YACS::ENGINE::ForEachLoopPassedData Class Reference
#include <ForEachLoop.hxx>
Collaboration diagram for YACS::ENGINE::ForEachLoopPassedData:
 ForEachLoopPassedData (const std::vector< unsigned int > &passedIds, const std::vector< SequenceAny * > &passedOutputs, const std::vector< std::string > &nameOfOutputs)
 ForEachLoopPassedData (const ForEachLoopPassedData &copy)
 ~ForEachLoopPassedData ()
void init ()
void checkCompatibilyWithNb (int nbOfElts) const
void checkLevel2 (const std::vector< AnyInputPort * > &ports) const
int getNumberOfEltsAlreadyDone () const
int toAbsId (int localId) const
int toAbsIdNot (int localId) const
int getNumberOfElementsToDo () const
void assignAlreadyDone (const std::vector< SequenceAny * > &execVals) const
const std::vector< unsigned int > & getIds () const
const std::vector< SequenceAny * > & getOutputs () const
const std::vector< std::string > & getOutputNames () const
std::vector< unsigned int > _passedIds
std::vector< SequenceAny * > _passedOutputs
std::vector< std::string > _nameOfOutputs
std::vector< bool > _flagsIds
Definition at line 126 of file ForEachLoop.hxx.
◆ ForEachLoopPassedData() [1/2]
ForEachLoopPassedData::ForEachLoopPassedData ( const std::vector< unsigned int > &  passedIds,
const std::vector< SequenceAny * > &  passedOutputs,
const std::vector< std::string > &  nameOfOutputs
Definition at line 306 of file ForEachLoop.cxx.
306 :_passedIds(passedIds),_passedOutputs(passedOutputs),_nameOfOutputs(nameOfOutputs)
307{
308 std::size_t sz(_passedIds.size()),sz1(passedOutputs.size()),sz2(nameOfOutputs.size());
309 if(sz1!=sz2)
310 throw YACS::Exception("ForEachLoopPassedData::ForEachLoopPassedData : nameOfOutputs and passedOutputs must have the same size !");
311 for(std::vector<SequenceAny *>::iterator it=_passedOutputs.begin();it!=_passedOutputs.end();it++)
312 {
313 const SequenceAny *elt(*it);
314 if(elt)
315 if(sz!=(std::size_t)elt->size())
316 throw YACS::Exception("ForEachLoopPassedData::ForEachLoopPassedData : incoherent input of passed data !");
317 }
318 for(std::vector<SequenceAny *>::iterator it=_passedOutputs.begin();it!=_passedOutputs.end();it++)
319 {
320 SequenceAny *elt(*it);
321 if(elt)
322 elt->incrRef();
323 }
324}
References _passedIds, _passedOutputs, YACS::ENGINE::RefCounter::incrRef(), and YACS::ENGINE::SequenceAny::size().
◆ ForEachLoopPassedData() [2/2]
ForEachLoopPassedData::ForEachLoopPassedData ( const ForEachLoopPassedData &  copy)
Definition at line 326 of file ForEachLoop.cxx.
◆ ~ForEachLoopPassedData()
ForEachLoopPassedData::~ForEachLoopPassedData ( )
Definition at line 334 of file ForEachLoop.cxx.
335{
336 for(std::vector<SequenceAny *>::iterator it=_passedOutputs.begin();it!=_passedOutputs.end();it++)
337 {
338 SequenceAny *elt(*it);
339 if(elt)
340 elt->decrRef();
341 }
342}
References _passedOutputs, and YACS::ENGINE::RefCounter::decrRef().
◆ assignAlreadyDone()
void ForEachLoopPassedData::assignAlreadyDone ( const std::vector< SequenceAny * > &  execVals) const
Definition at line 448 of file ForEachLoop.cxx.
