YACS::ENGINE::DynParaLoop Class Reference
Base class for dynamically (fully or semifully) built graphs. More...
#include <DynParaLoop.hxx>
Inheritance diagram for YACS::ENGINE::DynParaLoop:
Collaboration diagram for YACS::ENGINE::DynParaLoop:
Node * edRemoveNode ()
Node * edRemoveInitNode ()
Node * edRemoveFinalizeNode ()
Node * edSetNode (Node *DISOWNnode)
Node * edSetInitNode (Node *DISOWNnode)
Node * edSetFinalizeNode (Node *DISOWNnode)
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add control link if necessary. More...
void init (bool start=true)
InputPort * edGetNbOfBranchesPort ()
unsigned getNumberOfEltsConsumed () const
int getBranchIDOfNode (Node *node) const
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
OutputPort * edGetSamplePort ()
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
 Get an output port given its name. More...
bool isPlacementPredictableB4Run () const
 For the moment false is returned : impovement about it coming soon. More...
void edRemoveChild (Node *node)
 Remove a child node. More...
bool isLoop () const override
virtual bool edAddChild (Node *DISOWNnode)
std::list< Node * > edGetDirectDescendants () const
unsigned getNumberOfBranchesCreatedDyn () const
Node * getChildByShortName (const std::string &name) const
Node * getChildByNameExec (const std::string &name, unsigned id) const
std::vector< Node * > getNodes () const
ComplexWeight * getWeight ()
void setWeight (double loopWeight)
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
Node * getInitNode ()
Node * getExecNode ()
Node * getFinalizeNode ()
virtual void cleanDynGraph ()
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
Protected Types
enum  TypeOfNode { INIT_NODE = 5 , WORK_NODE = 6 , FINALIZE_NODE = 7 }
 DynParaLoop (const std::string &name, TypeCode *typeOfDataSplitted, std::unique_ptr< NbBranchesAbstract > &&branchManager)
virtual ~DynParaLoop ()
 DynParaLoop (const DynParaLoop &other, ComposedNode *father, bool editionOnly)
void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
void prepareInputsFromOutOfScope (int branchNb)
void putValueOnBranch (Any *val, unsigned branchId, bool first)
TypeOfNode getIdentityOfNotifyerNode (const Node *node, unsigned &id)
InputPort * getDynInputPortByAbsName (int branchNb, const std::string &name, bool initNodeAdmitted)
virtual void forwardExecStateToOriginalBody (Node *execNode)
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
std::vector< Node * > cloneAndPlaceNodesCoherently (const std::vector< Node * > &origNodes)
 Clone nodes and make their placement consistent with the placement of the original ones. More...
Node * checkConsistencyAndSetNode (Node *&nodeToReplace, Node *DISOWNnode)
 This method is used to factorize methods edSetNode, edSetInitNode and edSetFinalizeNode. More...
Node * removeNode (Node *&nodeToRemove)
 This method is used to factorize methods edRemoveNode, edRemoveInitNode and edRemoveFinalizeNode. More...
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const std::string &name)
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
Node * _node
Node * _initNode
Node * _finalizeNode
unsigned _nbOfEltConsumed
std::vector< int > _execIds
std::unique_ptr< NbBranchesAbstract > _nbOfBranches
AnyOutputPort _splittedPort
std::vector< Node * > _execNodes
std::vector< Node * > _execInitNodes
std::vector< Node * > _execFinalizeNodes
int _initializingCounter
int _unfinishedCounter
int _failedCounter
ComplexWeight _weight
double _loopWeight
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
Static Protected Attributes
static const char NAME_OF_SPLITTED_SEQ_OUT [] = "evalSamples"
static const char OLD_NAME_OF_SPLITTED_SEQ_OUT [] = "SmplPrt"
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
Definition at line 40 of file DynParaLoop.hxx.
◆ TypeOfNode
INIT_NODE
WORK_NODE
FINALIZE_NODE
Definition at line 43 of file DynParaLoop.hxx.
◆ DynParaLoop() [1/2]
DynParaLoop::DynParaLoop ( const std::string &  name,
TypeCode *  typeOfDataSplitted,
std::unique_ptr< NbBranchesAbstract > &&  branchManager
Definition at line 42 of file DynParaLoop.cxx.
44 _nbOfBranches(std::move(branchManager)),
46{
48}
Definition: DynParaLoop.hxx:56
static const char NAME_OF_SPLITTED_SEQ_OUT[]
Definition: DynParaLoop.hxx:67
Definition: DynParaLoop.hxx:57
friend class ComposedNode
Definition: Node.hxx:79
References _weight, and YACS::ENGINE::ComplexWeight::setDefaultLoop().
◆ ~DynParaLoop()
DynParaLoop::~DynParaLoop ( )
Definition at line 50 of file DynParaLoop.cxx.
51{
52 delete _node;
53 delete _initNode;
54 delete _finalizeNode;
55}
References _finalizeNode, _initNode, and _node.
◆ DynParaLoop() [2/2]
DynParaLoop::DynParaLoop ( const DynParaLoop &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 57 of file DynParaLoop.cxx.
58 : ComposedNode(other,father),_nbOfBranches(other._nbOfBranches->copy(this)),
61{
62 if(other._node)
63 _node=other._node->clone(this,editionOnly);
64 if(other._initNode)
65 _initNode=other._initNode->clone(this,editionOnly);
66 if(other._finalizeNode)
67 _finalizeNode = other._finalizeNode->clone(this,editionOnly);
68 const AnyOutputPort& startOfLinksToReproduce=other._splittedPort;
69 set<InPort *> endsOfLinksToReproduce=startOfLinksToReproduce.edSetInPort();
70 for(set<InPort *>::iterator iter=endsOfLinksToReproduce.begin();iter!=endsOfLinksToReproduce.end();iter++)
72}
std::string getPortName(const PORT *port) const
bool edAddLink(OutPort *start, InPort *end)
Node * clone(ComposedNode *father, bool editionOnly=true) const
This method MUST NEVER BE VIRTUAL
Definition: Node.cxx:131
InPort * getInPort(const std::string &name) const
Definition: Node.cxx:239
std::set< InPort * > edSetInPort() const
Definition: OutputPort.cxx:239
References _finalizeNode, _initNode, _node, _splittedPort, YACS::ENGINE::Node::clone(), YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::OutputPort::edSetInPort(), YACS::ENGINE::Node::getInPort(), and YACS::ENGINE::ComposedNode::getPortName().
◆ accept()
void DynParaLoop::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ComposedNode.
Reimplemented in YACS::ENGINE::ForEachLoop, YACS::ENGINE::ForEachLoopDyn, and YACS::ENGINE::OptimizerLoop.
Definition at line 889 of file DynParaLoop.cxx.
890{
891 visitor->visitDynParaLoop(this);
892}
virtual void visitDynParaLoop(DynParaLoop *node)=0
References YACS::ENGINE::Visitor::visitDynParaLoop().
◆ buildDelegateOf() [1/2]
void DynParaLoop::buildDelegateOf ( InPort *&  port,
OutPort *  initialStart,
const std::list< ComposedNode * > &  pointsOfView
Reimplemented in YACS::ENGINE::OptimizerLoop.
Definition at line 455 of file DynParaLoop.cxx.
456{
457 string typeOfPortInstance=port->getNameOfTypeOfCurrentInstance();
458 if(typeOfPortInstance!=InputPort::NAME)
459 throw Exception("DynParaLoop::buildDelegateOf : A link with datastream end inside DynParaLoop is not possible");
460}
Definition: DataPort.cxx:56
static const char NAME[]
Definition: InputPort.hxx:48
References YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), and YACS::ENGINE::InputPort::NAME.
