YACS::ENGINE::TypeCodeSeq Class Reference
Class for sequence objects. More...
#include <TypeCode.hxx>
Inheritance diagram for YACS::ENGINE::TypeCodeSeq:
Collaboration diagram for YACS::ENGINE::TypeCodeSeq:
 TypeCodeSeq (const char *repositoryId, const char *name, const TypeCode *content)
 Create a sequence type with a given name, a given id and a given contained type. More...
TypeCode * clone () const
void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
void destroyZippedAny (char *data) const
virtual unsigned getSizeInByteOfAnyReprInSeq () const
AnyPtr getOrBuildAnyFromZippedData (char *data) const
const char * id () const
const char * name () const
const char * shortName () const
virtual std::string getPrintStr () const
virtual const TypeCode * contentType () const
virtual int isA (const TypeCode *tc) const
virtual int isAdaptable (const TypeCode *tc) const
 Check if this TypeCode is adaptable to a given TypeCode (tc) More...
virtual int isEquivalent (const TypeCode *tc) const
 Check if this TypeCode can be used in place of tc. More...
- Public Member Functions inherited from YACS::ENGINE::TypeCode
 TypeCode (DynType kind)
DynType kind () const
const char * getKindRepr () const
const TypeCode * subContentType (int lev) const
virtual TypeCode * clone () const
virtual void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
virtual void destroyZippedAny (char *data) const
virtual AnyPtr getOrBuildAnyFromZippedData (char *data) const
virtual const char * name () const
virtual const char * shortName () const
virtual const char * id () const
virtual int isA (const char *repositoryId) const
void incrRef () const
bool decrRef () const
virtual ~TypeCodeSeq ()
 TypeCodeSeq (const TypeCodeSeq &tc)
- Protected Member Functions inherited from YACS::ENGINE::TypeCodeComposed
 TypeCodeComposed (const TypeCodeComposed &other)
 TypeCodeComposed (DynType kind, const char *repositoryId, const char *name)
 TypeCode (const TypeCode &tc)
TypeCode & operator= (const TypeCode &tc)
virtual ~TypeCode ()
 RefCounter ()
virtual ~RefCounter ()
const TypeCode * _content
- Static Public Member Functions inherited from YACS::ENGINE::TypeCode
static const char * getKindRepr (DynType kind)
static TypeCode * interfaceTc (const char *id, const char *name)
 static factory of object reference type given an id and a name More...
static TypeCode * interfaceTc (const char *id, const char *name, const std::list< TypeCodeObjref * > &ltc)
 static factory of object reference type given an id, a name and a list of base types More...
static TypeCode * sequenceTc (const char *id, const char *name, TypeCode *content)
 static factory of sequence type given an id, a name and a content type More...
static TypeCode * structTc (const char *id, const char *name)
 static factory of struct type given an id and a name More...
- Protected Attributes inherited from YACS::ENGINE::TypeCodeComposed
const std::string _name
const std::string _repoId
std::string _shortName
const DynType _kind
unsigned int _cnt
- Static Protected Attributes inherited from YACS::ENGINE::TypeCode
static const char * KIND_STR_REPR [] ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
Definition at line 159 of file TypeCode.hxx.
◆ TypeCodeSeq() [1/2]
TypeCodeSeq::TypeCodeSeq ( const char *  repositoryId,
const char *  name,
repositoryId: the given id
name: the given name
content: the given contained TypeCode
Definition at line 419 of file TypeCode.cxx.
421 : TypeCodeComposed(Sequence,repositoryId,name), _content(content)
422{
423 _content->incrRef();
424}
TypeCodeComposed(const TypeCodeComposed &other)
Definition: TypeCode.cxx:275
const char * name() const
Definition: TypeCode.cxx:461
Definition: TypeCode.hxx:184
References _content, and YACS::ENGINE::RefCounter::incrRef().
Referenced by clone().
◆ ~TypeCodeSeq()
TypeCodeSeq::~TypeCodeSeq ( )
Definition at line 426 of file TypeCode.cxx.
427{
428 ((TypeCode *)_content)->decrRef();
429}
Definition: TypeCode.hxx:68
References _content.
◆ TypeCodeSeq() [2/2]
TypeCodeSeq::TypeCodeSeq ( const TypeCodeSeq &  tc)
Definition at line 513 of file TypeCode.cxx.
513 :TypeCodeComposed(tc),
515{
516 _content->incrRef();
517}
◆ clone()
TypeCode * TypeCodeSeq::clone ( ) const
Reimplemented from YACS::ENGINE::TypeCode.
Definition at line 431 of file TypeCode.cxx.
432{
433 return new TypeCodeSeq(*this);
434}
TypeCodeSeq(const char *repositoryId, const char *name, const TypeCode *content)
Definition: TypeCode.cxx:419
References TypeCodeSeq().
