
1091 PyDict_SetItemString(_context,DPL_INFO_NAME,ob);
1092 Py_XDECREF(ob);
1093 }
1094}
1095
1096PyFuncNode::PyFuncNode(const PyFuncNode& other, ComposedNode *father):InlineFuncNode(other,father),_pyfunc(0)
1097{
1099 {
1100 AutoGIL agil;
1101 _context=PyDict_New();
1102 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1103 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
1104 {
1105 stringstream msg;
1106 msg << "Not possible to set builtins" << __FILE__ << ":" << __LINE__;
1107 _errorDetails=msg.str();
1108 throw Exception(msg.str());
1109 }
1110 }
1111}
1112
1113PyFuncNode::PyFuncNode(const std::string& name): InlineFuncNode(name),_pyfunc(0)
1114{
1115
1117 DEBTRACE( "PyFuncNode::PyFuncNode " << name );
1118 {
1119 AutoGIL agil;
1120 _context=PyDict_New();
1121 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1122 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
1123 {
1124 stringstream msg;
1125 msg << "Not possible to set builtins" << __FILE__ << ":" << __LINE__;
1126 _errorDetails=msg.str();
1127 throw Exception(msg.str());
1128 }
1129 }
1130}
1131
1133{
1134 if(!CORBA::is_nil(_pynode))
1135 {
1136 _pynode->UnRegister();
1137 }
1138}
1139
1140void PyFuncNode::init(bool start)
1141{
1143 if(_state == YACS::DISABLED)
1144 {
1145 exDisabledState(); // to refresh propagation of DISABLED state
1146 return ;
1147 }
1148 if(start) //complete initialization
1150 else if(_state > YACS::LOADED)// WARNING FuncNode has internal vars (CEA usecase) ! Partial initialization (inside a loop). Exclusivity of funcNode.
1152}
1153
1155{
1156 DEBTRACE("checkBasicConsistency");
1158 {
1159 AutoGIL agil;
1160 PyObject* res;
1161 res=Py_CompileString(_script.c_str(),getName().c_str(),Py_file_input);
1162 if(res == NULL)
1163 {
1164 std::string error="";
1165 PyObject* new_stderr = newPyStdOut(error);
1166 PySys_SetObject((char*)"stderr", new_stderr);
1167 PyErr_Print();
1168 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1169 Py_DECREF(new_stderr);
1170 throw Exception(error);
1171 }
1172 else
1173 Py_XDECREF(res);
1174 }
1175}
1176
1178{
1179 DEBTRACE( "---------------PyfuncNode::load function---------------" );
1181 loadRemote();
1182 else
1183 loadLocal();
1184}
1185
1187{
1188 commonRemoteLoad(this);
1189}
1190
1192{
1193 DEBTRACE( "---------------PyFuncNode::load function " << getName() << " ---------------" );
1194 DEBTRACE( _script );
1195
1196#ifdef _DEVDEBUG_
1197 list<OutputPort *>::iterator iter;
1198 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
1199 {
1200 OutputPyPort *p=(OutputPyPort *)*iter;
1201 DEBTRACE( "port name: " << p->getName() );
1202 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1203 }
1204#endif
1205
1206 {
1207 AutoGIL agil;
1208 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1209
1210 std::ostringstream stream;
1211 stream << "/tmp/PythonNode_";
1212 stream << getpid();
1213
1214 PyObject* code=Py_CompileString(_script.c_str(), stream.str().c_str(), Py_file_input);
1215 if(code == NULL)
1216 {
1217 _errorDetails="";
1218 PyObject* new_stderr = newPyStdOut(_errorDetails);
1219 PySys_SetObject((char*)"stderr", new_stderr);
1220 PyErr_Print();
1221 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1222 Py_DECREF(new_stderr);
