ItemEdition.cxx
20#include "ItemEdition.hxx"
21#include "EditionProc.hxx"
22#include "EditionBloc.hxx"
23#include "EditionComponent.hxx"
24#include "EditionContainer.hxx"
26#include "EditionDataLink.hxx"
27#include "EditionDataType.hxx"
31#include "EditionInputPort.hxx"
32#include "EditionLoop.hxx"
33#include "EditionWhile.hxx"
34#include "EditionOutNode.hxx"
35#include "EditionOutputPort.hxx"
36#include "EditionPresetNode.hxx"
37#include "EditionPyFunc.hxx"
38#include "EditionSalomeNode.hxx"
39#include "EditionScript.hxx"
42#include "EditionSwitch.hxx"
43
44#include "QtGuiContext.hxx"
45#include "TypeCode.hxx"
46#include "commandsProc.hxx"
47
48#include <QLineEdit>
49#include <QLabel>
50#include <QPushButton>
51#include <QLayout>
52
53
54//#define _DEVDEBUG_
55#include "YacsTrace.hxx"
56
57#include <string>
58#include <cassert>
59
60using namespace std;
61
62using namespace YACS;
63using namespace YACS::HMI;
64
65
68ItemEditionBase::ItemEditionBase(Subject* subject)
69 : GuiObserver(), _subject(subject)
70{
71 _subject->attach(this);
72 _stackId = -1;
74 _type = "Unknown";
75 _category = "Unknown";
77 if (SubjectNode * sub = dynamic_cast<SubjectNode*>(_subject))
78 {
79 _category = "Node";
80 _type = invoc->getTypeName(invoc->getTypeOfNode(sub->getNode()));
81 }
82 else if (SubjectDataPort * sub = dynamic_cast<SubjectDataPort*>(_subject))
83 {
84 _category = "Port";
85 _type = invoc->getTypeName(invoc->getTypeOfPort(sub->getPort()));
86 }
87 else if (SubjectLink * sub = dynamic_cast<SubjectLink*>(_subject))
88 {
89 _category = "Link";
90 _type = "Link";
91 }
92 else if (SubjectControlLink * sub = dynamic_cast<SubjectControlLink*>(_subject))
93 {
94 _category = "ControlLink";
95 _type = "Control Link";
96 }
97 else if (SubjectDataType * sub = dynamic_cast<SubjectDataType*>(_subject))
98 {
99 _category = "Data";
100 switch (sub->getTypeCode()->kind())
101 {
102 case YACS::ENGINE::Double: _type = "Double"; break;
103 case YACS::ENGINE::Int: _type = "Int"; break;
104 case YACS::ENGINE::String: _type = "String"; break;
105 case YACS::ENGINE::Bool: _type = "Bool"; break;
106 case YACS::ENGINE::Objref: _type = "Objref"; break;
107 case YACS::ENGINE::Sequence: _type = "Sequence"; break;
108 case YACS::ENGINE::Array: _type = "Array"; break;
109 case YACS::ENGINE::Struct: _type = "Struct"; break;
110 default: _type = "None or Unknown";
111 }
112 }
113 else if (SubjectComponent * sub = dynamic_cast<SubjectComponent*>(_subject))
114 {
115 _category = "Component";
116 _type = "Salome Component";
117 }
118 else if (SubjectContainerBase * sub = dynamic_cast<SubjectContainerBase*>(_subject))
119 {
120 _category = "Container";
121 _type = sub->getLabelForHuman();
122 }
123}
124
126{
127}
128
129void ItemEditionBase::select(bool isSelected)
130{
131 DEBTRACE("ItemEditionBase::select " << isSelected);
132}
133
135{
136}
137
138void ItemEditionBase::update(GuiEvent event, int type, Subject* son)
139{
140}
141
143{
144 return _subject;
145}
146
152 QWidget* parent,
153 const char* name)
154 : FormEditItem(parent), ItemEditionBase(subject)
155{
156 DEBTRACE("ItemEdition::ItemEdition " << name);
157
158 _haveScript = false;
159 _isEdited = false;
160 setEdited(false);
161
162 connect(_wid->pb_apply, SIGNAL(clicked()), this, SLOT(onApply()));
163 connect(_wid->pb_cancel, SIGNAL(clicked()), this, SLOT(onCancel()));
164
165 // --- type of item and name
166
167 _wid->la_type->setText(_type.c_str());
168 _wid->le_name->setText(_name.c_str());
169 connect(_wid->le_name, SIGNAL(textChanged(const QString&)),
170 this, SLOT(onModifyName(const QString&)));
171 _wid->le_name->setReadOnly(true); // to be changed on derived classes depending on context
172
174 DEBTRACE("_stackId " << _stackId);
175 YASSERT(!QtGuiContext::getQtCurrent()->_mapOfEditionItem.count(_subject));
177 //QtGuiContext::getQtCurrent()->getStackedWidget()->raiseWidget(_stackId);
178}
179
181{
