YACS::HMI::ProcInvoc Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::ProcInvoc:
Collaboration diagram for YACS::HMI::ProcInvoc:
 ProcInvoc ()
- Public Member Functions inherited from YACS::HMI::Invocator
 Invocator ()
void add (Command *command)
bool undo ()
bool redo ()
std::list< std::string > getDone ()
std::list< std::string > getUndone ()
YACS::ENGINE::Proc * getUndoProc ()
YACS::ENGINE::Catalog * getUndoCata ()
bool isSpecialReverse ()
static TypeOfElem getTypeOfNode (YACS::ENGINE::Node *node)
static TypeOfElem getTypeOfPort (YACS::ENGINE::DataPort *port)
static std::string getTypeName (TypeOfElem type)
Static Protected Attributes
static std::map< int, std::string > _typeNameMap
- Static Public Attributes inherited from YACS::HMI::Invocator
static int _ctr = 0
- Protected Attributes inherited from YACS::HMI::Invocator
std::vector< Command * > _commandsDone
std::vector< Command * > _commandsUndone
std::vector< Command * > _commandsInProgress
YACS::ENGINE::Proc * _undoProc
YACS::ENGINE::Catalog * _undoCata
bool _isRedo
bool _isUndo
bool _specialReverse
Definition at line 96 of file commandsProc.hxx.
◆ ProcInvoc()
ProcInvoc::ProcInvoc ( )
Definition at line 99 of file commandsProc.cxx.
100 : Invocator()
101{
102 _typeNameMap.clear();
103 _typeNameMap[SALOMEPROC] = "SALOMEPROC";
104 _typeNameMap[BLOC] = "BLOC";
105 _typeNameMap[FOREACHLOOP] = "FOREACHLOOP";
106 _typeNameMap[OPTIMIZERLOOP] = "OPTIMIZERLOOP";
107 _typeNameMap[FORLOOP] = "FORLOOP";
108 _typeNameMap[WHILELOOP] = "WHILELOOP";
109 _typeNameMap[SWITCH] = "SWITCH";
110 _typeNameMap[PYTHONNODE] = "PYTHONNODE";
111 _typeNameMap[PYFUNCNODE] = "PYFUNCNODE";
112 _typeNameMap[CORBANODE] = "CORBANODE";
113 _typeNameMap[SALOMENODE] = "SALOMENODE";
114 _typeNameMap[CPPNODE] = "CPPNODE";
115 _typeNameMap[SALOMEPYTHONNODE] = "SALOMEPYTHONNODE";
116 _typeNameMap[XMLNODE] = "XMLNODE";
117 _typeNameMap[SPLITTERNODE] = "SPLITTERNODE";
118 _typeNameMap[DFTODSFORLOOPNODE] = "DFTODSFORLOOPNODE";
119 _typeNameMap[DSTODFFORLOOPNODE] = "DSTODFFORLOOPNODE";
120 _typeNameMap[PRESETNODE] = "PRESETNODE";
121 _typeNameMap[OUTNODE] = "OUTNODE";
122 _typeNameMap[STUDYINNODE] = "STUDYINNODE";
123 _typeNameMap[STUDYOUTNODE] = "STUDYOUTNODE";
124 _typeNameMap[INPUTPORT] = "INPUTPORT";
125 _typeNameMap[OUTPUTPORT] = "OUTPUTPORT";
126 _typeNameMap[INPUTDATASTREAMPORT] = "INPUTDATASTREAMPORT";
127 _typeNameMap[OUTPUTDATASTREAMPORT] = "OUTPUTDATASTREAMPORT";
128 _typeNameMap[DATALINK] = "DATALINK";
129 _typeNameMap[CONTROLLINK] = "CONTROLLINK";
130 _typeNameMap[CONTAINER] = "CONTAINER";
131 _typeNameMap[COMPONENT] = "COMPONENT";
132 _typeNameMap[REFERENCE] = "REFERENCE";
133 _typeNameMap[DATATYPE] = "DATATYPE";
134}
@ OUTPUTDATASTREAMPORT
@ INPUTDATASTREAMPORT
References _typeNameMap, YACS::HMI::BLOC, YACS::HMI::COMPONENT, YACS::HMI::CONTAINER, YACS::HMI::CONTROLLINK, YACS::HMI::CORBANODE, YACS::HMI::CPPNODE, YACS::HMI::DATALINK, YACS::HMI::DATATYPE, YACS::HMI::DFTODSFORLOOPNODE, YACS::HMI::DSTODFFORLOOPNODE, YACS::HMI::FOREACHLOOP, YACS::HMI::FORLOOP, YACS::HMI::INPUTDATASTREAMPORT, YACS::HMI::INPUTPORT, YACS::HMI::OPTIMIZERLOOP, YACS::HMI::OUTNODE, YACS::HMI::OUTPUTDATASTREAMPORT, YACS::HMI::OUTPUTPORT, YACS::HMI::PRESETNODE, YACS::HMI::PYFUNCNODE, YACS::HMI::PYTHONNODE, YACS::HMI::REFERENCE, YACS::HMI::SALOMENODE, YACS::HMI::SALOMEPROC, YACS::HMI::SALOMEPYTHONNODE, YACS::HMI::SPLITTERNODE, YACS::HMI::STUDYINNODE, YACS::HMI::STUDYOUTNODE, YACS::HMI::SWITCH, YACS::HMI::WHILELOOP, and YACS::HMI::XMLNODE.
