20#ifndef __VISITOR_HXX__
21#define __VISITOR_HXX__
46 class ServiceInlineNode;
Base class for dynamically (fully or semifully) built graphs.
Loop node for parametric calculation.
Base class for loop node.
Base class for all nodes.
Class for reference objects.
virtual void visitProc(Proc *node)=0
Visitor(ComposedNode *root)
virtual void visitStudyOutNode(DataNode *node)=0
virtual void visitLoop(Loop *node)=0
virtual void visitElementaryNode(ElementaryNode *node)=0
std::map< std::string, std::string > getNodeProperties(Node *node)
std::map< std::string, Container * > getContainerMap(Proc *proc)
virtual void visitForEachLoopDyn(ForEachLoopDyn *node)=0
virtual void visitForLoop(ForLoop *node)=0
virtual void visitServiceInlineNode(ServiceInlineNode *node)=0
virtual void visitDynParaLoop(DynParaLoop *node)=0
virtual void visitOutNode(DataNode *node)=0
virtual void visitServerNode(ServerNode *node)=0
virtual void visitWhileLoop(WhileLoop *node)=0
virtual void visitForEachLoop(ForEachLoop *node)=0
virtual void visitSwitch(Switch *node)=0
virtual void visitPresetNode(DataNode *node)=0
virtual void visitInlineFuncNode(InlineFuncNode *node)=0
std::list< TypeCodeObjref * > getListOfBases(TypeCodeObjref *objref)
virtual void visitStudyInNode(DataNode *node)=0
virtual void visitInlineNode(InlineNode *node)=0
virtual void visitServiceNode(ServiceNode *node)=0
virtual void visitOptimizerLoop(OptimizerLoop *node)=0
std::map< std::string, TypeCode * > getTypeCodeMap(Proc *proc)
virtual void visitBloc(Bloc *node)=0