182 DEBTRACE("ItemEdition::~ItemEdition " << _name);
184 {
185 DEBTRACE("---");
186 QtGuiContext::getQtCurrent()->getStackedWidget()->removeWidget(this);
188 DEBTRACE("---");
189 }
190}
191
195{
196}
197
198void ItemEdition::select(bool isSelected)
199{
200 DEBTRACE("ItemEdition::select " << isSelected);
201 if (isSelected)
202 {
203 synchronize();
204 QtGuiContext::getQtCurrent()->getStackedWidget()->setCurrentWidget(this);
205 }
206}
207
208void ItemEdition::setName(std::string name)
209{
210 _name = name;
211 setEdited(false);
212}
213
215{
216 DEBTRACE("onApply");
217 string name = _wid->le_name->text().toStdString();
218 name = filterName(name);
219 bool nameEdited = false;
220 if (name != _name)
221 {
222 nameEdited = true;
223 bool ret = _subject->setName(name);
224 if (ret)
225 {
226 nameEdited = false;
227 _name = name;
228 }
229 }
230 DEBTRACE(_isEdited << " " << nameEdited);
231 _isEdited = nameEdited;
233}
234
236{
237 DEBTRACE("onCancel");
238 _wid->le_name->setText(_name.c_str());
239 setEdited(false);
240}
241
242std::string ItemEdition::filterName(const std::string& name)
243{
244 string nameFiltered;
245 nameFiltered = "";
246 for (int i= 0; i< name.size(); i++)
247 {
248 unsigned char a = (unsigned char)(name[i]);
249 if ( ((a >= '0') && (a <= '9'))
250 || ((a >= 'A') && (a <= 'Z'))
251 || ((a >= 'a') && (a <= 'z'))
252 || ( a == '_'))
253 nameFiltered += a;
254 }
255 DEBTRACE(name << " " << nameFiltered);
256 return nameFiltered;
257}
258
259void ItemEdition::onModifyName(const QString &text)
260{
261 if (_name != text.toStdString()) setEdited(true);
262}
263
264void ItemEdition::setEdited(bool isEdited)
265{
266 DEBTRACE("ItemEdition::setEdited " << isEdited);
267 if (isEdited)
268 {
271 if (QtGuiContext::getQtCurrent()->getSubjectProc())
273 }
274 else
275 {
278 if (QtGuiContext::getQtCurrent()->_setOfModifiedSubjects.empty() && QtGuiContext::getQtCurrent()->getSubjectProc())
280 }
281
284 if (schemaItem)
285 {
286 QModelIndex index = schemaItem->modelIndex();
287 model->setData(index, QVariant()); // just to emit dataChanged signal
288 }
289
290 _wid->pb_apply->setEnabled(isEdited);
291 _wid->pb_cancel->setEnabled(isEdited);
292}
293
298void ItemEdition::update(GuiEvent event, int type, Subject* son)
299{
300 DEBTRACE("ItemEdition::update " <<eventName(event) << " " << type);
301 if (QtGuiContext::getQtCurrent()->isLoading())
302 {
303 // --- create only EditionProc while loading to store status
304 if (event == NEWROOT)
305 ItemEdition *item = new EditionProc(son,
306 QtGuiContext::getQtCurrent()->getStackedWidget(),
307 son->getName().c_str());
308 return;
309 }
310
311 ItemEdition *item = 0;
312 switch (event)
313 {
314 case NEWROOT:
315 item = new EditionProc(son,
316 QtGuiContext::getQtCurrent()->getStackedWidget(),
317 son->getName().c_str());
318 break;
319 case ADD:
320 switch (type)
321 {
323 item = new EditionProc(son,
324 QtGuiContext::getQtCurrent()->getStackedWidget(),
325 son->getName().c_str());
326 break;
327 case YACS::HMI::BLOC:
328 item = new EditionBloc(son,
329 QtGuiContext::getQtCurrent()->getStackedWidget(),
330 son->getName().c_str());
331 break;
333 item = new EditionForEachLoop(son,
334 QtGuiContext::getQtCurrent()->getStackedWidget(),
335 son->getName().c_str());
336 break;
338 item = new EditionOptimizerLoop(son, QtGuiContext::getQtCurrent()->getStackedWidget(),
339 son->getName().c_str());
340 break;
342 item = new EditionLoop(son,
343 QtGuiContext::getQtCurrent()->getStackedWidget(),
344 son->getName().c_str());
345 break;
347 item = new EditionWhile(son,
348 QtGuiContext::getQtCurrent()->getStackedWidget(),
349 son->getName().c_str());
350 break;
352 item = new EditionSwitch(son,
353 QtGuiContext::getQtCurrent()->getStackedWidget(),
354 son->getName().c_str());
355 break;
357 item = new EditionScript(son,
358 QtGuiContext::getQtCurrent()->getStackedWidget(),
359 son->getName().c_str());
360 break;
362 item = new EditionPyFunc(son,
