YACS::ENGINE::ComposedNode Class Referenceabstract
Base class for all composed nodes. More...
#include <ComposedNode.hxx>
Inheritance diagram for YACS::ENGINE::ComposedNode:
Collaboration diagram for YACS::ENGINE::ComposedNode:
struct  SortHierarc
virtual ~ComposedNode ()
bool isFinished ()
void init (bool start=true)
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual bool edAddChild (Node *DISOWNnode)
virtual void edRemoveChild (Node *node)
 Remove a child node. More...
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
Static Public Attributes
static const char SEP_CHAR_BTW_LEVEL [] ="."
 ComposedNode (const std::string &name)
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
Static Protected Attributes
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
Friends
class Bloc
class Loop
class OutPort
class ElementaryNode
YACS::Colour _colour
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
This is an abstract class that must be specialized.
Definition at line 42 of file ComposedNode.hxx.
◆ ComposedNode() [1/2]
ComposedNode::ComposedNode ( const std::string &  name)
Definition at line 54 of file ComposedNode.cxx.
54 :Node(name)
55{
56}
Node(const std::string &name)
Definition: Node.cxx:69
◆ ComposedNode() [2/2]
ComposedNode::ComposedNode ( const ComposedNode &  other,
ComposedNode *  father
Definition at line 58 of file ComposedNode.cxx.
58 :Node(other,father)
59{
60}
◆ ~ComposedNode()
ComposedNode::~ComposedNode ( )
Definition at line 62 of file ComposedNode.cxx.
63{
64}
◆ accept()
void ComposedNode::accept ( Visitor *  visitor)
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoop, YACS::ENGINE::ForEachLoopDyn, YACS::ENGINE::ForLoop, YACS::ENGINE::Loop, YACS::ENGINE::OptimizerLoop, YACS::ENGINE::Proc, YACS::ENGINE::Switch, and YACS::ENGINE::WhileLoop.
Definition at line 1495 of file ComposedNode.cxx.
1496{
1497 list<Node *> constituents=edGetDirectDescendants();
1498 for(list<Node *>::iterator iter=constituents.begin(); iter!=constituents.end(); iter++)
1499 {
1500 (*iter)->accept(visitor);
1501 }
1502}
virtual std::list< Node * > edGetDirectDescendants() const =0
References edGetDirectDescendants().
Referenced by YACS::ENGINE::Executor::saveState(), and YACS::ENGINE::VisitorSaveSalomeSchemaUnsafe().
◆ buildDelegateOf() [1/2]
void ComposedNode::buildDelegateOf ( InPort *&  port,
OutPort *  initialStart,
const std::list< ComposedNode * > &  pointsOfView
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::Loop, and YACS::ENGINE::OptimizerLoop.
Definition at line 1464 of file ComposedNode.cxx.
1465{
1466}
Referenced by edAddLink().
◆ buildDelegateOf() [2/2]
void ComposedNode::buildDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
InPort *  finalTarget,
◆ checkBasicConsistency()
void ComposedNode::checkBasicConsistency ( ) const
Definition at line 1603 of file ComposedNode.cxx.
1604{
1605 DEBTRACE("ComposedNode::checkBasicConsistency");
1606 std::list<InputPort *>::const_iterator iter;
1607 std::list<InputPort *> inports=getLocalInputPorts();
1608 for(iter=inports.begin();iter!=inports.end();iter++)
1609 (*iter)->checkBasicConsistency();
1610}
std::list< InputPort * > getLocalInputPorts() const
References DEBTRACE, and getLocalInputPorts().
Referenced by YACS::ENGINE::DynParaLoop::checkBasicConsistency(), YACS::ENGINE::Loop::checkBasicConsistency(), and edUpdateState().
◆ checkCFLinks()
void ComposedNode::checkCFLinks ( const std::list< OutPort * > &  starts,
InputPort *  end,
unsigned char &  alreadyFed,
bool  direction,
LinkInfo &  info
startsIf different of 0, must aggregate at leat 1 element.
end:
alreadyFedin/out parameter. Indicates if 'end' ports is already and surely set or fed by an another port.
directionIf true : forward direction else backward direction.
info: informations collectedduring the check
Reimplemented in YACS::ENGINE::Bloc, YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForLoop, YACS::ENGINE::Loop, YACS::ENGINE::OptimizerLoop, and YACS::ENGINE::Switch.
Definition at line 807 of file ComposedNode.cxx.
808{
809 static const char what[]="ComposedNode::checkCFLinks : Internal error occured - uncorrect hierarchy detected !";
810 Node *nodeEnd=isInMyDescendance(end->getNode());
811 if(!nodeEnd)
812 return solveObviousOrDelegateCFLinks(starts,end,alreadyFed,direction,info);
813 //This case is typically dedicated when direct son is ElementaryNode and self link is defined on this.
814 if(!dynamic_cast<ElementaryNode *>(nodeEnd))
815 throw Exception(what);
816
817 list< OutPort *>::const_iterator iter=starts.begin();
818 Node *nodeStart=(*iter)->getNode();
819 iter++;
820 if(nodeEnd!=nodeStart)
821 throw Exception(what);
822
823 for(;iter!=starts.end();iter++)
824 if((*iter)->getNode()!=nodeStart)
825 throw Exception(what);
826 //Ok at this step we are sure that we have back links on the same elementary node.
827 if(starts.size()>1)
828 for(iter=starts.begin();iter!=starts.end();iter++)
829 info.pushWarnLink(*iter,end,W_BACK_COLLAPSE_EL);
830 else//here no need to look at 'alreadyFed' var because it is waranteed to be equal to FREE_ST by construction.
831 info.pushInfoLink(*(starts.begin()),end,I_BACK);
832 alreadyFed=FED_ST;
833}
void solveObviousOrDelegateCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
Node * isInMyDescendance(Node *nodeToTest) const
void pushInfoLink(OutPort *semStart, InPort *end, InfoReason reason)
Definition: LinkInfo.cxx:71
void pushWarnLink(OutPort *semStart, InPort *end, WarnReason reason)
Definition: LinkInfo.cxx:76
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
@ W_BACK_COLLAPSE_EL
Definition: LinkInfo.hxx:62
References FED_ST, YACS::ENGINE::Port::getNode(), YACS::ENGINE::I_BACK, isInMyDescendance(), YACS::ENGINE::LinkInfo::pushInfoLink(), YACS::ENGINE::LinkInfo::pushWarnLink(), solveObviousOrDelegateCFLinks(), and YACS::ENGINE::W_BACK_COLLAPSE_EL.
Referenced by YACS::ENGINE::Loop::checkCFLinks(), and YACS::ENGINE::Switch::checkCFLinks().
◆ checkConsistency()
void ComposedNode::checkConsistency ( LinkInfo &  info) const
Definition at line 615 of file ComposedNode.cxx.
616{
617 info.clearAll();
618 info.setPointOfView((ComposedNode *)this);
620 list<InputPort *> setOfInToTest=getSetOfInputPort();
621 for(list<InputPort *>::iterator iter1=setOfInToTest.begin();iter1!=setOfInToTest.end();iter1++)
622 {
623 vector<OutPort *> candidateForAdvCheck;
624 set<OutPort *> outPorts=(*iter1)->edSetOutPort();
625 //Filtering among outPorts, which of them, are candidates to fill *iter1 at the current scope.
626 for(set<OutPort *>::iterator iter2=outPorts.begin();iter2!=outPorts.end();iter2++)
627 {
628 (*iter2)->checkConsistency(info);
629 ComposedNode *manager=getLowestCommonAncestor((*iter2)->getNode(),(*iter1)->getNode());
630 if(isInMyDescendance(manager))
631 candidateForAdvCheck.push_back(*iter2);
632 }
633 if(!candidateForAdvCheck.empty())
634 //End of filtering. Now regarding CF constraints for the current InPutPort.
635 try
636 {
637 checkLinksCoherenceRegardingControl(candidateForAdvCheck,*iter1,info);
638 }
639 catch(YACS::Exception& ex)
640 {
641 std::string what=ex.what();
642 what += "\nfor input port: ";
643 what += (*iter1)->getNode()->getName();
644 what += ".";
645 what += (*iter1)->getName();
646
648 throw YACS::Exception(what);
649 }
650 else
651 //No backlinks
652 if(!(*iter1)->canBeNull() && !(*iter1)->edIsManuallyInitialized())
653 info.pushErrLink(0,*iter1,E_NEVER_SET_INPUTPORT);
654 }
656}
void checkLinksCoherenceRegardingControl(const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void performCFComputations(LinkInfo &info) const
virtual void destructCFComputations(LinkInfo &info) const
static ComposedNode * getLowestCommonAncestor(Node *node1, Node *node2)
void pushErrLink(OutPort *semStart, InPort *end, ErrReason reason)
Definition: LinkInfo.cxx:86
void setPointOfView(ComposedNode *pov)
Definition: LinkInfo.cxx:66
@ E_NEVER_SET_INPUTPORT
Definition: LinkInfo.hxx:69
References checkLinksCoherenceRegardingControl(), YACS::ENGINE::LinkInfo::clearAll(), destructCFComputations(), YACS::ENGINE::E_NEVER_SET_INPUTPORT, testCppPluginInvokation::ex, getLowestCommonAncestor(), getSetOfInputPort(), isInMyDescendance(), performCFComputations(), YACS::ENGINE::LinkInfo::pushErrLink(), and YACS::ENGINE::LinkInfo::setPointOfView().
Referenced by main(), YACS::HMI::GenericGui::onRunLoadedSchema(), and YACS::HMI::EditionProc::synchronize().
◆ checkControlDependancy()
virtual void YACS::ENGINE::ComposedNode::checkControlDependancy ( OutPort *  start,
InPort *  end,
bool  cross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  fw,
std::vector< OutPort * > &  fwCross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  bw,
LinkInfo &  info
protectedpure virtual
◆ checkDeploymentTree()
DeploymentTree ComposedNode::checkDeploymentTree ( bool  deep) const
deepif true a deep check is perfomed. Typically has to be called by an executor before any attempt to launch an execution.
Definition at line 189 of file ComposedNode.cxx.
190{
191 DeploymentTree ret;
192 list< ElementaryNode * > tasks=getRecursiveConstituents();
193 for(list< ElementaryNode * >::iterator iter=tasks.begin();iter!=tasks.end();iter++)
194 {
195 switch(ret.appendTask(*iter,(*iter)->getDynClonerIfExists(this)))
196 {
198 {
199 string what("ComposedNode::checkDeploymentTree : ServiceNode with name \""); what+=(*iter)->getName();
200 what+="\" coexists in a component with an another Task which context is incompatible with it.";
201 throw Exception(what);
202 }
204 {
205 if(deep)
206 {
207 string what("ComposedNode::checkDeploymentTree : ServiceNode with name \""); what+=(*iter)->getName();
208 what+="\" is deployable but no component is specified on it.";
209 throw Exception(what);
210 }
211 }
212 }
213 }
214 return ret;
215}
std::list< ElementaryNode * > getRecursiveConstituents() const
static const unsigned char DUP_TASK_NOT_COMPATIBLE_WITH_EXISTING_TREE
static const unsigned char DEPLOYABLE_BUT_NOT_SPECIFIED
unsigned char appendTask(Task *task, Scheduler *cloner)
References YACS::ENGINE::DeploymentTree::appendTask(), YACS::ENGINE::DeploymentTree::DEPLOYABLE_BUT_NOT_SPECIFIED, YACS::ENGINE::DeploymentTree::DUP_TASK_NOT_COMPATIBLE_WITH_EXISTING_TREE, and getRecursiveConstituents().
Referenced by YACS::ENGINE::ServiceNode::setComponent().
◆ checkInMyDescendance()
void ComposedNode::checkInMyDescendance ( Node *  nodeToTest) const
Check that 'nodeToTest' is in descendance of 'this' OR equal to 'this'
Exceptions
Exception: If 'nodeToTest' is NOT in descendance of 'this' AND not equal to 'this'
nodeToTest: the node to check
Definition at line 1017 of file ComposedNode.cxx.
1018{
1019 const char whatC[]=" is not the descendance of node ";
1020 if(nodeToTest==0)
1021 {
1022 string what("node "); what+= nodeToTest->getName(); what+=" ";
1023 what+=whatC; what+=_name;
1024 throw Exception(what);
1025 }
1026 if((ComposedNode *)nodeToTest==this)
1027 return;
1028 ComposedNode *iter=nodeToTest->_father;
1029 while(iter!=0 && iter!=this)
1030 iter=iter->_father;
1031 if(iter==0)
1032 {
1033 string what("node "); what+= nodeToTest->getName(); what+=" ";
1034 what+=whatC; what+=_name;
1035 throw Exception(what);
1036 }
1037}
std::string _name
Definition: Node.hxx:89
Definition: Node.hxx:90
Definition: Node.hxx:125
References YACS::ENGINE::Node::_father, YACS::ENGINE::Node::_name, and YACS::ENGINE::Node::getName().
Referenced by edAddLink(), edRemoveLink(), and getPortName().
◆ checkLinkPossibility()
void ComposedNode::checkLinkPossibility ( OutPort *  start,
const std::list< ComposedNode * > &  pointsOfViewStart,
InPort *  end,
const std::list< ComposedNode * > &  pointsOfViewEnd
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::OptimizerLoop, YACS::ENGINE::Switch, and YACS::ENGINE::WhileLoop.
Definition at line 1447 of file ComposedNode.cxx.
1449{
1450 if((dynamic_cast<DataFlowPort *>(start) || dynamic_cast<DataFlowPort *>(end))
1451 && (dynamic_cast<DataStreamPort *>(start) || dynamic_cast<DataStreamPort *>(end)))
1452 {//cross protocol required : deeper check needed
1453 bool isOK=false;
1454 list<ComposedNode *>::const_iterator iter;
1455 for(iter=pointsOfViewStart.begin();iter!=pointsOfViewStart.end() && !isOK;iter++)
1456 isOK=(*iter)->isRepeatedUnpredictablySeveralTimes();
1457 for(iter=pointsOfViewEnd.begin();iter!=pointsOfViewEnd.end() && !isOK;iter++)
1458 isOK=(*iter)->isRepeatedUnpredictablySeveralTimes();
1459 if(!isOK)
1460 throw Exception("ComposedNode::checkLinkPossibility : Request for cross protocol link impossible.");
1461 }
1462}
Referenced by YACS::ENGINE::DynParaLoop::checkLinkPossibility(), and edAddLink().