Referenced by YACS::ENGINE::OptimizerLoop::buildDelegateOf(), and YACS::ENGINE::ForEachLoopGen::buildDelegateOf().
◆ buildDelegateOf() [2/2]
void DynParaLoop::buildDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
InPort *  finalTarget,
Reimplemented in YACS::ENGINE::ForEachLoopGen, and YACS::ENGINE::OptimizerLoop.
Definition at line 462 of file DynParaLoop.cxx.
463{
464 std::string linkName("(");
465 linkName += port.first->getName()+" to "+finalTarget->getName()+")";
466 if(_initNode)
467 if(isInMyDescendance(port.first->getNode())==_initNode)
468 throw Exception(std::string("Illegal link within a parallel loop: \
469a link starting from the init node can't leave the scope of the loop.")
470 + linkName);
471
472 if(_finalizeNode)
473 if(isInMyDescendance(port.first->getNode())==_finalizeNode)
474 throw Exception(std::string("Illegal link within a parallel loop: \
475an output port of the finalize node can't be linked.")
476 + linkName);
477
478 if(port.first==&_splittedPort)
479 throw Exception(std::string("Illegal link within a parallel loop: \
480the 'evalSamples' port must be linked within the scope of the loop.")
481 + linkName);
482}
Node * isInMyDescendance(Node *nodeToTest) const
std::string getName() const
Definition: DataPort.hxx:55
References _finalizeNode, _initNode, _splittedPort, YACS::ENGINE::DataPort::getName(), and YACS::ENGINE::ComposedNode::isInMyDescendance().
◆ checkBasicConsistency()
void DynParaLoop::checkBasicConsistency ( ) const
Definition at line 579 of file DynParaLoop.cxx.
580{
581 DEBTRACE("DynParaLoop::checkBasicConsistency");
583 if(!_node)
584 throw Exception("For a dynamic loop, internal node is mandatory");
585}
References _node, YACS::ENGINE::ComposedNode::checkBasicConsistency(), and DEBTRACE.
Referenced by YACS::ENGINE::OptimizerLoop::checkBasicConsistency().
◆ checkCFLinks()
void DynParaLoop::checkCFLinks ( const std::list< OutPort * > &  starts,
InputPort *  end,
unsigned char &  alreadyFed,
bool  direction,
LinkInfo &  info
startsIf different of 0, must aggregate at leat 1 element.
end:
alreadyFedin/out parameter. Indicates if 'end' ports is already and surely set or fed by an another port.
directionIf true : forward direction else backward direction.
info: informations collectedduring the check
Definition at line 484 of file DynParaLoop.cxx.
485{
486 const char what[]="DynParaLoop::checkCFLinks : internal error.";
487 //First dealing checkCFLinks forwarding...
488 if(isInMyDescendance(end->getNode())==0)//no chance that _splittedPort is in starts due to buildDelegate.
489 solveObviousOrDelegateCFLinks(starts,end,alreadyFed,direction,info);
490 else
491 {//no forwarding here.
492 if(starts.size()!=1)
493 throw Exception(what);
494 //ASSERT(direction) : see DynParaLoop::checkControlDependancy only 'fw' filled.
495 if(alreadyFed==FREE_ST)
496 alreadyFed=FED_ST;
497 else if(alreadyFed==FED_ST)
498 {//Shame ! splittedPort fills a port already fed...
499 info.pushInfoLink(*(starts.begin()),end,I_USELESS);
500 }
501 }
502}
void solveObviousOrDelegateCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
void pushInfoLink(OutPort *semStart, InPort *end, InfoReason reason)
Definition: LinkInfo.cxx:71
Node * getNode() const
Definition: Port.hxx:46
References YACS::ENGINE::ComposedNode::FED_ST, YACS::ENGINE::ComposedNode::FREE_ST, YACS::ENGINE::Port::getNode(), YACS::ENGINE::I_USELESS, YACS::ENGINE::ComposedNode::isInMyDescendance(), YACS::ENGINE::LinkInfo::pushInfoLink(), and YACS::ENGINE::ComposedNode::solveObviousOrDelegateCFLinks().
Referenced by YACS::ENGINE::OptimizerLoop::checkCFLinks().
◆ checkConsistencyAndSetNode()
Node * DynParaLoop::checkConsistencyAndSetNode ( Node *&  nodeToReplace,
Node *  DISOWNnode
Definition at line 80 of file DynParaLoop.cxx.
81{
82 if (node == NULL || nodeToReplace == node)
83 return 0;
84 if (node->_father)
85 throw Exception(string("Can't set node: node ") + node->getName() + " is not orphan.");
86 if (_node && _node != nodeToReplace && _node->getName() == node->getName())
87 throw Exception(string("Can't set node: node ") + node->getName() +
88 " has the same name than exec node already in " + _name + ".");
89 if (_initNode && _initNode != nodeToReplace && _initNode->getName() == node->getName())
90 throw Exception(string("Can't set node: node ") + node->getName() +
91 " has the same name than init node already in " + _name + ".");
92 if (_finalizeNode && _finalizeNode != nodeToReplace && _finalizeNode->getName() == node->getName())
93 throw Exception(string("Can't set node: node ") + node->getName() +
94 " has the same name than finalize node already in " + _name + ".");
96 ComposedNode::edRemoveChild(nodeToReplace);
97 Node * ret = nodeToReplace;
98 nodeToReplace = node;
99 nodeToReplace->_father = this;
100 // set _modified flag so that edUpdateState can refresh state
101 modified();
102 return ret;
103}
void checkNoCrossHierachyWith(Node *node) const
virtual void edRemoveChild(Node *node)
Base class for all nodes.
Definition: Node.hxx:70
std::string _name
Definition: Node.hxx:89
Definition: Node.hxx:90
Definition: Node.hxx:125
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
References YACS::ENGINE::Node::_father, _finalizeNode, _initNode, YACS::ENGINE::Node::_name, _node, YACS::ENGINE::ComposedNode::checkNoCrossHierachyWith(), YACS::ENGINE::ComposedNode::edRemoveChild(), YACS::ENGINE::Node::getName(), and YACS::ENGINE::Node::modified().
Referenced by edSetFinalizeNode(), edSetInitNode(), and edSetNode().
◆ checkControlDependancy()
void DynParaLoop::checkControlDependancy ( OutPort *  start,
InPort *  end,
bool  cross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  fw,
std::vector< OutPort * > &  fwCross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  bw,
LinkInfo &  info
start: start port
end: end port
crossindicates if start -> end link is a DS link behind.
fwout parameter.
fwCrossout parameter storing links where a cross has been detected.
bwout parameter where backward links are stored.
info: collected information
Implements YACS::ENGINE::ComposedNode.
Definition at line 513 of file DynParaLoop.cxx.
518{
519 fw[(ComposedNode *)this].push_back(start);
520}
Referenced by YACS::ENGINE::OptimizerLoop::checkControlDependancy().
◆ checkLinkPossibility()
void DynParaLoop::checkLinkPossibility ( OutPort *  start,
const std::list< ComposedNode * > &  pointsOfViewStart,
InPort *  end,
const std::list< ComposedNode * > &  pointsOfViewEnd
Definition at line 522 of file DynParaLoop.cxx.
