TypeCode.cxx
20#include "TypeCode.hxx"
21#include <sstream>
22#include <iostream>
23#include <cstring>
24
25//#define _DEVDEBUG_
26#include "YacsTrace.hxx"
27
28using namespace YACS::ENGINE;
29using namespace std;
30
31const char *TypeCode::KIND_STR_REPR []={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" };
32
33// --- TypeCode
34
35TypeCode::TypeCode(DynType kind):_kind(kind)
36{
37}
38
39TypeCode::TypeCode(const TypeCode& tc):_kind(tc._kind)
40{
41}
42
44{
45}
46
48{
49 return _kind;
50}
51
53{
54 return new TypeCode(*this);
55}
56
57void TypeCode::putReprAtPlace(char *pt, const char *val, bool deepCpy) const
58{
59 AtomAny::putReprAtPlace(pt,val,this,deepCpy);
60}
61
62void TypeCode::destroyZippedAny(char *data) const
63{
65}
66
68{
69 return AtomAny::getOrBuildFromData(data,this);
70}
71
72const char * TypeCode::name() const
73{
74 return id();
75}
76
77const char * TypeCode::shortName() const
78{
79 return id();
80}
81
82const char * TypeCode::id() const
83{
84 switch(_kind)
85 {
86 case Double:
87 return "double";
88 case Int:
89 return "int";
90 case String:
91 return "string";
92 case Bool:
93 return "bool";
94 default:
95 return "";
96 }
97}
98
99int TypeCode::isA(const char* id) const
100{
101 throw Exception("Not implemented for this type");
102}
103
104int TypeCode::isA(const TypeCode* tc) const
105{
106 if(_kind == tc->kind()) return 1;
107 return 0;
108}
109
111
116int TypeCode::isAdaptable(const TypeCode* tc) const
117{
118 switch(_kind)
119 {
120 case Double:
121 if (tc->kind() == Double) return 1;
122 if (tc->kind() == Int) return 1;
123 return 0;
124 case Int:
125 if (tc->kind() == Int) return 1;
126 return 0;
127 case String:
128 if (tc->kind() == String) return 1;
129 return 0;
130 case Bool:
131 if (tc->kind() == Bool) return 1;
132 if (tc->kind() == Int) return 1;
133 return 0;
134 default:
135 //objref, sequence, ...
136 return 0;
137 }
138}
139
140std::string TypeCode::getPrintStr() const
141{
142 return id();
143}
144
146
151int TypeCode::isEquivalent(const TypeCode* tc) const
152{
153 if(_kind == tc->kind()) return 1;
154 return 0;
155}
156
158{
159 switch(_kind)
160 {
161 case Double:
162 return sizeof(double);
163 case Int:
164 return sizeof(int);
165 case String:
166 return sizeof(StringOnHeap *);
167 case Bool:
168 return sizeof(bool);
169 default:
170 return sizeof(void *);
171 }
172}
173
175{
176 throw Exception("No content type");
177};
178
179static inline int validChar0(char c)
180{
181 return ((c >= 'a' && c <= 'z') || (c >= 'A' && c <= 'Z'));
182}
183
184static inline int validNextChar(char c)
185{
186 return ((c >= 'a' && c <= 'z') || (c >= 'A' && c <= 'Z') ||
187 (c >= '0' && c <= '9') || (c == '_') || (c == '/'));
188}
189
190static void checkValidName(const char* name)
191{
192 int ok = 1;
193 if (*name)
194 {
195 if (!validChar0(*name++)) ok = 0;
196 for(; ok && *name; name++) if (!validNextChar(*name)) ok = 0;
197 }
198 if (!ok)throw YACS::Exception("Invalid Name");
199}
200
202{
203 return KIND_STR_REPR[(int)kind];
204}
205
207{
208 if(lev<0)
209 throw YACS::Exception("subContentType: Invalid input val !");
210 if(lev==0)
211 return this;
212 const TypeCode *ret(this);
213 for(int i=0;i<lev;i++)
214 {
215 const TypeCode *cand(ret->contentType());
216 if(!cand)
217 throw YACS::Exception("subContentType : Invalid input val 2 !");
218 ret=cand;
219 }
220 return ret;
221}
222
223const char * TypeCode::getKindRepr() const
224{
225 return KIND_STR_REPR[(int)_kind];
226}
227
230 const char* name)
231{
233 return new TypeCodeObjref(id, name);
234};
