InlineNode.cxx
20#include "InlineNode.hxx"
21#include "Visitor.hxx"
22#include "Container.hxx"
23#include <iostream>
24
25#define _DEVDEBUG_
26#include "YacsTrace.hxx"
27
28using namespace YACS::ENGINE;
29using namespace std;
30
31const char InlineNode::LOCAL_STR[]="local";
32
33const char InlineNode::REMOTE_STR[]="remote";
34
35InlineNode::~InlineNode()
36{
37 if(_container)
39}
40
42{
43 visitor->visitInlineNode(this);
44}
45
47
50void InlineNode::setScript(const std::string& script)
51{
52 _script=script;
53 modified();
54}
55
56
58{
59}
60
62{
63 visitor->visitInlineFuncNode(this);
64}
65
69void InlineFuncNode::setFname(const std::string& fname)
70{
71 _fname=fname;
72 modified();
73}
74
76{
78 if(_fname.empty() )
79 {
80 string mess = "Function name is not defined";
81 throw Exception(mess);
82 }
83}
84
85void InlineNode::setExecutionMode(const std::string& mode)
86{
87 if(mode == _mode)return;
88 if(mode == LOCAL_STR || mode == REMOTE_STR)
89 {
90 _mode=mode;
91 modified();
92 }
93}
94
96{
97 return _mode;
98}
99
101{
102 return _container;
103}
104
106{
107 if (cont == _container) return;
108 if(_container)
110 _container=cont;
111 if(_container)
113}
114
116{
117 const InlineNode &otherC=*(dynamic_cast<const InlineNode *>(&other));
118 //if other has no container don't clone: this will not have one
119 if(otherC._container)
120 _container=otherC._container->clone();
121}
122
124{
125 const InlineNode &otherC=*(dynamic_cast<const InlineNode *>(&other));
126 //if other has no container don't clone: this will not have one
127 if(otherC._container)
128 {
129 _container=otherC._container;
131 }
132}
133
135{
136 if(_mode==REMOTE_STR)
137 return true;
138 else
139 return false;
140}
141
143{
144 if(!isDeployable())
145 return 1;
146 if(!_container)
147 return 1;
148 std::map<std::string,std::string> props(_container->getProperties());
149 std::map<std::string,std::string>::iterator it(props.find(std::string("nb_proc_per_node")));
150 if(it==props.end())
151 return 1;
152 if((*it).second.empty())
153 return 1;
154 std::istringstream iss((*it).second);
155 int ret(1); iss >> ret;
156 return ret;
157}
virtual Container * clone() const =0
WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method
virtual std::map< std::string, std::string > getProperties() const =0
virtual void setFname(const std::string &fname)
Set the function name to use in node execution.
Definition: InlineNode.cxx:69
Definition: InlineNode.cxx:75
void accept(Visitor *visitor)
Definition: InlineNode.cxx:61
Definition: InlineNode.hxx:44
static const char LOCAL_STR[]
Definition: InlineNode.hxx:72
virtual Container * getContainer()
Definition: InlineNode.cxx:100
virtual void setScript(const std::string &script)
Set the script (as a string) to execute.
Definition: InlineNode.cxx:50
virtual void setContainer(Container *container)
Definition: InlineNode.cxx:105
void performDuplicationOfPlacement(const Node &other)
performs a duplication of placement using clone method of containers and components....
Definition: InlineNode.cxx:115
static const char REMOTE_STR[]
Definition: InlineNode.hxx:73
virtual std::string getExecutionMode()
Definition: InlineNode.cxx:95
int getMaxLevelOfParallelism() const
Definition: InlineNode.cxx:142
virtual void setExecutionMode(const std::string &mode)
Definition: InlineNode.cxx:85
virtual void accept(Visitor *visitor)
Definition: InlineNode.cxx:41
void performShallowDuplicationOfPlacement(const Node &other)
performs a also duplication of placement but here containers and components are not copied at all wha...
Definition: InlineNode.cxx:123
Base class for all nodes.
Definition: Node.hxx:70
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
virtual void visitInlineFuncNode(InlineFuncNode *node)=0
virtual void visitInlineNode(InlineNode *node)=0