524{
525 ComposedNode::checkLinkPossibility(start, pointsOfViewStart, end, pointsOfViewEnd);
526 Node * startNode = isInMyDescendance(start->getNode());
527 Node * endNode = isInMyDescendance(end->getNode());
528 std::string linkName("(");
529 linkName += start->getName()+" to "+end->getName()+")";
530
531 if(start == &_splittedPort && endNode != _node)
532 throw Exception(std::string("Illegal link within a parallel loop: \
533the 'evalSamples' port can only be connected to the working node of the loop.")
534 + linkName);
535
536 if(_finalizeNode && _finalizeNode == startNode)
537 throw Exception(std::string("Illegal link within a parallel loop: \
538the finalize node can't be the origin of a link.")
539 + linkName);
540
541 if(_initNode && _node == startNode && _initNode == endNode)
542 throw Exception(std::string("Illegal link within a parallel loop: \
543can't make a link from the working node to the init node.")
544 + linkName);
545
546 if(_finalizeNode && _node == startNode && _finalizeNode == endNode)
547 throw Exception(std::string("Illegal link within a parallel loop: \
548can't make a link from the working node to the finalize node.")
549 + linkName);
550}
virtual void checkLinkPossibility(OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
References _finalizeNode, _initNode, _node, _splittedPort, YACS::ENGINE::ComposedNode::checkLinkPossibility(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Port::getNode(), and YACS::ENGINE::ComposedNode::isInMyDescendance().
Referenced by YACS::ENGINE::ForEachLoopGen::checkLinkPossibility(), and YACS::ENGINE::OptimizerLoop::checkLinkPossibility().
◆ cleanDynGraph()
void DynParaLoop::cleanDynGraph ( )
Reimplemented in YACS::ENGINE::ForEachLoopGen.
Definition at line 333 of file DynParaLoop.cxx.
334{
335 vector<Node *>::iterator iter;
336 for(iter=_execNodes.begin() ; iter!=_execNodes.end() ; iter++)
337 delete *iter;
338 _execNodes.clear();
339 for(iter=_execInitNodes.begin() ; iter!=_execInitNodes.end() ; iter++)
340 delete *iter;
341 _execInitNodes.clear();
342 for(iter=_execFinalizeNodes.begin() ; iter!=_execFinalizeNodes.end() ; iter++)
343 delete *iter;
344 _execFinalizeNodes.clear();
345}
Definition: DynParaLoop.hxx:58
Definition: DynParaLoop.hxx:60
Definition: DynParaLoop.hxx:59
References _execFinalizeNodes, _execInitNodes, and _execNodes.
Referenced by YACS::ENGINE::ForEachLoopGen::cleanDynGraph(), YACS::ENGINE::OptimizerLoop::init(), and YACS::ENGINE::OptimizerLoop::~OptimizerLoop().
◆ cloneAndPlaceNodesCoherently()
vector< Node * > DynParaLoop::cloneAndPlaceNodesCoherently ( const std::vector< Node * > &  origNodes)
For instance, if two original nodes are placed on a component comp1 in a container cont1 and a third one is placed on a component comp2 in the container cont1, the clones of the two first nodes will be placed on a component comp3 in a container cont2 and the third clone will be placed on a component comp4 in the container cont2.
Definition at line 744 of file DynParaLoop.cxx.
745{
746 DEBTRACE("Begin cloneAndPlaceNodesCoherently")
747 vector<Node *> clones;
748 DeploymentTree treeToDup;
749 vector<list<ElementaryNode *> > origElemNodeList;
750 for (int i=0 ; i<origNodes.size() ; i++)
751 {
752 DEBTRACE("Cloning node " << i)
753 if (origNodes[i] == NULL)
754 {
755 DEBTRACE("Cloning node " << i << ", NULL" )
756 clones.push_back(NULL);
757 origElemNodeList.push_back(list<ElementaryNode *>());
758 }
759 else
760 {
761 DEBTRACE("Cloning node " << i << "," << origNodes[i]->getName())
762 clones.push_back(origNodes[i]->simpleClone(this, false));
763 list<ElementaryNode *> tasks = origNodes[i]->getRecursiveConstituents();
764 origElemNodeList.push_back(tasks);
765 for (list< ElementaryNode *>::iterator iter=tasks.begin() ; iter!=tasks.end() ; iter++)
766 treeToDup.appendTask(*iter, (*iter)->getDynClonerIfExists(this));
767 }
768 }
769
770 // Build the links between clones.
771 // Only the links starting from initNode are possible.
772 if(_initNode)
773 {
774 std::vector< std::pair<OutPort *, InPort *> > outLinks = _initNode->getSetOfLinksLeavingCurrentScope();
775 std::vector< std::pair<OutPort *, InPort *> >::const_iterator it;
776 for(it=outLinks.begin(); it!=outLinks.end(); it++)
777 {
778 OutPort *startPort = it->first;
779 InPort *endPort = it->second;
780 Node* destNode = isInMyDescendance(endPort->getNode());
781 if(destNode == _node)
782 edAddLink(clones[0]->getOutPort(startPort->getName()),
783 clones[1]->getInPort(endPort->getName()));
784 if(destNode == _finalizeNode)
785 edAddLink(clones[0]->getOutPort(startPort->getName()),
786 clones[2]->getInPort(endPort->getName()));
787 }
788 }
789
790 DEBTRACE("Placing nodes...")
791 vector<Container *> conts=treeToDup.getAllContainers();
792
793 //iterate on all containers
794 for(vector<Container *>::iterator iterCt=conts.begin();iterCt!=conts.end();iterCt++)
795 {
796 DEBTRACE("Container " << ((*iterCt)?(*iterCt)->getName():"NULL"))
797 vector<ComponentInstance *> comps=treeToDup.getComponentsLinkedToContainer(*iterCt);
798 Container *contCloned=0;
799 if((*iterCt))
800 contCloned=(*iterCt)->clone();
801
802 //iterate on all component instances linked to the container
803 for(vector<ComponentInstance *>::iterator iterCp=comps.begin();iterCp!=comps.end();iterCp++)
804 {
805 DEBTRACE("Component " << (*iterCp)->getCompoName())
806 vector<Task *> tasks=treeToDup.getTasksLinkedToComponent(*iterCp);
807 ComponentInstance *curCloned=(*iterCp)->clone();
808 DEBTRACE("Assign container " << (*iterCp)->getCompoName())
809 curCloned->setContainer(contCloned);
810 for(vector<Task *>::iterator iterT=tasks.begin();iterT!=tasks.end();iterT++)
811 {
812 DEBTRACE("Task " << ((ElementaryNode *)(*iterT))->getName())
813 int i = 0;
814 ElementaryNode * origElemNode = NULL;
815 for (i=0 ; i<origNodes.size() ; i++)
816 if (origNodes[i] != NULL)
817 {
818 DEBTRACE("Looking in original node " << i)
819 list<ElementaryNode *>::iterator res=find(origElemNodeList[i].begin(),
820 origElemNodeList[i].end(),
821 (ElementaryNode *)(*iterT));
822 if (res != origElemNodeList[i].end()) {
823 origElemNode = *res;
824 break;
825 }
826 }
827
828 YASSERT(origElemNode != NULL)
829 DEBTRACE("Found task in node " << i)
830 ServiceNode * nodeC = NULL;
831 if (origNodes[i] == origElemNode)
832 nodeC = (ServiceNode *)clones[i];
833 else
834 {
835 string childName = ((ComposedNode *)origNodes[i])->getChildName(origElemNode);
