ForEachLoop.hxx
20#pragma once
21
23#include "ElementaryNode.hxx"
24#include "DynParaLoop.hxx"
25#include "OutputPort.hxx"
26#include "InputPort.hxx"
27#include "AnyInputPort.hxx"
28
29namespace YACS
30{
31 namespace ENGINE
32 {
33 class ForEachLoop;
34 class ForEachLoopGen;
35 class SplitterNode;
36 class AnySplitOutputPort;
37 class TypeCode;
38 class TypeCodeSeq;
39
41 {
42 friend class ForEachLoopGen;
43 friend class SplitterNode;
44 private:
46 private:
47 InterceptorInputPort(const std::string& name, Node *node, TypeCode* type);
48 InterceptorInputPort(const InterceptorInputPort& other, Node *newHelder);
49 void getAllRepresentants(std::set<InPort *>& repr) const;
50 InputPort *clone(Node *newHelder) const;
51 void setRepr(AnySplitOutputPort *repr);
52 };
53
55 {
56 friend class ForEachLoopGen;
57 friend class SplitterNode;
58 private:
61 mutable unsigned int _cnt;
62 private:
63 bool decrRef();
64 void incrRef() const;
65 AnySplitOutputPort(const std::string& name, Node *node, TypeCode *type);
66 AnySplitOutputPort(const AnySplitOutputPort& other, Node *newHelder);
67 bool addInPort(InPort *inPort) ;
68 void getAllRepresented(std::set<OutPort *>& represented) const;
69 int removeInPort(InPort *inPort, bool forward) ;
70 void addRepr(OutPort *repr, InterceptorInputPort *intercptr);
71 OutPort *getRepr() const { return _repr; }
72 OutputPort *clone(Node *newHelder) const;
73 };
74
76 {
77 friend class ForEachLoopGen;
78 friend class SplitterNode;
79 public:
80 unsigned getNumberOfElements() const;
81 virtual std::string dump();
82 private:
83 SeqAnyInputPort(const std::string& name, Node *node, TypeCodeSeq* type);
84 SeqAnyInputPort(const SeqAnyInputPort& other, Node *newHelder);
85 InputPort *clone(Node *newHelder) const;
86 Any *getValueAtRank(int i) const;
87 };
88
90 {
91 friend class ForEachLoopGen;
92 private:
93 static const char NAME_OF_SEQUENCE_INPUT[];
94 private:
95 SplitterNode(const std::string& name, TypeCode *typeOfData, ForEachLoopGen *father);
96 SplitterNode(const SplitterNode& other, ForEachLoopGen *father);
97 InputPort *getInputPort(const std::string& name) const ;
98 Node *simpleClone(ComposedNode *father, bool editionOnly) const;
99 unsigned getNumberOfElements() const;
100 void execute();
101 void init(bool start=true);
102 void putSplittedValueOnRankTo(int rankInSeq, int branch, bool first);
103 private:
105 };
106
108 {
109 friend class ForEachLoopGen;
110 private:
113 private:
114 FakeNodeForForEachLoop(ForEachLoopGen *loop, bool normalFinish);
116 Node *simpleClone(ComposedNode *father, bool editionOnly) const;
117 void exForwardFailed();
118 void exForwardFinished();
119 void execute();
120 void aborted();
121 void finished();
122 private:
123 static const char NAME[];
124 };
125
127 {
128 public:
129 ForEachLoopPassedData(const std::vector<unsigned int>& passedIds, const std::vector<SequenceAny *>& passedOutputs, const std::vector<std::string>& nameOfOutputs);
132 void init();
133 void checkCompatibilyWithNb(int nbOfElts) const;
134 void checkLevel2(const std::vector<AnyInputPort *>& ports) const;
135 int getNumberOfEltsAlreadyDone() const { return (int)_passedIds.size(); }
136 int toAbsId(int localId) const;
137 int toAbsIdNot(int localId) const;
138 int getNumberOfElementsToDo() const;
139 void assignAlreadyDone(const std::vector<SequenceAny *>& execVals) const;
140 const std::vector<unsigned int>& getIds()const {return _passedIds;}
141 const std::vector<SequenceAny *>& getOutputs()const {return _passedOutputs;}
142 const std::vector<std::string>& getOutputNames()const {return _nameOfOutputs;}
143 //const std::vector<bool>& getFlags()const {return _flagsIds;}
144 private:
145 std::vector<unsigned int> _passedIds;
146 std::vector<SequenceAny *> _passedOutputs;
147 std::vector<std::string> _nameOfOutputs;
148 mutable std::vector<bool> _flagsIds;
149 };
150
151 class Executor;
152
154 {
155 friend class SplitterNode;
157
158 public:
159 static const char NAME_OF_SPLITTERNODE[];
160 protected:
161 static const int NOT_RUNNING_BRANCH_ID;
162 protected:
166 std::vector<AnySplitOutputPort *> _outGoingPorts;
167 std::vector<InterceptorInputPort *> _intecptrsForOutGoingPorts;
168 //part of attributes defining graph dynamically built on control notification
170 std::vector<SequenceAny *> _execVals;
171 std::vector< std::vector<AnyInputPort *> > _execOutGoingPorts;
173 public:
174 ForEachLoopGen(const std::string& name, TypeCode *typeOfDataSplitted, std::unique_ptr<NbBranchesAbstract>&& branchManager);
175 ForEachLoopGen(const ForEachLoopGen& other, ComposedNode *father, bool editionOnly);
177 void init(bool start=true);
178 void exUpdateState();
179 void exUpdateProgress();
180 void getReadyTasks(std::vector<Task *>& tasks);
181 int getNumberOfInputPorts() const;
182 //
183 void checkNoCyclePassingThrough(Node *node) ;
184 void selectRunnableTasks(std::vector<Task *>& tasks);
185 //
186 unsigned getExecCurrentId() const { return _execCurrentId; } // for update progress bar on GUI part
187 std::list<InputPort *> getSetOfInputPort() const;
188 std::list<InputPort *> getLocalInputPorts() const;
190 InputPort *getInputPort(const std::string& name) const ;
191 OutPort *getOutPort(const std::string& name) const ;
192 OutputPort *getOutputPort(const std::string& name) const ;
193 Node *getChildByShortName(const std::string& name) const ;
194 std::list<OutputPort *> getLocalOutputPorts() const;
195 void writeDot(std::ostream &os) const;
196 virtual std::string typeName() {return "YACS__ENGINE__ForEachLoop";}
197 virtual void resetState(int level);
198 std::string getProgress() const;
199 std::list<ProgressWeight> getProgressWeight() const;
200 int getCurrentIndex() const { return _currentIndex; }
201 int getNbOfElementsToBeProcessed() const;
202 static int getFEDeltaBetween(OutPort *start, InPort *end);
203#ifndef SWIG
204 ForEachLoopPassedData* getProcessedData()const;
205 void setProcessedData(ForEachLoopPassedData* processedData);
206 std::vector<unsigned int> getPassedResults(Executor *execut, std::vector<SequenceAny *>& outputs, std::vector<std::string>& nameOfOutputs) const;
207 void assignPassedResults(const std::vector<unsigned int>& passedIds, const std::vector<SequenceAny *>& passedOutputs, const std::vector<std::string>& nameOfOutputs);
208#endif
209 const TypeCode* getOutputPortType(const std::string& portName)const;
210 void cleanDynGraph() override;
211 protected:
212 void checkLinkPossibility(OutPort *start, const std::list<ComposedNode *>& pointsOfViewStart,
213 InPort *end, const std::list<ComposedNode *>& pointsOfViewEnd) ;
214 YACS::Event updateStateOnFinishedEventFrom(Node *node);
215 YACS::Event updateStateForInitNodeOnFinishedEventFrom(Node *node, unsigned int id);
216 YACS::Event updateStateForWorkNodeOnFinishedEventFrom(Node *node, unsigned int id, bool isNormalFinish);
217 YACS::Event updateStateForFinalizeNodeOnFinishedEventFrom(Node *node, unsigned int id);
218 YACS::Event updateStateOnFailedEventFrom(Node *node, const Executor *execInst);
219 void buildDelegateOf(std::pair<OutPort *, OutPort *>& port, InPort *finalTarget, const std::list<ComposedNode *>& pointsOfView);
220 void getDelegateOf(std::pair<OutPort *, OutPort *>& port, InPort *finalTarget, const std::list<ComposedNode *>& pointsOfView) ;
221 void releaseDelegateOf(OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list<ComposedNode *>& pointsOfView) ;