◆ checkLinksCoherenceRegardingControl()
void ComposedNode::checkLinksCoherenceRegardingControl ( const std::vector< OutPort * > &  starts,
InputPort *  end,
LinkInfo &  info
call it only for 'starts' to 'end' links DEALED by 'this'.
Definition at line 717 of file ComposedNode.cxx.
718{
719 map < ComposedNode *, list<OutPort *>, SortHierarc > outputs;//forward link classical
720 vector<OutPort *> outputsCross;//forward link cross
721 map < ComposedNode *, list<OutPort *>, SortHierarc > outputsBw;//backward
722 vector<OutPort *>::const_iterator iter1;
723 //vector<DataPort *> history=((*iter1).second)[0]->calculateHistoryOfLinkWith(end);
724 //DataPort *cross=DataPort::isCrossingType(history);
725 for(iter1=starts.begin();iter1!=starts.end();iter1++)
726 {
727 ComposedNode *manager=getLowestCommonAncestor((*iter1)->getNode(),end->getNode());
728 manager->checkControlDependancy((*iter1), end, false, outputs, outputsCross, outputsBw, info);
729 }
730 //Ok now let's regarding outputs all combinations : (outputs.size())*(outputs.size()-1)/2
731 unsigned char isAlreadyFed=FREE_ST;
732 //Dealing excusively with DS. Level is useless here because simultaneity is required for DS.
733 if(outputsCross.size()>0)
734 {
735 isAlreadyFed=FED_DS_ST;
736 if(outputsCross.size()>1)
737 for(vector< OutPort *>::const_iterator iter1=outputsCross.begin();iter1!=(outputsCross.end()-2);iter1++)
738 info.pushErrLink(*iter1,end,E_COLLAPSE_DS);
739 }
740 map < ComposedNode *, list<OutPort *>, SortHierarc >::iterator iter3=outputs.begin();
741 for(;iter3!=outputs.end();iter3++)
742 ((*iter3).first)->checkCFLinks((*iter3).second,end,isAlreadyFed,true,info);
743 if(isAlreadyFed==FREE_ST)
744 if(!end->edIsManuallyInitialized())
746 isAlreadyFed=FREE_ST;
747 //
748 map < ComposedNode *, list<OutPort *>, SortHierarc >::reverse_iterator iter5=outputsBw.rbegin();
749 for(;iter5!=outputsBw.rend();iter5++)
750 ((*iter5).first)->checkCFLinks((*iter5).second,end,isAlreadyFed,false,info);
751}
virtual void checkControlDependancy(OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
virtual bool edIsManuallyInitialized() const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition: InputPort.cxx:76
@ E_ONLY_BACKWARD_DEFINED
Definition: LinkInfo.hxx:70
References checkControlDependancy(), YACS::ENGINE::E_COLLAPSE_DS, YACS::ENGINE::E_ONLY_BACKWARD_DEFINED, YACS::ENGINE::InputPort::edIsManuallyInitialized(), FED_DS_ST, FREE_ST, getLowestCommonAncestor(), YACS::ENGINE::Port::getNode(), and YACS::ENGINE::LinkInfo::pushErrLink().
Referenced by checkConsistency().
◆ checkNoCrossHierachyWith()
void ComposedNode::checkNoCrossHierachyWith ( Node *  node) const
This method check that G1 <- G2 <- G3 <- G1 does not happened. Typically called by methods that set a hierarchy (Bloc::edAddChild, Loop::edSetNode, ...).
Definition at line 662 of file ComposedNode.cxx.
663{
664 ComposedNode *nodeC=dynamic_cast<ComposedNode *>(node);
665 if(!nodeC)
666 return ;
667 list<ComposedNode *> ascendants=getAllAscendanceOf();
668 if(find(ascendants.begin(),ascendants.end(),nodeC)!=ascendants.end())
669 {
670 const char what[]="ComposedNode::checkNoCrossHierachyWith : ComposedNode with name \"";
671 string stream(what); stream+=node->getName(); stream+="\" is already in hierarchy ascendance of node with name \"";
672 stream+=_name; stream+="\" ; So it can't be now in its descendance !";
673 throw Exception(stream);
674 }
675}
std::list< ComposedNode * > getAllAscendanceOf(ComposedNode *levelToStop=0) const
Definition: Node.cxx:317
References YACS::ENGINE::Node::_name, YACS::ENGINE::Node::getAllAscendanceOf(), and YACS::ENGINE::Node::getName().
Referenced by YACS::ENGINE::DynParaLoop::checkConsistencyAndSetNode(), YACS::ENGINE::Bloc::edAddChild(), YACS::ENGINE::Switch::edSetNode(), and YACS::ENGINE::Loop::edSetNode().
◆ checkNoCyclePassingThrough()
virtual void YACS::ENGINE::ComposedNode::checkNoCyclePassingThrough ( Node *  node)
◆ cleanNodes()
void ComposedNode::cleanNodes ( )
This method should be called on a control-c or sigterm
Reimplemented from YACS::ENGINE::Node.
Definition at line 1629 of file ComposedNode.cxx.
1630{
1631 DEBTRACE("ComposedNode::cleanNodes");
1632 list<Node *> nodes=edGetDirectDescendants();
1633 for(list<Node *>::iterator iter=nodes.begin();iter!=nodes.end();iter++)
1634 (*iter)->cleanNodes();
1635}
References DEBTRACE, and edGetDirectDescendants().
Referenced by Handler().
◆ connected()
void ComposedNode::connected ( )
Definition at line 1491 of file ComposedNode.cxx.
1492{
1493}
◆ destructCFComputations()
void ComposedNode::destructCFComputations ( LinkInfo &  info) const
Reimplemented in YACS::ENGINE::Bloc.
Definition at line 687 of file ComposedNode.cxx.
688{
689 list<Node *> nodes=edGetDirectDescendants();
690 for(list<Node *>::iterator iter=nodes.begin();iter!=nodes.end();iter++)
691 if(dynamic_cast<ComposedNode *>(*iter))
692 ((ComposedNode *)(*iter))->destructCFComputations(info);
693}
References destructCFComputations(), and edGetDirectDescendants().
Referenced by checkConsistency(), YACS::ENGINE::Bloc::destructCFComputations(), and destructCFComputations().
◆ edAddCFLink()
bool ComposedNode::edAddCFLink ( Node *  nodeS,
Node *  nodeE
Add a controlflow link between two nodes by calling edAddLink on their control ports
Definition at line 421 of file ComposedNode.cxx.
422{
423 return edAddLink(nodeS->getOutGate(),nodeE->getInGate());
424}
bool edAddLink(OutPort *start, InPort *end)
OutGate * getOutGate()
Definition: Node.hxx:124
InGate * getInGate()
Definition: Node.hxx:123
References edAddLink(), YACS::ENGINE::Node::getInGate(), and YACS::ENGINE::Node::getOutGate().
Referenced by YACS::ENGINE::Bloc::Bloc(), edAddDFLink(), YACS::HMI::CommandAddControlLink::localExecute(), and YACS::HMI::SubjectNode::restoreLinks().
◆ edAddChild()
◆ edAddDFLink()
bool ComposedNode::edAddDFLink ( OutPort *  start,
InPort *  end
Connect the ports with a data link (edAddLink) and add a control flow link between the children of the lowest common ancestor node.
start: the OutPort to connect
end: the InPort to connect
true if a new link has been created, false otherwise.
Reimplemented in YACS::ENGINE::DynParaLoop, and YACS::ENGINE::Loop.
Definition at line 333 of file ComposedNode.cxx.
334{
335 Node* n1=start->getNode();
336 Node* n2=end->getNode();
337 DEBTRACE( n1->getName() << ":" << n2->getName())
339 DEBTRACE( "ComposedNode::edAddDFLink: this="<<this->getName()
340 << " father=" << father->getName() )
342 << " InPort=" << end->getName() )
343 if (father != this)
344 {
345 bool ret = father->edAddDFLink(start,end); // special treatement for loop
346 return ret;
347 }
348 if(n2 == father)
349 throw Exception("Back link authorized only in special context (loop for example)");
350
351 bool ret= edAddLink(start,end);
352 if(n1 != father)
353 {
354 //add a control link only if nodes are not in the same descendance
355 //if n1 == father (n2 is after n1) : the control link is not needed
356 //if n2 == father (n1 is after n2) : it's a back link authorized only in loop context
357 while(n1->getFather() != father)
358 n1=n1->getFather();
359 while(n2->getFather() != father)
360 n2=n2->getFather();
361 try
362 {
363 edAddCFLink(n1,n2);
364 }
365 catch (Exception& ex)
366 {
367 // --- remove DF link already created in case of cycle dtection
368 DEBTRACE("Cycle detected, remove CF link");
369 if(start->isAlreadyLinkedWith(end))
370 edRemoveLink(start, end);
371 throw ex;
372 }
373 }
374 return ret;
375}
std::string getName() const
virtual bool edAddDFLink(OutPort *start, InPort *end)
bool edAddCFLink(Node *nodeS, Node *nodeE)
void edRemoveLink(OutPort *start, InPort *end)
virtual bool isAlreadyLinkedWith(InPort *withp) const =0
References DEBTRACE, edAddCFLink(), edAddDFLink(), edAddLink(), edRemoveLink(), testCppPluginInvokation::ex, YACS::ENGINE::Node::getFather(), getLowestCommonAncestor(), getName(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), and YACS::ENGINE::OutPort::isAlreadyLinkedWith().
Referenced by edAddDFLink(), YACS::ENGINE::ElementaryNode::getReadyTasks(), YACS::HMI::CommandAddLink::localExecute(), and YACS::HMI::SubjectNode::restoreLinks().
◆ edAddLink() [1/2]
bool ComposedNode::edAddLink ( OutGate *  start,
InGate *  end
Precondition : 'start' AND 'end' are in/outGate contained in a node in DIRECT descendance of 'this'.
Exceptions
Exception: If a cycle has been detected, or incompatibility between input and output, or 'start'/'end' is/are NOT in/outputPort contained in a node in descendance of 'this', or a mutilple link to an input not supporting it.
Definition at line 387 of file ComposedNode.cxx.
388{
389 Node* n1=start->getNode();
390 Node* n2=end->getNode();
391 if(n1==n2)
392 throw Exception("ComposedNode::edAddLink: can not add a control link to a node with itself",1);
393 ComposedNode* father=checkHavingCommonFather(start->getNode(),end->getNode());
394 if(father==0)
395 throw Exception("ComposedNode::edAddLink: Trying to add CF link on orphan nodes.");
396 if(father!=this)
397 {
398 checkInMyDescendance(father);
399 return father->edAddLink(start,end);
400 }
401 bool ret=start->edAddInGate(end);
402 if(ret)
403 try
404 {
406 }
407 catch (Exception& ex)
408 {
409 // --- remove created CF link in case of cycle detection
410 DEBTRACE("Cycle detected, remove CF link");
411 edRemoveCFLink(start->getNode(), end->getNode());
412 throw ex;
413 }
414 return ret;
415}
void edRemoveCFLink(Node *nodeS, Node *nodeE)
void checkInMyDescendance(Node *nodeToTest) const
virtual void checkNoCyclePassingThrough(Node *node)=0
static ComposedNode * checkHavingCommonFather(Node *node1, Node *node2)
Definition: Node.cxx:468
bool edAddInGate(InGate *inGate)
Definition: OutGate.cxx:98
References YACS::ENGINE::Node::checkHavingCommonFather(), checkInMyDescendance(), checkNoCyclePassingThrough(), DEBTRACE, YACS::ENGINE::OutGate::edAddInGate(), edAddLink(), edRemoveCFLink(), testCppPluginInvokation::ex, and YACS::ENGINE::Port::getNode().
◆ edAddLink() [2/2]
bool ComposedNode::edAddLink ( OutPort *  start,
InPort *  end
Precondition : 'start' AND 'end' are in/outputPort contained in a node in descendance of 'this'.
Exceptions
Exception: if incompatibility between input and output (type), or 'start'/'end' is/are NOT in/outputPort contained in a node in descendance of 'this', or a multiple link to an input not supporting it.
Definition at line 273 of file ComposedNode.cxx.
274{
275 DEBTRACE("ComposedNode::edAddLink");
276 set<OutPort *> represented;
277
278 start->getAllRepresented(represented);
279 if(represented.size()!=1)
280 {
281 bool ret=false;
282 for(set<OutPort *>::iterator iter=represented.begin();iter!=represented.end();iter++)
283 ret|=edAddLink(*iter,end);
284 return ret;
285 }
286 if(start->isAlreadyLinkedWith(end))
287 return false;
288 ComposedNode* lwstCmnAnctr=getLowestCommonAncestor(start->getNode(),end->getNode());
289 list<ComposedNode *> allAscendanceOfNodeStart=start->getNode()->getAllAscendanceOf(lwstCmnAnctr);
290 list<ComposedNode *> allAscendanceOfNodeEnd=end->getNode()->getAllAscendanceOf(lwstCmnAnctr);
291 checkInMyDescendance(lwstCmnAnctr);
292 lwstCmnAnctr->checkLinkPossibility(start,allAscendanceOfNodeStart,end,allAscendanceOfNodeEnd);
293 ComposedNode *iterS;
294 if(dynamic_cast<ComposedNode *>(start->getNode()))
295 iterS=(ComposedNode *)start->getNode();
296 else
297 iterS=start->getNode()->_father;
298 pair<OutPort *, OutPort *> pO(start,start);
299 while(iterS!=lwstCmnAnctr)
300 {
301 iterS->buildDelegateOf(pO, end, allAscendanceOfNodeEnd);
302 iterS=iterS->_father;
303 }
304 if(dynamic_cast<ComposedNode *>(end->getNode()))
305 iterS=(ComposedNode *)end->getNode();
306 else
307 iterS=end->getNode()->_father;
308
309 InPort *currentPortI=end;
310 bool isLoopProofLink(true),isFirstTurn(true);
311 while(iterS!=lwstCmnAnctr)
312 {
313 if(!isFirstTurn && iterS->isLoop())// isFirstTurn is a way to filter special inputs like nbBranches, splitPort... These special inputs are loopProof -> they must not be realeased by ForEachLoop::exUpdateState
314 isLoopProofLink=false;
315 iterS->buildDelegateOf(currentPortI, start, allAscendanceOfNodeStart);
316 iterS=iterS->_father;
317 isFirstTurn=false;
318 }
319 bool ret=(pO.first)->addInPort(currentPortI);
320 end->edNotifyReferencedBy(pO.second,isLoopProofLink);
321 return ret;
322}
virtual void buildDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual bool isLoop() const
virtual void checkLinkPossibility(OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void edNotifyReferencedBy(OutPort *fromPort, bool isLoopProof=true)
Definition: InPort.cxx:93
virtual void getAllRepresented(std::set< OutPort * > &represented) const
Definition: OutPort.cxx:45
References YACS::ENGINE::Node::_father, buildDelegateOf(), checkInMyDescendance(), checkLinkPossibility(), DEBTRACE, edAddLink(), YACS::ENGINE::InPort::edNotifyReferencedBy(), YACS::ENGINE::Node::getAllAscendanceOf(), YACS::ENGINE::OutPort::getAllRepresented(), getLowestCommonAncestor(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::OutPort::isAlreadyLinkedWith(), and isLoop().