836 nodeC = (ServiceNode *)clones[i]->getChildByName(childName);
837 }
838 DEBTRACE("Assign component: " << (*iterCp)->getCompoName() << "," << nodeC->getName())
839 nodeC->setComponent(curCloned);
840 }
841 curCloned->decrRef();
842 }
843
844 // iterate on all tasks linked to the container
845 vector<Task *> tasks=treeToDup.getTasksLinkedToContainer(*iterCt);
846 for(vector<Task *>::iterator iterT=tasks.begin();iterT!=tasks.end();iterT++)
847 {
848 DEBTRACE("Task " << ((ElementaryNode *)(*iterT))->getName())
849 int i = 0;
850 ElementaryNode * origElemNode = NULL;
851 for (i=0 ; i<origNodes.size() ; i++)
852 if (origNodes[i] != NULL)
853 {
854 DEBTRACE("Looking in original node " << i)
855 list<ElementaryNode *>::iterator res=find(origElemNodeList[i].begin(),
856 origElemNodeList[i].end(),
857 (ElementaryNode *)(*iterT));
858 if (res != origElemNodeList[i].end())
859 {
860 origElemNode = *res;
861 break;
862 }
863 }
864 YASSERT(origElemNode != NULL)
865 DEBTRACE("Found task in node " << i)
866 InlineFuncNode * nodeC = NULL;
867 if (origNodes[i] == origElemNode)
868 {
869 nodeC = (InlineFuncNode *)clones[i];
870 }
871 else
872 {
873 string childName = ((ComposedNode *)origNodes[i])->getChildName(origElemNode);
874 nodeC = (InlineFuncNode *)clones[i]->getChildByName(childName);
875 }
876 DEBTRACE("Assign container " << nodeC->getName() << "," << contCloned->getName())
877 nodeC->setContainer(contCloned);
878 }
879
880 // ended with current container
881 if(contCloned)
882 contCloned->decrRef();
883 }
884
886 return clones;
887}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::list< ElementaryNode * > getRecursiveConstituents() const
std::vector< Node * > cloneAndPlaceNodesCoherently(const std::vector< Node * > &origNodes)
OutPort * getOutPort(const std::string &name) const
Definition: InlineNode.hxx:93
virtual std::vector< std::pair< OutPort *, InPort * > > getSetOfLinksLeavingCurrentScope() const =0
virtual Node * simpleClone(ComposedNode *father, bool editionOnly=true) const =0
References _finalizeNode, _initNode, _node, YACS::ENGINE::DeploymentTree::appendTask(), YACS::ENGINE::ComponentInstance::clone(), YACS::ENGINE::Container::clone(), DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::DeploymentTree::getAllContainers(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::DeploymentTree::getComponentsLinkedToContainer(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Container::getName(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), getOutPort(), YACS::ENGINE::Node::getSetOfLinksLeavingCurrentScope(), YACS::ENGINE::DeploymentTree::getTasksLinkedToComponent(), YACS::ENGINE::DeploymentTree::getTasksLinkedToContainer(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::ComposedNode::isInMyDescendance(), YACS::ENGINE::ServiceNode::setComponent(), YACS::ENGINE::ComponentInstance::setContainer(), YACS::ENGINE::InlineNode::setContainer(), YACS::ENGINE::Node::simpleClone(), and YASSERT.
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), and YACS::ENGINE::OptimizerLoop::exUpdateState().
◆ edAddChild()
bool DynParaLoop::edAddChild ( Node *  DISOWNnode)
Definition at line 257 of file DynParaLoop.cxx.
258{
259 return edSetNode(DISOWNnode);
260}
Node * edSetNode(Node *DISOWNnode)
Definition: DynParaLoop.cxx:74
References edSetNode().
◆ edAddDFLink()
bool DynParaLoop::edAddDFLink ( OutPort *  start,
InPort *  end
Connect the ports with a data link (edAddLink) In a Loop don't add control flow link : use this only to add data back links
start: the OutPort to connect
end: the InPort to connect
true if a new link has been created, false otherwise.
Definition at line 141 of file DynParaLoop.cxx.
142{
143 return edAddLink(start,end);
144}
References YACS::ENGINE::ComposedNode::edAddLink().
◆ edGetDirectDescendants()
std::list< Node * > DynParaLoop::edGetDirectDescendants ( ) const
Definition at line 262 of file DynParaLoop.cxx.
263{
264 list<Node *> ret;
265 if(_node)
266 ret.push_back(_node);
267 if(_initNode)
268 ret.push_back(_initNode);
269 if(_finalizeNode)
270 ret.push_back(_finalizeNode);
271 return ret;
272}
Referenced by getErrorReport(), and YACS::ENGINE::ForEachLoopGen::getProgressWeight().
◆ edGetNbOfBranchesPort()
◆ edGetSamplePort()
◆ edRemoveChild()
void DynParaLoop::edRemoveChild ( Node *  node)
Definition at line 245 of file DynParaLoop.cxx.
246{
248 if(node==_node)
249 _node=0;
250 if(node==_initNode)
251 _initNode=0;
252 if(node==_finalizeNode)
254 modified();
255}
References _finalizeNode, _initNode, _node, YACS::ENGINE::ComposedNode::edRemoveChild(), and YACS::ENGINE::Node::modified().
Referenced by YACS::HMI::SubjectForEachLoop::clean().
◆ edRemoveFinalizeNode()
Node * DynParaLoop::edRemoveFinalizeNode ( )
Definition at line 240 of file DynParaLoop.cxx.
241{
243}
Node * removeNode(Node *&nodeToRemove)
References _finalizeNode, and removeNode().
◆ edRemoveInitNode()
Node * DynParaLoop::edRemoveInitNode ( )
Definition at line 235 of file DynParaLoop.cxx.
236{
237 return removeNode(_initNode);
238}
References _initNode, and removeNode().
◆ edRemoveNode()
Node * DynParaLoop::edRemoveNode ( )
Definition at line 218 of file DynParaLoop.cxx.
219{
220 return removeNode(_node);
221}
References _node, and removeNode().
◆ edSetFinalizeNode()
Node * DynParaLoop::edSetFinalizeNode ( Node *  DISOWNnode)
Definition at line 127 of file DynParaLoop.cxx.
128{
130}
Node * checkConsistencyAndSetNode(Node *&nodeToReplace, Node *DISOWNnode)
Definition: DynParaLoop.cxx:80
References _finalizeNode, and checkConsistencyAndSetNode().
Referenced by YACS::dynparalooptypeParser< T >::finalizenode().
◆ edSetInitNode()
Node * DynParaLoop::edSetInitNode ( Node *  DISOWNnode)
Definition at line 122 of file DynParaLoop.cxx.
123{
125}
References _initNode, and checkConsistencyAndSetNode().
Referenced by YACS::dynparalooptypeParser< T >::initnode().
◆ edSetNode()
Node * DynParaLoop::edSetNode ( Node *  DISOWNnode)
Definition at line 74 of file DynParaLoop.cxx.
75{
77}
References _node, and checkConsistencyAndSetNode().
Referenced by edAddChild().
◆ forceMultiplicity()
void DynParaLoop::forceMultiplicity ( unsigned  value)
Implements YACS::ENGINE::Scheduler.
Definition at line 450 of file DynParaLoop.cxx.
451{
452 _nbOfBranches->forceMultiplicity(value);
453}
References _nbOfBranches.
◆ forwardExecStateToOriginalBody()
void DynParaLoop::forwardExecStateToOriginalBody ( Node *  execNode)
Definition at line 663 of file DynParaLoop.cxx.
