YACS::ENGINE::TypeCodeStruct Class Reference
Class for struct type. More...
#include <TypeCode.hxx>
Inheritance diagram for YACS::ENGINE::TypeCodeStruct:
Collaboration diagram for YACS::ENGINE::TypeCodeStruct:
 TypeCodeStruct (const char *repositoryId, const char *name)
 Create a struct type with a given name and a given id. More...
TypeCode * clone () const
void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
void destroyZippedAny (char *data) const
AnyPtr getOrBuildAnyFromZippedData (char *data) const
const char * id () const
const char * name () const
const char * shortName () const
virtual unsigned getSizeInByteOfAnyReprInSeq () const
const TypeCode * contentType () const
virtual int isA (const char *repositoryId) const
 Check if this TypeCode is derived from a TypeCode with a given id. More...
virtual int isA (const TypeCode *tc) const
 Check if this TypeCode is derived from a given TypeCode. More...
virtual int isAdaptable (const TypeCode *tc) const
 Check if this TypeCode is adaptable to a given TypeCode (tc) More...
virtual int isEquivalent (const TypeCode *tc) const
 Check if this TypeCode can be used in place of tc. More...
virtual void addMember (const std::string &name, TypeCode *tc)
 The only non const method. More...
const TypeCode * getMember (const std::string &name, unsigned &offset) const
 Get typecode of struct member given its name. More...
int memberCount () const
const char * memberName (int index) const
TypeCode * memberType (int index) const
- Public Member Functions inherited from YACS::ENGINE::TypeCode
 TypeCode (DynType kind)
DynType kind () const
const char * getKindRepr () const
const TypeCode * subContentType (int lev) const
virtual TypeCode * clone () const
virtual void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
virtual void destroyZippedAny (char *data) const
virtual AnyPtr getOrBuildAnyFromZippedData (char *data) const
virtual const char * name () const
virtual const char * shortName () const
virtual const char * id () const
virtual const TypeCode * contentType () const
virtual std::string getPrintStr () const
void incrRef () const
bool decrRef () const
virtual ~TypeCodeStruct ()
 TypeCodeStruct (const TypeCodeStruct &tc)
- Protected Member Functions inherited from YACS::ENGINE::TypeCodeComposed
 TypeCodeComposed (const TypeCodeComposed &other)
 TypeCodeComposed (DynType kind, const char *repositoryId, const char *name)
 TypeCode (const TypeCode &tc)
TypeCode & operator= (const TypeCode &tc)
virtual ~TypeCode ()
 RefCounter ()
virtual ~RefCounter ()
std::vector< std::pair< std::string, TypeCode * > > _members
Friends
class StructAny
- Static Public Member Functions inherited from YACS::ENGINE::TypeCode
static const char * getKindRepr (DynType kind)
static TypeCode * interfaceTc (const char *id, const char *name)
 static factory of object reference type given an id and a name More...
static TypeCode * interfaceTc (const char *id, const char *name, const std::list< TypeCodeObjref * > &ltc)
 static factory of object reference type given an id, a name and a list of base types More...
static TypeCode * sequenceTc (const char *id, const char *name, TypeCode *content)
 static factory of sequence type given an id, a name and a content type More...
static TypeCode * structTc (const char *id, const char *name)
 static factory of struct type given an id and a name More...
- Protected Attributes inherited from YACS::ENGINE::TypeCodeComposed
const std::string _name
const std::string _repoId
std::string _shortName
const DynType _kind
unsigned int _cnt
- Static Protected Attributes inherited from YACS::ENGINE::TypeCode
static const char * KIND_STR_REPR [] ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
Definition at line 227 of file TypeCode.hxx.
◆ TypeCodeStruct() [1/2]
TypeCodeStruct::TypeCodeStruct ( const char *  repositoryId,
const char *  name
repositoryId: the given id
name: the given name
Definition at line 644 of file TypeCode.cxx.
645 : TypeCodeComposed(Struct,repositoryId,name)
646{
647}
TypeCodeComposed(const TypeCodeComposed &other)
Definition: TypeCode.cxx:275
const char * name() const
Definition: TypeCode.cxx:686
Referenced by clone().
◆ ~TypeCodeStruct()
TypeCodeStruct::~TypeCodeStruct ( )
Definition at line 649 of file TypeCode.cxx.
650{
651 for(vector< pair<string,TypeCode*> >::iterator iter=_members.begin();iter!=_members.end();iter++)
652 (*iter).second->decrRef();
653}
Definition: TypeCode.hxx:257
References _members.
◆ TypeCodeStruct() [2/2]
TypeCodeStruct::TypeCodeStruct ( const TypeCodeStruct &  tc)
Definition at line 660 of file TypeCode.cxx.
