YACS::ENGINE::OutputDataStreamPort Class Reference
#include <OutputDataStreamPort.hxx>
Inheritance diagram for YACS::ENGINE::OutputDataStreamPort:
Collaboration diagram for YACS::ENGINE::OutputDataStreamPort:
 OutputDataStreamPort (const OutputDataStreamPort &other, Node *newHelder)
 OutputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual ~OutputDataStreamPort ()
virtual OutputDataStreamPort * clone (Node *newHelder) const
virtual bool addInPort (InPort *inPort)
virtual bool edAddInputDataStreamPort (InputDataStreamPort *port)
int edRemoveInputDataStreamPort (InputDataStreamPort *inPort, bool forward)
int removeInPort (InPort *inPort, bool forward)
- Public Member Functions inherited from YACS::ENGINE::DataStreamPort
 Set a new value for a property of the port. More...
 Set the values of all properties of the port. More...
 Get the value of a property of the port. More...
std::map< std::string, std::string > getProperties () const
virtual void initPortProperties ()
 Initialize port properties at the start of calculation phase. More...
virtual ~DataStreamPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
Static Public Attributes
static const char NAME [] ="OutputDataStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::DataStreamPort
static const char NAME [] ="DataStreamPort"
std::set< InputDataStreamPort * > _setOfInputDataStreamPort
- Protected Attributes inherited from YACS::ENGINE::DataStreamPort
TypeCode * _type
Node * _node
int _id
bool isAlreadyInSet (InputDataStreamPort *inPort) const
Friends
class ElementaryNode
- Protected Member Functions inherited from YACS::ENGINE::DataStreamPort
 DataStreamPort (const DataStreamPort &other, Node *newHelder)
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 37 of file OutputDataStreamPort.hxx.
◆ OutputDataStreamPort() [1/2]
OutputDataStreamPort::OutputDataStreamPort ( const OutputDataStreamPort &  other,
Node *  newHelder
Definition at line 35 of file OutputDataStreamPort.cxx.
35 :DataStreamPort(other,newHelder),
36 OutPort(other,newHelder),
37 DataPort(other,newHelder),
38 Port(other,newHelder)
39{
40}
Definition: DataPort.cxx:41
DataStreamPort(const DataStreamPort &other, Node *newHelder)
OutPort(const OutPort &other, Node *newHelder)
Definition: OutPort.cxx:29
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ OutputDataStreamPort() [2/2]
OutputDataStreamPort::OutputDataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 42 of file OutputDataStreamPort.cxx.
42 :DataStreamPort(name,node,type),
43OutPort(name,node,type),
44DataPort(name,node,type),
45Port(node)
46{
47}
◆ ~OutputDataStreamPort()
OutputDataStreamPort::~OutputDataStreamPort ( )
Definition at line 49 of file OutputDataStreamPort.cxx.
50{
51}
◆ addInPort()
bool OutputDataStreamPort::addInPort ( InPort *  inPort)
Implements YACS::ENGINE::OutPort.
Reimplemented in YACS::ENGINE::OutputCalStreamPort.
Definition at line 132 of file OutputDataStreamPort.cxx.
133{
134 DEBTRACE("OutputDataStreamPort::addInPort");
136 {
137 string what="not compatible type of port requested during building of link FROM ";
138 what+=NAME; what+=" TO "; what+=inPort->getNameOfTypeOfCurrentInstance();
139 throw Exception(what);
140 }
141 return edAddInputDataStreamPort(static_cast<InputDataStreamPort*>(inPort));
142}
Definition: DataPort.cxx:56
virtual bool edAddInputDataStreamPort(InputDataStreamPort *port)
References DEBTRACE, edAddInputDataStreamPort(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::InputDataStreamPort::NAME, and NAME.
◆ clone()
OutputDataStreamPort * OutputDataStreamPort::clone ( Node *  newHelder) const
Definition at line 53 of file OutputDataStreamPort.cxx.