664{
665 unsigned int id;
666 Node * origNode = NULL;
667 switch (getIdentityOfNotifyerNode(execNode,id))
668 {
669 case INIT_NODE:
670 {
671 origNode = _initNode;
672 break;
673 }
674 case WORK_NODE:
675 {
676 origNode = _node;
677 break;
678 }
679 case FINALIZE_NODE:
680 {
681 origNode = _finalizeNode;
682 break;
683 }
684 default:
685 YASSERT(false)
686 }
687
688 YASSERT(origNode != NULL)
689 origNode->setState(execNode->getState());
690 origNode->setErrorDetails(execNode->getErrorDetails());
691
692 ComposedNode* compNode = dynamic_cast<ComposedNode*>(origNode);
693 ComposedNode* compNodeExe = dynamic_cast<ComposedNode*>(execNode);
694 if (compNode && compNodeExe)
695 {
696 list<Node *> aChldn = compNodeExe->getAllRecursiveConstituents();
697 list<Node *>::iterator iter=aChldn.begin();
698 for(;iter!=aChldn.end();iter++)
699 {
700 Node* node=compNode->getChildByName(compNodeExe->getChildName(*iter));
701 node->setState((*iter)->getState());
702 node->setErrorDetails((*iter)->getErrorDetails());
703 }
704 }
705}
virtual std::list< Node * > getAllRecursiveConstituents()
TypeOfNode getIdentityOfNotifyerNode(const Node *node, unsigned &id)
virtual void setErrorDetails(const std::string &error)
Definition: Node.hxx:191
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
virtual std::string getErrorDetails() const
Definition: Node.hxx:190
virtual YACS::StatesForNode getState() const
Definition: Node.hxx:118
References _finalizeNode, _initNode, _node, FINALIZE_NODE, YACS::ENGINE::ComposedNode::getAllRecursiveConstituents(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getErrorDetails(), getIdentityOfNotifyerNode(), YACS::ENGINE::Node::getState(), INIT_NODE, YACS::ENGINE::Node::setErrorDetails(), YACS::ENGINE::Node::setState(), WORK_NODE, and YASSERT.
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), and updateStateOnFailedEventFrom().
◆ getBranchIDOfNode()
int DynParaLoop::getBranchIDOfNode ( Node *  node) const
DynParaLoop creates at runtime (exupdateState) clone of nodes. One clone per branch. This method returns the id of the branch given the node node. If node is not a dynamically created node in this -1 is returned.
Definition at line 161 of file DynParaLoop.cxx.
162{
163 if(_node)
164 {
165 for(std::vector<Node *>::const_iterator it=_execNodes.begin();it!=_execNodes.end();it++)
166 if(node==*it)
167 return std::distance(_execNodes.begin(),it);
168 }
169 if(_finalizeNode)
170 {
171 for(std::vector<Node *>::const_iterator it=_execFinalizeNodes.begin();it!=_execFinalizeNodes.end();it++)
172 if(node==*it)
173 return std::distance(_execFinalizeNodes.begin(),it);
174 }
175 if(_initNode)
176 {
177 for(std::vector<Node *>::const_iterator it=_execInitNodes.begin();it!=_execInitNodes.end();it++)
178 if(node==*it)
179 return std::distance(_execInitNodes.begin(),it);
180 }
181 return -1;
182}
def distance(node, new_node)
Definition: graph.py:275
References _execFinalizeNodes, _execInitNodes, _execNodes, _finalizeNode, _initNode, _node, and gui.graph::distance().
Referenced by YACS::ENGINE::Node::getDPLScopeInfo().
◆ getChildByNameExec()
Node * DynParaLoop::getChildByNameExec ( const std::string &  name,
unsigned  id
Definition at line 319 of file DynParaLoop.cxx.
320{
322 throw Exception("ForEachLoop::getChildByNameExec : invalid id - too large compared with dynamically created branches.");
323 if (_node && name == _node->getName())
324 return _execNodes[id];
325 if (_initNode && name == _initNode->getName())
326 return _execInitNodes[id];
327 if (_finalizeNode && name == _finalizeNode->getName())
328 return _execFinalizeNodes[id];
329 std::string what("node "); what+= name ; what+=" is not a child of DynParaLoop node "; what += getName();
330 throw Exception(what);
331}
unsigned getNumberOfBranchesCreatedDyn() const
References _execFinalizeNodes, _execInitNodes, _execNodes, _finalizeNode, _initNode, _node, YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), and getNumberOfBranchesCreatedDyn().
◆ getChildByShortName()
Node * DynParaLoop::getChildByShortName ( const std::string &  name) const
Definition at line 307 of file DynParaLoop.cxx.
308{
309 if (_node && name == _node->getName())
310 return _node;
311 if (_initNode && name == _initNode->getName())
312 return _initNode;
313 if (_finalizeNode && name == _finalizeNode->getName())
314 return _finalizeNode;
315 std::string what("node "); what+= name ; what+=" is not a child of DynParaLoop node "; what += getName();
316 throw Exception(what);
317}
References _finalizeNode, _initNode, _node, YACS::ENGINE::ComposedNode::getName(), and YACS::ENGINE::Node::getName().
Referenced by YACS::ENGINE::ForEachLoopGen::getChildByShortName().
◆ getDynInputPortByAbsName()
InputPort * DynParaLoop::getDynInputPortByAbsName ( int  branchNb,
: For a given name 'name' of port in absolute form from this, returns the corresponding InputPort instance of the port for the branch # 'branchNb'. The port can be part of _node or _initNode if it exists (if 'initNodeAdmitted' is true). WARNING : no check performed on 'branchNb' value to see if it is compatible with size of '_execNodes'. This method is called to dispatch value on each InputPort linked to this->._splitterNode._splittedPort
Definition at line 559 of file DynParaLoop.cxx.
560{
561 string portName, nodeName;
562 splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,true);
563 Node *staticChild = getChildByName(nodeName);
564 Node *desc=isInMyDescendance(staticChild);
565 if(desc==_node)
566 {
567 splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,false);
568 return _execNodes[branchNb]->getInputPort(portName);
569 }
570 else if(desc==_initNode)
571 if(initNodeAdmitted)
572 {
573 splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,false);
574 return _execInitNodes[branchNb]->getInputPort(portName);
575 }
576 return 0;
577}
static bool splitNamesBySep(const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
static const char SEP_CHAR_IN_PORT[]
Definition: Node.hxx:94
References _execInitNodes, _execNodes, _initNode, _node, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComposedNode::isInMyDescendance(), YACS::ENGINE::Node::SEP_CHAR_IN_PORT, and YACS::ENGINE::ComposedNode::splitNamesBySep().
Referenced by prepareInputsFromOutOfScope(), and putValueOnBranch().
◆ getErrorReport()
std::string DynParaLoop::getErrorReport ( )
returns a string that contains an error report if the node is in error
Definition at line 587 of file DynParaLoop.cxx.
