YACS::ENGINE::TypeCodeComposed Class Reference
#include <TypeCode.hxx>
Inheritance diagram for YACS::ENGINE::TypeCodeComposed:
Collaboration diagram for YACS::ENGINE::TypeCodeComposed:
 TypeCodeComposed (const TypeCodeComposed &other)
 TypeCodeComposed (DynType kind, const char *repositoryId, const char *name)
- Protected Member Functions inherited from YACS::ENGINE::TypeCode
 TypeCode (const TypeCode &tc)
TypeCode & operator= (const TypeCode &tc)
virtual ~TypeCode ()
 RefCounter ()
virtual ~RefCounter ()
const std::string _name
const std::string _repoId
std::string _shortName
- Protected Attributes inherited from YACS::ENGINE::TypeCode
const DynType _kind
unsigned int _cnt
- Public Member Functions inherited from YACS::ENGINE::TypeCode
 TypeCode (DynType kind)
DynType kind () const
const char * getKindRepr () const
const TypeCode * subContentType (int lev) const
virtual TypeCode * clone () const
virtual void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
virtual void destroyZippedAny (char *data) const
virtual AnyPtr getOrBuildAnyFromZippedData (char *data) const
virtual const char * name () const
virtual const char * shortName () const
virtual const char * id () const
virtual const TypeCode * contentType () const
virtual int isA (const char *repositoryId) const
virtual int isA (const TypeCode *tc) const
virtual int isAdaptable (const TypeCode *tc) const
 Check if this TypeCode is adaptable to a given TypeCode (tc) More...
virtual int isEquivalent (const TypeCode *tc) const
 Check if this TypeCode can be used in place of tc. More...
virtual unsigned getSizeInByteOfAnyReprInSeq () const
virtual std::string getPrintStr () const
void incrRef () const
bool decrRef () const
- Static Public Member Functions inherited from YACS::ENGINE::TypeCode
static const char * getKindRepr (DynType kind)
static TypeCode * interfaceTc (const char *id, const char *name)
 static factory of object reference type given an id and a name More...
static TypeCode * interfaceTc (const char *id, const char *name, const std::list< TypeCodeObjref * > &ltc)
 static factory of object reference type given an id, a name and a list of base types More...
static TypeCode * sequenceTc (const char *id, const char *name, TypeCode *content)
 static factory of sequence type given an id, a name and a content type More...
static TypeCode * structTc (const char *id, const char *name)
 static factory of struct type given an id and a name More...
- Static Protected Attributes inherited from YACS::ENGINE::TypeCode
static const char * KIND_STR_REPR [] ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
Definition at line 108 of file TypeCode.hxx.
◆ TypeCodeComposed() [1/2]
TypeCodeComposed::TypeCodeComposed ( const TypeCodeComposed &  other)
Definition at line 275 of file TypeCode.cxx.
275 :TypeCode(other),
276 _name(other._name),_repoId(other._repoId),
278{
279}
Definition: TypeCode.hxx:115
TypeCode(DynType kind)
Definition: TypeCode.cxx:35
◆ TypeCodeComposed() [2/2]
TypeCodeComposed::TypeCodeComposed ( DynType  kind,
const char *  repositoryId,
const char *  name
Definition at line 281 of file TypeCode.cxx.
281 :TypeCode(kind),
282 _repoId(repositoryId),_name(name)
283{
284 string::size_type debut =_name.find_last_of('/');
285 if(debut == std::string::npos)
287 else
288 _shortName=_name.substr(debut+1);
289}
Definition: TypeCode.cxx:72
DynType kind() const
Definition: TypeCode.cxx:47
References _name, _shortName, and YACS::ENGINE::TypeCode::name().
◆ _name
const std::string YACS::ENGINE::TypeCodeComposed::_name
◆ _repoId
◆ _shortName