661{
662 for(vector< std::pair<std::string,TypeCode*> >::iterator iter=_members.begin();iter!=_members.end();iter++)
663 (*iter).second->incrRef();
664}
References _members, and YACS::ENGINE::RefCounter::incrRef().
◆ addMember()
void TypeCodeStruct::addMember ( const std::string &  name,
TypeCode *  tc
Definition at line 781 of file TypeCode.cxx.
782{
783 DEBTRACE(name << " " << tc->name());
784 std::vector< std::pair<std::string,TypeCode*> >::const_iterator iter;
785 for(iter=_members.begin();iter != _members.end(); iter++)
786 {
787 if((*iter).first == name)
788 throw Exception("Struct member " + name + " already defined");
789 }
790 _members.push_back(std::pair<std::string,TypeCode*>(name,tc));
791 tc->incrRef();
792}
Definition: TypeCode.cxx:72
References _members, DEBTRACE, YACS::ENGINE::RefCounter::incrRef(), YACS::ENGINE::TypeCode::name(), and name().
Referenced by YACS::ENGINE::Runtime::Runtime().
◆ clone()
TypeCode * TypeCodeStruct::clone ( ) const
Reimplemented from YACS::ENGINE::TypeCode.
Definition at line 655 of file TypeCode.cxx.
656{
657 return new TypeCodeStruct(*this);
658}
TypeCodeStruct(const char *repositoryId, const char *name)
Definition: TypeCode.cxx:644
References TypeCodeStruct().
◆ contentType()
const TypeCode * TypeCodeStruct::contentType ( ) const
Definition at line 704 of file TypeCode.cxx.
705{
706 const char what[]="Content type is specified by giving a key.";
707 throw Exception(what);
708}
◆ destroyZippedAny()
void TypeCodeStruct::destroyZippedAny ( char *  data) const
Definition at line 671 of file TypeCode.cxx.
672{
674}
static void destroyReprAtPlace(char *data, const TypeCodeStruct *type)
Definition: Any.cxx:1138
References YACS::ENGINE::StructAny::destroyReprAtPlace().
◆ getMember()
const TypeCode * TypeCodeStruct::getMember ( const std::string &  name,
unsigned &  offset
If name is not an existing key, 0 is returned.
name: the member name
offset: Out parameter, that specified the location of start of data discriminated by name key.
the member TypeCode
Definition at line 801 of file TypeCode.cxx.
802{
803 std::vector< std::pair<std::string,TypeCode*> >::const_iterator iter;
804 offset=0;
805 for(iter=_members.begin();iter != _members.end(); iter++)
806 {
807 if((*iter).first==name)
808 return (*iter).second;
809 offset+=(*iter).second->getSizeInByteOfAnyReprInSeq();
810 }
811 return 0;
812}
References _members, YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), and name().
Referenced by YACS::ENGINE::StructAny::setEltAtRank().
◆ getOrBuildAnyFromZippedData()
AnyPtr TypeCodeStruct::getOrBuildAnyFromZippedData ( char *  data) const
Definition at line 676 of file TypeCode.cxx.
677{
678 return StructAny::getOrBuildFromData(data,this);
679}
static AnyPtr getOrBuildFromData(char *data, const TypeCodeStruct *type)
Definition: Any.cxx:1149
References YACS::ENGINE::StructAny::getOrBuildFromData().
◆ getSizeInByteOfAnyReprInSeq()
unsigned TypeCodeStruct::getSizeInByteOfAnyReprInSeq ( ) const
Definition at line 696 of file TypeCode.cxx.
697{
698 unsigned ret=0;
699 for(vector< pair<string,TypeCode*> >::const_iterator iter=_members.begin();iter!=_members.end();iter++)
700 ret+=(*iter).second->getSizeInByteOfAnyReprInSeq();
701 return ret;
702}
◆ id()
const char * TypeCodeStruct::id ( ) const
Definition at line 681 of file TypeCode.cxx.
682{
683 return _repoId.c_str();
684};
Definition: TypeCode.hxx:115
References YACS::ENGINE::TypeCodeComposed::_repoId.
◆ isA() [1/2]
int TypeCodeStruct::isA ( const char *  id) const
id: a given id
1 if true, 0 if false
Definition at line 715 of file TypeCode.cxx.
716{
717 if(_repoId == id)return 1;
718 return 0;
719}
Referenced by isA().
◆ isA() [2/2]
int TypeCodeStruct::isA ( const TypeCode *  tc) const
tc: the given TypeCode
Definition at line 726 of file TypeCode.cxx.