1223 throw Exception("Error during execution");
1224 }
1225 PyObject *res = PyEval_EvalCode( code, _context, _context);
1226 Py_DECREF(code);
1227 Py_XDECREF(res);
1228
1229 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1230 if(PyErr_Occurred ())
1231 {
1232 _errorDetails="";
1233 PyObject* new_stderr = newPyStdOut(_errorDetails);
1234 PySys_SetObject((char*)"stderr", new_stderr);
1235 ofstream errorfile(stream.str().c_str());
1236 if (errorfile.is_open())
1237 {
1238 errorfile << _script;
1239 errorfile.close();
1240 }
1241 PyErr_Print();
1242 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1243 Py_DECREF(new_stderr);
1244 throw Exception("Error during execution");
1245 return;
1246 }
1247 _pyfunc=PyDict_GetItemString(_context,_fname.c_str());
1248 DEBTRACE( "_pyfunc refcnt: " << _pyfunc->ob_refcnt );
1249 if(_pyfunc == NULL)
1250 {
1251 _errorDetails="";
1252 PyObject* new_stderr = newPyStdOut(_errorDetails);
1253 PySys_SetObject((char*)"stderr", new_stderr);
1254 PyErr_Print();
1255 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1256 Py_DECREF(new_stderr);
1257 throw Exception("Error during execution");
1258 }
1259 DEBTRACE( "---------------End PyFuncNode::load function---------------" );
1260 }
1261}
1262
1264{
1266 executeRemote();
1267 else
1268 executeLocal();
1269}
1270
1272{
1273 DEBTRACE( "++++++++++++++ PyFuncNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
1274 if(!_pyfuncSer)
1275 throw Exception("DistributedPythonNode badly loaded");
1276 //
1277 if(dynamic_cast<HomogeneousPoolContainer *>(getContainer()))
1278 {
1279 bool dummy;
1280 loadPythonAdapter(this,dummy);
1281 _pynode->executeAnotherPieceOfCode(getScript().c_str());
1282 }
1283 //
1284 Engines::pickledArgs_var serializationInputCorba(new Engines::pickledArgs);;
1285 {
1286#if PY_VERSION_HEX < 0x03070000
1287 std::unique_lock<std::mutex> lock(data_mutex);
1288#endif
1289 AutoGIL agil;
1290 PyObject *ob(0);
1291 //===========================================================================
1292 // Get inputs in input ports, build a Python tuple and pickle it
1293 //===========================================================================
1294 PyObject *args(PyTuple_New(getNumberOfInputPorts()));
1295 int pos(0);
1296 for(std::list<InputPort *>::iterator iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++,pos++)
1297 {
1298 InputPyPort *p=(InputPyPort *)*iter2;
1299 ob=p->getPyObj();
1300 Py_INCREF(ob);
1301 PyTuple_SetItem(args,pos,ob);
1302 }
1303#ifdef _DEVDEBUG_
1304 PyObject_Print(args,stderr,Py_PRINT_RAW);
1305 std::cerr << endl;
1306#endif
1307 PyObject *serializationInput=PyObject_CallObject(_pyfuncSer,args);
1308 Py_DECREF(args);
1309 //The pickled string may contain NULL characters so use PyString_AsStringAndSize
1310 char *serializationInputC(0);
1311 Py_ssize_t len;
1312 if (PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len))
1313 throw Exception("DistributedPythonNode problem in python pickle");
1314
1315 serializationInputCorba->length(len);
1316 for(int i=0; i < len ; i++)
1317 serializationInputCorba[i]=serializationInputC[i];
1318 Py_DECREF(serializationInput);
1319 }
1320
1321 //===========================================================================
1322 // Execute in remote Python node