588{
589 DEBTRACE("DynParaLoop::getErrorReport: " << getName() << " " << _state);
590 YACS::StatesForNode effectiveState=getEffectiveState();
591
592 if(effectiveState != YACS::INVALID && effectiveState != YACS::ERROR && effectiveState != YACS::FAILED)
593 return "";
594
595 std::string report="<error node= " + getName();
596 switch(effectiveState)
597 {
598 case YACS::INVALID:
599 report=report+" state= INVALID";
600 break;
601 case YACS::ERROR:
602 report=report+" state= ERROR";
603 break;
604 case YACS::FAILED:
605 report=report+" state= FAILED";
606 break;
607 default:
608 break;
609 }
610 report=report + ">\n" ;
611 if(_errorDetails != "")
612 report=report+_errorDetails+"\n";
613
614 if(_execNodes.empty())
615 {
616 // edition node
617 list<Node *> constituents=edGetDirectDescendants();
618 for(list<Node *>::iterator iter=constituents.begin(); iter!=constituents.end(); iter++)
619 {
620 std::string rep=(*iter)->getErrorReport();
621 if(rep != "")
622 {
623 report=report+rep+"\n";
624 }
625 }
626 }
627 else
628 {
629 // execution nodes
630 for(vector<Node *>::iterator iter=_execInitNodes.begin();iter!=_execInitNodes.end();iter++)
631 {
632 std::string rep=(*iter)->getErrorReport();
633 if(rep != "")
634 {
635 report=report+rep+"\n";
636 }
637 }
638 for(vector<Node *>::iterator iter=_execNodes.begin();iter!=_execNodes.end();iter++)
639 {
640 if(*iter)
641 {
642 std::string rep=(*iter)->getErrorReport();
643 if(rep != "")
644 {
645 report=report+rep+"\n";
646 }
647 }
648 }
649 for(vector<Node *>::iterator iter=_execFinalizeNodes.begin();iter!=_execFinalizeNodes.end();iter++)
650 {
651 std::string rep=(*iter)->getErrorReport();
652 if(rep != "")
653 {
654 report=report+rep+"\n";
655 }
656 }
657 }
658
659 report=report+"</error>";
660 return report;
661}
std::list< Node * > edGetDirectDescendants() const
Definition: Node.hxx:93
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
Definition: Node.cxx:538
Definition: Node.hxx:91
StatesForNode
Definition: define.hxx:34
@ INVALID
Definition: define.hxx:36
@ FAILED
Definition: define.hxx:51
@ ERROR
Definition: define.hxx:52
References YACS::ENGINE::Node::_errorDetails, _execFinalizeNodes, _execInitNodes, _execNodes, YACS::ENGINE::Node::_state, DEBTRACE, edGetDirectDescendants(), YACS::ERROR, YACS::FAILED, YACS::ENGINE::Node::getEffectiveState(), YACS::ENGINE::ComposedNode::getName(), and YACS::INVALID.
◆ getExecNode()
Node * DynParaLoop::getExecNode ( )
◆ getFinalizeNode()
Node * DynParaLoop::getFinalizeNode ( )
◆ getIdentityOfNotifyerNode()
DynParaLoop::TypeOfNode DynParaLoop::getIdentityOfNotifyerNode ( const Node *  node,
unsigned &  id
Definition at line 413 of file DynParaLoop.cxx.
414{
415 vector<Node *>::iterator iter;
416 id=0;
417 for (iter=_execNodes.begin() ; iter!=_execNodes.end() ; iter++,id++)
418 if (*iter==node)
419 return WORK_NODE;
420 id=0;
421 for (iter=_execInitNodes.begin() ; iter!=_execInitNodes.end() ; iter++,id++)
422 if (*iter==node)
423 return INIT_NODE;
424 id=0;
425 for (iter=_execFinalizeNodes.begin() ; iter!=_execFinalizeNodes.end() ; iter++,id++)
426 if (*iter==node)
427 return FINALIZE_NODE;
428 throw Exception("DynParaLoop::getIdentityOfNotifyerNode: unrecognized node !");
429}
References _execFinalizeNodes, _execInitNodes, _execNodes, FINALIZE_NODE, INIT_NODE, and WORK_NODE.
Referenced by forwardExecStateToOriginalBody(), updateStateOnFailedEventFrom(), YACS::ENGINE::ForEachLoopGen::updateStateOnFailedEventFrom(), YACS::ENGINE::ForEachLoopGen::updateStateOnFinishedEventFrom(), and YACS::ENGINE::OptimizerLoop::updateStateOnFinishedEventFrom().
◆ getInitNode()
Node * DynParaLoop::getInitNode ( )
◆ getInputPort()
InputPort * DynParaLoop::getInputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getOutputPort, this method is NOT recursive and so the leaf of type ElementaryNode aggregating this InputPort is directly invoked.
Definition at line 283 of file DynParaLoop.cxx.
284{
285 if(_nbOfBranches->isMyName(name))
286 return _nbOfBranches->getPort();
287 return ComposedNode::getInputPort(name);
288}
InputPort * getInputPort(const std::string &name) const
References _nbOfBranches, and YACS::ENGINE::ComposedNode::getInputPort().
Referenced by YACS::ENGINE::ForEachLoopGen::getInputPort(), and YACS::ENGINE::OptimizerLoop::getInputPort().
◆ getLocalInputPorts()
std::list< InputPort * > DynParaLoop::getLocalInputPorts ( ) const
Definition at line 290 of file DynParaLoop.cxx.
291{
292 list<InputPort *> ret=ComposedNode::getLocalInputPorts();
293 InputPort *port(_nbOfBranches->getPort());
294 if(port)
295 ret.push_back(port);
296 return ret;
297}
std::list< InputPort * > getLocalInputPorts() const
Base class for Input Ports.
Definition: InputPort.hxx:44
References _nbOfBranches, and YACS::ENGINE::ComposedNode::getLocalInputPorts().
Referenced by YACS::ENGINE::ForEachLoopGen::getLocalInputPorts(), YACS::ENGINE::OptimizerLoop::getLocalInputPorts(), and prepareInputsFromOutOfScope().
◆ getLocalOutputPorts()
std::list< OutputPort * > DynParaLoop::getLocalOutputPorts ( ) const
Definition at line 191 of file DynParaLoop.cxx.
192{
193 list<OutputPort *> ret=ComposedNode::getLocalOutputPorts();
194 ret.push_back((OutputPort *)&_splittedPort);
195 return ret;
196}
std::list< OutputPort * > getLocalOutputPorts() const
References _splittedPort, and YACS::ENGINE::ComposedNode::getLocalOutputPorts().
Referenced by YACS::ENGINE::OptimizerLoop::getLocalOutputPorts().
◆ getMaxLevelOfParallelism()
int DynParaLoop::getMaxLevelOfParallelism ( ) const
Definition at line 909 of file DynParaLoop.cxx.
910{
911 return _nbOfBranches->getIntValue() * _node->getMaxLevelOfParallelism();
912}
virtual int getMaxLevelOfParallelism() const =0
References _nbOfBranches, _node, and YACS::ENGINE::Node::getMaxLevelOfParallelism().
◆ getNodes()
std::vector< Node * > YACS::ENGINE::DynParaLoop::getNodes ( ) const
Definition at line 105 of file DynParaLoop.hxx.
105{ return _execNodes; } // need to use in GUI part for adding observers for clone nodes
◆ getNumberOfBranchesCreatedDyn()
unsigned DynParaLoop::getNumberOfBranchesCreatedDyn ( ) const
Definition at line 299 of file DynParaLoop.cxx.
300{
301 if(_execNodes.empty())
302 throw Exception("ForEachLoop::getNumberOfBranches : No branches created dynamically ! - ForEachLoop needs to run or to be runned to call getNumberOfBranches");
303 else
304 return _execNodes.size();
305}
References _execNodes.
Referenced by getChildByNameExec().
◆ getNumberOfEltsConsumed()
unsigned YACS::ENGINE::DynParaLoop::getNumberOfEltsConsumed ( ) const
Definition at line 86 of file DynParaLoop.hxx.
86{ return _nbOfEltConsumed; }
◆ getNumberOfInputPorts()
int DynParaLoop::getNumberOfInputPorts ( ) const
◆ getNumberOfOutputPorts()
int DynParaLoop::getNumberOfOutputPorts ( ) const
◆ getOutPort()
OutPort * DynParaLoop::getOutPort ( const std::string &  name) const
: Contrary to getOutputPort method, this method returns the output port at highest level, possible. That is to say in some ComposedNode, like ForEachLoop or Switch, an outport inside 'this' is seen differently than the true outport.