235
237
245 const char* name,
246 const std::list<TypeCodeObjref *>& ltc)
247{
249 return new TypeCodeObjref(id, name,ltc);
250}
251
252
255 const char* name,
256 TypeCode *content)
257{
258 std::string typname;
259 if(std::string(name)=="")
260 {
261 typname="seq"+std::string(content->name());
262 name=typname.c_str();
263 }
264 if(std::string(id)=="")
265 id=name;
266 return new TypeCodeSeq(id, name,content);
267};
270 const char* name)
271{
272 return new TypeCodeStruct(id, name);
273};
274
276 _name(other._name),_repoId(other._repoId),
277 _shortName(other._shortName)
278{
279}
280
281TypeCodeComposed::TypeCodeComposed(DynType kind, const char* repositoryId, const char* name):TypeCode(kind),
282 _repoId(repositoryId),_name(name)
283{
284 string::size_type debut =_name.find_last_of('/');
285 if(debut == std::string::npos)
287 else
288 _shortName=_name.substr(debut+1);
289}
290
291// --- TypeCodeObjref
292
293
294TypeCodeObjref::TypeCodeObjref(const char* repositoryId,
295 const char* name) : TypeCodeComposed(Objref,repositoryId,name)
296{
297}
298
299
301{
302 list<TypeCodeObjref *>::iterator iter;
303 for(iter=_listOfBases.begin();iter != _listOfBases.end(); iter++)
304 (*iter)->decrRef();
305}
306
308{
309 return new TypeCodeObjref(*this);
310}
311
312void TypeCodeObjref::putReprAtPlace(char *pt, const char *val, bool deepCpy) const
313{
314 AtomAny::putReprAtPlace(pt,val,this,deepCpy);
315}
316
318{
320}
321
323{
324 return AtomAny::getOrBuildFromData(data,this);
325}
326
327const char * TypeCodeObjref::id() const
328{
329 return _repoId.c_str();
330};
331
332const char * TypeCodeObjref::name() const
333{
334 return _name.c_str();
335}
336
337const char * TypeCodeObjref::shortName() const
338{
339 return _shortName.c_str();
340}
341
342TypeCodeObjref::TypeCodeObjref(const char* repositoryId,
343 const char* name,
344 const std::list<TypeCodeObjref *>& ltc) : TypeCodeComposed(Objref,repositoryId,name)
345{
346 _listOfBases=ltc;
347 list<TypeCodeObjref *>::const_iterator iter;
348 for(iter=_listOfBases.begin();iter != _listOfBases.end(); iter++)
349 (*iter)->incrRef();
350}
351
353
357int TypeCodeObjref::isA(const char* id) const
358{
359 if(_repoId == id)return 1;
360 list<TypeCodeObjref *>::const_iterator iter;
361 for(iter=_listOfBases.begin();iter != _listOfBases.end(); iter++)
362 {
363 if ((*iter)->isA(id)) return 1;
364 }
365 return 0;
366}
367
369
373int TypeCodeObjref::isA(const TypeCode* tc) const
374{
375 return isA(tc->id());
376}
377
379
384{
385 if(_kind == tc->kind()) return isA(tc->id());
386 return 0;
387}
388
390
396{
397 if(_kind != tc->kind())return 0;
398 if(_repoId == tc->id())return 1;
399 return 0;
400}
401
403 _listOfBases(other._listOfBases)
404{
405 list<TypeCodeObjref *>::const_iterator iter;
406 for(iter=other._listOfBases.begin();iter!=other._listOfBases.end();iter++)
407 (*iter)->incrRef();
408}
409
410// --- TypeCodeSeq
411
412
414
419TypeCodeSeq::TypeCodeSeq(const char* repositoryId,
420 const char* name,
421 const TypeCode *content) : TypeCodeComposed(Sequence,repositoryId,name), _content(content)
422{
423 _content->incrRef();
424}
425
427{
428 ((TypeCode *)_content)->decrRef();
429}
430
432{
433 return new TypeCodeSeq(*this);
434}
435
436void TypeCodeSeq::putReprAtPlace(char *pt, const char *val, bool deepCpy) const
437{
438 SequenceAny::putReprAtPlace(pt,val,this,deepCpy);
439}
440
441void TypeCodeSeq::destroyZippedAny(char *data) const
442{
444}
445
447{
448 return sizeof(void*);
449}
450
452{
453 return SequenceAny::getOrBuildFromData(data,this);