Referenced by YACS::ENGINE::Bloc::Bloc(), YACS::ENGINE::Loop::buildDelegateOf(), YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), YACS::ENGINE::DynParaLoop::DynParaLoop(), edAddCFLink(), edAddDFLink(), YACS::ENGINE::DynParaLoop::edAddDFLink(), YACS::ENGINE::Loop::edAddDFLink(), edAddLink(), YACS::ENGINE::ForLoop::ForLoop(), YACS::ENGINE::ElementaryNode::getReadyTasks(), YACS::HMI::CommandAddLink::localExecute(), YACS::ENGINE::OptimizerLoop::OptimizerLoop(), YACS::HMI::SubjectNode::restoreLinks(), and YACS::ENGINE::WhileLoop::WhileLoop().
◆ edDisconnectAllLinksWithMe()
void ComposedNode::edDisconnectAllLinksWithMe ( )
Called typically by ComposedNode to correctly update DF/CF/DS links
Definition at line 903 of file ComposedNode.cxx.
904{
905 //CF
906 DEBTRACE("-");
908 //Leaving part
909 DEBTRACE("--");
910 vector< pair<OutPort *, InPort *> > linksToDestroy=getSetOfLinksLeavingCurrentScope();
911 vector< pair<OutPort *, InPort *> >::iterator iter;
912 for(iter=linksToDestroy.begin();iter!=linksToDestroy.end();iter++)
913 {
914 DEBTRACE("---");
915 (*iter).first->removeInPort((*iter).second,true);
916 }
917 //Arriving part
918 vector< pair<InPort *, OutPort *> > linksToDestroy2=getSetOfLinksComingInCurrentScope();
919 vector< pair<InPort *, OutPort *> >::iterator iter2;
920 for(iter2=linksToDestroy2.begin();iter2!=linksToDestroy2.end();iter2++)
921 {
922 DEBTRACE("----");
923 (*iter2).second->removeInPort((*iter2).first,true);
924 }
925}
virtual std::vector< std::pair< OutPort *, InPort * > > getSetOfLinksLeavingCurrentScope() const
virtual std::vector< std::pair< InPort *, OutPort * > > getSetOfLinksComingInCurrentScope() const
virtual void edDisconnectAllLinksWithMe()
Definition: Node.cxx:395
References DEBTRACE, YACS::ENGINE::Node::edDisconnectAllLinksWithMe(), getSetOfLinksComingInCurrentScope(), and getSetOfLinksLeavingCurrentScope().
◆ edGetDirectDescendants()
◆ edRemoveCFLink()
void ComposedNode::edRemoveCFLink ( Node *  nodeS,
Node *  nodeE
◆ edRemoveChild()
◆ edRemoveLink() [1/2]
void ComposedNode::edRemoveLink ( OutGate *  start,
InGate *  end
Definition at line 523 of file ComposedNode.cxx.
524{
525 ComposedNode* father=checkHavingCommonFather(start->getNode(),end->getNode());
526 if(father!=this)
527 throw Exception("edRemoveLink : nodes not in direct descendance of this");
528 start->edRemoveInGate(end);
529}
void edRemoveInGate(InGate *inGate, bool coherenceWithInGate=true)
Definition: OutGate.cxx:120
References YACS::ENGINE::Node::checkHavingCommonFather(), YACS::ENGINE::OutGate::edRemoveInGate(), and YACS::ENGINE::Port::getNode().
◆ edRemoveLink() [2/2]
void ComposedNode::edRemoveLink ( OutPort *  start,
InPort *  end
Exceptions
Exception: If the specified link does not exist. The content of Exception is different in accordance with the link from 'start' to 'end' implies DF/DS gateway.
Definition at line 441 of file ComposedNode.cxx.
442{
443 if(!start->isAlreadyLinkedWith(end))
444 throw Exception("ComposedNode::edRemoveLink : unexisting link");
445 ComposedNode* lwstCmnAnctr=getLowestCommonAncestor(start->getNode(),end->getNode());
446 checkInMyDescendance(lwstCmnAnctr);
447 list<ComposedNode *> allAscendanceOfNodeStart=start->getNode()->getAllAscendanceOf(lwstCmnAnctr);
448 list<ComposedNode *> allAscendanceOfNodeEnd=end->getNode()->getAllAscendanceOf(lwstCmnAnctr);
449
450 // --- Part of test if the link from 'start' to 'end' really exist particulary all eventually intermediate ports created
451
452 ComposedNode *iterS=start->getNode()->_father;
453 pair<OutPort *,OutPort *> currentPortO(start,start);
454 vector<pair< ComposedNode * , pair < OutPort* , OutPort *> > > needsToDestroyO;
455
456 Node *nodeOTemp=start->getNode();
457 if(*nodeOTemp<*lwstCmnAnctr)
458 {
459 iterS=nodeOTemp->_father;
460 while(iterS!=lwstCmnAnctr)
461 {
462 if (!iterS)
463 {
464 stringstream what;
465 what << "ComposedNode::edRemoveLink: "
466 << start->getNode()->getName() << "." <<start->getName() << "->"
467 << end->getNode()->getName() << "." << end->getName();
468 throw Exception(what.str());
469 }
470 OutPort *tmp=currentPortO.first;
471 iterS->getDelegateOf(currentPortO, end, allAscendanceOfNodeEnd);
472 needsToDestroyO.push_back(pair< ComposedNode * , pair < OutPort* , OutPort *> >(iterS,pair<OutPort* , OutPort *> (tmp,currentPortO.first)));
473 iterS=iterS->_father;
474 }
475 }
476 Node *nodeTemp=end->getNode();
477 InPort * currentPortI=end;
478 if(*nodeTemp<*lwstCmnAnctr)
479 {
480 iterS=nodeTemp->_father;
481 while(iterS!=lwstCmnAnctr)
482 {
483 if (!iterS)
484 {
485 stringstream what;
486 what << "ComposedNode::edRemoveLink: "
487 << start->getNode()->getName() << "." <<start->getName() << "->"
488 << end->getNode()->getName() << "." << end->getName();
489 throw Exception(what.str());
490 }
491 iterS->getDelegateOf(currentPortI, start, allAscendanceOfNodeStart);
492 iterS=iterS->_father;
493 }
494 }
495 // --- End of test for evt intermediate ports created
496
497 (currentPortO.first)->removeInPort(currentPortI,false);
498 set<OutPort *> repr;
499 (currentPortO.second)->getAllRepresented(repr);
500 if(repr.size()==1)
501 end->edNotifyDereferencedBy(currentPortO.second);
502
503 // --- Performing deletion of intermediate ports
504
505 iterS=start->getNode()->_father;
506 vector<pair< ComposedNode * , pair < OutPort* , OutPort *> > >::reverse_iterator iter;
507 for(iter=needsToDestroyO.rbegin();iter!=needsToDestroyO.rend();iter++)
508 (*iter).first->releaseDelegateOf(((*iter).second).first, ((*iter).second).second, end,allAscendanceOfNodeEnd);
509 nodeTemp=end->getNode();
510 if(*nodeTemp<*lwstCmnAnctr)
511 {
512 iterS=end->getNode()->_father;
513 currentPortI=end;
514 while(iterS!=lwstCmnAnctr)
515 {
516 iterS->releaseDelegateOf(currentPortI, start, allAscendanceOfNodeStart);
517 iterS=iterS->_father;
518 }
519 }
520}
virtual void getDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
Definition: DataPort.hxx:55
virtual void edNotifyDereferencedBy(OutPort *fromPort)
Definition: InPort.cxx:102
References YACS::ENGINE::Node::_father, checkInMyDescendance(), YACS::ENGINE::InPort::edNotifyDereferencedBy(), YACS::ENGINE::Node::getAllAscendanceOf(), getDelegateOf(), getLowestCommonAncestor(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::OutPort::isAlreadyLinkedWith(), and releaseDelegateOf().
Referenced by edAddDFLink(), YACS::ENGINE::InPort::edRemoveAllLinksLinkedWithMe(), edRemoveCFLink(), YACS::ENGINE::OutputDataStreamPort::edRemoveInputDataStreamPort(), YACS::ENGINE::OutputPort::edRemoveInputPort(), and YACS::HMI::SubjectLink::localclean().
◆ edUpdateState()
void ComposedNode::edUpdateState ( )
update the status of the node
Only useful when editing a schema Do nothing in base Node : to implement in derived classes
Definition at line 1532 of file ComposedNode.cxx.
1533{
1534 DEBTRACE("ComposedNode::edUpdateState(): " << _state << " " << _modified);
1536
1537 try
1538 {
1540 _errorDetails="";
1541 }
1542 catch(Exception& e)
1543 {
1545 _errorDetails=e.what();
1546 }
1547 DEBTRACE("ComposedNode::edUpdateState: " << _errorDetails);
1548
1549 //update children if needed
1550 list<Node *> constituents=edGetDirectDescendants();
1551 for(list<Node *>::iterator iter=constituents.begin(); iter!=constituents.end(); iter++)
1552 {
1553 if(!(*iter)->isValid())
1555 }
1556 if(state != _state)
1557 setState(state);
1558 _modified=0;
1559}
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
Definition: Node.hxx:93
Definition: Node.hxx:91
StatesForNode
Definition: define.hxx:34
@ INVALID
Definition: define.hxx:36
@ READY
Definition: define.hxx:37
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_modified, YACS::ENGINE::Node::_state, checkBasicConsistency(), DEBTRACE, edGetDirectDescendants(), YACS::INVALID, YACS::READY, YACS::ENGINE::Node::setState(), yacsorb.CORBAEngineTest::state, and YACS::Exception::what().
Referenced by YACS::ENGINE::Proc::modified(), and YACS::ENGINE::Proc::setEdition().
◆ getAllInPortsComingFromOutsideOfCurrentScope()
std::set< InPort * > ComposedNode::getAllInPortsComingFromOutsideOfCurrentScope ( ) const
List all input ports of 'this' so that, for each it exists at least 1 link coming from outside to it.
Reimplemented in YACS::ENGINE::Switch.
Definition at line 885 of file ComposedNode.cxx.
886{
887 set<InPort *> ret;
888 list<InPort *> temp=getSetOfInPort();
889 for(list<InPort *>::iterator iter2=temp.begin();iter2!=temp.end();iter2++)
890 {
891 set<OutPort *> temp2=(*iter2)->edSetOutPort();
892 for(set<OutPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
893 if(*iter3)
894 if(!isInMyDescendance((*iter3)->getNode()))
895 {
896 ret.insert(*iter2);
897 break;
898 }
899 }
900 return ret;
901}
std::list< InPort * > getSetOfInPort() const
Definition: Node.cxx:289
References YACS::ENGINE::Node::getSetOfInPort(), and isInMyDescendance().
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), YACS::ENGINE::Switch::getAllInPortsComingFromOutsideOfCurrentScope(), getSetOfLinksComingInCurrentScope(), and YACS::ENGINE::DynParaLoop::prepareInputsFromOutOfScope().
◆ getAllOutPortsLeavingCurrentScope()
std::set< OutPort * > ComposedNode::getAllOutPortsLeavingCurrentScope ( ) const
List all output ports of nodes sons of 'this' that are linked to input ports of nodes not in descendance of 'this'. This method contrary to getAllInPortsComingFromOutsideOfCurrentScope is NOT virtual because for the moment all daughter classes have no more hidden YACS::ENGINE::OutPort.
Definition at line 861 of file ComposedNode.cxx.
862{
863 set<OutPort *> ret;
864 list<OutPort *> temp=getSetOfOutPort();
865 for(list<OutPort *>::iterator iter2=temp.begin();iter2!=temp.end();iter2++)
866 {
867 set<InPort *> temp2=(*iter2)->edSetInPort();
868 for(set<InPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
869 if(!isInMyDescendance((*iter3)->getNode()))
870 {
871 ret.insert(*iter2);
872 break;
873 }
874 }
875 return ret;
876}
std::list< OutPort * > getSetOfOutPort() const
Definition: Node.cxx:299
References YACS::ENGINE::Node::getSetOfOutPort(), and isInMyDescendance().
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), YACS::ENGINE::ForLoop::exUpdateState(), YACS::ENGINE::OptimizerLoop::exUpdateState(), YACS::ENGINE::Switch::exUpdateState(), YACS::ENGINE::WhileLoop::exUpdateState(), getSetOfLinksLeavingCurrentScope(), and YACS::ENGINE::OptimizerLoop::initInterceptors().
◆ getAllRecursiveConstituents()
list< Node * > ComposedNode::getAllRecursiveConstituents ( )
Definition at line 1134 of file ComposedNode.cxx.
1135{
1136 list<Node *> ret;
1137 list<Node *> setOfNode=edGetDirectDescendants();
1138 for(list<Node *>::const_iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
1139 {
1140 if ( dynamic_cast<ComposedNode*> (*iter) )
1141 {
1142 list<Node *> myCurrentSet=((ComposedNode*)(*iter))->getAllRecursiveConstituents();
1143 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
1144 ret.push_back(*iter);
1145 }
1146 else
1147 {
1148 list<ElementaryNode *> myCurrentSet=(*iter)->getRecursiveConstituents();
1149 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
1150 }
1151 }
1152 return ret;
1153}
virtual std::list< Node * > getAllRecursiveConstituents()
References edGetDirectDescendants(), and getAllRecursiveConstituents().
Referenced by YACS::ENGINE::OptimizerLoop::finalize(), YACS::ENGINE::DynParaLoop::forwardExecStateToOriginalBody(), getAllRecursiveConstituents(), YACS::ENGINE::Proc::getIds(), YACS::ENGINE::Proc::getNumIds(), YACS::HMI::GuiExecutor::registerStatusObservers(), YACS::HMI::GuiExecutor::updateSchema(), and YACS::ENGINE::ForEachLoopGen::updateStateForWorkNodeOnFinishedEventFrom().
