YACS::ENGINE::ForLoop Class Reference
Class for for loop node. More...
#include <ForLoop.hxx>
Inheritance diagram for YACS::ENGINE::ForLoop:
Collaboration diagram for YACS::ENGINE::ForLoop:
 ForLoop (const ForLoop &other, ComposedNode *father, bool editionOnly)
 ForLoop (const std::string &name)
void exUpdateState ()
 Update the state of the for loop. More...
void exUpdateProgress ()
void init (bool start=true)
 Initialize the node. More...
InputPort * edGetNbOfTimesInputPort ()
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
 Get an input port given its name. More...
OutPort * getOutPort (const std::string &name) const
 Get an output port given its name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
InputPort * getDecisionPort () const
 Returns the port which value is used to take decision about the continuation of the loop. More...
OutputPort * edGetIndexPort ()
std::string getProgress () const
int getNbSteps () const
- Public Member Functions inherited from YACS::ENGINE::Loop
 Loop (const Loop &other, ComposedNode *father, bool editionOnly)
 ~Loop ()
int getNbOfTurns () const
Node * edSetNode (Node *DISOWNnode)
virtual bool edAddChild (Node *DISOWNnode)
bool isLoop () const override
Node * edRemoveNode ()
virtual InputPort * getDecisionPort () const =0
 Collect all the child nodes that are ready. More...
void edRemoveChild (Node *node)
 Remove a child node. More...
bool isRepeatedUnpredictablySeveralTimes () const
std::list< Node * > edGetDirectDescendants () const
Node * getChildByShortName (const std::string &name) const
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add control link if necessary. More...
void writeDot (std::ostream &os) const
 Dump the node state to a stream. More...
- Public Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
YACS::Event updateStateOnFinishedEventFrom (Node *node)
 Method used to notify the node that a child node has ended. More...
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
- Protected Member Functions inherited from YACS::ENGINE::Loop
void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void checkNoCyclePassingThrough (Node *node)
- Protected Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
AnyInputPort _nbOfTimesPort
AnyOutputPort _indexPort
- Protected Attributes inherited from YACS::ENGINE::Loop
Node * _node
int _nbOfTurns
FakeNodeForLoop * _nodeForNullTurnOfLoops
std::set< DSToDFForLoop * > _inputsTraducer
std::set< DFToDSForLoop * > _outputsTraducer
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
Static Protected Attributes
static const char NAME_OF_INDEX [] ="index"
static const char NAME_OF_NSTEPS_NUMBER [] ="nsteps"
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
- Static Public Member Functions inherited from YACS::ENGINE::Loop
static TypeCode * MappingDF2DS (TypeCode *type)
static TypeCode * MappingDS2DF (TypeCode *type)
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Static Protected Member Functions inherited from YACS::ENGINE::Loop
static bool isNecessaryToBuildSpecificDelegateDF2DS (const std::list< ComposedNode * > &pointsOfView)
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
This kind of loop makes a fixed number of steps and stops
Definition at line 32 of file ForLoop.hxx.
◆ ForLoop() [1/2]
ForLoop::ForLoop ( const ForLoop &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 50 of file ForLoop.cxx.
50 :Loop(other,father,editionOnly),
52 _indexPort(other._indexPort,this)
53{
54 //Copy Data linking
55 std::vector< std::pair<OutPort *, InPort *> > linksToReproduce=other.getSetOfInternalLinks();
56 std::vector< std::pair<OutPort *, InPort *> >::iterator iter=linksToReproduce.begin();
57 for(;iter!=linksToReproduce.end();++iter)
58 {
59 OutPort* pout = iter->first;
60 InPort* pin = iter->second;
61 edAddLink(getOutPort(other.getPortName(pout)),getInPort(other.getPortName(pin)));
62 }
63}
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks() const
std::string getPortName(const PORT *port) const
bool edAddLink(OutPort *start, InPort *end)
OutPort * getOutPort(const std::string &name) const
Definition: ForLoop.cxx:185
Definition: ForLoop.hxx:37
Definition: ForLoop.hxx:38
InPort * getInPort(const std::string &name) const
Definition: Node.cxx:239
References YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::Node::getInPort(), getOutPort(), YACS::ENGINE::ComposedNode::getPortName(), and YACS::ENGINE::ComposedNode::getSetOfInternalLinks().