454}
455
456const char * TypeCodeSeq::id() const
457{
458 return _repoId.c_str();
459}
460
461const char * TypeCodeSeq::name() const
462{
463 return _name.c_str();
464}
465const char * TypeCodeSeq::shortName() const
466{
467 return _shortName.c_str();
468}
469
470std::string TypeCodeSeq::getPrintStr() const
471{
472 std::ostringstream oss; oss << "seq[" << contentType()->getPrintStr() << "]";
473 return oss.str();
474}
475
477{
478 return _content;
479}
480
481int TypeCodeSeq::isA(const TypeCode* tc) const
482{
483 if(_kind == tc->kind())
484 return _content->isA(tc->contentType());
485 return 0;
486}
487
489
494{
495 if(_kind == tc->kind())
496 return contentType()->isAdaptable(tc->contentType());
497 return 0;
498}
499
501
507{
508 if(_kind == tc->kind())
509 return _content->isEquivalent(tc->contentType());
510 return 0;
511}
512
514 _content(tc._content)
515{
516 _content->incrRef();
517}
518
519// --- TypeCodeArray
520
521
523
529TypeCodeArray::TypeCodeArray(const char* repositoryId,
530 const char* name,
531 const TypeCode *content,
532 unsigned staticLgth) : TypeCodeComposed(Array,repositoryId,name), _content(content),_staticLgth(staticLgth)
533{
534 _content->incrRef();
535}
536
538{
539 ((TypeCode *)_content)->decrRef();
540}
541
543{
544 return new TypeCodeArray(*this);
545}
546
547void TypeCodeArray::putReprAtPlace(char *pt, const char *val, bool deepCpy) const
548{
549 ArrayAny::putReprAtPlace(pt,val,this,deepCpy);
550}
551
553{
555}
556
558{
559 return ArrayAny::getOrBuildFromData(data,this);
560}
561
562const char * TypeCodeArray::id() const
563{
564 return _repoId.c_str();
565}
566
567const char * TypeCodeArray::name() const
568{
569 return _name.c_str();
570}
571const char * TypeCodeArray::shortName() const
572{
573 return _shortName.c_str();
574}
575
577{
578 return _staticLgth;
579}
580
582{
583 return _content;
584}
585
586int TypeCodeArray::isA(const TypeCode* tc) const
587{
588 if(_kind == tc->kind())
589 if(_content->isA(tc->contentType()))
590 {
591 const TypeCodeArray *tcC=dynamic_cast<const TypeCodeArray *>(tc);
592 if(tcC)
593 return tcC->getStaticLgth()==_staticLgth;
594 return 0;
595 }
596 return 0;
597}
598
600
605{
606 if(_kind == tc->kind())
607 return contentType()->isAdaptable(tc->contentType());
608 return 0;
609}
610
612
618{
619 if(_kind == tc->kind())
620 return _content->isEquivalent(tc->contentType());
621 return 0;
622}
623
625 _content(tc._content),
626 _staticLgth(tc._staticLgth)
627{
628 _content->incrRef();
629}
630
632{
634}
635
636// --- TypeCodeStruct
637
638
640
644TypeCodeStruct::TypeCodeStruct(const char* repositoryId,
645 const char* name) : TypeCodeComposed(Struct,repositoryId,name)
646{
647}
648
650{
651 for(vector< pair<string,TypeCode*> >::iterator iter=_members.begin();iter!=_members.end();iter++)
652 (*iter).second->decrRef();
653}
654
656{
657 return new TypeCodeStruct(*this);
658}
659
661{
662 for(vector< std::pair<std::string,TypeCode*> >::iterator iter=_members.begin();iter!=_members.end();iter++)
663 (*iter).second->incrRef();
664}
665
666void TypeCodeStruct::putReprAtPlace(char *pt, const char *val, bool deepCpy) const
667{
668 StructAny::putReprAtPlace(pt,val,this,deepCpy);
669}
670
672{
674}
675
677{
678 return StructAny::getOrBuildFromData(data,this);
679}
680
681const char * TypeCodeStruct::id() const
682{
683 return _repoId.c_str();
684};
685
686const char * TypeCodeStruct::name() const
687{
688 return _name.c_str();
689}
690
691const char * TypeCodeStruct::shortName() const
692{
693 return _shortName.c_str();
694}
695
697{
