Classes | |
| class | A |
| class | B |
| class | BoundMethodWeakref |
| class | CONNECTOR |
| class | ConnectorError |
Functions | |
| def | ref (target, callback=None) |
| def | f (a) |
Variables | |
| _the_connector = CONNECTOR() | |
| Connect = _the_connector.Connect | |
| Emit = _the_connector.Emit | |
| Disconnect = _the_connector.Disconnect | |
| a = A() | |
| b = B() | |
| c = B() | |
| def gui.CONNECTOR.f | ( | a | ) |
Definition at line 151 of file CONNECTOR.py.
Referenced by YACS::HMI::MenusBase.addHeader(), YACS::ENGINE::convertToYacsObjref< CORBAImpl, CORBA::Any *, void *, IMPLOUT, TOUT >.convert(), driverTest(), YACS::ENGINE::XmlNode.execute(), YACS::inlinetypeParser< T >.function(), YACS::remotetypeParser< T >.function(), YACS::containertypeParser.initializescriptkey(), Local.Local(), main(), YACS::HMI::GenericGui.onImportSupervSchema(), operator<<(), LogViewer.readFile(), YACS::inlinetypeParser< T >.script(), YACS::remotetypeParser< T >.script(), YACS::servertypeParser< T >.script(), and YACS::ENGINE::Node.writeDotInFile().
| def gui.CONNECTOR.ref | ( | target, | |
callback = None |
Definition at line 120 of file CONNECTOR.py.
Referenced by YACS::HMI::SubjectProc.addContainer(), YACS::HMI::SubjectProc.addHPContainer(), YACS::HMI::Subject.addSubjectReference(), YACS::HMI::SubjectServiceNode.addSubjectReference(), YACS::outnodetypeParser< T >.buildAttr(), gui.CONNECTOR.CONNECTOR.Connect(), YACS::ENGINE::DistributedPythonNode.dealException(), YACS::ENGINE::AbstractPoint.IsCommonDirectSonOf(), YACS::HMI::CommandAddContainerBase.localExecute(), YACS::HMI::CommandSetContainerProperties.localExecute(), YACS::HMI::CommandSetComponentInstanceProperties.localExecute(), YACS::HMI::CommandSetContainerProperties.localReverse(), YACS::HMI::CommandSetComponentInstanceProperties.localReverse(), YACS::HMI::GenericGui.onSelectComponentInstance(), YACS::HMI::GenericGui.onSelectReference(), YACS::outnodetypeParser< T >.ref(), YACS::HMI::GuiExecutor.setEngineRef(), YACS::ENGINE::DataNode.setRef(), YACS::ENGINE::ServiceNode.setRef(), YACS::ENGINE::XmlNode.setRef(), YACS::HMI::SubjectReference.SubjectReference(), YACS::HMI::SchemaComponentItem.update(), YACS::HMI::SchemaContainerItem.update(), YACS::ENGINE::VisitorSaveSalomeSchema.visitOutNode(), YACS::ENGINE::VisitorSaveSalomeSchema.visitPresetNode(), YACS::ENGINE::VisitorSaveSalomeSchema.visitStudyInNode(), and YACS::ENGINE::VisitorSaveSalomeSchema.visitStudyOutNode().
private |
Definition at line 138 of file CONNECTOR.py.
| gui.CONNECTOR.a = A() |
Definition at line 154 of file CONNECTOR.py.
Referenced by YACS::ENGINE::convertFromYacsStruct< CORBAImpl, CORBA::Any * >.convert(), YACS::ENGINE::convertFromYacsSequence< CORBAImpl, CORBA::Any * >.convert(), YACS::ENGINE.convertCppNeutral(), YACS::ENGINE.convertCppPyObject(), YACS::HMI::ItemEdition.filterName(), YACS::ENGINE::Bloc.fitToPlayGround(), YACS::HMI::SceneLinkItem.force2points(), genrand_res53(), YACS::ENGINE::OutputCorbaPort.getAnyOut(), YACS::ENGINE::Switch.getCaseId(), YACS::HMI::LinkMatrix.getPath(), YACS::HMI::Cost.operator<(), YACS::HMI::SceneHeaderNodeItem.paint(), YACS::ENGINE::CppCorba.put(), YACS::ENGINE::CppCpp.put(), YACS::ENGINE::XmlCorba.put(), YACS::ENGINE::CorbaCorba.put(), YACS::ENGINE::PyCorbaInt.put(), YACS::ENGINE::PyCorbaDouble.put(), YACS::ENGINE::PyCorbaString.put(), YACS::ENGINE::PyCorbaBool.put(), YACS::ENGINE::PyCorbaObjref.put(), YACS::ENGINE::PyCorbaSequence.put(), YACS::ENGINE::PyCorbaStruct.put(), YACS::ENGINE::PyCpp.put(), YACS::ENGINE::NeutralCorbaInt.put(), YACS::ENGINE::NeutralCorbaDouble.put(), YACS::ENGINE::NeutralCorbaBool.put(), YACS::ENGINE::NeutralCorbaSequence.put(), YACS::ENGINE::NeutralCorbaString.put(), YACS::ENGINE::NeutralCorbaObjref.put(), YACS::ENGINE::NeutralCorbaStruct.put(), and YACS::ENGINE::NeutralCpp.put().
| gui.CONNECTOR.b = B() |
Definition at line 156 of file CONNECTOR.py.
Referenced by YACS::looptypeParser< T >.bloc(), YACS::bloctypeParser< T >.bloc(), YACS::ENGINE::convertToYacsBool< CORBAImpl, CORBA::Any *, void *, IMPLOUT, TOUT >.convert(), YACS::ENGINE::CORBANode.execute(), YACS::HMI::SceneLinkItem.force2points(), YACS::looptypeParser< T >.foreach(), YACS::bloctypeParser< T >.foreach(), YACS::looptypeParser< T >.forloop(), YACS::bloctypeParser< T >.forloop(), genrand_res53(), PMMLlib::PMMLlib.HasIntercept(), YACS::looptypeParser< T >.optimizer(), YACS::bloctypeParser< T >.optimizer(), YACS::bloctypeParser< T >.post(), YACS::booltypeParser.post(), YACS::whilelooptypeParser< T >.post(), YACS::forlooptypeParser< T >.post(), YACS::pseudocomposednodetypeParser< T >.post(), YACS::foreachlooptypeParser< T >.post(), YACS::optimizerlooptypeParser< T >.post(), YACS::roottypeParser.proc(), YACS::looptypeParser< T >.switch_(), YACS::bloctypeParser< T >.switch_(), YACS::looptypeParser< T >.while_(), and YACS::bloctypeParser< T >.while_().
| gui.CONNECTOR.c = B() |
Definition at line 158 of file CONNECTOR.py.
Referenced by CheckEntry(), Yacsgui_Resource.colorValue(), YACS::ENGINE.PyStdOut_write(), YACS::HMI::LCostNode.setFCost(), YACS::HMI::LCostNode.setGCost(), YACS::HMI::LCostNode.setHCost(), tochar(), YACS::HMI::BatchJobsListDialog.userCell(), validChar0(), and validNextChar().
| gui.CONNECTOR.Connect = _the_connector.Connect |
Definition at line 139 of file CONNECTOR.py.
| gui.CONNECTOR.Disconnect = _the_connector.Disconnect |
Definition at line 141 of file CONNECTOR.py.
| gui.CONNECTOR.Emit = _the_connector.Emit |
Definition at line 140 of file CONNECTOR.py.