Definition at line 198 of file DynParaLoop.cxx.
199{
201 return (OutPort *)&_splittedPort;
202 return ComposedNode::getOutPort(name);
203}
static const char OLD_NAME_OF_SPLITTED_SEQ_OUT[]
Definition: DynParaLoop.hxx:68
References _splittedPort, YACS::ENGINE::ComposedNode::getOutPort(), NAME_OF_SPLITTED_SEQ_OUT, and OLD_NAME_OF_SPLITTED_SEQ_OUT.
Referenced by cloneAndPlaceNodesCoherently(), YACS::ENGINE::ForEachLoopGen::getOutPort(), and YACS::ENGINE::OptimizerLoop::getOutPort().
◆ getOutputPort()
OutputPort * DynParaLoop::getOutputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getInputPort, this method is recursive and go down hierarchy step by step to complete its work.
Definition at line 206 of file DynParaLoop.cxx.
207{
209 return (OutputPort *)&_splittedPort;
210 return ComposedNode::getOutputPort(name);
211}
OutputPort * getOutputPort(const std::string &name) const
References _splittedPort, YACS::ENGINE::ComposedNode::getOutputPort(), NAME_OF_SPLITTED_SEQ_OUT, and OLD_NAME_OF_SPLITTED_SEQ_OUT.
Referenced by YACS::ENGINE::ForEachLoopGen::getOutputPort(), and YACS::ENGINE::OptimizerLoop::getOutputPort().
◆ getSetOfInputPort()
std::list< InputPort * > DynParaLoop::getSetOfInputPort ( ) const
Definition at line 274 of file DynParaLoop.cxx.
275{
276 list<InputPort *> ret=ComposedNode::getSetOfInputPort();
277 InputPort *port(_nbOfBranches->getPort());
278 if(port)
279 ret.push_back(port);
280 return ret;
281}
References _nbOfBranches, and YACS::ENGINE::ComposedNode::getSetOfInputPort().
Referenced by YACS::ENGINE::ForEachLoopGen::getSetOfInputPort(), and YACS::ENGINE::OptimizerLoop::getSetOfInputPort().
◆ getSetOfOutputPort()
std::list< OutputPort * > DynParaLoop::getSetOfOutputPort ( ) const
Definition at line 184 of file DynParaLoop.cxx.
185{
186 list<OutputPort *> ret=ComposedNode::getSetOfOutputPort();
187 ret.push_back((OutputPort *)&_splittedPort);
188 return ret;
189}
std::list< OutputPort * > getSetOfOutputPort() const
References _splittedPort, and YACS::ENGINE::ComposedNode::getSetOfOutputPort().
Referenced by YACS::ENGINE::OptimizerLoop::getSetOfOutputPort().
◆ getWeight()
ComplexWeight * DynParaLoop::getWeight ( )
◆ getWeightRegardingDPL()
void YACS::ENGINE::DynParaLoop::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 108 of file DynParaLoop.hxx.
108{weight->addWeight(getWeight());}
ComplexWeight * getWeight()
References YACS::ENGINE::ComplexWeight::addWeight().
◆ init()
void DynParaLoop::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Definition at line 105 of file DynParaLoop.cxx.
106{
107 ComposedNode::init(start);
108 if(!_node)
109 {
110 string what("DynParaLoop::init : no node specified for ForEachLoop with name "); what +=_name;
111 throw Exception(what);
112 }
113 _node->init(start);
114 if (_initNode) _initNode->init(start);
115 if (_finalizeNode) _finalizeNode->init(start);
116 _nbOfBranches->exInit(start);
120}
void init(bool start=true)
virtual void init(bool start=true)
Definition: Node.cxx:102
virtual void exInit()
Definition: OutputPort.cxx:62
References _failedCounter, _finalizeNode, _initNode, YACS::ENGINE::Node::_name, _nbOfBranches, _nbOfEltConsumed, _node, _splittedPort, YACS::ENGINE::OutputPort::exInit(), YACS::ENGINE::ComposedNode::init(), and YACS::ENGINE::Node::init().
Referenced by YACS::ENGINE::ForEachLoopGen::init(), and YACS::ENGINE::OptimizerLoop::init().
◆ isLoop()
bool YACS::ENGINE::DynParaLoop::isLoop ( ) const
inlineoverridevirtual
Definition at line 97 of file DynParaLoop.hxx.
97{ return true; }
◆ isMultiplicitySpecified()
bool DynParaLoop::isMultiplicitySpecified ( unsigned &  value) const
Definition at line 445 of file DynParaLoop.cxx.
446{
447 return _nbOfBranches->isMultiplicitySpecified(value);
448}
◆ isPlacementPredictableB4Run()
bool DynParaLoop::isPlacementPredictableB4Run ( ) const
Definition at line 213 of file DynParaLoop.cxx.
214{
215 return false;
216}
◆ partitionRegardingDPL()
void DynParaLoop::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 914 of file DynParaLoop.cxx.
915{
917 zeMap[this]=pd2;
918 if(_node)
919 _node->partitionRegardingDPL(pd,zeMap);
920}
virtual void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)=0
virtual PartDefinition * copy() const =0
References _node, YACS::ENGINE::PartDefinition::copy(), and YACS::ENGINE::Node::partitionRegardingDPL().
◆ prepareInputsFromOutOfScope()
void DynParaLoop::prepareInputsFromOutOfScope ( int  branchNb)
This method applies on newly cloned on exec nodes (_execNodes/_execInitNodes) the setting of input ports coming from outside of 'this'
Definition at line 351 of file DynParaLoop.cxx.
352{
353 set< InPort * > portsToSetVals=getAllInPortsComingFromOutsideOfCurrentScope();
354
355 // This tweak is to fix problems with nested dynamic loops where links are not cloned properly
356 list<InPort *> temp = getSetOfInPort();
357 for(list<InPort *>::iterator iter2=temp.begin();iter2!=temp.end();iter2++)
358 {
359 if ((*iter2)->edSetOutPort().size() == 1 && *(*iter2)->edSetOutPort().begin() == NULL)
360 {
361 portsToSetVals.insert(*iter2);
362 }
363 }
364
365 // local input ports are not candidates for dynamically duplicated inport.
366 list<InputPort *> localPorts = getLocalInputPorts();
367 for(list<InputPort *>::iterator iter = localPorts.begin() ; iter != localPorts.end() ; iter++)
368 portsToSetVals.erase(*iter);
369 for(set< InPort * >::iterator iter=portsToSetVals.begin();iter!=portsToSetVals.end();iter++)
370 {
371 InputPort *curPortCasted=(InputPort *) *iter;//Cast granted by ForEachLoop::buildDelegateOf(InPort)
372 void *val=curPortCasted->get();
373 InputPort *portToSet=getDynInputPortByAbsName(branchNb,getInPortName(*iter),true);
374 if(portToSet)//portToSet==0 in case of portToSet==_splitterNode._dataPortToDispatch of ForEach
375 {
376 portToSet->put((const void *)val);
377 portToSet->edNotifyReferencedBy(nullptr,false);//This is to indicate that somewhere somebody deals with this inputport
378 //even if no direct physical link exists. This exclusively for _execNodes[branchNb]::init on the next turn of loop.
379 //false is put as 2nd parameter to tell to portToSet, do not touch to the data in case of squeezeMemory.