449{
450 std::size_t sz(execVals.size());
451 if(_passedOutputs.size()!=sz)
452 throw YACS::Exception("ForEachLoopPassedData::assignedAlreadyDone : mismatch of size of vectors !");
453 for(std::size_t i=0;i<sz;i++)
454 {
456 SequenceAny *eltDestination(execVals[i]);
457 if(!elt)
458 throw YACS::Exception("ForEachLoopPassedData::assignedAlreadyDone : presence of null elt !");
459 unsigned int szOfElt(elt->size());
460 for(unsigned int j=0;j<szOfElt;j++)
461 {
462 AnyPtr elt1((*elt)[j]);
463 int jAbs(toAbsIdNot(j));
464 eltDestination->setEltAtRank(jAbs,elt1);
465 }
466 }
467}
: Allow to manage memory of instances of T. The only constraint on T is to have method incrRef and De...
Definition: SharedPtr.hxx:30
int toAbsIdNot(int localId) const
References _passedOutputs, yacsorb.CORBAEngineTest::i, YACS::ENGINE::SequenceAny::setEltAtRank(), YACS::ENGINE::SequenceAny::size(), and toAbsIdNot().
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState().
◆ checkCompatibilyWithNb()
void ForEachLoopPassedData::checkCompatibilyWithNb ( int  nbOfElts) const
Definition at line 349 of file ForEachLoop.cxx.
350{
351 if(nbOfElts<0)
352 throw YACS::Exception("ForEachLoopPassedData::checkCompatibilyWithNb : nb of elts is expected to be > 0 !");
353 std::size_t sizeExp(_passedIds.size()),nbOfElts2(nbOfElts);
354 if(nbOfElts2<sizeExp)
355 throw YACS::Exception("ForEachLoopPassedData::checkCompatibilyWithNb : Invalid nb of elemts in input seq regarding passed data set !");
356 for(std::vector<unsigned int>::const_iterator it=_passedIds.begin();it!=_passedIds.end();it++)
357 {
358 if((*it)>=nbOfElts2)
359 throw YACS::Exception("ForEachLoopPassedData::checkCompatibilyWithNb : Invalid nb of elemts in input seq regarding passed data set 2 !");
360 }
361 _flagsIds.resize(nbOfElts);
362 std::fill(_flagsIds.begin(),_flagsIds.end(),false);
363 for(std::vector<unsigned int>::const_iterator it=_passedIds.begin();it!=_passedIds.end();it++)
364 {
365 if(*it<nbOfElts)
366 {
367 if(!_flagsIds[*it])
368 _flagsIds[*it]=true;
369 else
370 {
371 std::ostringstream oss; oss << "ForEachLoopPassedData::checkCompatibilyWithNb : id " << *it << " in list of ids appears more than once !";
372 throw YACS::Exception(oss.str());
373 }
374 }
375 else
376 {
377 std::ostringstream oss; oss << "ForEachLoopPassedData::checkCompatibilyWithNb : Presence of id " << *it << " in list of ids ! Must be in [0," << nbOfElts << ") !";
378 throw YACS::Exception(oss.str());
379 }
380 }
381}
References _flagsIds, and _passedIds.
◆ checkLevel2()
void ForEachLoopPassedData::checkLevel2 ( const std::vector< AnyInputPort * > &  ports) const
Definition at line 383 of file ForEachLoop.cxx.
384{
385 std::size_t sz(_nameOfOutputs.size());
386 if(sz!=ports.size())
387 throw YACS::Exception("ForEachLoopPassedData::checkLevel2 : mismatch of size of vectors !");
388 for(std::size_t i=0;i<sz;i++)
389 {
390 AnyInputPort *elt(ports[i]);
391 if(!elt)
392 throw YACS::Exception("ForEachLoopPassedData::checkLevel2 : presence of null instance !");
393 if(_nameOfOutputs[i]!=elt->getName())
394 {
395 std::ostringstream oss; oss << "ForEachLoopPassedData::checkLevel2 : At pos #" << i << " the name is not OK !";
396 throw YACS::Exception(oss.str());
397 }
398 }
399}
References _nameOfOutputs, YACS::ENGINE::DataPort::getName(), and yacsorb.CORBAEngineTest::i.
