YACS::ENGINE::StudyOutNode Class Reference
#include <StudyNodes.hxx>
Inheritance diagram for YACS::ENGINE::StudyOutNode:
Collaboration diagram for YACS::ENGINE::StudyOutNode:
 StudyOutNode (const std::string &name)
 StudyOutNode (const StudyOutNode &other, ComposedNode *father)
virtual void execute ()
virtual void setData (InputPort *port, const std::string &data)
- Public Member Functions inherited from YACS::ENGINE::DataNode
virtual void setData (OutputPort *port, const std::string &data)
virtual void setRef (const std::string &ref)
virtual std::string getRef ()
virtual ~DataNode ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char IMPL_NAME [] ="XML"
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::DataNode
 DataNode (const DataNode &other, ComposedNode *father)
 DataNode (const std::string &name)
template<class PORT >
YACS::Colour _colour
- Protected Attributes inherited from YACS::ENGINE::DataNode
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 46 of file StudyNodes.hxx.
◆ StudyOutNode() [1/2]
YACS::ENGINE::StudyOutNode::StudyOutNode ( const std::string &  name)
Definition at line 140 of file StudyNodes.cxx.
141 : DataNode(name)
142{
144}
DataNode(const DataNode &other, ComposedNode *father)
Definition: DataNode.hxx:40
Definition: Node.hxx:97
static const char IMPL_NAME[]
Definition: StudyNodes.hxx:60
References YACS::ENGINE::Node::_implementation, and IMPL_NAME.
Referenced by simpleClone().
◆ StudyOutNode() [2/2]
YACS::ENGINE::StudyOutNode::StudyOutNode ( const StudyOutNode &  other,
ComposedNode *  father
Definition at line 146 of file StudyNodes.cxx.
147 : DataNode(other, father)
148{
149}
◆ accept()
void YACS::ENGINE::StudyOutNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 272 of file StudyNodes.cxx.
273{
274 visitor->visitStudyOutNode(this);
275}
References YACS::ENGINE::Visitor::visitStudyOutNode().
◆ checkBasicConsistency()
void YACS::ENGINE::StudyOutNode::checkBasicConsistency ( ) const
Definition at line 233 of file StudyNodes.cxx.
234{
235 DEBTRACE("StudyOutNode::checkBasicConsistency");
236 if (! _setOfOutputPort.empty())
237 {
238 std::string what = "StudyNode ";
239 what += getName();
240 what += " only accepts InputStudyPort, no OutputPort";
241 throw Exception(what);
242 }
243
244 std::list<InputPort *>::const_iterator iter;
245 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
246 {
247 InputStudyPort *inp = dynamic_cast<InputStudyPort*>(*iter);
248 if (!inp)
249 {
250 std::string what("Input port: ");
251 what += (*iter)->getName();
252 what += " is not an InputStudyPort. StudyNode ";
253 what += getName();
254 what += " only accepts InputStudyPorts";
255 throw Exception(what);
256 }
257 inp->checkBasicConsistency();
258
259 std::string data = inp->getData();
260 DEBTRACE(data);
261 if (data.empty())
262 {
263 std::string what("InputStudyPort: ");
264 what += (*iter)->getName();
265 what += " is not initialised";
266 throw Exception(what);
267 }
268 }
269
270}
Definition: Node.hxx:125
References YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::InputPort::checkBasicConsistency(), DEBTRACE, YACS::ENGINE::InputStudyPort::getData(), and YACS::ENGINE::Node::getName().
◆ createInputPort()
InputPort * YACS::ENGINE::StudyOutNode::createInputPort ( const std::string &  inputPortName,
TypeCode *  type
Definition at line 156 of file StudyNodes.cxx.
157{
158 return new InputStudyPort(inputPortName, this, type);
159}
◆ execute()
void YACS::ENGINE::StudyOutNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 202 of file StudyNodes.cxx.
203{
204 DEBTRACE("+++++++ StudyOutNode::execute +++++++++++");
205
206 SALOMEDS::StudyBuilder_var aBuilder =KERNEL::getStudyServant()->NewBuilder() ;
207 if(CORBA::is_nil(aBuilder))
208 {
209 _errorDetails="Execution problem: can not create StudyBuilder";
211 }
212
213 SALOMEDS::GenericAttribute_var aGAttr;
214 SALOMEDS::SObject_var aSO ;
215 SALOMEDS::AttributeName_var anAttr ;
216 SALOMEDS::AttributeIOR_var iorAttr ;
217
218 std::list<InputPort *>::const_iterator iter;
219 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
220 {
221 InputStudyPort *inp = dynamic_cast<InputStudyPort *>(*iter);
222 inp->putDataInStudy(aBuilder);
223 }
224
225 // save in file if ref is given
226 if(_ref != "")
227 {
228 KERNEL::getStudyServant()->SaveAs(Kernel_Utils::decode_s( _ref ), false, false);
229 }
230 DEBTRACE("+++++++ end StudyOutNode::execute +++++++++++" );
231}
Definition: Node.hxx:93
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::DataNode::_ref, YACS::ENGINE::ElementaryNode::_setOfInputPort, DEBTRACE, and YACS::ENGINE::InputStudyPort::putDataInStudy().
◆ setData()
void YACS::ENGINE::StudyOutNode::setData ( InputPort *  port,
const std::string &  data
Reimplemented from YACS::ENGINE::DataNode.
Definition at line 161 of file StudyNodes.cxx.
162{
163 InputStudyPort *inp = dynamic_cast<InputStudyPort *>(port);
164 inp->setData(data);
165}
References YACS::ENGINE::InputStudyPort::setData().
◆ simpleClone()
Node * YACS::ENGINE::StudyOutNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 151 of file StudyNodes.cxx.
152{
153 return new StudyOutNode(*this,father);
154}
StudyOutNode(const std::string &name)
Definition: StudyNodes.cxx:140
References StudyOutNode().
◆ typeName()
virtual std::string YACS::ENGINE::StudyOutNode::typeName ( )
Definition at line 58 of file StudyNodes.hxx.
58{return "YACS__ENGINE__StudyOutNode";}
◆ IMPL_NAME
const char YACS::ENGINE::StudyOutNode::IMPL_NAME ="XML"
Definition at line 60 of file StudyNodes.hxx.
Referenced by StudyOutNode().