380 }
381 }
382}
std::string getInPortName(const InPort *) const
std::set< InPort * > getAllInPortsComingFromOutsideOfCurrentScope() const
InputPort * getDynInputPortByAbsName(int branchNb, const std::string &name, bool initNodeAdmitted)
virtual void edNotifyReferencedBy(OutPort *fromPort, bool isLoopProof=true)
Definition: InPort.cxx:93
virtual void * get() const =0
std::list< InPort * > getSetOfInPort() const
Definition: Node.cxx:289
References YACS::ENGINE::InPort::edNotifyReferencedBy(), YACS::ENGINE::InputPort::get(), YACS::ENGINE::ComposedNode::getAllInPortsComingFromOutsideOfCurrentScope(), getDynInputPortByAbsName(), YACS::ENGINE::ComposedNode::getInPortName(), getLocalInputPorts(), YACS::ENGINE::Node::getSetOfInPort(), and YACS::ENGINE::InputPort::put().
◆ putValueOnBranch()
void DynParaLoop::putValueOnBranch ( Any *  val,
unsigned  branchId,
bool  first
Definition at line 384 of file DynParaLoop.cxx.
385{
386 bool isDispatched = false;
387 set<InPort *> inPrtLkdWthSplttdPrt=_splittedPort.edSetInPort();
388 for(set<InPort *>::iterator iter=inPrtLkdWthSplttdPrt.begin();iter!=inPrtLkdWthSplttdPrt.end();iter++)
389 {
390 std::string portNameOnCurPrt=getPortName(*iter);
391 InputPort *portOnGivenBranch=getDynInputPortByAbsName(branchId,portNameOnCurPrt,first);//Cast granted because impossible to have cross protocol with _splittedPort
392 //see OptimizerLoop::buildDelegateOf
393 if(portOnGivenBranch)
394 {
395 if(first)
396 portOnGivenBranch->edNotifyReferencedBy(0);
397 InputPort *traducer=getRuntime()->adapt(portOnGivenBranch,
399 traducer->put((const void *)val);
400 isDispatched = true;
401 if(traducer!=portOnGivenBranch)
402 delete traducer;
403 }
404 }
405 if ( isDispatched )
406 {
407 Any *tmp=val->clone();
409 tmp->decrRef();
410 }
411}
virtual void setValue(Any *data)
store the current dispatched value
Definition: Any.hxx:79
virtual Any * clone() const =0
TypeCode * edGetType() const
Definition: DataPort.hxx:53
static const char RUNTIME_ENGINE_INTERACTION_IMPL_NAME[]
Definition: Runtime.hxx:135
virtual InputPort * adapt(InputPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
Definition: Runtime.cxx:61
References _splittedPort, YACS::ENGINE::Runtime::adapt(), YACS::ENGINE::Any::clone(), YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::InPort::edNotifyReferencedBy(), YACS::ENGINE::OutputPort::edSetInPort(), getDynInputPortByAbsName(), YACS::ENGINE::ComposedNode::getPortName(), YACS::ENGINE::getRuntime(), YACS::ENGINE::InputPort::put(), YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME, and YACS::ENGINE::AnyOutputPort::setValue().
Referenced by YACS::ENGINE::OptimizerLoop::launchMaxOfSamples(), and YACS::ENGINE::SplitterNode::putSplittedValueOnRankTo().
◆ removeNode()
Node * DynParaLoop::removeNode ( Node *&  nodeToRemove)
Definition at line 224 of file DynParaLoop.cxx.
225{
226 if (!nodeToRemove)
227 return NULL;
228 ComposedNode::edRemoveChild(nodeToRemove);
229 Node * ret = nodeToRemove;
230 nodeToRemove = NULL;
231 modified();
232 return ret;
233}
References YACS::ENGINE::ComposedNode::edRemoveChild(), and YACS::ENGINE::Node::modified().
Referenced by edRemoveFinalizeNode(), edRemoveInitNode(), and edRemoveNode().
◆ setWeight()
void DynParaLoop::setWeight ( double  loopWeight)
Definition at line 431 of file DynParaLoop.cxx.
432{
433 if(loopWeight<=0.)
434 throw Exception("DynParaLoop::setWeight : invalid input value !");
435 _loopWeight=loopWeight;
436}
References _loopWeight.
Referenced by YACS::optimizerlooptypeParser< T >::postAttr().
◆ shutdown()
void DynParaLoop::shutdown ( int  level)
This method should be called when a Proc is finished and must be deleted from the YACS server
Definition at line 922 of file DynParaLoop.cxx.
923{
924 if(level==0)return;
925 if(!_node) return;
926
927 std::vector<Node *>::iterator iter;
928 for (iter=_execNodes.begin() ; iter!=_execNodes.end() ; iter++)
929 (*iter)->shutdown(level);
930 for (iter=_execInitNodes.begin() ; iter!=_execInitNodes.end() ; iter++)
931 (*iter)->shutdown(level);
932 for (iter=_execFinalizeNodes.begin() ; iter!=_execFinalizeNodes.end() ; iter++)
933 (*iter)->shutdown(level);
934}
References _execFinalizeNodes, _execInitNodes, _execNodes, and _node.
◆ updateStateOnFailedEventFrom()
YACS::Event DynParaLoop::updateStateOnFailedEventFrom ( Node *  node,
const Executor *  execInst
Update the current state and return the change state
node: the child node that has failed
the state change
Definition at line 714 of file DynParaLoop.cxx.
715{
716 DEBTRACE("DynParaLoop::updateStateOnFailedEventFrom " << node->getName());
719 unsigned int id;
720 switch (getIdentityOfNotifyerNode(node,id))
721 {
722 case INIT_NODE:
723 {
726 break;
727 }
728 case WORK_NODE:
729 {
731 break;
732 }
733 }
734 return YACS::ABORT;
735}
virtual void forwardExecStateToOriginalBody(Node *execNode)
@ ABORT
Definition: define.hxx:60
References _finalizeNode, _node, YACS::ABORT, DEBTRACE, YACS::FAILED, forwardExecStateToOriginalBody(), getIdentityOfNotifyerNode(), YACS::ENGINE::Node::getName(), INIT_NODE, YACS::ENGINE::Node::setState(), and WORK_NODE.
Referenced by YACS::ENGINE::ForEachLoopGen::updateStateOnFailedEventFrom(), and YACS::ENGINE::OptimizerLoop::updateStateOnFailedEventFrom().
◆ _execFinalizeNodes
◆ _execIds
◆ _execInitNodes
◆ _execNodes
◆ _failedCounter
◆ _finalizeNode
◆ _initializingCounter
◆ _initNode
◆ _loopWeight
double YACS::ENGINE::DynParaLoop::_loopWeight
Definition at line 65 of file DynParaLoop.hxx.
Referenced by getWeight(), and setWeight().
◆ _nbOfBranches
◆ _nbOfEltConsumed
◆ _node
◆ _splittedPort
◆ _unfinishedCounter
◆ _weight
ComplexWeight YACS::ENGINE::DynParaLoop::_weight
Definition at line 64 of file DynParaLoop.hxx.
Referenced by DynParaLoop(), and getWeight().
◆ NAME_OF_SPLITTED_SEQ_OUT
const char DynParaLoop::NAME_OF_SPLITTED_SEQ_OUT = "evalSamples"
staticprotected
◆ OLD_NAME_OF_SPLITTED_SEQ_OUT
const char DynParaLoop::OLD_NAME_OF_SPLITTED_SEQ_OUT = "SmplPrt"
staticprotected
Definition at line 68 of file DynParaLoop.hxx.
Referenced by getOutPort(), and getOutputPort().
