OutputPort.hxx
20#ifndef __OUTPUTPORT_HXX__
21#define __OUTPUTPORT_HXX__
24#include "OutPort.hxx"
25#include "DataFlowPort.hxx"
27
28#include <set>
30namespace YACS
31{
32 namespace ENGINE
33 {
34 class InPort;
35 class Runtime;
36 class InputPort;
37 class InPropertyPort;
38 class OptimizerLoop;
39 class ElementaryNode;
40 class CollectorSwOutputPort;
41
43 {
44 friend class CollectorSwOutputPort; // for conect
45 friend class ElementaryNode; // for disconnect...
46 friend class OptimizerLoop; // for interceptors
47 friend class InputPort;
48 friend class Runtime; // for port creation
49 friend class ForLoop; // for port creation
50 public:
51 virtual ~OutputPort();
52 std::set<InPort *> edSetInPort() const;
53 bool isAlreadyLinkedWith(InPort *withp) const;
54 bool isAlreadyInSet(InputPort *inputPort) const;
55 bool isConnected() const;
56 std::string getNameOfTypeOfCurrentInstance() const;
57 int removeInPort(InPort *inPort, bool forward) ;
58 virtual bool edAddInputPort(InputPort *phyPort) ;
59 virtual bool edAddInPropertyPort(InPropertyPort *phyPort) ;
60 virtual int edRemoveInputPort(InputPort *inputPort, bool forward) ;
61 bool addInPort(InPort *inPort) ;
62 void edRemoveAllLinksLinkedWithMe() ;//entry point for forward port deletion
63 virtual void exInit();
64 virtual void checkBasicConsistency() const ;
65 virtual OutputPort *clone(Node *newHelder) const = 0;
66 virtual std::string dump();
67
68 virtual void put(const void *data);
69 virtual std::string typeName() {return "YACS__ENGINE__OutputPort";}
70
71 protected:
72 OutputPort(const OutputPort& other, Node *newHelder);
73 OutputPort(const std::string& name, Node *node, TypeCode* type);
74 protected:
75 const std::set<InputPort *>& getSetOfPhyLinks() const;
76 protected:
77 std::set<InputPort *> _setOfInputPort;//Key is for physical Data link
78 public:
79 static const char NAME[];
80 };
81 }
82}
83
84#endif
#define YACSLIBENGINE_EXPORT
Class for for loop node.
Definition: ForLoop.hxx:33
class for Input Property Ports
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
Definition: OutputPort.hxx:69
virtual OutputPort * clone(Node *newHelder) const =0
std::set< InputPort * > _setOfInputPort
Definition: OutputPort.hxx:77
Definition: TypeCode.hxx:68