Referenced by simpleClone().
◆ ForLoop() [2/2]
ForLoop::ForLoop ( const std::string &  name)
Definition at line 45 of file ForLoop.cxx.
47{
48}
static const char NAME_OF_NSTEPS_NUMBER[]
Definition: ForLoop.hxx:36
static const char NAME_OF_INDEX[]
Definition: ForLoop.hxx:35
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
◆ accept()
void ForLoop::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::Loop.
Definition at line 173 of file ForLoop.cxx.
174{
175 visitor->visitForLoop(this);
176}
virtual void visitForLoop(ForLoop *node)=0
References YACS::ENGINE::Visitor::visitForLoop().
◆ checkCFLinks()
void ForLoop::checkCFLinks ( const std::list< OutPort * > &  starts,
InputPort *  end,
unsigned char &  alreadyFed,
bool  direction,
LinkInfo &  info
startsIf different of 0, must aggregate at leat 1 element.
end:
alreadyFedin/out parameter. Indicates if 'end' ports is already and surely set or fed by an another port.
directionIf true : forward direction else backward direction.
info: informations collectedduring the check
Reimplemented from YACS::ENGINE::ComposedNode.
Definition at line 220 of file ForLoop.cxx.
222{
223 const char what[]="ForLoop::checkCFLinks : internal error.";
224 Node *nodeEnd=end->getNode();
225 if(nodeEnd==this)
226 {//In this case 'end' port is a special port of this (for exemple ForLoop::_nbOfTimesPort)
227 solveObviousOrDelegateCFLinks(starts,end,alreadyFed,direction,info);
228 }
229 else if(isInMyDescendance(nodeEnd)==0)
230 {
231 solveObviousOrDelegateCFLinks(starts,end,alreadyFed,direction,info);
232 }
233 else
234 {//no forwarding here.
235 if(starts.size()!=1)
236 throw Exception(what);
237
238 Node *nodeStart=(*(starts.begin()))->getNode();
239 if(nodeStart==this)
240 {
241 // Link between the loop and the internal node
242 if(*(starts.begin())!=&_indexPort)
243 throw Exception(what);
244 }
245 else
246 {
247 // Link from internal node to internal node
248 if(nodeEnd!=nodeStart)
249 throw Exception(what);
250 }
251
252 if(alreadyFed==FREE_ST)
253 alreadyFed=FED_ST;
254 else if(alreadyFed==FED_ST)
255 {
256 info.pushInfoLink(*(starts.begin()),end,I_USELESS);
257 }
258 }
259}
void solveObviousOrDelegateCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
Node * isInMyDescendance(Node *nodeToTest) const
void pushInfoLink(OutPort *semStart, InPort *end, InfoReason reason)
Definition: LinkInfo.cxx:71
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
References _indexPort, YACS::ENGINE::ComposedNode::FED_ST, YACS::ENGINE::ComposedNode::FREE_ST, YACS::ENGINE::Port::getNode(), YACS::ENGINE::I_USELESS, YACS::ENGINE::ComposedNode::isInMyDescendance(), YACS::ENGINE::LinkInfo::pushInfoLink(), and YACS::ENGINE::ComposedNode::solveObviousOrDelegateCFLinks().
◆ checkControlDependancy()
void ForLoop::checkControlDependancy ( OutPort *  start,
InPort *  end,
bool  cross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  fw,
std::vector< OutPort * > &  fwCross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  bw,
LinkInfo &  info
Implements YACS::ENGINE::ComposedNode.
Definition at line 206 of file ForLoop.cxx.
211{
212 //First testing if start==indexPort. This is the only case possible in theory.
213 if(start != &_indexPort)
214 return StaticDefinedComposedNode::checkControlDependancy(start,end,cross,fw,fwCross,bw,info);
215 if(cross)
216 throw Exception("Internal error occured - cross type link detected on decision port of a loop. Forbidden !");
217 fw[(ComposedNode *)this].push_back(start);
218}
void checkControlDependancy(OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
References _indexPort, and YACS::ENGINE::StaticDefinedComposedNode::checkControlDependancy().
