YACS::ENGINE::NbBranches Class Reference
#include <NbBranches.hxx>
Inheritance diagram for YACS::ENGINE::NbBranches:
Collaboration diagram for YACS::ENGINE::NbBranches:
 NbBranches (Node *node)
 NbBranches (const NbBranches &other, Node *node)
bool isMyName (const std::string &name) const override
std::unique_ptr< NbBranchesAbstract > copy (Node *node) const override
int getNumberOfBranches (int nbOfElems) const override
void exInit (bool start) override
InputPort * getPort () const override
bool isMultiplicitySpecified (unsigned &value) const override
void forceMultiplicity (unsigned value) override
int getIntValue () const override
virtual std::unique_ptr< NbBranchesAbstract > copy (Node *node) const =0
virtual int getNumberOfBranches (int nbOfElems) const =0
virtual bool isMyName (const std::string &name) const =0
virtual void exInit (bool start)=0
virtual InputPort * getPort () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual int getIntValue () const =0
AnyInputPort _nbOfBranches
- Static Public Member Functions inherited from YACS::ENGINE::NbBranchesAbstract
static bool IsBranchPortName (const std::string &name)
- Static Protected Attributes inherited from YACS::ENGINE::NbBranchesAbstract
static const char NAME_OF_NUMBER_OF_BRANCHES [] ="nbBranches"
Definition at line 48 of file NbBranches.hxx.
◆ NbBranches() [1/2]
YACS::ENGINE::NbBranches::NbBranches ( Node *  node)
Definition at line 51 of file NbBranches.hxx.
static const char NAME_OF_NUMBER_OF_BRANCHES[]
Definition: NbBranches.hxx:45
Definition: NbBranches.hxx:62
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
Referenced by copy().
◆ NbBranches() [2/2]
YACS::ENGINE::NbBranches::NbBranches ( const NbBranches &  other,
Node *  node
Definition at line 52 of file NbBranches.hxx.
52:_nbOfBranches(other._nbOfBranches,node) { }
◆ copy()
std::unique_ptr< NbBranchesAbstract > NbBranches::copy ( Node *  node) const
overridevirtual
Implements YACS::ENGINE::NbBranchesAbstract.
Definition at line 31 of file NbBranches.cxx.
32{
33 return std::unique_ptr<NbBranchesAbstract>(new NbBranches(*this,node));
34}
References NbBranches().
◆ exInit()
void NbBranches::exInit ( bool  start)
overridevirtual
Definition at line 46 of file NbBranches.cxx.
47{
48 _nbOfBranches.exInit(start);
49}
virtual void exInit(bool start)
Definition: InputPort.cxx:63
References _nbOfBranches, and YACS::ENGINE::InputPort::exInit().
◆ forceMultiplicity()
void NbBranches::forceMultiplicity ( unsigned  value)
overridevirtual
◆ getIntValue()
int YACS::ENGINE::NbBranches::getIntValue ( ) const
inlineoverridevirtual
Definition at line 60 of file NbBranches.hxx.
60{ return _nbOfBranches.getIntValue(); }
Referenced by getNumberOfBranches().
◆ getNumberOfBranches()
int NbBranches::getNumberOfBranches ( int  nbOfElems) const
overridevirtual
Definition at line 36 of file NbBranches.cxx.
37{
38 return this->getIntValue();
39}
int getIntValue() const override
Definition: NbBranches.hxx:60
References getIntValue().
◆ getPort()
InputPort * NbBranches::getPort ( ) const
overridevirtual
Definition at line 51 of file NbBranches.cxx.
52{
53 return const_cast<AnyInputPort *>(&_nbOfBranches);
54}
References _nbOfBranches.
◆ isMultiplicitySpecified()
bool NbBranches::isMultiplicitySpecified ( unsigned &  value) const
overridevirtual
Definition at line 56 of file NbBranches.cxx.
57{
60 {
62 return true;
63 }
64 return false;
65}
virtual int edGetNumberOfLinks() const
Returns number of physical backlinks NOT number of user backlinks.
Definition: InPort.cxx:45
virtual bool edIsManuallyInitialized() const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition: InputPort.cxx:76
References _nbOfBranches, YACS::ENGINE::InPort::edGetNumberOfLinks(), YACS::ENGINE::InputPort::edIsManuallyInitialized(), and YACS::ENGINE::AnyInputPort::getIntValue().
◆ isMyName()
bool NbBranches::isMyName ( const std::string &  name) const
overridevirtual
Definition at line 41 of file NbBranches.cxx.
42{
44}
static bool IsBranchPortName(const std::string &name)
Definition: NbBranches.cxx:26
References YACS::ENGINE::NbBranchesAbstract::IsBranchPortName().
◆ _nbOfBranches
AnyInputPort YACS::ENGINE::NbBranches::_nbOfBranches
Definition at line 62 of file NbBranches.hxx.
Referenced by exInit(), forceMultiplicity(), getPort(), and isMultiplicitySpecified().