698 unsigned ret=0;
699 for(vector< pair<string,TypeCode*> >::const_iterator iter=_members.begin();iter!=_members.end();iter++)
700 ret+=(*iter).second->getSizeInByteOfAnyReprInSeq();
701 return ret;
702}
703
705{
706 const char what[]="Content type is specified by giving a key.";
707 throw Exception(what);
708}
709
711
715int TypeCodeStruct::isA(const char* id) const
716{
717 if(_repoId == id)return 1;
718 return 0;
719}
720
722
726int TypeCodeStruct::isA(const TypeCode* tc) const
727{
728 if(_kind != tc->kind()) return 0;
729 if(_repoId == tc->id())return 1;
730 int nMember=memberCount();
731 if(nMember != ((TypeCodeStruct*)tc)->memberCount())return 0;
732 for(int i=0;i<nMember;i++)
733 {
734 const char * name=memberName(i);
735 if(strcmp(memberName(i),((TypeCodeStruct*)tc)->memberName(i)) != 0)return 0;
736 if(!memberType(i)->isA(((TypeCodeStruct*)tc)->memberType(i)))return 0;
737 }
738 return 1;
739}
740
742
747{
748 if (_kind != tc->kind()) return 0;
749 if (_repoId == tc->id()) return 1;
750 int nMember = memberCount();
751 if (nMember != ((TypeCodeStruct*)tc)->memberCount()) return 0;
752 for (int i=0 ; i<nMember ; i++)
753 {
754 const char * name = memberName(i);
755 if (strcmp(memberName(i), ((TypeCodeStruct*)tc)->memberName(i)) != 0) return 0;
756 if (!memberType(i)->isAdaptable(((TypeCodeStruct*)tc)->memberType(i))) return 0;
757 }
758 return 1;
759}
760
762
768{
769 if(_kind != tc->kind()) return 0;
770 int nMember=memberCount();
771 if(nMember != ((TypeCodeStruct*)tc)->memberCount())return 0;
772 for(int i=0;i<nMember;i++)
773 {
774 const char * name=memberName(i);
775 if(strcmp(memberName(i),((TypeCodeStruct*)tc)->memberName(i)) != 0)return 0;
776 if(!memberType(i)->isEquivalent(((TypeCodeStruct*)tc)->memberType(i)))return 0;
777 }
778 return 1;
779}
780
781void TypeCodeStruct::addMember(const std::string& name,TypeCode* tc)
782{
783 DEBTRACE(name << " " << tc->name());
784 std::vector< std::pair<std::string,TypeCode*> >::const_iterator iter;
785 for(iter=_members.begin();iter != _members.end(); iter++)
786 {
787 if((*iter).first == name)
788 throw Exception("Struct member " + name + " already defined");
789 }
790 _members.push_back(std::pair<std::string,TypeCode*>(name,tc));
791 tc->incrRef();
792}
793
795
801const TypeCode *TypeCodeStruct::getMember(const std::string& name, unsigned& offset) const
802{
803 std::vector< std::pair<std::string,TypeCode*> >::const_iterator iter;
804 offset=0;
805 for(iter=_members.begin();iter != _members.end(); iter++)
806 {
807 if((*iter).first==name)
808 return (*iter).second;
809 offset+=(*iter).second->getSizeInByteOfAnyReprInSeq();
810 }
811 return 0;
812}
813
815{
816 return _members.size();
817}
818
819const char* TypeCodeStruct::memberName(int index) const
820{
821 if(index > _members.size())
822 {
823 stringstream msg;
824 msg << "Struct size less than " << index;
825 msg << " : " << __FILE__ << ":" << __LINE__;
826 throw Exception(msg.str());
827 }
828 return _members[index].first.c_str();
829}
830
832{
833 if(index > _members.size())
834 {
835 stringstream msg;
836 msg << "Struct size less than " << index;
837 msg << " : " << __FILE__ << ":" << __LINE__;
838 throw Exception(msg.str());
839 }
840 return _members[index].second;
841}
842
843
static void checkValidName(const char *name)
Definition: TypeCode.cxx:190
static int validChar0(char c)
Definition: TypeCode.cxx:179
static int validNextChar(char c)
Definition: TypeCode.cxx:184
: Allow to manage memory of instances of T. The only constraint on T is to have method incrRef and De...