54{
55 return new OutputDataStreamPort(*this,newHelder);
56}
OutputDataStreamPort(const OutputDataStreamPort &other, Node *newHelder)
References OutputDataStreamPort().
Referenced by YACS::ENGINE::ElementaryNode::createMultiDatastreamPorts().
◆ edAddInputDataStreamPort()
bool OutputDataStreamPort::edAddInputDataStreamPort ( InputDataStreamPort *  port)
Definition at line 86 of file OutputDataStreamPort.cxx.
87{
88 DEBTRACE("OutputDataStreamPort::edAddInputDataStreamPort");
89 if(!isAlreadyInSet(port))
90 {
91 if(!port->edGetType()->isAdaptable(edGetType()))
92 {
93 string what="Can not connect 2 ports with incompatible types : ";
94 what=what+ port->edGetType()->id();
95 what=what+" is not a ";
96 what=what+ edGetType()->id();
97 throw ConversionException(what);
98 }
99 _setOfInputDataStreamPort.insert(port);
100 port->edAddOutputDataStreamPort(this);
101 return true;
102 }
103 else
104 return false;
105}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual void edAddOutputDataStreamPort(OutputDataStreamPort *port)
bool isAlreadyInSet(InputDataStreamPort *inPort) const
virtual const char * id() const
Definition: TypeCode.cxx:82
virtual int isAdaptable(const TypeCode *tc) const
Check if this TypeCode is adaptable to a given TypeCode (tc)
Definition: TypeCode.cxx:116
References _setOfInputDataStreamPort, DEBTRACE, YACS::ENGINE::InputDataStreamPort::edAddOutputDataStreamPort(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::TypeCode::isAdaptable(), and isAlreadyInSet().
Referenced by addInPort(), and YACS::ENGINE::OutputCalStreamPort::addInPort().
◆ edRemoveAllLinksLinkedWithMe()
void OutputDataStreamPort::edRemoveAllLinksLinkedWithMe ( )
Implements YACS::ENGINE::DataPort.
Definition at line 144 of file OutputDataStreamPort.cxx.
145{
146 set<InputDataStreamPort *>::iterator iter;
147 set<InputDataStreamPort *> vec(_setOfInputDataStreamPort);
148 for( set<InputDataStreamPort *>::iterator iter2=vec.begin();iter2!=vec.end();iter2++)
149 edRemoveInputDataStreamPort(*iter2,true);
151}
int edRemoveInputDataStreamPort(InputDataStreamPort *inPort, bool forward)
References _setOfInputDataStreamPort, and edRemoveInputDataStreamPort().
◆ edRemoveInputDataStreamPort()
int OutputDataStreamPort::edRemoveInputDataStreamPort ( InputDataStreamPort *  inPort,
bool  forward
Definition at line 107 of file OutputDataStreamPort.cxx.
108{
109 if(forward)
110 {
111 set<InPort *> s;
112 inPort->getAllRepresentants(s);
113 for(set<InPort *>::iterator iter=s.begin();iter!=s.end();iter++)
114 _node->getRootNode()->edRemoveLink(this,*iter);
115 return -1;
116 }
117 else
118 {
119 set<InputDataStreamPort *>::iterator iter=_setOfInputDataStreamPort.find(inPort);
120 if(iter!=_setOfInputDataStreamPort.end())
121 {
122 (*iter)->modified();
123 _setOfInputDataStreamPort.erase(iter);
124 modified();
125 return edGetNumberOfOutLinks();
126 }
127 else
128 throw Exception("OutputDataStreamPort::edRemoveInputPort : link does not exist, unable to remove it");
129 }
130}
void edRemoveLink(OutPort *start, InPort *end)
Remove a dataflow link.
virtual void getAllRepresentants(std::set< InPort * > &repr) const
Definition: InPort.cxx:110
virtual ComposedNode * getRootNode() const
Definition: Node.cxx:431
virtual int edGetNumberOfOutLinks() const
Definition: OutPort.cxx:50
void modified()
Definition: Port.cxx:53
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, _setOfInputDataStreamPort, YACS::ENGINE::OutPort::edGetNumberOfOutLinks(), YACS::ENGINE::ComposedNode::edRemoveLink(), YACS::ENGINE::InPort::getAllRepresentants(), YACS::ENGINE::Node::getRootNode(), and YACS::ENGINE::Port::modified().