◆ getAllRecursiveNodes()
list< Node * > ComposedNode::getAllRecursiveNodes ( )
Definition at line 1156 of file ComposedNode.cxx.
1157{
1158 list<Node *> ret;
1159 list<Node *> setOfNode=edGetDirectDescendants();
1160 for(list<Node *>::iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
1161 {
1162 if ( dynamic_cast<ElementaryNode*> (*iter) )
1163 {
1164 list<ElementaryNode *> myCurrentSet=(*iter)->getRecursiveConstituents();
1165 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
1166 }
1167 else
1168 {
1169 list<Node *> myCurrentSet=((ComposedNode*)(*iter))->getAllRecursiveNodes();
1170 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
1171 }
1172 }
1173 ret.push_back(this);
1174 return ret;
1175}
std::list< Node * > getAllRecursiveNodes()
References edGetDirectDescendants(), and getAllRecursiveNodes().
Referenced by getAllRecursiveNodes(), Proc_i::getIds(), main(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ getChildByName()
Node * ComposedNode::getChildByName ( const std::string &  name) const
Definition at line 999 of file ComposedNode.cxx.
1000{
1001 string potentiallyDirectSonName, remainsPath;
1002 bool forwardNeeded=ComposedNode::splitNamesBySep(name, SEP_CHAR_BTW_LEVEL,
1003 potentiallyDirectSonName,remainsPath,false);
1004 Node *child=getChildByShortName(potentiallyDirectSonName);
1005 if(!forwardNeeded)
1006 return child;
1007 else
1008 return child->getChildByName(remainsPath);
1009}
static const char SEP_CHAR_BTW_LEVEL[]
static bool splitNamesBySep(const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
virtual Node * getChildByShortName(const std::string &name) const =0
virtual Node * getChildByName(const std::string &name) const =0
References YACS::ENGINE::Node::getChildByName(), getChildByShortName(), SEP_CHAR_BTW_LEVEL, and splitNamesBySep().
Referenced by YACS::ENGINE::Bloc::Bloc(), YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), DefineCustomObservers(), YACS::ENGINE::DynParaLoop::forwardExecStateToOriginalBody(), YACS::ENGINE::DynParaLoop::getDynInputPortByAbsName(), YACS::ENGINE::ForEachLoopGen::getDynOutPortByAbsName(), getInputDataStreamPort(), getInputPort(), YACS::HMI::SceneBlocItem::getNodesInfo(), getOutputDataStreamPort(), YACS::HMI::YACSGuiLoader::getPrsData(), YACS::HMI::CommandAddNodeFromCatalog::localExecute(), YACS::HMI::CommandReparentNode::localExecute(), YACS::HMI::CommandPutInComposedNode::localExecute(), YACS::HMI::CommandCopyNode::localExecute(), YACS::HMI::CommandRenameNode::localExecute(), YACS::HMI::CommandRenameInDataPort::localExecute(), YACS::HMI::CommandRenameOutDataPort::localExecute(), YACS::HMI::CommandAddInputPortFromCatalog::localExecute(), YACS::HMI::CommandAddOutputPortFromCatalog::localExecute(), YACS::HMI::CommandAddIDSPortFromCatalog::localExecute(), YACS::HMI::CommandAddODSPortFromCatalog::localExecute(), YACS::HMI::CommandOrderInputPorts::localExecute(), YACS::HMI::CommandOrderOutputPorts::localExecute(), YACS::HMI::CommandSetInPortValue::localExecute(), YACS::HMI::CommandSetOutPortValue::localExecute(), YACS::HMI::CommandSetSwitchSelect::localExecute(), YACS::HMI::CommandSetSwitchCase::localExecute(), YACS::HMI::CommandSetForLoopSteps::localExecute(), YACS::HMI::CommandSetWhileCondition::localExecute(), YACS::HMI::CommandSetForEachBranch::localExecute(), YACS::HMI::CommandSetAlgo::localExecute(), YACS::HMI::CommandAddLink::localExecute(), YACS::HMI::CommandAddControlLink::localExecute(), YACS::HMI::CommandSetNodeProperties::localExecute(), YACS::HMI::CommandSetDSPortProperties::localExecute(), YACS::HMI::CommandSetLinkProperties::localExecute(), YACS::HMI::CommandSetFuncNodeFunctionName::localExecute(), YACS::HMI::CommandSetInlineNodeScript::localExecute(), YACS::HMI::CommandSetExecutionMode::localExecute(), YACS::HMI::CommandSetContainer::localExecute(), YACS::HMI::CommandAssociateServiceToComponent::localExecute(), YACS::HMI::CommandAddComponentFromCatalog::localExecute(), YACS::HMI::CommandDestroy::localExecute(), YACS::HMI::CommandAddNodeFromCatalog::localReverse(), YACS::HMI::CommandReparentNode::localReverse(), YACS::HMI::CommandPutInComposedNode::localReverse(), YACS::HMI::CommandCopyNode::localReverse(), YACS::HMI::CommandRenameNode::localReverse(), YACS::HMI::CommandRenameInDataPort::localReverse(), YACS::HMI::CommandRenameOutDataPort::localReverse(), YACS::HMI::CommandAddInputPortFromCatalog::localReverse(), YACS::HMI::CommandAddOutputPortFromCatalog::localReverse(), YACS::HMI::CommandAddIDSPortFromCatalog::localReverse(), YACS::HMI::CommandAddODSPortFromCatalog::localReverse(), YACS::HMI::CommandOrderInputPorts::localReverse(), YACS::HMI::CommandOrderOutputPorts::localReverse(), YACS::HMI::CommandSetInPortValue::localReverse(), YACS::HMI::CommandSetOutPortValue::localReverse(), YACS::HMI::CommandSetSwitchSelect::localReverse(), YACS::HMI::CommandSetSwitchCase::localReverse(), YACS::HMI::CommandSetForLoopSteps::localReverse(), YACS::HMI::CommandSetWhileCondition::localReverse(), YACS::HMI::CommandSetForEachBranch::localReverse(), YACS::HMI::CommandSetAlgo::localReverse(), YACS::HMI::CommandAddLink::localReverse(), YACS::HMI::CommandAddControlLink::localReverse(), YACS::HMI::CommandSetNodeProperties::localReverse(), YACS::HMI::CommandSetDSPortProperties::localReverse(), YACS::HMI::CommandSetLinkProperties::localReverse(), YACS::HMI::CommandSetFuncNodeFunctionName::localReverse(), YACS::HMI::CommandSetInlineNodeScript::localReverse(), YACS::HMI::CommandSetExecutionMode::localReverse(), YACS::HMI::CommandSetContainer::localReverse(), YACS::HMI::CommandAssociateServiceToComponent::localReverse(), YACS::HMI::CommandAddComponentFromCatalog::localReverse(), YACS::ENGINE::graphParser::onEnd(), YACS::ENGINE::nodeParser::onEnd(), YACS::ENGINE::portParser::onEnd(), performDuplicationOfPlacement(), performShallowDuplicationOfPlacement(), YACS::HMI::GuiObserver_i::setConversion(), and YACS::ENGINE::Node::setName().
◆ getChildByShortName()
virtual Node * YACS::ENGINE::ComposedNode::getChildByShortName ( const std::string &  name) const
◆ getChildName()
string ComposedNode::getChildName ( const Node *  node) const
Definition at line 968 of file ComposedNode.cxx.
969{
970 string nodeName=node->getQualifiedName();
971 if (!isNodeAlreadyAggregated(node))
972 {
973 if (node->getName() == "thisIsAFakeNode")
974 {
975 string child = node->getName()+".thisIsAFakeNode";
976 return child;
977 }
978 else
979 {
980 string what("node "); what+= node->getName() ; what+=" is not a child of node "; what += getName();
981 throw Exception(what);
982 }
983 }
984
985 const Node *father = node->_father;
986 while (father != this)
987 {
988 nodeName = father->getQualifiedName() + SEP_CHAR_BTW_LEVEL + nodeName;
989 father = father->_father;
990 }
991 return nodeName;
992}
bool isNodeAlreadyAggregated(const Node *node) const
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
References YACS::ENGINE::Node::_father, getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Node::getQualifiedName(), isNodeAlreadyAggregated(), and SEP_CHAR_BTW_LEVEL.
Referenced by YACS::HMI::SubjectElementaryNode::addIDSPort(), YACS::HMI::SubjectElementaryNode::addInputPort(), YACS::HMI::SubjectElementaryNode::addODSPort(), YACS::HMI::SubjectElementaryNode::addOutputPort(), YACS::HMI::SceneBlocItem::arrangeCanvasNodes(), YACS::HMI::SubjectServiceNode::associateToComponent(), YACS::ENGINE::Bloc::Bloc(), YACS::HMI::SubjectNode::copy(), YACS::HMI::SubjectComposedNode::createNode(), YACS::HMI::Subject::destroy(), YACS::HMI::EditionNode::EditionNode(), YACS::ENGINE::DynParaLoop::forwardExecStateToOriginalBody(), YACS::ENGINE::Node::getDPLScopeInfo(), YACS::ENGINE::Node::getId(), YACS::ENGINE::Proc::getIds(), YACS::ENGINE::LinkInfo::getInfoRepr(), YACS::HMI::SceneBlocItem::getNodesInfo(), getTaskName(), YACS::HMI::CommandReparentNode::localExecute(), YACS::HMI::CommandPutInComposedNode::localExecute(), YACS::HMI::CommandRenameNode::localExecute(), YACS::HMI::CommandSetSwitchCase::localExecute(), YACS::HMI::CommandPutInComposedNode::localReverse(), YACS::ENGINE::graphParser::onEnd(), YACS::HMI::SubjectElementaryNode::OrderDataPorts(), performDuplicationOfPlacement(), performShallowDuplicationOfPlacement(), YACS::HMI::SubjectNode::putInComposedNode(), YACS::HMI::SubjectDataPort::registerUndoDestroy(), YACS::HMI::SubjectInputDataStreamPort::registerUndoDestroy(), YACS::HMI::SubjectOutputDataStreamPort::registerUndoDestroy(), YACS::HMI::SubjectNode::registerUndoDestroy(), YACS::HMI::SubjectLink::registerUndoDestroy(), YACS::HMI::SubjectControlLink::registerUndoDestroy(), YACS::HMI::SubjectNode::reparent(), YACS::HMI::SubjectOptimizerLoop::setAlgorithm(), YACS::HMI::SubjectSwitch::setCase(), YACS::HMI::SubjectServiceNode::setComponentFromCatalog(), YACS::HMI::SubjectWhileLoop::setCondition(), YACS::HMI::SubjectInlineNode::setContainer(), YACS::HMI::SubjectInlineNode::setExecutionMode(), YACS::HMI::SubjectPyFuncNode::setFunctionName(), YACS::HMI::GuiExecutor::setInPortValue(), YACS::HMI::SubjectDataPort::setName(), YACS::HMI::SubjectNode::setName(), YACS::HMI::SubjectDynParaLoop::setNbBranches(), YACS::HMI::SubjectForLoop::setNbSteps(), YACS::HMI::SubjectInputDataStreamPort::setProperties(), YACS::HMI::SubjectOutputDataStreamPort::setProperties(), YACS::HMI::SubjectNode::setProperties(), YACS::HMI::SubjectLink::setProperties(), YACS::HMI::SubjectInlineNode::setScript(), YACS::HMI::SubjectSwitch::setSelect(), YACS::HMI::SubjectInputPort::setValue(), YACS::HMI::SubjectOutputPort::setValue(), YACS::HMI::SubjectControlLink::SubjectControlLink(), YACS::HMI::SubjectLink::SubjectLink(), YACS::HMI::SchemaNodeItem::toggleState(), YACS::HMI::SubjectDataPort::tryCreateLink(), YACS::HMI::SubjectNode::tryCreateLink(), YACS::HMI::EditionNode::update(), YACS::HMI::SchemaComponentItem::update(), YACS::ENGINE::VisitorSaveSchema::visitBloc(), YACS::ENGINE::VisitorSaveState::visitBloc(), YACS::ENGINE::VisitorSaveSchema::visitDynParaLoop(), YACS::ENGINE::VisitorSaveSchema::visitElementaryNode(), YACS::ENGINE::VisitorSaveState::visitElementaryNode(), YACS::ENGINE::VisitorSalomeSaveState::visitForEachLoop(), YACS::ENGINE::VisitorSaveSchema::visitForEachLoop(), YACS::ENGINE::VisitorSaveState::visitForEachLoop(), YACS::ENGINE::VisitorSaveSchema::visitForEachLoopDyn(), YACS::ENGINE::VisitorSaveState::visitForEachLoopDyn(), YACS::ENGINE::VisitorSaveSchema::visitForLoop(), YACS::ENGINE::VisitorSaveState::visitForLoop(), YACS::ENGINE::VisitorSaveSchema::visitInlineFuncNode(), YACS::ENGINE::VisitorSaveSchema::visitInlineNode(), YACS::ENGINE::VisitorSaveSchema::visitLoop(), YACS::ENGINE::VisitorSaveState::visitLoop(), YACS::ENGINE::VisitorSaveSchema::visitOptimizerLoop(), YACS::ENGINE::VisitorSaveState::visitOptimizerLoop(), YACS::ENGINE::VisitorSaveSchema::visitOutNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitOutNode(), YACS::ENGINE::VisitorSaveSchema::visitPresetNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitPresetNode(), YACS::ENGINE::VisitorSaveState::visitProc(), YACS::ENGINE::VisitorSaveSchema::visitServerNode(), YACS::ENGINE::VisitorSaveSchema::visitServiceInlineNode(), YACS::ENGINE::VisitorSaveSchema::visitServiceNode(), YACS::ENGINE::VisitorSaveSchema::visitStudyInNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitStudyInNode(), YACS::ENGINE::VisitorSaveSchema::visitStudyOutNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitStudyOutNode(), YACS::ENGINE::VisitorSaveSchema::visitSwitch(), YACS::ENGINE::VisitorSaveState::visitSwitch(), YACS::ENGINE::VisitorSaveSchema::visitWhileLoop(), YACS::ENGINE::VisitorSaveState::visitWhileLoop(), YACS::ENGINE::VisitorSaveSchema::writeControls(), YACS::ENGINE::VisitorSaveSchema::writeParametersNode(), YACS::HMI::VisitorSaveGuiSchema::writePresentation(), YACS::ENGINE::VisitorSaveSchema::writeSimpleDataLinks(), and YACS::ENGINE::VisitorSaveSchema::writeSimpleStreamLinks().