Definition: SharedPtr.hxx:30
static AnyPtr getOrBuildFromData(char *data, const TypeCodeArray *type)
Definition: Any.cxx:1042
static void destroyReprAtPlace(char *data, const TypeCodeArray *type)
Definition: Any.cxx:1034
static void putReprAtPlace(char *data, const char *src, const TypeCodeArray *type, bool deepCpy)
Definition: Any.cxx:1026
static void putReprAtPlace(char *data, const char *src, const TypeCode *type, bool deepCpy)
Definition: Any.cxx:448
static AnyPtr getOrBuildFromData(char *data, const TypeCode *type)
Definition: Any.cxx:481
static void destroyReprAtPlace(char *data, const TypeCode *type)
Definition: Any.cxx:468
Definition: Any.cxx:721
Definition: Any.cxx:737
Definition: Any.cxx:745
static AnyPtr getOrBuildFromData(char *data, const TypeCodeStruct *type)
Definition: Any.cxx:1149
static void putReprAtPlace(char *data, const char *src, const TypeCodeStruct *type, bool deepCpy)
Definition: Any.cxx:1127
static void destroyReprAtPlace(char *data, const TypeCodeStruct *type)
Definition: Any.cxx:1138
Class for array objects.
Definition: TypeCode.hxx:193
const char * name() const
Definition: TypeCode.cxx:567
TypeCodeArray(const char *repositoryId, const char *name, const TypeCode *content, unsigned staticLgth)
Create an Array type with a given name, a given id and a given contained type.
Definition: TypeCode.cxx:529
TypeCode * clone() const
Definition: TypeCode.cxx:542
AnyPtr getOrBuildAnyFromZippedData(char *data) const
Definition: TypeCode.cxx:557
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:581
const TypeCode * _content
Definition: TypeCode.hxx:216
void putReprAtPlace(char *pt, const char *val, bool deepCpy) const
Definition: TypeCode.cxx:547
virtual int isEquivalent(const TypeCode *tc) const
Check if this TypeCode can be used in place of tc.
Definition: TypeCode.cxx:617
void destroyZippedAny(char *data) const
Definition: TypeCode.cxx:552
const char * id() const
Definition: TypeCode.cxx:562
unsigned getSizeInByteOfAnyReprInSeq() const
Definition: TypeCode.cxx:631
unsigned getStaticLgth() const
Definition: TypeCode.cxx:576
virtual int isAdaptable(const TypeCode *tc) const
Check if this TypeCode is adaptable to a given TypeCode (tc)
Definition: TypeCode.cxx:604
const char * shortName() const
Definition: TypeCode.cxx:571
const unsigned _staticLgth
Definition: TypeCode.hxx:217
virtual int isA(const TypeCode *tc) const
Definition: TypeCode.cxx:586
TypeCodeComposed(const TypeCodeComposed &other)
Definition: TypeCode.cxx:275
const std::string _repoId
Definition: TypeCode.hxx:115
Class for reference objects.
Definition: TypeCode.hxx:126
Definition: TypeCode.cxx:312
Definition: TypeCode.cxx:327
int isA(const char *repositoryId) const
Check if this TypeCode is derived from a TypeCode with a given id.