◆ edGetIndexPort()
OutputPort * YACS::ENGINE::ForLoop::edGetIndexPort ( )
Definition at line 55 of file ForLoop.hxx.
55{ return &_indexPort; }
◆ edGetNbOfTimesInputPort()
◆ exUpdateProgress()
void ForLoop::exUpdateProgress ( )
Definition at line 167 of file ForLoop.cxx.
168{
169 // emit notification to all observers registered with the dispatcher on any change of the node's state
170 sendEvent("progress");
171}
virtual void sendEvent(const std::string &event)
Definition: Node.cxx:691
References YACS::ENGINE::Node::sendEvent().
Referenced by init(), and updateStateOnFinishedEventFrom().
◆ exUpdateState()
void ForLoop::exUpdateState ( )
If the inGate port is ready goes to YACS::ACTIVATED state If the steps number is 0, create an special internal node
Reimplemented from YACS::ENGINE::Node.
Definition at line 103 of file ForLoop.cxx.
104{
105 DEBTRACE("ForLoop::exUpdateState " << getName() << " " << _state);
107 return;
108 if(_inGate.exIsReady())
109 {
113 {
115 _nodeForNullTurnOfLoops=new FakeNodeForLoop(this,false,true);
116 }
117 else
118 {
120 {
121 bool normalFinish=getAllOutPortsLeavingCurrentScope().empty();
123 _nodeForNullTurnOfLoops=new FakeNodeForLoop(this,normalFinish);
124 }
125 else if(_nbOfTimesPort.getIntValue()<0)
126 {
129 }
130 else
131 {
134 }
135 }
136 }
137}
std::string getName() const
std::set< OutPort * > getAllOutPortsLeavingCurrentScope() const
bool exIsReady() const
Definition: InGate.cxx:126
friend class FakeNodeForLoop
Definition: Loop.hxx:149
Definition: Loop.hxx:154
InGate _inGate
Definition: Node.hxx:86
virtual void exUpdateState()
Update the node state.
Definition: Node.cxx:206
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
Definition: Node.hxx:91
@ ACTIVATED
Definition: define.hxx:41
@ DISABLED
Definition: define.hxx:50
References YACS::ENGINE::Node::_inGate, _nbOfTimesPort, YACS::ENGINE::Loop::_node, YACS::ENGINE::Loop::_nodeForNullTurnOfLoops, YACS::ENGINE::Node::_state, YACS::ACTIVATED, DEBTRACE, YACS::DISABLED, YACS::ENGINE::InGate::exIsReady(), YACS::ENGINE::Node::exUpdateState(), YACS::ENGINE::Loop::FakeNodeForLoop, YACS::ENGINE::ComposedNode::getAllOutPortsLeavingCurrentScope(), YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::AnyInputPort::isEmpty(), and YACS::ENGINE::Node::setState().
◆ getDecisionPort()
InputPort * YACS::ENGINE::ForLoop::getDecisionPort ( ) const
Implements YACS::ENGINE::Loop.
Definition at line 54 of file ForLoop.hxx.
54{ return (InputPort *)&_nbOfTimesPort; }
friend class InputPort
Definition: Node.hxx:74
◆ getInputPort()
InputPort * ForLoop::getInputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getOutputPort, this method is NOT recursive and so the leaf of type ElementaryNode aggregating this InputPort is directly invoked.
Definition at line 70 of file ForLoop.cxx.
71{
73 return Loop::getInputPort(name);
74
75}
InputPort * getInputPort(const std::string &name) const
Base class for Input Ports.
Definition: InputPort.hxx:44
References _nbOfTimesPort, YACS::ENGINE::ComposedNode::getInputPort(), and NAME_OF_NSTEPS_NUMBER.
◆ getLocalInputPorts()
std::list< InputPort * > ForLoop::getLocalInputPorts ( ) const
Definition at line 178 of file ForLoop.cxx.
179{
180 list<InputPort *> ret;
181 ret.push_back((InputPort *)&_nbOfTimesPort);
182 return ret;
183}
References _nbOfTimesPort.