363 QtGuiContext::getQtCurrent()->getStackedWidget(),
364 son->getName().c_str());
365 break;
368 item = new EditionSalomeNode(son,
369 QtGuiContext::getQtCurrent()->getStackedWidget(),
370 son->getName().c_str());
371 break;
373 item = new EditionPresetNode(son,
374 QtGuiContext::getQtCurrent()->getStackedWidget(),
375 son->getName().c_str());
376 break;
378 item = new EditionOutNode(son,
379 QtGuiContext::getQtCurrent()->getStackedWidget(),
380 son->getName().c_str());
381 break;
383 item = new EditionStudyInNode(son,
384 QtGuiContext::getQtCurrent()->getStackedWidget(),
385 son->getName().c_str());
386 break;
388 item = new EditionStudyOutNode(son,
389 QtGuiContext::getQtCurrent()->getStackedWidget(),
390 son->getName().c_str());
391 break;
394 item = new EditionInputPort(son,
395 QtGuiContext::getQtCurrent()->getStackedWidget(),
396 son->getName().c_str());
397 break;
400 item = new EditionOutputPort(son,
401 QtGuiContext::getQtCurrent()->getStackedWidget(),
402 son->getName().c_str());
403 break;
405 item = new EditionContainer(son,QtGuiContext::getQtCurrent()->getStackedWidget(),son->getName().c_str());
406 break;
408 item = new EditionComponent(son,
409 QtGuiContext::getQtCurrent()->getStackedWidget(),
410 son->getName().c_str());
411
412 break;
414 item = new EditionDataType(son,
415 QtGuiContext::getQtCurrent()->getStackedWidget(),
416 son->getName().c_str());
417 break;
425 item = new ItemEdition(son,
426 QtGuiContext::getQtCurrent()->getStackedWidget(),
427 son->getName().c_str());
428 break;
429 default:
430 DEBTRACE("ItemEdition::update() ADD, type not handled:" << type);
431 }
432 break;
433 case ADDLINK:
434 switch (type)
435 {
437 item = new EditionDataLink(son,
438 QtGuiContext::getQtCurrent()->getStackedWidget(),
439 son->getName().c_str());
440 break;
441 default:
442 DEBTRACE("ItemEdition::update() ADDLINK, type not handled:" << type);
443 }
444 break;
445 case ADDCONTROLLINK:
446 switch (type)
447 {
449 item = new EditionControlLink(son,
450 QtGuiContext::getQtCurrent()->getStackedWidget(),
451 son->getName().c_str());
452 break;
453 default:
454 DEBTRACE("ItemEdition::update() ADDCONTROLLINK, type not handled:" << type);
455 }
456 break;
457 case RENAME:
459 _wid->le_name->setText(_name.c_str());
460 break;
461 case SYNCHRO:
462 synchronize();
463 break;
464// default:
465// DEBTRACE("ItemEdition::update(), event not handled: " << eventName(event));
466 }
467}
468
470 QWidget* parent,
471 const char* name)
472 : ItemEdition(subject, parent, name)
473{
474 DEBTRACE("ItemEditionRoot::ItemEditionRoot")
475}
476
478{
479 _subjectSet.clear(); // --- avoid destruction loop on delete context
480}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
WidEditItem * _wid
Definition: guiContext.hxx:51
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
std::set< Subject * > _subjectSet
virtual Subject * getSubject()
virtual void select(bool isSelected)
ItemEditionRoot(Subject *subject, QWidget *parent=0, const char *name=0)
virtual void onModifyName(const QString &text)
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
static std::string filterName(const std::string &name)
virtual void setName(std::string name)
virtual void setEdited(bool isEdited)
virtual void onApply()
virtual void synchronize()
virtual void onCancel()
static std::string getTypeName(TypeOfElem type)
static TypeOfElem getTypeOfPort(YACS::ENGINE::DataPort *port)
static TypeOfElem getTypeOfNode(YACS::ENGINE::Node *node)
QStackedWidget * getStackedWidget()
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
std::set< YACS::HMI::Subject * > _setOfModifiedSubjects
std::map< YACS::HMI::Subject *, QWidget * > _mapOfEditionItem
Definition: SchemaItem.cxx:253
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
virtual bool setName(std::string name)
virtual std::string getName()
virtual void attach(GuiObserver *obs)
@ OUTPUTDATASTREAMPORT
@ INPUTDATASTREAMPORT