◆ getTypeName()
std::string ProcInvoc::getTypeName ( TypeOfElem  type)
Definition at line 170 of file commandsProc.cxx.
171{
172 if (_typeNameMap.count(type))
173 return _typeNameMap[type];
174 else
175 return "UNKNOWN";
176}
References _typeNameMap.
Referenced by YACS::HMI::CommandDestroy::dump(), and YACS::HMI::ItemEditionBase::ItemEditionBase().
◆ getTypeOfNode()
TypeOfElem ProcInvoc::getTypeOfNode ( YACS::ENGINE::Node *  node)
Definition at line 136 of file commandsProc.cxx.
137{
138 TypeOfElem nodeType = UNKNOWN;
139 if (dynamic_cast<YACS::ENGINE::Bloc*>(node)) nodeType = BLOC;
140 else if (dynamic_cast<YACS::ENGINE::PythonNode*>(node)) nodeType = PYTHONNODE;
141 else if (dynamic_cast<YACS::ENGINE::PyFuncNode*>(node)) nodeType = PYFUNCNODE;
142 else if (dynamic_cast<YACS::ENGINE::CORBANode*>(node)) nodeType = CORBANODE;
143 else if (dynamic_cast<YACS::ENGINE::CppNode*>(node)) nodeType = CPPNODE;
144 else if (dynamic_cast<YACS::ENGINE::SalomeNode*>(node)) nodeType = SALOMENODE;
145 else if (dynamic_cast<YACS::ENGINE::SalomePythonNode*>(node)) nodeType = SALOMEPYTHONNODE;
146 else if (dynamic_cast<YACS::ENGINE::XmlNode*>(node)) nodeType = XMLNODE;
147 else if (dynamic_cast<YACS::ENGINE::SplitterNode*>(node)) nodeType = SPLITTERNODE;
148 else if (dynamic_cast<YACS::ENGINE::ForLoop*>(node)) nodeType = FORLOOP;
149 else if (dynamic_cast<YACS::ENGINE::WhileLoop*>(node)) nodeType = WHILELOOP;
150 else if (dynamic_cast<YACS::ENGINE::Switch*>(node)) nodeType = SWITCH;
151 else if (dynamic_cast<YACS::ENGINE::ForEachLoopGen*>(node)) nodeType = FOREACHLOOP;
152 else if (dynamic_cast<YACS::ENGINE::OptimizerLoop*>(node)) nodeType = OPTIMIZERLOOP;
153 else if (dynamic_cast<YACS::ENGINE::PresetNode*>(node)) nodeType = PRESETNODE;
154 else if (dynamic_cast<YACS::ENGINE::OutNode*>(node)) nodeType = OUTNODE;
155 else if (dynamic_cast<YACS::ENGINE::StudyInNode*>(node)) nodeType = STUDYINNODE;
156 else if (dynamic_cast<YACS::ENGINE::StudyOutNode*>(node)) nodeType = STUDYOUTNODE;
157 return nodeType;
158}
Definition: Bloc.hxx:36
Class for CORBA Service Node.
Definition: CORBANode.hxx:45
Class for C++ Nodes (in process component)
Definition: CppNode.hxx:47
Class for for loop node.
Definition: ForLoop.hxx:33
Class for data out node.
Definition: OutNode.hxx:30
Class for data in node.
Definition: PresetNode.hxx:31
Class for Salome component Service Node.
Definition: CORBANode.hxx:68
Definition: Switch.hxx:85
Class for a while loop.
Definition: WhileLoop.hxx:39
References YACS::HMI::BLOC, YACS::HMI::CORBANODE, YACS::HMI::CPPNODE, YACS::HMI::FOREACHLOOP, YACS::HMI::FORLOOP, YACS::HMI::OPTIMIZERLOOP, YACS::HMI::OUTNODE, YACS::HMI::PRESETNODE, YACS::HMI::PYFUNCNODE, YACS::HMI::PYTHONNODE, YACS::HMI::SALOMENODE, YACS::HMI::SALOMEPYTHONNODE, YACS::HMI::SPLITTERNODE, YACS::HMI::STUDYINNODE, YACS::HMI::STUDYOUTNODE, YACS::HMI::SWITCH, YACS::HMI::UNKNOWN, YACS::HMI::WHILELOOP, and YACS::HMI::XMLNODE.
Referenced by YACS::HMI::SubjectComposedNode::addSubjectNode(), YACS::HMI::GenericGui::createContext(), YACS::HMI::ItemEditionBase::ItemEditionBase(), YACS::HMI::CommandAddNodeFromCatalog::localExecute(), YACS::HMI::CommandReparentNode::localExecute(), YACS::HMI::CommandPutInComposedNode::localExecute(), YACS::HMI::CommandReparentNode::localReverse(), YACS::HMI::CommandPutInComposedNode::localReverse(), YACS::HMI::SubjectNode::notifyObserver(), YACS::HMI::SchemaInPortItem::SchemaInPortItem(), and YACS::HMI::SchemaInPortItem::update().
◆ getTypeOfPort()
◆ _typeNameMap
std::map< int, std::string > ProcInvoc::_typeNameMap
staticprotected
Definition at line 104 of file commandsProc.hxx.
Referenced by getTypeName(), and ProcInvoc().