◆ getLocalOutputPorts()
std::list< OutputPort * > ForLoop::getLocalOutputPorts ( ) const
Definition at line 199 of file ForLoop.cxx.
200{
201 list<OutputPort *> ret;
202 ret.push_back(getOutputPort(NAME_OF_INDEX));
203 return ret;
204}
OutputPort * getOutputPort(const std::string &name) const
Definition: ForLoop.cxx:192
References getOutputPort(), and NAME_OF_INDEX.
◆ getNbSteps()
int ForLoop::getNbSteps ( ) const
Definition at line 269 of file ForLoop.cxx.
270{
271 AnyInputPort* aNbStepsPort = (AnyInputPort*)&_nbOfTimesPort;
272 int nbSteps = 0;
273 if (aNbStepsPort && !aNbStepsPort->isEmpty())
274 nbSteps = aNbStepsPort->getIntValue();
275 return nbSteps;
276}
References _nbOfTimesPort, YACS::ENGINE::AnyInputPort::getIntValue(), and YACS::ENGINE::AnyInputPort::isEmpty().
Referenced by getProgress(), and getProgressWeight().
◆ getOutPort()
OutPort * ForLoop::getOutPort ( const std::string &  name) const
: Contrary to getOutputPort method, this method returns the output port at highest level, possible. That is to say in some ComposedNode, like ForEachLoop or Switch, an outport inside 'this' is seen differently than the true outport.
Definition at line 185 of file ForLoop.cxx.
186{
187 if(name==NAME_OF_INDEX)
188 return (OutPort *)&_indexPort;
189 return Loop::getOutPort(name);
190}
References _indexPort, YACS::ENGINE::ComposedNode::getOutPort(), and NAME_OF_INDEX.
Referenced by ForLoop().
◆ getOutputPort()
OutputPort * ForLoop::getOutputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getInputPort, this method is recursive and go down hierarchy step by step to complete its work.
Definition at line 192 of file ForLoop.cxx.
193{
194 if(name==NAME_OF_INDEX)
195 return (OutputPort *)&_indexPort;
196 return Loop::getOutputPort(name);
197}
References _indexPort, YACS::ENGINE::ComposedNode::getOutputPort(), and NAME_OF_INDEX.
Referenced by getLocalOutputPorts().
◆ getProgress()
std::string ForLoop::getProgress ( ) const
Definition at line 278 of file ForLoop.cxx.
279{
280 std::stringstream aProgress;
281 aProgress << "0";
282 int nbSteps = getNbSteps();
283 if (nbSteps > 0 && _nbOfTurns >= 0)
284 {
285 aProgress.str("");
286 aProgress << _nbOfTurns << "/" << nbSteps;
287 }
288 return aProgress.str();
289}
int getNbSteps() const
Definition: ForLoop.cxx:269
References YACS::ENGINE::Loop::_nbOfTurns, and getNbSteps().
◆ getProgressWeight()
list< ProgressWeight > ForLoop::getProgressWeight ( ) const
Get the progress weight for all elementary nodes.
Only elementary nodes have weight. For each node in the loop, the weight done is multiplied by the number of steps done and the weight total by the number total of steps
Definition at line 297 of file ForLoop.cxx.
298{
299 list<ProgressWeight> ret;
300 list<Node *> setOfNode=edGetDirectDescendants();
301 int nbStepsDone=getNbOfTurns();
302 int nbStepsTotal=getNbSteps();
303 for(list<Node *>::const_iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
304 {
305 list<ProgressWeight> myCurrentSet=(*iter)->getProgressWeight();
306 for(list<ProgressWeight>::iterator iter=myCurrentSet.begin();iter!=myCurrentSet.end();iter++)
307 {
308 (*iter).weightDone=((*iter).weightTotal) * nbStepsDone;
309 (*iter).weightTotal*=nbStepsTotal;
310 }
311 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
312 }
313 return ret;
314}
std::list< Node * > edGetDirectDescendants() const
Definition: Loop.cxx:401
int getNbOfTurns() const
Definition: Loop.hxx:162
References YACS::ENGINE::Loop::edGetDirectDescendants(), YACS::ENGINE::Loop::getNbOfTurns(), and getNbSteps().