◆ getDelegateOf() [1/2]
void ComposedNode::getDelegateOf ( InPort *&  port,
Reimplemented in YACS::ENGINE::Loop.
Definition at line 1472 of file ComposedNode.cxx.
1473{
1474}
Referenced by YACS::ENGINE::OutPort::calculateHistoryOfLinkWith(), and edRemoveLink().
◆ getDelegateOf() [2/2]
void ComposedNode::getDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
Reimplemented in YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::Loop, and YACS::ENGINE::Switch.
Definition at line 1476 of file ComposedNode.cxx.
1477{
1478}
◆ getDeploymentTree()
DeploymentTree ComposedNode::getDeploymentTree ( ) const
Implements YACS::ENGINE::Scheduler.
Definition at line 176 of file ComposedNode.cxx.
177{
178 DeploymentTree ret;
179 list< ElementaryNode * > tasks=getRecursiveConstituents();
180 for(list< ElementaryNode * >::iterator iter=tasks.begin();iter!=tasks.end();iter++)
181 ret.appendTask(*iter,(*iter)->getDynClonerIfExists(this));
182 return ret;
183}
References YACS::ENGINE::DeploymentTree::appendTask(), and getRecursiveConstituents().
Referenced by performDuplicationOfPlacement(), performShallowDuplicationOfPlacement(), and YACS::ENGINE::Proc::updateContainersAndComponents().
◆ getErrorReport()
std::string ComposedNode::getErrorReport ( )
returns a string that contains an error report if the node is in error
Reimplemented in YACS::ENGINE::DynParaLoop.
Definition at line 1561 of file ComposedNode.cxx.
1562{
1563 DEBTRACE("ComposedNode::getErrorReport: " << getName() << " " << _state);
1564 YACS::StatesForNode effectiveState=getEffectiveState();
1565
1566 if(effectiveState != YACS::INVALID && effectiveState != YACS::ERROR && effectiveState != YACS::FAILED)
1567 return "";
1568
1569 std::string report="<error node= " + getName();
1570 switch(effectiveState)
1571 {
1572 case YACS::INVALID:
1573 report=report+" state= INVALID";
1574 break;
1575 case YACS::ERROR:
1576 report=report+" state= ERROR";
1577 break;
1578 case YACS::FAILED:
1579 report=report+" state= FAILED";
1580 break;
1581 default:
1582 break;
1583 }
1584 report=report + ">\n" ;
1585 if(_errorDetails != "")
1586 report=report+_errorDetails+"\n";
1587
1588 list<Node *> constituents=edGetDirectDescendants();
1589 for(list<Node *>::iterator iter=constituents.begin(); iter!=constituents.end(); iter++)
1590 {
1591 std::string rep=(*iter)->getErrorReport();
1592 if(rep != "")
1593 {
1594 report=report+rep+"\n";
1595 }
1596 }
1597 report=report+"</error>";
1598 return report;
1599}
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
Definition: Node.cxx:538
@ FAILED
Definition: define.hxx:51
@ ERROR
Definition: define.hxx:52
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_state, DEBTRACE, edGetDirectDescendants(), YACS::ERROR, YACS::FAILED, YACS::ENGINE::Node::getEffectiveState(), getName(), and YACS::INVALID.
Referenced by main(), and YACS::HMI::EditionProc::synchronize().
◆ getInPortName()
string ComposedNode::getInPortName ( const InPort *  inPort) const
get the input port name used by the current node, recursively built with children names.
Definition at line 1200 of file ComposedNode.cxx.
1201{
1202 return getPortName<InPort>(inPort);
1203}
Referenced by YACS::ENGINE::LinkInfo::getErrRepr(), YACS::ENGINE::LinkInfo::getInfoRepr(), YACS::ENGINE::LinkInfo::getWarnRepr(), and YACS::ENGINE::DynParaLoop::prepareInputsFromOutOfScope().
◆ getInputDataStreamPort()
InputDataStreamPort * ComposedNode::getInputDataStreamPort ( const std::string &  name) const
Definition at line 1337 of file ComposedNode.cxx.
1338{
1339 string portName, nodeName;
1340 if(splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,true))
1341 {
1342 Node *child = getChildByName(nodeName);
1343 return child->getInputDataStreamPort(portName);
1344 }
1345 else
1346 {
1347 string what("ComposedNode::getInputDataStreamPort : the port with name "); what+=name; what+=" does not exist on the current level";
1348 throw Exception(what);
1349 }
1350}
static const char SEP_CHAR_IN_PORT[]
Definition: Node.hxx:94
virtual InputDataStreamPort * getInputDataStreamPort(const std::string &name) const =0
References getChildByName(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::SEP_CHAR_IN_PORT, and splitNamesBySep().
◆ getInputPort()
InputPort * ComposedNode::getInputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getOutputPort, this method is NOT recursive and so the leaf of type ElementaryNode aggregating this InputPort is directly invoked.
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::ForLoop, YACS::ENGINE::OptimizerLoop, YACS::ENGINE::Switch, and YACS::ENGINE::WhileLoop.
Definition at line 1297 of file ComposedNode.cxx.
1298{
1299 try {
1300 return Node::getInputPort(name);
1301 }
1302 catch(Exception& e) {}
1303
1304 string portName, nodeName;
1305 if(splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,true))
1306 {
1307 Node *child = getChildByName(nodeName);
1308 return child->getInputPort(portName);
1309 }
1310 else
1311 {
1312 string what("ComposedNode::getInputPort : the port with name "); what+=name; what+=" does not exist on the current level";
1313 throw Exception(what);
1314 }
1315}
virtual InputPort * getInputPort(const std::string &name) const
Definition: Node.cxx:260
References getChildByName(), YACS::ENGINE::Node::getInputPort(), YACS::ENGINE::Node::SEP_CHAR_IN_PORT, and splitNamesBySep().
Referenced by YACS::ENGINE::DynParaLoop::getInputPort(), YACS::ENGINE::ForLoop::getInputPort(), YACS::ENGINE::Switch::getInputPort(), and YACS::ENGINE::WhileLoop::getInputPort().
◆ getLocalInputPorts()
std::list< InputPort * > ComposedNode::getLocalInputPorts ( ) const
◆ getLocalOutputPorts()
std::list< OutputPort * > ComposedNode::getLocalOutputPorts ( ) const
redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::ForLoop, and YACS::ENGINE::OptimizerLoop.
Definition at line 1522 of file ComposedNode.cxx.
1523{
1524 std::list<OutputPort *> lop; return lop; // empty list
1525}
Referenced by YACS::ENGINE::DynParaLoop::getLocalOutputPorts(), and YACS::HMI::SubjectComposedNode::loadChildren().
◆ getLowestCommonAncestor()
ComposedNode * ComposedNode::getLowestCommonAncestor ( Node *  node1,
Node *  node2
Retrieves the lowest common ancestor of 'node1' AND 'node2'. If 'node1' or 'node2' are both or indiscriminately instances of ComposedNode and that 'node1' is in descendance of 'node2' (resp. 'node2' in descendance of 'node1') 'node2' is returned (resp. 'node1').
Exceptions
Exception: if 'node1' and 'node2' do not share the same genealogy.
The lowest common ancestor if it exists.
Definition at line 1050 of file ComposedNode.cxx.
1051{
1052 const char what[]="The two nodes do not share the same genealogy";
1053 if(node1==0 || node2==0)
1054 throw Exception(what);
1055 ComposedNode *temp;
1056 if(dynamic_cast<ComposedNode *>(node1))
1057 temp=(ComposedNode *)node1;//->_father;
1058 else
1059 temp=(ComposedNode *)node1->_father;
1060 set<ComposedNode *> s;
1061 while(temp)
1062 {
1063 s.insert(temp);
1064 temp=temp->_father;
1065 }
1066 //
1067 if(dynamic_cast<ComposedNode *>(node2))
1068 temp=(ComposedNode *)node2;//->_father;
1069 else
1070 temp=(ComposedNode *)node2->_father;
1071 set<ComposedNode *>::iterator iter=s.find(temp);
1072 while(temp && iter==s.end())
1073 {
1074 iter=s.find(temp);
1075 temp=temp->_father;
1076 }
1077 if(iter==s.end())
1078 throw Exception(what);
1079 return *iter;
1080}
References YACS::ENGINE::Node::_father, testCppPluginInvokation::node1, and testCppPluginInvokation::node2.
Referenced by YACS::ENGINE::Bloc::Bloc(), YACS::ENGINE::OutPort::calculateHistoryOfLinkWith(), checkConsistency(), checkLinksCoherenceRegardingControl(), edAddDFLink(), edAddLink(), edRemoveLink(), and YACS::ENGINE::ForEachLoopGen::getFEDeltaBetween().
◆ getLowestCommonAncestorStr()
std::string ComposedNode::getLowestCommonAncestorStr ( const std::string &  node1,
const std::string &  node2
Same as getLowestCommonAncestor method except that absolute string representation is considered here instead of instances.
Definition at line 1085 of file ComposedNode.cxx.
1086{
1087 std::string ret;
1088 std::size_t it1_b(0),it1_e(0),it2_b(0),it2_e(0);
1089 while(it1_b!=std::string::npos && it2_b!=std::string::npos)
1090 {
1091 it1_e=node1.find(SEP_CHAR_BTW_LEVEL,it1_b);
1092 it2_e=node2.find(SEP_CHAR_BTW_LEVEL,it2_b);
1093 if(it1_e!=it2_e && it1_e!=std::string::npos && it2_e!=std::string::npos)
1094 break;
1095 std::string elt1(node1.substr(it1_b,it1_e-it1_b)),elt2(node2.substr(it2_b,it2_e-it2_b));
1096 if(elt1!=elt2)
1097 break;
1098 if(!ret.empty())
1099 ret+=SEP_CHAR_BTW_LEVEL;
1100 ret+=elt1;
1101 it1_b=node1.find_first_not_of(SEP_CHAR_BTW_LEVEL,it1_e);
1102 it2_b=node2.find_first_not_of(SEP_CHAR_BTW_LEVEL,it2_e);
1103 }
1104 return ret;
1105}
References testCppPluginInvokation::node1, testCppPluginInvokation::node2, and SEP_CHAR_BTW_LEVEL.
◆ getLowestNodeDealingAll()
Node * ComposedNode::getLowestNodeDealingAll ( const std::list< OutPort * > &  ports) const
Returns the lowest Node (Elementary or Composed) (is sense of hierachy level ( operator< ) ) containing all 'ports'. Typically use in consistency computation. Precondition : 'ports' must contain at least one element. All elements of 'ports' should be in descendance of 'this'.
Definition at line 700 of file ComposedNode.cxx.
701{
702 list< OutPort *>::const_iterator iter=ports.begin();
703 Node *ret=(*iter)->getNode();
704 iter++;
705 for(;iter!=ports.end();iter++)
706 {
707 Node *tmp=(*iter)->getNode();
708 if(*tmp>*ret)
709 ret=tmp;
710 }
711 return ret;
712}
Referenced by solveObviousOrDelegateCFLinks().
◆ getMyQualifiedName()
std::string ComposedNode::getMyQualifiedName ( const Node *  directSon) const
Definition at line 994 of file ComposedNode.cxx.
995{
996 return directSon->getName();
997}
References YACS::ENGINE::Node::getName().
Referenced by YACS::ENGINE::Node::getQualifiedName().
◆ getName()
std::string ComposedNode::getName ( ) const
Definition at line 165 of file ComposedNode.cxx.
166{
167 return Node::getName();
168}
Referenced by YACS::HMI::SceneBlocItem::arrangeChildNodes(), YACS::ENGINE::OptimizerLoop::checkTypeCode(), YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), YACS::ENGINE::CppNode::cloneNode(), YACS::ENGINE::PythonNode::cloneNode(), YACS::ENGINE::PyFuncNode::cloneNode(), YACS::ENGINE::SalomePythonNode::cloneNode(), YACS::ENGINE::CollectorSwOutPort::CollectorSwOutPort(), YACS::HMI::SubjectNode::copy(), YACS::HMI::Subject::destroy(), YACS::ENGINE::DFToDSForLoop::DFToDSForLoop(), YACS::ENGINE::DSToDFForLoop::DSToDFForLoop(), edAddDFLink(), edRemoveChild(), YACS::ENGINE::CORBANode::execute(), YACS::ENGINE::SalomeNode::execute(), YACS::ENGINE::DistributedPythonNode::execute(), YACS::ENGINE::SalomePythonNode::execute(), YACS::ENGINE::XmlNode::execute(), YACS::ENGINE::PythonNode::executeLocal(), YACS::ENGINE::PyFuncNode::executeLocal(), YACS::ENGINE::PythonNode::executeRemote(), YACS::ENGINE::PyFuncNode::executeRemote(), YACS::ENGINE::ForEachLoopGen::exUpdateState(), YACS::ENGINE::ForLoop::exUpdateState(), YACS::ENGINE::Switch::getCaseId(), YACS::ENGINE::DynParaLoop::getChildByNameExec(), YACS::ENGINE::Bloc::getChildByShortName(), YACS::ENGINE::DynParaLoop::getChildByShortName(), YACS::ENGINE::Loop::getChildByShortName(), YACS::ENGINE::Switch::getChildByShortName(), getChildName(), YACS::ENGINE::Switch::getDelegateOf(), getErrorReport(), YACS::ENGINE::DynParaLoop::getErrorReport(), YACS::ENGINE::Node::getId(), YACS::ENGINE::SalomePythonNode::load(), YACS::ENGINE::ProcCataLoader::loadCata(), YACS::ENGINE::PyFuncNode::loadLocal(), YACS::HMI::CommandReparentNode::localExecute(), YACS::HMI::CommandPutInComposedNode::localExecute(), YACS::HMI::CommandCopyNode::localExecute(), YACS::HMI::CommandRenameNode::localExecute(), YACS::HMI::CommandRenameInDataPort::localExecute(), YACS::HMI::CommandRenameOutDataPort::localExecute(), YACS::HMI::CommandAddLink::localExecute(), YACS::HMI::CommandAddControlLink::localExecute(), YACS::HMI::CommandAssociateServiceToComponent::localExecute(), YACS::HMI::CommandReparentNode::localReverse(), YACS::HMI::CommandPutInComposedNode::localReverse(), YACS::HMI::CommandCopyNode::localReverse(), YACS::HMI::CommandRenameNode::localReverse(), YACS::HMI::CommandRenameInDataPort::localReverse(), YACS::HMI::CommandRenameOutDataPort::localReverse(), YACS::HMI::CommandAssociateServiceToComponent::localReverse(), YACS::ENGINE::graphParser::onEnd(), YACS::ENGINE::nodeParser::onEnd(), YACS::optimizerlooptypeParser< T >::post(), YACS::HMI::SubjectNode::registerUndoDestroy(), YACS::HMI::SubjectNode::reparent(), YACS::ENGINE::Node::setName(), YACS::ENGINE::PythonNode::squeezeMemory(), YACS::ENGINE::PythonNode::squeezeMemoryRemote(), YACS::switchtypeParser::state(), YACS::HMI::SubjectControlLink::SubjectControlLink(), YACS::HMI::SubjectLink::SubjectLink(), YACS::ENGINE::VisitorSaveSchema::visitBloc(), YACS::ENGINE::VisitorSaveState::visitBloc(), YACS::ENGINE::VisitorSalomeSaveState::visitForEachLoop(), YACS::ENGINE::VisitorSaveSchema::visitForEachLoop(), YACS::ENGINE::VisitorSaveState::visitForEachLoop(), YACS::ENGINE::VisitorSaveSchema::visitForEachLoopDyn(), YACS::ENGINE::VisitorSaveState::visitForEachLoopDyn(), YACS::ENGINE::VisitorSaveSchema::visitForLoop(), YACS::ENGINE::VisitorSaveState::visitForLoop(), YACS::ENGINE::VisitorSaveState::visitLoop(), YACS::ENGINE::VisitorSaveSchema::visitOptimizerLoop(), YACS::ENGINE::VisitorSaveState::visitOptimizerLoop(), YACS::ENGINE::VisitorSaveSchema::visitProc(), YACS::ENGINE::VisitorSaveState::visitProc(), YACS::ENGINE::VisitorSaveSchema::visitSwitch(), YACS::ENGINE::VisitorSaveState::visitSwitch(), YACS::ENGINE::VisitorSaveSchema::visitWhileLoop(), YACS::ENGINE::VisitorSaveState::visitWhileLoop(), YACS::ENGINE::ForEachLoopGen::writeDot(), and YACS::ENGINE::VisitorSaveSchema::writeSimpleDataLinks().
