Runtime.hxx
20#ifndef _RUNTIME_HXX_
21#define _RUNTIME_HXX_
26#include<string>
27#include<set>
28#include<map>
29#include<vector>
30#include<list>
31
32namespace YACS
33{
34 namespace ENGINE
35 {
36 class Runtime;
38
39 class Any;
40 class InputPort;
41 class OutputPort;
42 class InPropertyPort;
43 class ForLoop;
44 class ForEachLoop;
45 class ForEachLoopDyn;
46 class OptimizerLoop;
47 class WhileLoop;
48 class Switch;
49 class InlineNode;
50 class InlineFuncNode;
51 class ServiceNode;
52 class DataNode;
53 class Container;
54 class ServiceInlineNode;
55 class ComponentInstance;
56 class Proc;
57 class Bloc;
58 class ElementaryNode;
59 class Node;
60 class TypeCode;
61 class TypeCodeStruct;
62 class TypeCodeObjref;
63 class InputDataStreamPort;
64 class OutputDataStreamPort;
65 class Catalog;
66 class CatalogLoader;
67
69 {
70 friend Runtime* getRuntime() ;
71 public:
72 virtual void init() { }
73 virtual void fini() { }
74 virtual std::vector< std::pair<std::string,int> > getCatalogOfComputeNodes() const = 0;
75 virtual Catalog* loadCatalog(const std::string& sourceKind,const std::string& path);
76 virtual InlineFuncNode* createFuncNode(const std::string& kind,const std::string& name);
77 virtual InlineNode* createScriptNode(const std::string& kind,const std::string& name);
78
79 virtual ServiceNode* createRefNode(const std::string& kind,const std::string& name);
80 virtual ServiceNode* createCompoNode(const std::string& kind,const std::string& name);
81 virtual ServiceInlineNode *createSInlineNode(const std::string& kind, const std::string& name);
82 virtual DataNode* createInDataNode(const std::string& kind,const std::string& name);
83 virtual DataNode* createOutDataNode(const std::string& kind,const std::string& name);
84
85 virtual ComponentInstance* createComponentInstance(const std::string& name,
86 const std::string& kind="");
87 virtual Container *createContainer(const std::string& kind="");
88 virtual Proc* createProc(const std::string& name);
89 virtual Bloc* createBloc(const std::string& name);
90 virtual WhileLoop* createWhileLoop(const std::string& name);
91 virtual ForLoop* createForLoop(const std::string& name);
92 virtual ForEachLoop* createForEachLoop(const std::string& name,TypeCode * type);
93 virtual ForEachLoopDyn* createForEachLoopDyn(const std::string& name,TypeCode * type);
94 virtual OptimizerLoop* createOptimizerLoop(const std::string& name,const std::string& algLib,
95 const std::string& factoryName,bool algInitOnFile,
96 const std::string& kind="", Proc * procForTypes = NULL);
97 virtual Switch* createSwitch(const std::string& name);
98
99 virtual TypeCode * createInterfaceTc(const std::string& id, const std::string& name,
100 std::list<TypeCodeObjref *> ltc);
101 virtual TypeCode * createSequenceTc(const std::string& id, const std::string& name, TypeCode *content);
102 virtual TypeCodeStruct * createStructTc(const std::string& id, const std::string& name);
103
104 virtual InputPort* createInputPort(const std::string& name,
105 const std::string& impl,
106 Node * node,
107 TypeCode * type) = 0;
108
109 virtual OutputPort* createOutputPort(const std::string& name,
110 const std::string& impl,
111 Node * node,
112 TypeCode * type) = 0;
113
114 virtual InputDataStreamPort* createInputDataStreamPort(const std::string& name,
115 Node * node,
116 TypeCode * type);
117 virtual OutputDataStreamPort* createOutputDataStreamPort(const std::string& name,
118 Node * node,
119 TypeCode * type);
120
121 virtual InputPort* adapt(InputPort* source, const std::string& impl, TypeCode * type,
122 bool init=false) = 0;
123
125 const std::string& impl,
126 TypeCode * type,
127 bool init=false) = 0;
128
129 virtual void* convertNeutral(TypeCode * type, Any *data);
130 virtual std::string convertNeutralAsString(TypeCode * type, Any *data);
131
132 virtual void removeRuntime();
133 virtual ~Runtime();
134 public:
135 static const char RUNTIME_ENGINE_INTERACTION_IMPL_NAME[];
143 virtual void setCatalogLoaderFactory(const std::string& name, CatalogLoader* factory);
144 std::map<std::string,CatalogLoader*> _catalogLoaderFactoryMap;
145 Catalog* getBuiltinCatalog();
146 virtual void addCatalog(Catalog* catalog);
147 virtual TypeCode* getTypeCode(const std::string& name);
148
149 protected:
151 Runtime();
152 std::set<std::string> _setOfImplementation;
154 std::vector<Catalog*> _catalogs;
155 };
156
157 }
158}
159#endif
#define YACSLIBENGINE_EXPORT
Definition: Any.hxx:79
Definition: Bloc.hxx:36
class for YACS catalog loader.
Definition: Catalog.hxx:63
class for YACS catalogs.
Definition: Catalog.hxx:42
Definition: DataNode.hxx:38
Loop node for parametric calculation.
Class for for loop node.
Definition: ForLoop.hxx:33
class for Input Property Ports
Definition: InlineNode.hxx:93
Definition: InlineNode.hxx:44
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
virtual void init()
Definition: Runtime.hxx:72
static YACS::ENGINE::TypeCode * _tc_double
Definition: Runtime.hxx:136
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
friend Runtime * getRuntime()
virtual std::vector< std::pair< std::string, int > > getCatalogOfComputeNodes() const =0
Catalog * _builtinCatalog
Definition: Runtime.hxx:153
virtual OutputPort * createOutputPort(const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
virtual InputPort * adapt(InPropertyPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
virtual InputPort * createInputPort(const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
static YACS::ENGINE::TypeCode * _tc_file
Definition: Runtime.hxx:140
virtual InputPort * adapt(InputPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
std::vector< Catalog * > _catalogs
Definition: Runtime.hxx:154
static Runtime * _singleton
Definition: Runtime.hxx:150
std::set< std::string > _setOfImplementation
Definition: Runtime.hxx:152
virtual void fini()
Definition: Runtime.hxx:73
static YACS::ENGINE::TypeCode * _tc_propvec
Definition: Runtime.hxx:142
std::map< std::string, CatalogLoader * > _catalogLoaderFactoryMap
Definition: Runtime.hxx:144
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
static YACS::ENGINE::TypeCode * _tc_stringpair
Definition: Runtime.hxx:141
Definition: Runtime.hxx:139
Definition: Switch.hxx:85
Class for struct type.
Definition: TypeCode.hxx:228
Definition: TypeCode.hxx:68
Class for a while loop.
Definition: WhileLoop.hxx:39
Definition: Runtime.cxx:61