◆ contentType()
const TypeCode * TypeCodeSeq::contentType ( ) const
Definition at line 476 of file TypeCode.cxx.
477{
478 return _content;
479}
Referenced by YACS::ENGINE::isAdaptableObjref< IMPLIN, IMPLOUT >::apply(), getPrintStr(), and isAdaptable().
◆ destroyZippedAny()
void TypeCodeSeq::destroyZippedAny ( char *  data) const
Definition at line 441 of file TypeCode.cxx.
442{
444}
static void destroyReprAtPlace(char *data, const TypeCode *type)
Definition: Any.cxx:737
References YACS::ENGINE::SequenceAny::destroyReprAtPlace().
◆ getOrBuildAnyFromZippedData()
AnyPtr TypeCodeSeq::getOrBuildAnyFromZippedData ( char *  data) const
Definition at line 451 of file TypeCode.cxx.
452{
453 return SequenceAny::getOrBuildFromData(data,this);
454}
static AnyPtr getOrBuildFromData(char *data, const TypeCode *type)
Definition: Any.cxx:745
References YACS::ENGINE::SequenceAny::getOrBuildFromData().
◆ getPrintStr()
std::string TypeCodeSeq::getPrintStr ( ) const
Definition at line 470 of file TypeCode.cxx.
471{
472 std::ostringstream oss; oss << "seq[" << contentType()->getPrintStr() << "]";
473 return oss.str();
474}
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:476
virtual std::string getPrintStr() const
Definition: TypeCode.cxx:140
References contentType(), and YACS::ENGINE::TypeCode::getPrintStr().
◆ getSizeInByteOfAnyReprInSeq()
unsigned TypeCodeSeq::getSizeInByteOfAnyReprInSeq ( ) const
Definition at line 446 of file TypeCode.cxx.
447{
448 return sizeof(void*);
449}
◆ id()
const char * TypeCodeSeq::id ( ) const
Definition at line 456 of file TypeCode.cxx.
457{
458 return _repoId.c_str();
459}
Definition: TypeCode.hxx:115
References YACS::ENGINE::TypeCodeComposed::_repoId.
◆ isA()
int TypeCodeSeq::isA ( const TypeCode *  tc) const
Definition at line 481 of file TypeCode.cxx.
482{
483 if(_kind == tc->kind())
484 return _content->isA(tc->contentType());
485 return 0;
486}
Definition: TypeCode.cxx:174
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:99
DynType kind() const
const DynType _kind
Definition: TypeCode.hxx:104
References _content, YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::isA(), and YACS::ENGINE::TypeCode::kind().
◆ isAdaptable()
int TypeCodeSeq::isAdaptable ( const TypeCode *  tc) const
tc: the given TypeCode
1 if true, 0 if false
Definition at line 493 of file TypeCode.cxx.
494{
495 if(_kind == tc->kind())
496 return contentType()->isAdaptable(tc->contentType());
497 return 0;
498}
virtual int isAdaptable(const TypeCode *tc) const
Definition: TypeCode.cxx:116
References YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCode::contentType(), contentType(), YACS::ENGINE::TypeCode::isAdaptable(), and YACS::ENGINE::TypeCode::kind().
◆ isEquivalent()
int TypeCodeSeq::isEquivalent ( const TypeCode *  tc) const
this TypeCode is equivalent to tc if they have the same kind
tc: the TypeCode to compare
Definition at line 506 of file TypeCode.cxx.
507{
508 if(_kind == tc->kind())
509 return _content->isEquivalent(tc->contentType());
510 return 0;
511}
virtual int isEquivalent(const TypeCode *tc) const
Definition: TypeCode.cxx:151
References _content, YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::isEquivalent(), and YACS::ENGINE::TypeCode::kind().
const char * TypeCodeSeq::name ( ) const
Definition at line 461 of file TypeCode.cxx.
462{
463 return _name.c_str();
464}
References YACS::ENGINE::TypeCodeComposed::_name.
◆ putReprAtPlace()
void TypeCodeSeq::putReprAtPlace ( char *  pt,
const char *  val,
bool  deepCpy
Definition at line 436 of file TypeCode.cxx.
437{
438 SequenceAny::putReprAtPlace(pt,val,this,deepCpy);
439}
static void putReprAtPlace(char *data, const char *src, const TypeCode *type, bool deepCpy)
Definition: Any.cxx:721
References YACS::ENGINE::SequenceAny::putReprAtPlace().
◆ shortName()
const char * TypeCodeSeq::shortName ( ) const
Definition at line 465 of file TypeCode.cxx.
466{
467 return _shortName.c_str();
468}
References YACS::ENGINE::TypeCodeComposed::_shortName.
◆ _content
const TypeCode* YACS::ENGINE::TypeCodeSeq::_content
Definition at line 184 of file TypeCode.hxx.
Referenced by contentType(), isA(), isEquivalent(), TypeCodeSeq(), and ~TypeCodeSeq().