1323 //===========================================================================
1324 DEBTRACE( "-----------------starting remote python invocation-----------------" );
1325 Engines::pickledArgs_var resultCorba;
1326 try
1327 {
1328 resultCorba=_pynode->execute(getFname().c_str(),serializationInputCorba);
1329 }
1330 catch( const SALOME::SALOME_Exception& ex )
1331 {
1332 std::string msg="Exception on remote python invocation";
1333 msg += '\n';
1334 msg += ex.details.text.in();
1335 _errorDetails=msg;
1336 throw Exception(msg);
1337 }
1338 catch(CORBA::COMM_FAILURE& ex)
1339 {
1340 std::ostringstream msg;
1341 msg << "Exception on remote python invocation." << std::endl ;
1342 msg << "Caught system exception COMM_FAILURE -- unable to contact the "
1343 << "object." << std::endl;
1344 _errorDetails=msg.str();
1345 throw Exception(msg.str());
1346 }
1347 catch(CORBA::SystemException& ex)
1348 {
1349 std::ostringstream msg;
1350 msg << "Exception on remote python invocation." << std::endl ;
1351 msg << "Caught a CORBA::SystemException." ;
1352 CORBA::Any tmp;
1353 tmp <<= ex;
1354 CORBA::TypeCode_var tc = tmp.type();
1355 const char *p = tc->name();
1356 if ( *p != '\0' )
1357 msg <<p;
1358 else
1359 msg << tc->id();
1360 msg << std::endl;
1361 _errorDetails=msg.str();
1362 throw Exception(msg.str());
1363 }
1364 catch(CORBA::Exception& ex)
1365 {
1366 std::ostringstream msg;
1367 msg << "Exception on remote python invocation." << std::endl ;
1368 msg << "Caught CORBA::Exception. " ;
1369 CORBA::Any tmp;
1370 tmp <<= ex;
1371 CORBA::TypeCode_var tc = tmp.type();
1372 const char *p = tc->name();
1373 if ( *p != '\0' )
1374 msg <<p;
1375 else
1376 msg << tc->id();
1377 msg << std::endl;
1378 _errorDetails=msg.str();
1379 throw Exception(msg.str());
1380 }
1381 catch(omniORB::fatalException& fe)
1382 {
1383 std::ostringstream msg;
1384 msg << "Exception on remote python invocation." << std::endl ;
1385 msg << "Caught omniORB::fatalException:" << std::endl;
1386 msg << " file: " << fe.file() << std::endl;
1387 msg << " line: " << fe.line() << std::endl;
1388 msg << " mesg: " << fe.errmsg() << std::endl;
1389 _errorDetails=msg.str();
1390 throw Exception(msg.str());
1391 }
1392 DEBTRACE( "-----------------end of remote python invocation-----------------" );
1393 //===========================================================================
1394 // Get results, unpickle and put them in output ports
1395 //===========================================================================
1396 char *resultCorbaC=new char[resultCorba->length()+1];
1397 resultCorbaC[resultCorba->length()]='\0';
1398 for(int i=0;i<resultCorba->length();i++)
1399 resultCorbaC[i]=resultCorba[i];
1400
1401 {
1402#if PY_VERSION_HEX < 0x03070000
1403 std::unique_lock<std::mutex> lock(data_mutex);
1404#endif
1405 AutoGIL agil;
1406
1407 PyObject *resultPython(PyBytes_FromStringAndSize(resultCorbaC,resultCorba->length()));
1408 delete [] resultCorbaC;
1409 PyObject *args(PyTuple_New(1)),*ob(0);
1410 PyTuple_SetItem(args,0,resultPython);
1411 PyObject *finalResult=PyObject_CallObject(_pyfuncUnser,args);
1412 Py_DECREF(args);
1413
1414 DEBTRACE( "-----------------PythonNode::outputs-----------------" );
1415 int nres=1;
1416 if(finalResult == Py_None)
