YACS::ENGINE::NoNbBranches Class Reference
#include <NbBranches.hxx>
Inheritance diagram for YACS::ENGINE::NoNbBranches:
Collaboration diagram for YACS::ENGINE::NoNbBranches:
 NoNbBranches ()=default
std::unique_ptr< NbBranchesAbstract > copy (Node *node) const override
int getNumberOfBranches (int nbOfElems) const override
bool isMyName (const std::string &name) const override
void exInit (bool start) override
InputPort * getPort () const override
bool isMultiplicitySpecified (unsigned &value) const override
void forceMultiplicity (unsigned value) override
int getIntValue () const override
virtual std::unique_ptr< NbBranchesAbstract > copy (Node *node) const =0
virtual int getNumberOfBranches (int nbOfElems) const =0
virtual bool isMyName (const std::string &name) const =0
virtual void exInit (bool start)=0
virtual InputPort * getPort () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual int getIntValue () const =0
- Static Public Member Functions inherited from YACS::ENGINE::NbBranchesAbstract
static bool IsBranchPortName (const std::string &name)
- Static Protected Attributes inherited from YACS::ENGINE::NbBranchesAbstract
static const char NAME_OF_NUMBER_OF_BRANCHES [] ="nbBranches"
Definition at line 65 of file NbBranches.hxx.
◆ NoNbBranches()
YACS::ENGINE::NoNbBranches::NoNbBranches ( )
default
◆ copy()
std::unique_ptr< NbBranchesAbstract > NoNbBranches::copy ( Node *  node) const
overridevirtual
Implements YACS::ENGINE::NbBranchesAbstract.
Definition at line 73 of file NbBranches.cxx.
74{
75 return std::unique_ptr<NbBranchesAbstract>(new NoNbBranches);
76}
◆ exInit()
void NoNbBranches::exInit ( bool  start)
overridevirtual
Definition at line 83 of file NbBranches.cxx.
84{
85}
◆ forceMultiplicity()
void NoNbBranches::forceMultiplicity ( unsigned  value)
overridevirtual
Definition at line 97 of file NbBranches.cxx.
98{
99 throw Exception("NoNbBranches::forceMultiplicity : impossible to be forced !");
100}
◆ getIntValue()
int NoNbBranches::getIntValue ( ) const
overridevirtual
Definition at line 102 of file NbBranches.cxx.
103{
104 throw Exception("NoNbBranches::getIntValue : no value stored !");
105}
◆ getNumberOfBranches()
int NoNbBranches::getNumberOfBranches ( int  nbOfElems) const
overridevirtual
Definition at line 78 of file NbBranches.cxx.
79{
80 return nbOfElems;
81}
◆ getPort()
InputPort * NoNbBranches::getPort ( ) const
overridevirtual
Definition at line 87 of file NbBranches.cxx.
88{
89 return nullptr;
90}
◆ isMultiplicitySpecified()
bool NoNbBranches::isMultiplicitySpecified ( unsigned &  value) const
overridevirtual
Definition at line 92 of file NbBranches.cxx.
93{
94 return false;
95}
◆ isMyName()
bool YACS::ENGINE::NoNbBranches::isMyName ( const std::string &  name) const
inlineoverridevirtual
Definition at line 71 of file NbBranches.hxx.
71{ return false; }