727{
728 if(_kind != tc->kind()) return 0;
729 if(_repoId == tc->id())return 1;
730 int nMember=memberCount();
731 if(nMember != ((TypeCodeStruct*)tc)->memberCount())return 0;
732 for(int i=0;i<nMember;i++)
733 {
734 const char * name=memberName(i);
735 if(strcmp(memberName(i),((TypeCodeStruct*)tc)->memberName(i)) != 0)return 0;
736 if(!memberType(i)->isA(((TypeCodeStruct*)tc)->memberType(i)))return 0;
737 }
738 return 1;
739}
Definition: TypeCode.hxx:228
const char * memberName(int index) const
Definition: TypeCode.cxx:819
TypeCode * memberType(int index) const
Definition: TypeCode.cxx:831
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:715
virtual const char * id() const
Definition: TypeCode.cxx:82
DynType kind() const
Definition: TypeCode.cxx:47
const DynType _kind
Definition: TypeCode.hxx:104
References YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCodeComposed::_repoId, yacsorb.CORBAEngineTest::i, YACS::ENGINE::TypeCode::id(), isA(), YACS::ENGINE::TypeCode::kind(), memberCount(), memberName(), memberType(), and name().
◆ isAdaptable()
int TypeCodeStruct::isAdaptable ( const TypeCode *  tc) const
Definition at line 746 of file TypeCode.cxx.
747{
748 if (_kind != tc->kind()) return 0;
749 if (_repoId == tc->id()) return 1;
750 int nMember = memberCount();
751 if (nMember != ((TypeCodeStruct*)tc)->memberCount()) return 0;
752 for (int i=0 ; i<nMember ; i++)
753 {
754 const char * name = memberName(i);
755 if (strcmp(memberName(i), ((TypeCodeStruct*)tc)->memberName(i)) != 0) return 0;
756 if (!memberType(i)->isAdaptable(((TypeCodeStruct*)tc)->memberType(i))) return 0;
757 }
758 return 1;
759}
virtual int isAdaptable(const TypeCode *tc) const
Definition: TypeCode.cxx:746
References YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCodeComposed::_repoId, yacsorb.CORBAEngineTest::i, YACS::ENGINE::TypeCode::id(), isAdaptable(), YACS::ENGINE::TypeCode::kind(), memberCount(), memberName(), memberType(), and name().
Referenced by isAdaptable().
◆ isEquivalent()
int TypeCodeStruct::isEquivalent ( const TypeCode *  tc) const
this TypeCode is equivalent to tc if they have the same kind
tc: the TypeCode to compare
Definition at line 767 of file TypeCode.cxx.
768{
769 if(_kind != tc->kind()) return 0;
770 int nMember=memberCount();
771 if(nMember != ((TypeCodeStruct*)tc)->memberCount())return 0;
772 for(int i=0;i<nMember;i++)
773 {
774 const char * name=memberName(i);
775 if(strcmp(memberName(i),((TypeCodeStruct*)tc)->memberName(i)) != 0)return 0;
776 if(!memberType(i)->isEquivalent(((TypeCodeStruct*)tc)->memberType(i)))return 0;
777 }
778 return 1;
779}
virtual int isEquivalent(const TypeCode *tc) const
Definition: TypeCode.cxx:767
References YACS::ENGINE::TypeCode::_kind, yacsorb.CORBAEngineTest::i, isEquivalent(), YACS::ENGINE::TypeCode::kind(), memberCount(), memberName(), memberType(), and name().
Referenced by isEquivalent().
◆ memberCount()
◆ memberName()
◆ memberType()
const char * TypeCodeStruct::name ( ) const
Definition at line 686 of file TypeCode.cxx.
687{
688 return _name.c_str();
689}
References YACS::ENGINE::TypeCodeComposed::_name.
Referenced by addMember(), getMember(), isA(), isAdaptable(), and isEquivalent().
◆ putReprAtPlace()
void TypeCodeStruct::putReprAtPlace ( char *  pt,
const char *  val,
bool  deepCpy
Definition at line 666 of file TypeCode.cxx.
667{
668 StructAny::putReprAtPlace(pt,val,this,deepCpy);
669}
static void putReprAtPlace(char *data, const char *src, const TypeCodeStruct *type, bool deepCpy)
Definition: Any.cxx:1127
References YACS::ENGINE::StructAny::putReprAtPlace().
◆ shortName()
const char * TypeCodeStruct::shortName ( ) const
Definition at line 691 of file TypeCode.cxx.
692{
693 return _shortName.c_str();
694}
References YACS::ENGINE::TypeCodeComposed::_shortName.
◆ StructAny
friend class StructAny
friend
Definition at line 229 of file TypeCode.hxx.
◆ _members