1417 nres=0;
1418 else if(PyTuple_Check(finalResult))
1419 nres=PyTuple_Size(finalResult);
1420
1421 if(getNumberOfOutputPorts() != nres)
1422 {
1423 std::string msg="Number of output arguments : Mismatch between definition and execution";
1424 Py_DECREF(finalResult);
1425 _errorDetails=msg;
1426 throw Exception(msg);
1427 }
1428
1429 try
1430 {
1431 int pos(0);
1432 for(std::list<OutputPort *>::iterator iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++, pos++)
1433 {
1434 OutputPyPort *p=(OutputPyPort *)*iter;
1435 DEBTRACE( "port name: " << p->getName() );
1436 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1437 DEBTRACE( "port pos : " << pos );
1438 if(PyTuple_Check(finalResult))
1439 ob=PyTuple_GetItem(finalResult,pos) ;
1440 else
1441 ob=finalResult;
1442 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1443 p->put(ob);
1444 }
1445 Py_DECREF(finalResult);
1446 }
1447 catch(ConversionException& ex)
1448 {
1449 Py_DECREF(finalResult);
1450 _errorDetails=ex.what();
1451 throw;
1452 }
1453 }
1454
1455 DEBTRACE( "++++++++++++++ ENDOF PyFuncNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
1456}
1457
1459{
1460 DEBTRACE( "++++++++++++++ PyFuncNode::execute: " << getName() << " ++++++++++++++++++++" );
1461
1462 int pos=0;
1463 PyObject* ob;
1464 if(!_pyfunc)throw Exception("PyFuncNode badly loaded");
1465 {
1466 AutoGIL agil;
1467 DEBTRACE( "---------------PyFuncNode::inputs---------------" );
1468 PyObject* args = PyTuple_New(getNumberOfInputPorts()) ;
1469 list<InputPort *>::iterator iter2;
1470 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
1471 {
1472 InputPyPort *p=(InputPyPort *)*iter2;
1473 DEBTRACE( "port name: " << p->getName() );
1474 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1475 ob=p->getPyObj();
1476#ifdef _DEVDEBUG_
1477 PyObject_Print(ob,stderr,Py_PRINT_RAW);
1478 cerr << endl;
1479#endif
1480 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1481 Py_INCREF(ob);
1482 PyTuple_SetItem(args,pos,ob);
1483 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1484 pos++;
1485 }
1486 DEBTRACE( "---------------End PyFuncNode::inputs---------------" );
1487
1488 DEBTRACE( "----------------PyFuncNode::calculation---------------" );
1489#ifdef _DEVDEBUG_
1490 PyObject_Print(_pyfunc,stderr,Py_PRINT_RAW);
1491 cerr << endl;
1492 PyObject_Print(args,stderr,Py_PRINT_RAW);
1493 cerr << endl;
1494#endif
1495 DEBTRACE( "_pyfunc refcnt: " << _pyfunc->ob_refcnt );
1496 PyObject* result = PyObject_CallObject( _pyfunc , args ) ;
1497 DEBTRACE( "_pyfunc refcnt: " << _pyfunc->ob_refcnt );
1498 Py_DECREF(args);
1499 fflush(stdout);
1500 fflush(stderr);
1501 if(result == NULL)
1502 {
1503 _errorDetails="";
1504 PyObject* new_stderr = newPyStdOut(_errorDetails);
1505 PySys_SetObject((char*)"stderr", new_stderr);
1506 std::ostringstream stream;
1507 stream << "/tmp/PythonNode_";
1508 stream << getpid();
1509 ofstream errorfile(stream.str().c_str());
1510 if (errorfile.is_open())
1511 {
1512 errorfile << _script;
1513 errorfile.close();
1514 }
1515 PyErr_Print();
1516 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1517 Py_DECREF(new_stderr);
1518 throw Exception("Error during execution");
1519 }
1520 DEBTRACE( "----------------End PyFuncNode::calculation---------------" );