◆ getNextTasks()
std::vector< Task * > ComposedNode::getNextTasks ( bool &  isMore)
Definition at line 217 of file ComposedNode.cxx.
218{
219 vector<Task *> ret;
220 isMore=false;
221 getReadyTasks(ret);
222 isMore=!ret.empty();
223 return ret;
224}
virtual void getReadyTasks(std::vector< Task * > &tasks)=0
References YACS::ENGINE::Node::getReadyTasks().
◆ getNumberOfInputPorts()
int ComposedNode::getNumberOfInputPorts ( ) const
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::Loop, YACS::ENGINE::OptimizerLoop, and YACS::ENGINE::Switch.
Definition at line 1210 of file ComposedNode.cxx.
1211{
1212 list<Node *> constituents=edGetDirectDescendants();
1213 int ret=0;
1214 for(list<Node *>::iterator iter=constituents.begin();iter!=constituents.end();iter++)
1215 ret+=(*iter)->getNumberOfInputPorts();
1216 return ret;
1217}
References edGetDirectDescendants().
Referenced by YACS::ENGINE::DynParaLoop::getNumberOfInputPorts(), YACS::ENGINE::Loop::getNumberOfInputPorts(), and YACS::ENGINE::Switch::getNumberOfInputPorts().
◆ getNumberOfOutputPorts()
int ComposedNode::getNumberOfOutputPorts ( ) const
Reimplemented in YACS::ENGINE::DynParaLoop, and YACS::ENGINE::OptimizerLoop.
Definition at line 1219 of file ComposedNode.cxx.
1220{
1221 list<Node *> constituents=edGetDirectDescendants();
1222 int ret=0;
1223 for(list<Node *>::iterator iter=constituents.begin();iter!=constituents.end();iter++)
1224 ret+=(*iter)->getNumberOfOutputPorts();
1225 return ret;
1226}
Referenced by YACS::ENGINE::DynParaLoop::getNumberOfOutputPorts().
◆ getOutPort()
OutPort * ComposedNode::getOutPort ( const std::string &  name) const
: Contrary to getOutputPort method, this method returns the output port at highest level, possible. That is to say in some ComposedNode, like ForEachLoop or Switch, an outport inside 'this' is seen differently than the true outport.
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::ForLoop, YACS::ENGINE::OptimizerLoop, and YACS::ENGINE::Switch.
Definition at line 1276 of file ComposedNode.cxx.
1277{
1278 string portName, nodeName;
1279 if(splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,false))
1280 {
1281 Node *child = getChildByShortName(nodeName);
1282 return child->getOutPort(portName);
1283 }
1284 else
1285 {
1286 string what("ComposedNode::getOutPort : the port with name "); what+=name; what+=" does not exist on the current level";
1287 throw Exception(what);
1288 }
1289}
virtual OutPort * getOutPort(const std::string &name) const
Definition: Node.cxx:275
References getChildByShortName(), YACS::ENGINE::Node::getOutPort(), YACS::ENGINE::Node::SEP_CHAR_IN_PORT, and splitNamesBySep().
Referenced by YACS::ENGINE::Bloc::Bloc(), YACS::ENGINE::DynParaLoop::getOutPort(), YACS::ENGINE::ForLoop::getOutPort(), YACS::ENGINE::Switch::getOutPort(), and YACS::ENGINE::WhileLoop::WhileLoop().
◆ getOutPortName()
◆ getOutputDataStreamPort()
OutputDataStreamPort * ComposedNode::getOutputDataStreamPort ( const std::string &  name) const
Definition at line 1352 of file ComposedNode.cxx.
1353{
1354 string portName, nodeName;
1355 if(splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,true))
1356 {
1357 Node *child = getChildByName(nodeName);
1358 return child->getOutputDataStreamPort(portName);
1359 }
1360 else
1361 {
1362 string what("ComposedNode::getOutputDataStreamPort : the port with name "); what+=name; what+=" does not exist on the current level";
1363 throw Exception(what);
1364 }
1365}
virtual OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const =0
References getChildByName(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::ENGINE::Node::SEP_CHAR_IN_PORT, and splitNamesBySep().
◆ getOutputPort()
OutputPort * ComposedNode::getOutputPort ( const std::string &  name) const
Get an output port given its name.
Contrary to YACS::ENGINE::ComposedNode::getInputPort, this method is recursive and go down hierarchy step by step to complete its work.
Definition at line 1322 of file ComposedNode.cxx.
1323{
1324 string portName, nodeName;
1325 if(splitNamesBySep(name,Node::SEP_CHAR_IN_PORT,nodeName,portName,false))
1326 {
1327 Node *child = getChildByShortName(nodeName);
1328 return child->getOutputPort(portName);
1329 }
1330 else
1331 {
1332 string what("ComposedNode::getOutputPort : the port with name "); what+=name; what+=" does not exist on the current level";
1333 throw Exception(what);
1334 }
1335}
virtual OutputPort * getOutputPort(const std::string &name) const =0
References getChildByShortName(), YACS::ENGINE::Node::getOutputPort(), YACS::ENGINE::Node::SEP_CHAR_IN_PORT, and splitNamesBySep().
Referenced by YACS::ENGINE::DynParaLoop::getOutputPort(), and YACS::ENGINE::ForLoop::getOutputPort().
◆ getPortName()
template<class PORT >
std::string YACS::ENGINE::ComposedNode::getPortName ( const PORT *  port) const
◆ getProgress()
virtual std::string YACS::ENGINE::ComposedNode::getProgress ( ) const
Reimplemented in YACS::ENGINE::ForEachLoopGen, and YACS::ENGINE::ForLoop.
Definition at line 126 of file ComposedNode.hxx.
126{ return "0"; }
◆ getProgressWeight()
list< ProgressWeight > ComposedNode::getProgressWeight ( ) const
Get the progress weight for all elementary nodes.
Only elementary nodes have weight. A simple composed node only sum up weight of all his descendants (working is different for loop or switch nodes)
Reimplemented in YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::ForLoop, and YACS::ENGINE::Switch.
Definition at line 1183 of file ComposedNode.cxx.
1184{
1185 list<ProgressWeight> ret;
1186 list<Node *> setOfNode=edGetDirectDescendants();
1187 for(list<Node *>::const_iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
1188 {
1189 list<ProgressWeight> myCurrentSet=((ComposedNode*)(*iter))->getProgressWeight();
1190 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
1191 }
1192 return ret;
1193}
std::list< ProgressWeight > getProgressWeight() const
References edGetDirectDescendants(), and getProgressWeight().
Referenced by YACS::ENGINE::Proc::getGlobalProgressPercent(), and getProgressWeight().
◆ getProperty()
std::string ComposedNode::getProperty ( const std::string &  name)
overridevirtual
Definition at line 1509 of file ComposedNode.cxx.
1510{
1511 return Node::getProperty(name);
1512}
virtual std::string getProperty(const std::string &name)
Definition: Node.cxx:497
References YACS::ENGINE::Node::getProperty().
Referenced by YACS::ENGINE::Node::getProperty().
◆ getRecursiveConstituents()
list< ElementaryNode * > ComposedNode::getRecursiveConstituents ( ) const
Definition at line 1121 of file ComposedNode.cxx.
1122{
1123 list<ElementaryNode *> ret;
1124 list<Node *> setOfNode=edGetDirectDescendants();
1125 for(list<Node *>::const_iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
1126 {
1127 list<ElementaryNode *> myCurrentSet=(*iter)->getRecursiveConstituents();
1128 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
1129 }
1130 return ret;
1131}
Referenced by checkDeploymentTree(), getDeploymentTree(), performDuplicationOfPlacement(), and performShallowDuplicationOfPlacement().
◆ getRootNode()
ComposedNode * ComposedNode::getRootNode ( ) const
Definition at line 927 of file ComposedNode.cxx.
928{
929 if(!_father)
930 return (ComposedNode *)this;
931 return Node::getRootNode();
932}
virtual ComposedNode * getRootNode() const
Definition: Node.cxx:431
References YACS::ENGINE::Node::_father, and YACS::ENGINE::Node::getRootNode().
Referenced by YACS::HMI::GuiExecutor::updateSchema().
◆ getSetOfInputDataStreamPort()
list< InputDataStreamPort * > ComposedNode::getSetOfInputDataStreamPort ( ) const
Definition at line 1252 of file ComposedNode.cxx.
1253{
1254 list<Node *> constituents=edGetDirectDescendants();
1255 list<InputDataStreamPort *> ret;
1256 for(list<Node *>::iterator iter=constituents.begin();iter!=constituents.end();iter++)
1257 {
1258 list<InputDataStreamPort *> currentsPorts=(*iter)->getSetOfInputDataStreamPort();
1259 ret.insert(ret.end(),currentsPorts.begin(),currentsPorts.end());
1260 }
1261 return ret;
1262}
Referenced by YACS::HMI::SubjectComposedNode::loadChildren().
◆ getSetOfInputPort()
list< InputPort * > ComposedNode::getSetOfInputPort ( ) const
Definition at line 1228 of file ComposedNode.cxx.
1229{
1230 list<Node *> constituents=edGetDirectDescendants();
1231 list<InputPort *> ret;
1232 for(list<Node *>::iterator iter=constituents.begin();iter!=constituents.end();iter++)
1233 {
1234 list<InputPort *> currentsPorts=(*iter)->getSetOfInputPort();
1235 ret.insert(ret.end(),currentsPorts.begin(),currentsPorts.end());
1236 }
1237 return ret;
1238}
Referenced by checkConsistency(), YACS::ENGINE::DynParaLoop::getSetOfInputPort(), YACS::ENGINE::Loop::getSetOfInputPort(), and YACS::ENGINE::Switch::getSetOfInputPort().
◆ getSetOfInternalLinks()
std::vector< std::pair< OutPort *, InPort * > > ComposedNode::getSetOfInternalLinks ( ) const
Definition at line 587 of file ComposedNode.cxx.
588{
589 vector< pair<OutPort *, InPort *> > ret;
590 list<OutPort *> temp=getSetOfOutPort();
591 for(list<OutPort *>::const_iterator iter2=temp.begin();iter2!=temp.end();iter2++)
592 {
593 set<InPort *> temp2=(*iter2)->edSetInPort();
594 for(set<InPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
595 if(isInMyDescendance((*iter3)->getNode()))
596 ret.push_back(pair<OutPort *, InPort *>((*iter2),(*iter3)));
597 }
598 return ret;
599}
Referenced by YACS::ENGINE::Bloc::Bloc(), YACS::ENGINE::ForLoop::ForLoop(), YACS::HMI::SubjectComposedNode::loadLinks(), and YACS::ENGINE::WhileLoop::WhileLoop().
◆ getSetOfLinksComingInCurrentScope()
std::vector< std::pair< InPort *, OutPort * > > ComposedNode::getSetOfLinksComingInCurrentScope ( ) const
Definition at line 835 of file ComposedNode.cxx.
836{
837 vector< pair<InPort *, OutPort *> > ret;
839 for(set<InPort *>::iterator iter2=ports.begin();iter2!=ports.end();iter2++)
840 {
841 set<OutPort *> temp2=(*iter2)->edSetOutPort();
842 for(set<OutPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
843 {
844 if(isInMyDescendance((*iter3)->getNode()))continue;
845 std::set<OutPort *> trueOutPorts;
846 (*iter3)->getAllRepresented(trueOutPorts);
847 for(std::set<OutPort *>::iterator iter4=trueOutPorts.begin();iter4!=trueOutPorts.end();++iter4)
848 ret.push_back(pair<InPort *, OutPort *>(*iter2,*iter4));
849 }
850 }
851 return ret;
852}
std::set< InPort * > getAllInPortsComingFromOutsideOfCurrentScope() const
List all input ports that are linked to out of scope ports.
References getAllInPortsComingFromOutsideOfCurrentScope(), and isInMyDescendance().
Referenced by edDisconnectAllLinksWithMe().
◆ getSetOfLinksLeavingCurrentScope()
std::vector< std::pair< OutPort *, InPort * > > ComposedNode::getSetOfLinksLeavingCurrentScope ( ) const
Definition at line 601 of file ComposedNode.cxx.