222 protected:
223 void pushAllSequenceValues();
224 void createOutputOutOfScopeInterceptors(int branchNb);
225 void prepareSequenceValues(int sizeOfSamples);
226 OutPort *getDynOutPortByAbsName(int branchNb, const std::string& name);
227 void storeOutValsInSeqForOutOfScopeUse(int rank, int branchNb);
228 private:
229 int getFinishedId();
230 public:
231 static void InterceptorizeNameOfPort(std::string& portName);
232 static const char INTERCEPTOR_STR[];
233 };
234
236 {
237 public:
238 ForEachLoop(const std::string& name, TypeCode *typeOfDataSplitted):ForEachLoopGen(name,typeOfDataSplitted,std::unique_ptr<NbBranchesAbstract>(new NbBranches(this))) { }
239 ForEachLoop(const ForEachLoop& other, ComposedNode *father, bool editionOnly):ForEachLoopGen(other,father,editionOnly) { }
241 void accept(Visitor *visitor);
242 protected:
243 Node *simpleClone(ComposedNode *father, bool editionOnly=true) const;
244 };
245
247 {
248 public:
249 ForEachLoopDyn(const std::string& name, TypeCode *typeOfDataSplitted):ForEachLoopGen(name,typeOfDataSplitted,std::unique_ptr<NbBranchesAbstract>(new NoNbBranches)) { }
250 ForEachLoopDyn(const ForEachLoopDyn& other, ComposedNode *father, bool editionOnly):ForEachLoopGen(other,father,editionOnly) { }
252 void accept(Visitor *visitor);
253 protected:
254 Node *simpleClone(ComposedNode *father, bool editionOnly=true) const;
255 };
256 }
257}
258
#define YACSLIBENGINE_EXPORT
void getAllRepresented(std::set< OutPort * > &represented) const
InterceptorInputPort * _intercptr
Definition: ForEachLoop.hxx:60
OutputPort * clone(Node *newHelder) const
AnySplitOutputPort(const std::string &name, Node *node, TypeCode *type)
Definition: ForEachLoop.cxx:98
Definition: Any.hxx:79
Base class for dynamically (fully or semifully) built graphs.
Definition: DynParaLoop.hxx:41
Threaded Executor.
Definition: Executor.hxx:63
Node * simpleClone(ComposedNode *father, bool editionOnly) const
ForEachLoopDyn(const std::string &name, TypeCode *typeOfDataSplitted)
ForEachLoopDyn(const ForEachLoopDyn &other, ComposedNode *father, bool editionOnly)
std::vector< SequenceAny * > _execVals
std::vector< AnySplitOutputPort * > _outGoingPorts
std::vector< InterceptorInputPort * > _intecptrsForOutGoingPorts
ports linked to node outside the current scope
InputPort * edGetSeqOfSamplesPort()
FakeNodeForForEachLoop * _nodeForSpecialCases
std::vector< std::vector< AnyInputPort * > > _execOutGoingPorts
ForEachLoopPassedData * _passedData
unsigned _execCurrentId
ports created for TypeCodes correctness
const std::vector< unsigned int > & getIds() const
std::vector< SequenceAny * > _passedOutputs
const std::vector< std::string > & getOutputNames() const
std::vector< std::string > _nameOfOutputs
const std::vector< SequenceAny * > & getOutputs() const
std::vector< unsigned int > _passedIds
Loop node for parametric calculation.
ForEachLoop(const ForEachLoop &other, ComposedNode *father, bool editionOnly)
ForEachLoop(const std::string &name, TypeCode *typeOfDataSplitted)
friend class InterceptorInputPort
Definition: InPort.hxx:61
Base class for Input Ports.
Definition: InputPort.hxx:44
InputPort * clone(Node *newHelder) const
Definition: ForEachLoop.cxx:78
void getAllRepresentants(std::set< InPort * > &repr) const
Definition: ForEachLoop.cxx:71
Definition: ForEachLoop.cxx:83
Base class for all nodes.
Definition: Node.hxx:70
InputPort * getInputPort(const std::string &name) const
SplitterNode(const std::string &name, TypeCode *typeOfData, ForEachLoopGen *father)
SeqAnyInputPort _dataPortToDispatch
Definition: ForEachLoop.hxx:93
Class for sequence objects.
Definition: TypeCode.hxx:160
Definition: TypeCode.hxx:68
Event
Definition: define.hxx:56