1521
1522 DEBTRACE( "-----------------PyFuncNode::outputs-----------------" );
1523 int nres=1;
1524 if(result == Py_None)
1525 nres=0;
1526 else if(PyTuple_Check(result))
1527 nres=PyTuple_Size(result);
1528
1529 if(getNumberOfOutputPorts() != nres)
1530 {
1531 std::string msg="Number of output arguments : Mismatch between definition and execution";
1532 Py_DECREF(result);
1533 _errorDetails=msg;
1534 throw Exception(msg);
1535 }
1536
1537 pos=0;
1538#ifdef _DEVDEBUG_
1539 PyObject_Print(result,stderr,Py_PRINT_RAW);
1540 cerr << endl;
1541#endif
1542 list<OutputPort *>::iterator iter;
1543 try
1544 {
1545 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
1546 {
1547 OutputPyPort *p=(OutputPyPort *)*iter;
1548 DEBTRACE( "port name: " << p->getName() );
1549 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1550 DEBTRACE( "port pos : " << pos );
1551 if(PyTuple_Check(result))ob=PyTuple_GetItem(result,pos) ;
1552 else ob=result;
1553 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1554#ifdef _DEVDEBUG_
1555 PyObject_Print(ob,stderr,Py_PRINT_RAW);
1556 cerr << endl;
1557#endif
1558 p->put(ob);
1559 pos++;
1560 }
1561 }
1562 catch(ConversionException& ex)
1563 {
1564 Py_DECREF(result);
1565 _errorDetails=ex.what();
1566 throw;
1567 }
1568 DEBTRACE( "-----------------End PyFuncNode::outputs-----------------" );
1569 Py_DECREF(result);
1570 }
1571 DEBTRACE( "++++++++++++++ End PyFuncNode::execute: " << getName() << " ++++++++++++++++++++" );
1572}
1573
1574Node *PyFuncNode::simpleClone(ComposedNode *father, bool editionOnly) const
1575{
1576 return new PyFuncNode(*this,father);
1577}
1578
1579void PyFuncNode::createRemoteAdaptedPyInterpretor(Engines::Container_ptr objContainer)
1580{
1581 if(!CORBA::is_nil(_pynode))
1582 _pynode->UnRegister();
1583 _pynode=objContainer->createPyNode(getName().c_str(),getScript().c_str());
1584}
1585
1586Engines::PyNodeBase_var PyFuncNode::retrieveDftRemotePyInterpretorIfAny(Engines::Container_ptr objContainer) const
1587{
1588 Engines::PyNode_var ret(objContainer->getDefaultPyNode(getName().c_str()));
1589 if(!CORBA::is_nil(ret))
1590 {
1591 ret->Register();
1592 }
1593 return Engines::PyNodeBase::_narrow(ret);
1594}
1595
1596void PyFuncNode::assignRemotePyInterpretor(Engines::PyNodeBase_var remoteInterp)
1597{
1598 if(!CORBA::is_nil(_pynode))
1599 {
1600 Engines::PyNode_var tmpp(Engines::PyNode::_narrow(remoteInterp));
1601 if(_pynode->_is_equivalent(tmpp))
1602 return ;
1603 }
1604 if(!CORBA::is_nil(_pynode))
1605 _pynode->UnRegister();
1606 _pynode=Engines::PyNode::_narrow(remoteInterp);
1607}
1608
1610{
1611 return Engines::PyNodeBase::_narrow(_pynode);
1612}
1613
1615PyFuncNode* PyFuncNode::cloneNode(const std::string& name)
1616{
1617 PyFuncNode* n=new PyFuncNode(name);
1618 n->setScript(_script);
1619 n->setFname(_fname);
1620 list<InputPort *>::iterator iter;
1621 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
1622 {
1623 InputPyPort *p=(InputPyPort *)*iter;
1624 n->edAddInputPort(p->getName(),p->edGetType());
1625 }
1626 list<OutputPort *>::iterator iter2;
1627 for(iter2 = _setOfOutputPort.begin(); iter2 != _setOfOutputPort.end(); iter2++)
1628 {
1629 OutputPyPort *p=(OutputPyPort *)*iter2;
1630 n->edAddOutputPort(p->getName(),p->edGetType());