◆ getSetOfOutputPort()
std::list< OutputPort * > ForLoop::getSetOfOutputPort ( ) const
Definition at line 261 of file ForLoop.cxx.
262{
263 list<OutputPort *> ret=ComposedNode::getSetOfOutputPort();
264 ret.push_back((OutputPort *)&_indexPort);
265 return ret;
266}
std::list< OutputPort * > getSetOfOutputPort() const
References _indexPort, and YACS::ENGINE::ComposedNode::getSetOfOutputPort().
◆ init()
void ForLoop::init ( bool  start = true)
starta boolean flag to indicate the initialization mode
If start is true, it's a complete initialization (with port values initialization) If start is false, there is no port values initialization
Definition at line 85 of file ForLoop.cxx.
86{
87 DEBTRACE("ForLoop::init " << start);
88 Loop::init(start);
92 _indexPort.put(tmp);
93 tmp->decrRef();
95}
Definition: Any.hxx:79
static AtomAny * New(T val)
Definition: Any.hxx:126
virtual void exInit(bool start)
Definition: InputPort.cxx:63
void init(bool start=true)
Definition: Loop.cxx:319
virtual void exInit()
Definition: OutputPort.cxx:62
References _indexPort, _nbOfTimesPort, YACS::ENGINE::Loop::_nbOfTurns, DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::OutputPort::exInit(), YACS::ENGINE::InputPort::exInit(), exUpdateProgress(), YACS::ENGINE::Loop::init(), YACS::ENGINE::AtomAny::New(), and YACS::ENGINE::AnyOutputPort::put().
◆ simpleClone()
Node * ForLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly = true
Definition at line 65 of file ForLoop.cxx.
66{
67 return new ForLoop(*this,father,editionOnly);
68}
ForLoop(const ForLoop &other, ComposedNode *father, bool editionOnly)
Definition: ForLoop.cxx:50
References ForLoop().
◆ typeName()
virtual std::string YACS::ENGINE::ForLoop::typeName ( )
Definition at line 56 of file ForLoop.hxx.
56{return "YACS__ENGINE__ForLoop";}
◆ updateStateOnFinishedEventFrom()
YACS::Event ForLoop::updateStateOnFinishedEventFrom ( Node *  node)
Update the loop state and return the loop change state
node: the child node that has ended
the loop state change
Definition at line 146 of file ForLoop.cxx.
147{
148 DEBTRACE("ForLoop::updateStateOnFinishedEventFrom " << node->getName());
151 {
153 return YACS::FINISH;
154 }
155 else
156 {
158 _indexPort.put(tmp);
159 tmp->decrRef();
161 _node->init(false);
163 }
164 return YACS::NOEVENT;
165}
Definition: Node.hxx:125
virtual void init(bool start=true)
Definition: Node.cxx:102
@ NOEVENT
Definition: define.hxx:57
@ FINISH
Definition: define.hxx:59
@ DONE
Definition: define.hxx:43
References _indexPort, _nbOfTimesPort, YACS::ENGINE::Loop::_nbOfTurns, YACS::ENGINE::Loop::_node, YACS::ACTIVATED, DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), YACS::DONE, exUpdateProgress(), YACS::ENGINE::Node::exUpdateState(), YACS::FINISH, YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Node::init(), YACS::ENGINE::AtomAny::New(), YACS::NOEVENT, YACS::ENGINE::AnyOutputPort::put(), and YACS::ENGINE::Node::setState().
◆ _indexPort
AnyOutputPort YACS::ENGINE::ForLoop::_indexPort
◆ _nbOfTimesPort
AnyInputPort YACS::ENGINE::ForLoop::_nbOfTimesPort
◆ NAME_OF_INDEX
const char ForLoop::NAME_OF_INDEX ="index"
staticprotected
Definition at line 35 of file ForLoop.hxx.
Referenced by getLocalOutputPorts(), getOutPort(), and getOutputPort().
◆ NAME_OF_NSTEPS_NUMBER
const char ForLoop::NAME_OF_NSTEPS_NUMBER ="nsteps"
staticprotected
Definition at line 36 of file ForLoop.hxx.
Referenced by getInputPort().
