ForLoop.hxx
20#ifndef __FORLOOP_HXX__
21#define __FORLOOP_HXX__
24#include "AnyInputPort.hxx"
25#include "AnyOutputPort.hxx"
26#include "Loop.hxx"
27
28namespace YACS
29{
30 namespace ENGINE
31 {
33 {
34 protected:
35 static const char NAME_OF_INDEX[];
36 static const char NAME_OF_NSTEPS_NUMBER[];
39 public:
40 ForLoop(const ForLoop& other, ComposedNode *father, bool editionOnly);
41 ForLoop(const std::string& name);
42 void exUpdateState();
43 void exUpdateProgress();
44 void init(bool start=true);
45 InputPort *edGetNbOfTimesInputPort() { return &_nbOfTimesPort; }
46 Node *simpleClone(ComposedNode *father, bool editionOnly=true) const;
47 InputPort* getInputPort(const std::string& name) const ;
48 OutPort *getOutPort(const std::string& name) const ;
49 OutputPort *getOutputPort(const std::string& name) const ;
50 std::list<InputPort *> getLocalInputPorts() const;
51 std::list<OutputPort *> getLocalOutputPorts() const;
52 std::list<OutputPort *> getSetOfOutputPort() const;
53 virtual void accept(Visitor *visitor);
54 InputPort *getDecisionPort() const { return (InputPort *)&_nbOfTimesPort; }
55 OutputPort *edGetIndexPort() { return &_indexPort; }
56 virtual std::string typeName() {return "YACS__ENGINE__ForLoop";}
57 std::string getProgress() const;
58 std::list<ProgressWeight> getProgressWeight() const;
59 int getNbSteps() const;
60
61 protected:
62 YACS::Event updateStateOnFinishedEventFrom(Node *node);
63 void checkCFLinks(const std::list<OutPort *>& starts, InputPort *end, unsigned char& alreadyFed,
64 bool direction, LinkInfo& info) const;
65 void checkControlDependancy(OutPort *start, InPort *end, bool cross,
66 std::map < ComposedNode *, std::list < OutPort * >, SortHierarc >& fw,
67 std::vector<OutPort *>& fwCross,
68 std::map< ComposedNode *, std::list < OutPort *>, SortHierarc >& bw,
69 LinkInfo& info) const;
70 };
71 }
72}
73
74#endif
#define YACSLIBENGINE_EXPORT
Class for for loop node.
Definition: ForLoop.hxx:33
InputPort * getDecisionPort() const
Returns the port which value is used to take decision about the continuation of the loop.
Definition: ForLoop.hxx:54
Definition: ForLoop.hxx:56
OutputPort * edGetIndexPort()
Definition: ForLoop.hxx:55
InputPort * edGetNbOfTimesInputPort()
Definition: ForLoop.hxx:45
AnyInputPort _nbOfTimesPort
Definition: ForLoop.hxx:37
AnyOutputPort _indexPort
Definition: ForLoop.hxx:38
Base class for Input Ports.
Definition: InputPort.hxx:44
Class that deal with list of semantics links for high level analysis.
Definition: LinkInfo.hxx:83
Base class for loop node.
Definition: Loop.hxx:147
Base class for all nodes.
Definition: Node.hxx:70
Event
Definition: define.hxx:56