1631 }
1632 return n;
1633}
1634
1636{
1638}
1639
1641{
1642 DEBTRACE("PyFuncNode::shutdown " << level);
1643 if(_mode=="local")return;
1644 if(_container)
1645 {
1646 if(!CORBA::is_nil(_pynode)) _pynode->UnRegister();
1647 _pynode=Engines::PyNode::_nil();
1648 _container->shutdown(level);
1649 }
1650}
1651
1652void PyFuncNode::imposeResource(const std::string& resource_name,
1653 const std::string& container_name)
1654{
1655 if(!resource_name.empty() && !container_name.empty())
1656 {
1657 _imposedResource = resource_name;
1658 _imposedContainer = container_name;
1659 }
1660}
1661
1663{
1664 return _container != nullptr && _container->canAcceptImposedResource();
1665}
1666
1668{
1670}
1671
int Py_ssize_t
Definition: PythonNode.cxx:45
Definition: PythonNode.cxx:84
Definition: PythonNode.cxx:90
Engines::Container_var GetContainerObj(InlineNode *reqNode, bool &isStandardCont)
Definition: PythonNode.cxx:139
#define DEBUG_YACSTRACE(msg)
Definition: YacsTrace.hxx:53
std::string getName() const
virtual void start(const Task *askingNode)=0
virtual void shutdown(int level)=0
virtual bool isAlreadyStarted(const Task *askingNode) const =0
virtual std::string getProperty(const std::string &name) const =0
virtual bool isUsingPythonCache()
Definition: Container.cxx:109
virtual bool canAcceptImposedResource()
Definition: Container.cxx:59
void initCommonPartWithoutStateManagement(bool start)
bool canSafelySqueezeMemory() const
Definition: InPort.cxx:73
Definition: InlineNode.hxx:93
Definition: InlineNode.cxx:75
virtual std::string getFname()
Definition: InlineNode.hxx:101
Definition: InlineNode.hxx:44
virtual Container * getContainer()
Definition: InlineNode.cxx:100
virtual std::string getScript()
Definition: InlineNode.hxx:51
Class for Python Ports.
Definition: PythonPorts.hxx:74
Base class for all nodes.
Definition: Node.hxx:70
virtual void setErrorDetails(const std::string &error)
Definition: Node.hxx:191
std::vector< std::pair< std::string, int > > getDPLScopeInfo(ComposedNode *gfn)
Definition: Node.cxx:660
Definition: Node.hxx:125
const std::string getId() const
Definition: Node.cxx:478
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
std::string _implementation
Definition: Node.hxx:97
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
std::string _errorDetails
Definition: Node.hxx:93
YACS::StatesForNode _state
Definition: Node.hxx:91
void putWithoutForward(PyObject *data)
Engines::PyNodeBase_var getRemoteInterpreterHandle()
bool hasImposedResource() const override
Stop all pending activities of the node.
virtual void loadLocal()
virtual void executeRemote()
virtual void loadRemote()
virtual void executeLocal()
std::string getContainerLog()
returns a string that contains the name of the container log file if it exists
void imposeResource(const std::string &resource_name, const std::string &container_name) override
Node * simpleClone(ComposedNode *father, bool editionOnly) const
Engines::PyNodeBase_var retrieveDftRemotePyInterpretorIfAny(Engines::Container_ptr objContainer) const
returns (if any) an object, you have to deal with (UnRegister)
void assignRemotePyInterpretor(Engines::PyNodeBase_var remoteInterp)
PyFuncNode * cloneNode(const std::string &name)
Create a new node of same type with a given name.
