NbBranches.hxx
20#pragma once
21
23#include "AnyInputPort.hxx"
24
25#include <memory>
26
27namespace YACS
28{
29 namespace ENGINE
30 {
31 class Node;
33 {
34 public:
35 virtual std::unique_ptr<NbBranchesAbstract> copy(Node *node) const = 0;
36 virtual int getNumberOfBranches(int nbOfElems) const = 0;
37 virtual bool isMyName(const std::string& name) const = 0;
38 virtual void exInit(bool start) = 0;
39 virtual InputPort *getPort() const = 0;
40 virtual bool isMultiplicitySpecified(unsigned& value) const = 0;
41 virtual void forceMultiplicity(unsigned value) = 0;
42 virtual int getIntValue() const = 0;
43 static bool IsBranchPortName(const std::string& name);
44 protected:
45 static const char NAME_OF_NUMBER_OF_BRANCHES[];
46 };
47
49 {
50 public:
51 NbBranches(Node *node):_nbOfBranches(NAME_OF_NUMBER_OF_BRANCHES,node,Runtime::_tc_int) { }
52 NbBranches(const NbBranches& other, Node *node):_nbOfBranches(other._nbOfBranches,node) { }
53 bool isMyName(const std::string& name) const override;
54 std::unique_ptr<NbBranchesAbstract> copy(Node *node) const override;
55 int getNumberOfBranches(int nbOfElems) const override;
56 void exInit(bool start) override;
57 InputPort *getPort() const override;
58 bool isMultiplicitySpecified(unsigned& value) const override;
59 void forceMultiplicity(unsigned value) override;
60 int getIntValue() const override { return _nbOfBranches.getIntValue(); }
61 private:
63 };
64
66 {
67 public:
68 NoNbBranches() = default;
69 std::unique_ptr<NbBranchesAbstract> copy(Node *node) const override;
70 int getNumberOfBranches(int nbOfElems) const override;
71 bool isMyName(const std::string& name) const override { return false; }
72 void exInit(bool start) override;
73 InputPort *getPort() const override;
74 bool isMultiplicitySpecified(unsigned& value) const override;
75 void forceMultiplicity(unsigned value) override;
76 int getIntValue() const override;
77 };
78 }
79}
#define YACSLIBENGINE_EXPORT
Base class for Input Ports.
Definition: InputPort.hxx:44
virtual InputPort * getPort() const =0
virtual int getNumberOfBranches(int nbOfElems) const =0
virtual void exInit(bool start)=0
virtual bool isMyName(const std::string &name) const =0
virtual std::unique_ptr< NbBranchesAbstract > copy(Node *node) const =0
virtual bool isMultiplicitySpecified(unsigned &value) const =0
virtual void forceMultiplicity(unsigned value)=0
virtual int getIntValue() const =0
NbBranches(const NbBranches &other, Node *node)
Definition: NbBranches.hxx:52
Definition: NbBranches.hxx:60
AnyInputPort _nbOfBranches
Definition: NbBranches.hxx:62
bool isMyName(const std::string &name) const override
Definition: NbBranches.hxx:71
Base class for all nodes.
Definition: Node.hxx:70