602{
603 vector< pair<OutPort *, InPort *> > ret;
604 std::set<OutPort *> ports=getAllOutPortsLeavingCurrentScope();
605 for(set<OutPort *>::iterator iter2=ports.begin();iter2!=ports.end();iter2++)
606 {
607 set<InPort *> temp2=(*iter2)->edSetInPort();
608 for(set<InPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
609 if(!isInMyDescendance((*iter3)->getNode()))
610 ret.push_back(pair<OutPort *, InPort *>(*iter2,*iter3));
611 }
612 return ret;
613}
std::set< OutPort * > getAllOutPortsLeavingCurrentScope() const
List all output ports of children nodes that are linked to out of scope input ports.
References getAllOutPortsLeavingCurrentScope(), and isInMyDescendance().
◆ getSetOfOutputDataStreamPort()
list< OutputDataStreamPort * > ComposedNode::getSetOfOutputDataStreamPort ( ) const
Definition at line 1264 of file ComposedNode.cxx.
1265{
1266 list<Node *> constituents=edGetDirectDescendants();
1267 list<OutputDataStreamPort *> ret;
1268 for(list<Node *>::iterator iter=constituents.begin();iter!=constituents.end();iter++)
1269 {
1270 list<OutputDataStreamPort *> currentsPorts=(*iter)->getSetOfOutputDataStreamPort();
1271 ret.insert(ret.end(),currentsPorts.begin(),currentsPorts.end());
1272 }
1273 return ret;
1274}
◆ getSetOfOutputPort()
list< OutputPort * > ComposedNode::getSetOfOutputPort ( ) const
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForLoop, and YACS::ENGINE::OptimizerLoop.
Definition at line 1240 of file ComposedNode.cxx.
1241{
1242 list<Node *> constituents=edGetDirectDescendants();
1243 list<OutputPort *> ret;
1244 for(list<Node *>::iterator iter=constituents.begin();iter!=constituents.end();iter++)
1245 {
1246 list<OutputPort *> currentsPorts=(*iter)->getSetOfOutputPort();
1247 ret.insert(ret.end(),currentsPorts.begin(),currentsPorts.end());
1248 }
1249 return ret;
1250}
Referenced by YACS::ENGINE::DynParaLoop::getSetOfOutputPort(), and YACS::ENGINE::ForLoop::getSetOfOutputPort().
◆ getTaskName()
std::string ComposedNode::getTaskName ( Task *  task) const
Definition at line 170 of file ComposedNode.cxx.
171{
172 return getChildName(dynamic_cast<ElementaryNode *>(task));
173}
References getChildName().
◆ init()
void ComposedNode::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Reimplemented from YACS::ENGINE::Node.
Reimplemented in YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, YACS::ENGINE::ForLoop, YACS::ENGINE::Loop, YACS::ENGINE::OptimizerLoop, YACS::ENGINE::Switch, YACS::ENGINE::WhileLoop, and YACS::ENGINE::SalomeProc.
Definition at line 160 of file ComposedNode.cxx.
161{
162 Node::init(start);
163}
virtual void init(bool start=true)
Definition: Node.cxx:102
References YACS::ENGINE::Node::init().
Referenced by YACS::ENGINE::DynParaLoop::init(), YACS::ENGINE::Loop::init(), and YACS::ENGINE::Switch::init().
◆ isFinished()
bool ComposedNode::isFinished ( )
◆ isInMyDescendance()
Node * ComposedNode::isInMyDescendance ( Node *  nodeToTest) const
Returns the parent of a node that is the direct child of this node.
if 'nodeToTest'=='this' this is returned. Else if 'nodeToTest' is in descendance of 'this' the direct son is returned. Else 0 is returned.
nodeToTest: the node to check
Definition at line 949 of file ComposedNode.cxx.
950{
951 if(nodeToTest==0)
952 return 0;
953 if((ComposedNode *)nodeToTest==this)
954 return (Node *)this;
955 Node *iterBack=nodeToTest;
956 ComposedNode *iter=nodeToTest->_father;
957 while(iter!=0 && iter!=this)
958 {
959 iterBack=iter;
960 iter=iter->_father;
961 }
962 if(iter!=0)
963 return iterBack;
964 else
965 return 0;
966}
References YACS::ENGINE::Node::_father.
Referenced by YACS::ENGINE::DynParaLoop::buildDelegateOf(), YACS::ENGINE::Loop::buildDelegateOf(), YACS::ENGINE::Bloc::checkCFLinks(), checkCFLinks(), YACS::ENGINE::DynParaLoop::checkCFLinks(), YACS::ENGINE::ForLoop::checkCFLinks(), checkConsistency(), YACS::ENGINE::Bloc::checkControlDependancy(), YACS::ENGINE::DynParaLoop::checkLinkPossibility(), YACS::ENGINE::OptimizerLoop::checkLinkPossibility(), YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), getAllInPortsComingFromOutsideOfCurrentScope(), YACS::ENGINE::Switch::getAllInPortsComingFromOutsideOfCurrentScope(), getAllOutPortsLeavingCurrentScope(), YACS::ENGINE::DynParaLoop::getDynInputPortByAbsName(), YACS::HMI::SceneBlocItem::getNodesInfo(), YACS::ENGINE::Switch::getRankOfNode(), getSetOfInternalLinks(), getSetOfLinksComingInCurrentScope(), getSetOfLinksLeavingCurrentScope(), YACS::ENGINE::OptimizerLoop::initInterceptors(), YACS::HMI::SubjectComposedNode::removeExternalControlLinks(), YACS::ENGINE::VisitorSaveSchema::writeControls(), YACS::ENGINE::VisitorSaveSchema::writeSimpleDataLinks(), and YACS::ENGINE::VisitorSaveSchema::writeSimpleStreamLinks().
◆ isLoop()
virtual bool YACS::ENGINE::ComposedNode::isLoop ( ) const
Reimplemented in YACS::ENGINE::DynParaLoop, and YACS::ENGINE::Loop.
Definition at line 79 of file ComposedNode.hxx.
79{ return false; }
Referenced by edAddLink().
◆ isNameAlreadyUsed()
bool ComposedNode::isNameAlreadyUsed ( const std::string &  name) const
Reimplemented in YACS::ENGINE::Bloc.
Definition at line 1527 of file ComposedNode.cxx.
1528{
1529 return false;
1530}
Referenced by YACS::ENGINE::Node::setName().
◆ isNodeAlreadyAggregated()
bool ComposedNode::isNodeAlreadyAggregated ( const Node *  node) const
Check that Node 'node' is already a direct son of this.
Definition at line 935 of file ComposedNode.cxx.
936{
937 list<ComposedNode *> nodeAncestors = node->getAllAscendanceOf();
938 return find(nodeAncestors.begin(),nodeAncestors.end(),(ComposedNode *)this)!=nodeAncestors.end();
939}
References YACS::ENGINE::Node::getAllAscendanceOf().
Referenced by YACS::ENGINE::Bloc::edAddChild(), and getChildName().
◆ isPlacementPredictableB4Run()
virtual bool YACS::ENGINE::ComposedNode::isPlacementPredictableB4Run ( ) const
pure virtual
◆ isRepeatedUnpredictablySeveralTimes()
virtual bool YACS::ENGINE::ComposedNode::isRepeatedUnpredictablySeveralTimes ( ) const
Definition at line 78 of file ComposedNode.hxx.
78{ return false; }
◆ loaded()
void ComposedNode::loaded ( )
Definition at line 1488 of file ComposedNode.cxx.
1489{
1490}
◆ notifyFrom()
void ComposedNode::notifyFrom ( const Task *  sender,
YACS::Event  event,
const Executor *  execInst
Notify the node a task has emitted an event.
TO COMMENT MORE
Runtime called method. Overloads the Scheduler::notifyFrom abstract method. Typically Called in Executor (in a parallel thread or not) by the Task 'task' to inform the scheduler that an event coded 'event' (in Executor static const var) happened. Contrary to updateStateFrom several levels may exist between 'sender' and 'this'.
sender: task emitting event
event: event emitted
Called by Executor::functionForTaskExecution on YACS::FINISH event
Called by Executor::launchTask on YACS::START event
Calls ComposedNode::updateStateFrom to update state from task to root node
Definition at line 243 of file ComposedNode.cxx.
247{
248 DEBTRACE("ComposedNode::notifyFrom " << event);
249 ElementaryNode *taskTyped=dynamic_cast<ElementaryNode *>((Task *)sender);
250 YACS::Event curEvent=event;
251 Node *lminus1LevelNode=taskTyped;
252 ComposedNode *curLevelNode=taskTyped->_father;
253 if(!curLevelNode)//Specific case of loop when 0 turn is specified without any enclosing bloc.
254 return ;
255 curEvent=curLevelNode->updateStateFrom(lminus1LevelNode,curEvent,execInst);
256 while(curEvent!=YACS::NOEVENT && curLevelNode!=this)
257 {
258 lminus1LevelNode=curLevelNode;
259 curLevelNode=curLevelNode->_father;
260 curEvent=curLevelNode->updateStateFrom(lminus1LevelNode,curEvent,execInst);
261 }
262}
YACS::Event updateStateFrom(Node *node, YACS::Event event, const Executor *execInst)
Update node state on receiving event from a node.
Event
Definition: define.hxx:56
@ NOEVENT
Definition: define.hxx:57
References YACS::ENGINE::Node::_father, DEBTRACE, YACS::NOEVENT, and updateStateFrom().
◆ performCFComputations()
void ComposedNode::performCFComputations ( LinkInfo &  info) const
perform recursively all CF computations.
Definition at line 678 of file ComposedNode.cxx.
679{
680 list<Node *> nodes=edGetDirectDescendants();
681 for(list<Node *>::iterator iter=nodes.begin();iter!=nodes.end();iter++)
682 if(dynamic_cast<ComposedNode *>(*iter))
683 ((ComposedNode *)(*iter))->performCFComputations(info);
684}
References edGetDirectDescendants(), and performCFComputations().
Referenced by checkConsistency(), YACS::ENGINE::Bloc::performCFComputations(), and performCFComputations().
◆ performDuplicationOfPlacement()
void ComposedNode::performDuplicationOfPlacement ( const Node &  other)
performs a duplication of placement using clone method of containers and components. clone behaviour is driven by attachOnCloning attribute.
Definition at line 66 of file ComposedNode.cxx.
67{
68 const ComposedNode &otherC=*(dynamic_cast<const ComposedNode *>(&other));
69 DeploymentTree treeToDup=otherC.getDeploymentTree();
70 list< ElementaryNode * > clones=otherC.getRecursiveConstituents();
71 vector<Container *> conts=treeToDup.getAllContainers();
72 //iterate on all containers
73 for(vector<Container *>::iterator iterCt=conts.begin();iterCt!=conts.end();iterCt++)
74 {
75 vector<ComponentInstance *> comps=treeToDup.getComponentsLinkedToContainer(*iterCt);
76 Container *contCloned=0;
77 if((*iterCt))
78 contCloned=(*iterCt)->clone();
79
80 //iterate on all component instances linked to the container
81 for(vector<ComponentInstance *>::iterator iterCp=comps.begin();iterCp!=comps.end();iterCp++)
82 {
83 vector<Task *> tasks=treeToDup.getTasksLinkedToComponent(*iterCp);
84 ComponentInstance *curCloned=(*iterCp)->clone();
85 curCloned->setContainer(contCloned);
86 for(vector<Task *>::iterator iterT=tasks.begin();iterT!=tasks.end();iterT++)
87 {
88 //No risk for static cast : appendTask called by ComposedNode.
89 list< ElementaryNode * >::iterator res=find(clones.begin(),clones.end(),(ElementaryNode *)(*iterT));
90 //No risk here to because called only on cloning process...
91 ServiceNode *nodeC=(ServiceNode *)getChildByName(otherC.getChildName(*res));
92 nodeC->setComponent(curCloned);
93 }
94 curCloned->decrRef();
95 }
96
97 // iterate on all tasks linked to the container
98 vector<Task *> tasks=treeToDup.getTasksLinkedToContainer(*iterCt);
99 for(vector<Task *>::iterator iterT=tasks.begin();iterT!=tasks.end();iterT++)
100 {
101 std::list< ElementaryNode * >::iterator res=find(clones.begin(),clones.end(),(ElementaryNode *)(*iterT));
103 nodeC->setContainer(contCloned);
104 }
105
106 // ended with current container
107 if(contCloned)
108 contCloned->decrRef();
109 }
110}
virtual bool setContainer(Container *cont)
virtual ComponentInstance * clone() const =0
DeploymentTree getDeploymentTree() const
Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is cons...
virtual Container * clone() const =0
WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method
std::vector< Task * > getTasksLinkedToComponent(ComponentInstance *comp) const
std::vector< ComponentInstance * > getComponentsLinkedToContainer(Container *cont) const
std::vector< Task * > getTasksLinkedToContainer(Container *cont) const
std::vector< Container * > getAllContainers() const
Definition: InlineNode.hxx:93
virtual void setContainer(Container *container)
Definition: InlineNode.cxx:105
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
References YACS::ENGINE::ComponentInstance::clone(), YACS::ENGINE::Container::clone(), YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::DeploymentTree::getAllContainers(), getChildByName(), getChildName(), YACS::ENGINE::DeploymentTree::getComponentsLinkedToContainer(), getDeploymentTree(), getRecursiveConstituents(), YACS::ENGINE::DeploymentTree::getTasksLinkedToComponent(), YACS::ENGINE::DeploymentTree::getTasksLinkedToContainer(), YACS::ENGINE::ServiceNode::setComponent(), YACS::ENGINE::ComponentInstance::setContainer(), and YACS::ENGINE::InlineNode::setContainer().
◆ performShallowDuplicationOfPlacement()
void ComposedNode::performShallowDuplicationOfPlacement ( const Node &  other)
performs a also duplication of placement but here containers and components are not copied at all whatever the value of attachedOnCloning.
Definition at line 112 of file ComposedNode.cxx.
113{
114 const ComposedNode &otherC=*(dynamic_cast<const ComposedNode *>(&other));
115 DeploymentTree treeToDup=otherC.getDeploymentTree();
116 list< ElementaryNode * > clones=otherC.getRecursiveConstituents();
117 vector<Container *> conts=treeToDup.getAllContainers();
118 //iterate on all containers
119 for(vector<Container *>::iterator iterCt=conts.begin();iterCt!=conts.end();iterCt++)
120 {
121 vector<ComponentInstance *> comps=treeToDup.getComponentsLinkedToContainer(*iterCt);
122 Container *contCloned((*iterCt));
123
124 //iterate on all component instances linked to the container
125 for(vector<ComponentInstance *>::iterator iterCp=comps.begin();iterCp!=comps.end();iterCp++)
126 {
127 vector<Task *> tasks=treeToDup.getTasksLinkedToComponent(*iterCp);
128 ComponentInstance *curCloned((*iterCp));
129 curCloned->setContainer(contCloned);
130 for(vector<Task *>::iterator iterT=tasks.begin();iterT!=tasks.end();iterT++)
131 {
132 //No risk for static cast : appendTask called by ComposedNode.