virtual void init(bool start=true)
void createRemoteAdaptedPyInterpretor(Engines::Container_ptr objContainer)
returns an object, you have to deal with (UnRegister)
bool canAcceptImposedResource() override
Engines::PyNode_var _pynode
Definition: PythonNode.hxx:168
PyFuncNode(const PyFuncNode &other, ComposedNode *father)
void loadRemoteContext(InlineNode *reqNode, Engines::Container_ptr objContainer, bool isInitializeRequested)
Definition: PythonNode.cxx:195
static void UnlinkOnDestructorIfProxy(PyObject *ob)
Definition: PythonNode.cxx:413
std::string _imposedResource
Definition: PythonNode.hxx:69
virtual bool hasImposedResource() const
Definition: PythonNode.cxx:326
static bool GetDestroyStatus(PyObject *ob)
Definition: PythonNode.cxx:355
virtual const char * getSerializationScript() const =0
void commonRemoteLoad(InlineNode *reqNode)
Definition: PythonNode.cxx:318
virtual Engines::PyNodeBase_var retrieveDftRemotePyInterpretorIfAny(Engines::Container_ptr objContainer) const =0
static PyObject * _pyClsBigObject
Definition: PythonNode.hxx:68
static void IfProxyDoSomething(PyObject *ob, const char *meth)
Definition: PythonNode.cxx:385
Engines::Container_var loadPythonAdapter(InlineNode *reqNode, bool &isInitializeRequested)
Definition: PythonNode.cxx:165
static void DoNotTouchFileIfProxy(PyObject *ob)
Definition: PythonNode.cxx:408
static const char SCRIPT_FOR_SIMPLE_SERIALIZATION[]
Definition: PythonNode.hxx:72
void loadRemoteContainer(InlineNode *reqNode)
Definition: PythonNode.cxx:106
static std::string GetContainerLog(const std::string &mode, Container *container, const Task *askingTask)
Definition: PythonNode.cxx:283
static bool IsProxy(PyObject *ob)
Definition: PythonNode.cxx:331
virtual void createRemoteAdaptedPyInterpretor(Engines::Container_ptr objContainer)=0
virtual Engines::PyNodeBase_var getRemoteInterpreterHandle()=0
std::string _imposedContainer
Definition: PythonNode.hxx:70
virtual void assignRemotePyInterpretor(Engines::PyNodeBase_var remoteInterp)=0
Definition: PythonNode.cxx:458
std::string pythonEntryName() const
Definition: PythonNode.cxx:951
void setSqueezeStatus(bool sqStatus)
Definition: PythonNode.hxx:111
Definition: PythonNode.cxx:946
Engines::PyScriptNode_var _pynode
Definition: PythonNode.hxx:131
Definition: PythonNode.cxx:509
static const char REMOTE_NAME[]
Definition: PythonNode.hxx:125
bool isUsingPythonCache() const
Definition: PythonNode.cxx:959
Definition: PythonNode.cxx:920
Definition: PythonNode.cxx:490
static void ExecuteLocalInternal(const std::string &codeStr, PyObject *context, std::string &errorDetails)
Definition: PythonNode.cxx:733
PythonNode(const PythonNode &other, ComposedNode *father)
Definition: PythonNode.cxx:418
void executeLocalInternal(const std::string &codeStr)
Definition: PythonNode.cxx:773
Definition: PythonNode.cxx:983
Definition: PythonNode.cxx:941
static const char IMPL_NAME[]
Definition: PythonNode.hxx:123
Definition: PythonNode.cxx:988
Definition: PythonNode.cxx:496
Definition: PythonNode.cxx:931
std::set< std::string > _nonSqueezableOutputNodes
list on output port name excluded from the squeeze mecanism
Definition: PythonNode.hxx:130
static const char DPL_INFO_NAME[]
Definition: PythonNode.hxx:126
Definition: PythonNode.cxx:778
Definition: PythonNode.cxx:915
void applyDPLScope(ComposedNode *gfn)
void setSqueezeStatusWithExceptions(bool sqStatus, const std::vector< std::string > &squeezeExceptions)
Definition: PythonNode.cxx:864
virtual void execute()
Definition: PythonNode.cxx:501
Definition: PythonNode.cxx:995
bool getSqueezeStatus() const
Definition: PythonNode.hxx:112
PythonNode * cloneNode(const std::string &name)
static SalomeContainerTmpForHP * BuildFrom(const SalomeHPContainer *cont, const Task *askingNode)
Engines::Container_ptr getContainerPtr(const Task *askingNode) const
const char * what(void) const noexcept
Definition: Exception.cxx:50
Proc * p
Definition: driver.cxx:216
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
@ LOADED
Definition: define.hxx:39
@ READY
Definition: define.hxx:37
@ DISABLED
Definition: define.hxx:50
@ TORECONNECT
Definition: define.hxx:48
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