Definition: TypeCode.cxx:357
Definition: TypeCode.cxx:337
std::list< TypeCodeObjref * > _listOfBases
Definition: TypeCode.hxx:150
Definition: TypeCode.cxx:332
Definition: TypeCode.cxx:383
TypeCodeObjref(const char *repositoryId, const char *name)
Definition: TypeCode.cxx:294
Definition: TypeCode.cxx:322
Definition: TypeCode.cxx:395
Definition: TypeCode.cxx:307
Definition: TypeCode.cxx:317
Class for sequence objects.
Definition: TypeCode.hxx:160
virtual std::string getPrintStr() const
Definition: TypeCode.cxx:470
Definition: TypeCode.cxx:441
Definition: TypeCode.cxx:461
Definition: TypeCode.cxx:431
Definition: TypeCode.cxx:506
Definition: TypeCode.cxx:476
TypeCodeSeq(const char *repositoryId, const char *name, const TypeCode *content)
Create a sequence type with a given name, a given id and a given contained type.
Definition: TypeCode.cxx:419
virtual unsigned getSizeInByteOfAnyReprInSeq() const
Definition: TypeCode.cxx:446
Definition: TypeCode.cxx:456
Definition: TypeCode.cxx:436
Definition: TypeCode.cxx:465
Definition: TypeCode.cxx:493
Definition: TypeCode.hxx:184
Definition: TypeCode.cxx:481
Definition: TypeCode.cxx:451
Class for struct type.
Definition: TypeCode.hxx:228
const char * memberName(int index) const
Definition: TypeCode.cxx:819
Definition: TypeCode.cxx:704
TypeCodeStruct(const char *repositoryId, const char *name)
Create a struct type with a given name and a given id.
Definition: TypeCode.cxx:644
Definition: TypeCode.cxx:681
virtual void addMember(const std::string &name, TypeCode *tc)
The only non const method.
Definition: TypeCode.cxx:781
Definition: TypeCode.cxx:671
Definition: TypeCode.cxx:767
Definition: TypeCode.cxx:686
const TypeCode * getMember(const std::string &name, unsigned &offset) const
Get typecode of struct member given its name.
Definition: TypeCode.cxx:801
Definition: TypeCode.cxx:666
TypeCode * memberType(int index) const
Definition: TypeCode.cxx:831
Definition: TypeCode.cxx:696
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:715
std::vector< std::pair< std::string, TypeCode * > > _members
Definition: TypeCode.hxx:257
Definition: TypeCode.cxx:655
Definition: TypeCode.cxx:676
Definition: TypeCode.cxx:746
Definition: TypeCode.cxx:691
Definition: TypeCode.hxx:68
Definition: TypeCode.cxx:72
static TypeCode * interfaceTc(const char *id, const char *name)
static factory of object reference type given an id and a name
Definition: TypeCode.cxx:229
virtual void destroyZippedAny(char *data) const
Definition: TypeCode.cxx:62
virtual const char * id() const
Definition: TypeCode.cxx:82
Definition: TypeCode.cxx:174
Definition: TypeCode.cxx:99
DynType kind() const
Definition: TypeCode.cxx:157
const DynType _kind
Definition: TypeCode.hxx:104
static TypeCode * sequenceTc(const char *id, const char *name, TypeCode *content)
static factory of sequence type given an id, a name and a content type
Definition: TypeCode.cxx:254
Definition: TypeCode.cxx:151
static const char * KIND_STR_REPR[]
Definition: TypeCode.hxx:105
Definition: TypeCode.cxx:116
virtual TypeCode * clone() const
static TypeCode * structTc(const char *id, const char *name)
static factory of struct type given an id and a name
Definition: TypeCode.cxx:269
Definition: TypeCode.cxx:140
const TypeCode * subContentType(int lev) const
Definition: TypeCode.cxx:206
virtual void putReprAtPlace(char *pt, const char *val, bool deepCpy) const
const char * getKindRepr() const
Definition: TypeCode.cxx:223
virtual const char * shortName() const
Definition: TypeCode.cxx:77
virtual AnyPtr getOrBuildAnyFromZippedData(char *data) const