◆ getIds()
const std::vector< unsigned int > & YACS::ENGINE::ForEachLoopPassedData::getIds ( ) const
Definition at line 140 of file ForEachLoop.hxx.
140{return _passedIds;}
Referenced by YACS::ENGINE::VisitorSalomeSaveState::visitForEachLoop().
◆ getNumberOfElementsToDo()
int ForEachLoopPassedData::getNumberOfElementsToDo ( ) const
Definition at line 441 of file ForEachLoop.cxx.
442{
443 std::size_t nbAllElts(_flagsIds.size());
444 std::size_t ret(nbAllElts-_passedIds.size());
445 return ret;
446}
Referenced by YACS::ENGINE::ForEachLoopGen::getFinishedId().
◆ getNumberOfEltsAlreadyDone()
int YACS::ENGINE::ForEachLoopPassedData::getNumberOfEltsAlreadyDone ( ) const
Definition at line 135 of file ForEachLoop.hxx.
135{ return (int)_passedIds.size(); }
◆ getOutputNames()
const std::vector< std::string > & YACS::ENGINE::ForEachLoopPassedData::getOutputNames ( ) const
Definition at line 142 of file ForEachLoop.hxx.
142{return _nameOfOutputs;}
◆ getOutputs()
const std::vector< SequenceAny * > & YACS::ENGINE::ForEachLoopPassedData::getOutputs ( ) const
Definition at line 141 of file ForEachLoop.hxx.
141{return _passedOutputs;}
◆ init()
void ForEachLoopPassedData::init ( )
Definition at line 344 of file ForEachLoop.cxx.
345{
346 _flagsIds.clear();
347}
References _flagsIds.
Referenced by YACS::ENGINE::ForEachLoopGen::init().
◆ toAbsId()
int ForEachLoopPassedData::toAbsId ( int  localId) const
performs local to abs id. Input localId refers to an id in all jobs to perform. Returned id refers to pos in whole output sequences.
Definition at line 404 of file ForEachLoop.cxx.
405{
406 if(localId<0)
407 throw YACS::Exception("ForEachLoopPassedData::toAbsId : local pos must be >= 0 !");
408 int ret(0),curLocId(0);
409 for(std::vector<bool>::const_iterator it=_flagsIds.begin();it!=_flagsIds.end();it++,ret++)
410 {
411 if(!*it)
412 {
413 if(localId==curLocId)
414 return ret;
415 curLocId++;
416 }
417 }
418 throw YACS::Exception("ForEachLoopPassedData::toAbsId : not referenced Id !");
419}
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), and YACS::ENGINE::ForEachLoopGen::updateStateForWorkNodeOnFinishedEventFrom().
◆ toAbsIdNot()
int ForEachLoopPassedData::toAbsIdNot ( int  localId) const
Equivalent to toAbsId except that only ON are considered here.
Definition at line 424 of file ForEachLoop.cxx.
425{
426 if(localId<0)
427 throw YACS::Exception("ForEachLoopPassedData::toAbsIdNot : local pos must be >= 0 !");
428 int ret(0),curLocId(0);
429 for(std::vector<bool>::const_iterator it=_flagsIds.begin();it!=_flagsIds.end();it++,ret++)
430 {
431 if(*it)//<- diff is here !
432 {
433 if(localId==curLocId)
434 return ret;
435 curLocId++;
436 }
437 }
438 throw YACS::Exception("ForEachLoopPassedData::toAbsIdNot : not referenced Id !");
439}
Referenced by assignAlreadyDone().
◆ _flagsIds
std::vector<bool> YACS::ENGINE::ForEachLoopPassedData::_flagsIds
mutableprivate
◆ _nameOfOutputs
std::vector<std::string> YACS::ENGINE::ForEachLoopPassedData::_nameOfOutputs
Definition at line 147 of file ForEachLoop.hxx.
Referenced by checkLevel2().
◆ _passedIds
std::vector<unsigned int> YACS::ENGINE::ForEachLoopPassedData::_passedIds
◆ _passedOutputs
std::vector<SequenceAny *> YACS::ENGINE::ForEachLoopPassedData::_passedOutputs