Referenced by edRemoveAllLinksLinkedWithMe(), removeInPort(), and YACS::ENGINE::OutputCalStreamPort::removeInPort().
◆ edSetInPort()
std::set< InPort * > OutputDataStreamPort::edSetInPort ( ) const
Definition at line 58 of file OutputDataStreamPort.cxx.
59{
60 set<InPort *> s;
61 for(set<InputDataStreamPort *>::const_iterator iter=_setOfInputDataStreamPort.begin();iter!=_setOfInputDataStreamPort.end();iter++)
62 (*iter)->getAllRepresentants(s);
63 return s;
64}
References _setOfInputDataStreamPort.
Referenced by YACS::ENGINE::ElementaryNode::ensureLoading(), YACS::ENGINE::InputPort4DF2DS::getAllRepresentants(), YACS::ENGINE::ElementaryNode::getCoupledNodes(), and YACS::ENGINE::VisitorSaveSchema::writeSimpleStreamLinks().
string OutputDataStreamPort::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::DataStreamPort.
Definition at line 81 of file OutputDataStreamPort.cxx.
82{
83 return NAME;
84}
References NAME.
◆ isAlreadyInSet()
bool OutputDataStreamPort::isAlreadyInSet ( InputDataStreamPort *  inPort) const
Definition at line 165 of file OutputDataStreamPort.cxx.
166{
167 return _setOfInputDataStreamPort.find(inPort)!=_setOfInputDataStreamPort.end();
168}
Referenced by edAddInputDataStreamPort().
◆ isAlreadyLinkedWith()
bool OutputDataStreamPort::isAlreadyLinkedWith ( InPort *  withp) const
Definition at line 66 of file OutputDataStreamPort.cxx.
67{
68 set<InPort *> s;
69 set<InputDataStreamPort *>::const_iterator iter;
70 for(iter=_setOfInputDataStreamPort.begin();iter!=_setOfInputDataStreamPort.end();iter++)
71 if(*iter==with)
72 return true;
73 for(iter=_setOfInputDataStreamPort.begin();iter!=_setOfInputDataStreamPort.end();iter++)
74 (*iter)->getAllRepresentants(s);
75 for(set<InPort *>::iterator iter2=s.begin();iter2!=s.end();iter2++)
76 if((*iter2)==with)
77 return true;
78 return false;
79}
◆ removeInPort()
int OutputDataStreamPort::removeInPort ( InPort *  inPort,
bool  forward
Definition at line 153 of file OutputDataStreamPort.cxx.
154{
155 DEBTRACE("OutputDataStreamPort::removeInPort");
157 {
158 string what="not compatible type of port requested during destruction of for link FROM ";
159 what+=NAME; what+=" TO "; what+=inPort->getNameOfTypeOfCurrentInstance();
160 throw Exception(what);
161 }
162 return edRemoveInputDataStreamPort(static_cast<InputDataStreamPort *>(inPort),forward);
163}
References DEBTRACE, edRemoveInputDataStreamPort(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::InputDataStreamPort::NAME, and NAME.
◆ typeName()
virtual std::string YACS::ENGINE::OutputDataStreamPort::typeName ( )
Definition at line 57 of file OutputDataStreamPort.hxx.
57{return "YACS__ENGINE__OutputDataStreamPort";}
◆ ElementaryNode
friend class ElementaryNode
friend
Definition at line 39 of file OutputDataStreamPort.hxx.
◆ _setOfInputDataStreamPort
◆ NAME
const char OutputDataStreamPort::NAME ="OutputDataStreamPort"