133 list< ElementaryNode * >::iterator res=find(clones.begin(),clones.end(),(ElementaryNode *)(*iterT));
134 //No risk here to because called only on cloning process...
135 ServiceNode *nodeC=(ServiceNode *)getChildByName(otherC.getChildName(*res));
136 nodeC->setComponent(curCloned);
137 }
138 }
139
140 // iterate on all tasks linked to the container
141 vector<Task *> tasks=treeToDup.getTasksLinkedToContainer(*iterCt);
142 for(vector<Task *>::iterator iterT=tasks.begin();iterT!=tasks.end();iterT++)
143 {
144 std::list< ElementaryNode * >::iterator res=find(clones.begin(),clones.end(),(ElementaryNode *)(*iterT));
146 nodeC->setContainer(contCloned);
147 }
148 }
149}
References YACS::ENGINE::DeploymentTree::getAllContainers(), getChildByName(), getChildName(), YACS::ENGINE::DeploymentTree::getComponentsLinkedToContainer(), getDeploymentTree(), getRecursiveConstituents(), YACS::ENGINE::DeploymentTree::getTasksLinkedToComponent(), YACS::ENGINE::DeploymentTree::getTasksLinkedToContainer(), YACS::ENGINE::ServiceNode::setComponent(), YACS::ENGINE::ComponentInstance::setContainer(), and YACS::ENGINE::InlineNode::setContainer().
◆ releaseDelegateOf() [1/2]
void ComposedNode::releaseDelegateOf ( InPort *&  port,
OutPort *  initialStart,
const std::list< ComposedNode * > &  pointsOfView
Definition at line 1480 of file ComposedNode.cxx.
1481{
1482}
Referenced by edRemoveLink().
◆ releaseDelegateOf() [2/2]
void ComposedNode::releaseDelegateOf ( OutPort *  portDwn,
OutPort *  portUp,
InPort *  finalTarget,
Definition at line 1484 of file ComposedNode.cxx.
1485{
1486}
◆ removeRecursivelyRedundantCL()
void ComposedNode::removeRecursivelyRedundantCL ( )
This method recursively all redundant control links in this.
Definition at line 1110 of file ComposedNode.cxx.
1111{
1112 std::list<Node *> dd(edGetDirectDescendants());
1113 for(std::list<Node *>::const_iterator it=dd.begin();it!=dd.end();it++)
1114 {
1115 ComposedNode *elt(dynamic_cast<ComposedNode *>(*it));
1116 if(elt)
1117 elt->removeRecursivelyRedundantCL();
1118 }
1119}
References edGetDirectDescendants(), and removeRecursivelyRedundantCL().
Referenced by YACS::ENGINE::Bloc::removeRecursivelyRedundantCL(), and removeRecursivelyRedundantCL().
◆ resetState()
void ComposedNode::resetState ( int  level)
Reset the state of the node and its children depending on the parameter level.
Reimplemented in YACS::ENGINE::ForEachLoopGen.
Definition at line 1638 of file ComposedNode.cxx.
1639{
1640 if(level==0)return;
1641
1642 DEBTRACE("ComposedNode::resetState " << level << "," << _state);
1644 {
1645 Node::resetState(level);
1646 std::list<Node *> nodes=edGetDirectDescendants();
1647 for(std::list<Node *>::iterator iter=nodes.begin();iter!=nodes.end();iter++)
1648 (*iter)->resetState(level);
1649 }
1650}
virtual void resetState(int level)
Reset the node state depending on the parameter level.
Definition: Node.cxx:851
@ ACTIVATED
Definition: define.hxx:41
References YACS::ENGINE::Node::_state, YACS::ACTIVATED, DEBTRACE, edGetDirectDescendants(), YACS::ERROR, YACS::FAILED, and YACS::ENGINE::Node::resetState().
Referenced by main(), and YACS::ENGINE::ForEachLoopGen::resetState().
◆ setProperty()
void ComposedNode::setProperty ( const std::string &  name,
const std::string &  value
overridevirtual
Definition at line 1504 of file ComposedNode.cxx.
1505{
1506 Node::setProperty(name, value);
1507}
virtual void setProperty(const std::string &name, const std::string &value)
Definition: Node.cxx:491
References YACS::ENGINE::Node::setProperty().
◆ shutdown()
void ComposedNode::shutdown ( int  level)
Stop all pending activities of the composed node.
This method should be called when a Proc is finished and must be deleted from the YACS server
Definition at line 1616 of file ComposedNode.cxx.
1617{
1618 if(level==0)return;
1619 DEBTRACE("ComposedNode::shutdown");
1620 list<Node *> nodes=edGetDirectDescendants();
1621 for(list<Node *>::iterator iter=nodes.begin();iter!=nodes.end();iter++)
1622 (*iter)->shutdown(level);
1623}
References DEBTRACE, and edGetDirectDescendants().
Referenced by Handler(), and main().
◆ solveObviousOrDelegateCFLinks()
void ComposedNode::solveObviousOrDelegateCFLinks ( const std::list< OutPort * > &  starts,
InputPort *  end,
unsigned char &  alreadyFed,
bool  direction,
LinkInfo &  info
Internal method during CF links. This methode is in charge to statuate on links consistency in the case that no control flow defined by user is set.
Definition at line 757 of file ComposedNode.cxx.
758{
759 static const char what[]="ComposedNode::solveObviousOrDelegateCFLinks : Internal error occured - uncorrect hierarchy detected !";
760 if(starts.size()==1)
761 {
762 if(alreadyFed==FREE_ST)
763 {
764 if(!direction)
765 info.pushInfoLink(*(starts.begin()),end,I_BACK);
766 alreadyFed=FED_ST;
767 }
768 else if(alreadyFed==FED_ST)
769 info.pushInfoLink(*(starts.begin()),end,direction ? I_USELESS : I_BACK_USELESS);
770 else
771 info.pushErrLink(*(starts.begin()),end,E_COLLAPSE_DFDS);
772 }
773 else
774 {
775 Node *levelOfDecision=getLowestNodeDealingAll(starts);
776 if(levelOfDecision==this)
777 throw Exception(what);
778 if(dynamic_cast<ElementaryNode *>(levelOfDecision))
779 {
780 WarnReason reason;
781 if(alreadyFed==FREE_ST || alreadyFed==FED_ST)
782 {
783 if(alreadyFed==FREE_ST)
784 {
785 reason=direction ? W_COLLAPSE_EL : W_BACK_COLLAPSE_EL;
786 alreadyFed=FED_ST;
787 }
788 else
790 for(list< OutPort *>::const_iterator iter=starts.begin();iter!=starts.end();iter++)
791 info.pushWarnLink(*iter,end,reason);
792 }
793 }
794 else
795 ((ComposedNode *)levelOfDecision)->checkCFLinks(starts,end,alreadyFed,direction,info);
796 }
797}
Node * getLowestNodeDealingAll(const std::list< OutPort * > &ports) const
@ W_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:59
@ W_BACK_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:63
References YACS::ENGINE::E_COLLAPSE_DFDS, FED_ST, FREE_ST, getLowestNodeDealingAll(), YACS::ENGINE::I_BACK, YACS::ENGINE::I_BACK_USELESS, YACS::ENGINE::I_USELESS, YACS::ENGINE::LinkInfo::pushErrLink(), YACS::ENGINE::LinkInfo::pushInfoLink(), YACS::ENGINE::LinkInfo::pushWarnLink(), YACS::ENGINE::W_BACK_COLLAPSE_EL, YACS::ENGINE::W_BACK_COLLAPSE_EL_AND_USELESS, YACS::ENGINE::W_COLLAPSE_EL, and YACS::ENGINE::W_COLLAPSE_EL_AND_USELESS.
Referenced by checkCFLinks(), YACS::ENGINE::DynParaLoop::checkCFLinks(), YACS::ENGINE::ForLoop::checkCFLinks(), YACS::ENGINE::Loop::checkCFLinks(), and YACS::ENGINE::OptimizerLoop::checkCFLinks().
◆ splitNamesBySep()
bool ComposedNode::splitNamesBySep ( const std::string &  globalName,
std::string &  firstPart,
std::string &  lastPart,
bool  priority
staticprotected
Splits name globalName in 2 parts using separator.
'priority' specifies if during search process of 'separator' the max part is for 'firstPart' (priority=true) or 'lastPart' (priority=false).
Exceptions
Exception: 'lastPart' or 'firstPart' is empty.
true if split process succeeds false otherwise (typically when character separator was not found).
Definition at line 561 of file ComposedNode.cxx.
563{
564 const string delims(separator);
565 string portName, nodeName;
566 string::size_type idx;
567 if(priority)
568 idx = globalName.find_last_of(delims);
569 else
570 idx = globalName.find_first_of(delims);
571 if (idx == string::npos)
572 {
573 firstPart=globalName;
574 lastPart="";
575 return false;
576 }
577 firstPart = globalName.substr(0,idx);
578 lastPart = globalName.substr(idx+1);
579 if ((firstPart.empty()) || (lastPart.empty()))
580 {
581 string what("the name "); what+= globalName ; what+=" is not a valid port name";
582 throw Exception(what);
583 }
584 return true;
585}
Referenced by getChildByName(), YACS::ENGINE::DynParaLoop::getDynInputPortByAbsName(), YACS::ENGINE::ForEachLoopGen::getDynOutPortByAbsName(), getInputDataStreamPort(), getInputPort(), getOutPort(), getOutputDataStreamPort(), and getOutputPort().
◆ typeName()
virtual std::string YACS::ENGINE::ComposedNode::typeName ( )
◆ updateStateFrom()
YACS::Event ComposedNode::updateStateFrom ( Node *  node,
YACS::Event  event,
Runtime called method. Perform, the state updating, from the son node 'node' emitting the event 'event' (among Executor static const var). WARNING Precondition : this == node->_father
The event (among Executor static const var) destinated to this->_father node to perform eventually up level update.
Calls ComposedNode::updateStateOnStartEventFrom if event is YACS::START
Calls ComposedNode::updateStateOnFinishedEventFrom if event is YACS::FINISH
Called by ComposedNode::notifyFrom
Definition at line 1382 of file ComposedNode.cxx.
1386{
1387 DEBTRACE("updateStateFrom: " << node->getName() << " " << event);
1388 try
1389 {
1390 switch(event)
1391 {
1392 case YACS::START:
1393 return updateStateOnStartEventFrom(node);
1394 break;
1395 case YACS::FINISH:
1396 return updateStateOnFinishedEventFrom(node);
1397 break;
1398 case YACS::ABORT:
1399 return updateStateOnFailedEventFrom(node,execInst);
1400 break;
1401 default:
1402 return YACS::NOEVENT;//TODO unexpected type of event
1403 break;
1404 }
1405 }
1406 catch(YACS::Exception& ex)
1407 {
1408 //unexpected exception: probably a bug in engine
1409 //try to keep a consistent global state
1410 DEBTRACE( "updateStateFrom: " << ex.what() );
1411 _errorDetails="Internal error: ";
1415 return YACS::ABORT;
1416 }
1417 catch(...)
1418 {
1419 //unexpected exception: probably a bug in engine
1420 //try to keep a consistent global state
1423 return YACS::ABORT;
1424 }
1425}
virtual YACS::Event updateStateOnFailedEventFrom(Node *node, const Executor *execInst)
Method used to notify the node that a child node has failed.
virtual YACS::Event updateStateOnFinishedEventFrom(Node *node)=0
virtual YACS::Event updateStateOnStartEventFrom(Node *node)
Method used to notify the node that a child node has started.
virtual void exForwardFailed()
Definition: Node.cxx:378
@ ABORT
Definition: define.hxx:60
@ START
Definition: define.hxx:58
@ FINISH
Definition: define.hxx:59
References YACS::ENGINE::Node::_errorDetails, YACS::ABORT, DEBTRACE, YACS::ERROR, testCppPluginInvokation::ex, YACS::ENGINE::Node::exForwardFailed(), YACS::FINISH, YACS::ENGINE::Node::getName(), YACS::NOEVENT, YACS::ENGINE::Node::setState(), YACS::START, updateStateOnFailedEventFrom(), updateStateOnFinishedEventFrom(), and updateStateOnStartEventFrom().
Referenced by notifyFrom().
◆ updateStateOnFailedEventFrom()
YACS::Event ComposedNode::updateStateOnFailedEventFrom ( Node *  node,
Reimplemented in YACS::ENGINE::Bloc, YACS::ENGINE::DynParaLoop, YACS::ENGINE::ForEachLoopGen, and YACS::ENGINE::OptimizerLoop.
Definition at line 1441 of file ComposedNode.cxx.
1442{
1444 return YACS::ABORT;
1445}
References YACS::ABORT, YACS::FAILED, and YACS::ENGINE::Node::setState().
Referenced by updateStateFrom().
◆ updateStateOnFinishedEventFrom()
virtual YACS::Event YACS::ENGINE::ComposedNode::updateStateOnFinishedEventFrom ( Node *  node)
protectedpure virtual
◆ updateStateOnStartEventFrom()
YACS::Event ComposedNode::updateStateOnStartEventFrom ( Node *  node)
Update the ComposedNode state and return the ComposedNode change state
node: the child node that has started
the loop state change
Definition at line 1434 of file ComposedNode.cxx.
1435{
1437 return YACS::START;
1438}
References YACS::ACTIVATED, YACS::ENGINE::Node::setState(), and YACS::START.
◆ Bloc
friend class Bloc
friend
Definition at line 44 of file ComposedNode.hxx.
Referenced by YACS::ENGINE::Bloc::simpleClone().
◆ ElementaryNode
friend class ElementaryNode
friend
Definition at line 47 of file ComposedNode.hxx.
◆ Loop
friend class Loop
friend
Definition at line 45 of file ComposedNode.hxx.
◆ OutPort
friend class OutPort
friend
Definition at line 46 of file ComposedNode.hxx.
◆ FED_DS_ST
const unsigned char YACS::ENGINE::ComposedNode::FED_DS_ST = 1
staticprotected
◆ FED_ST
◆ FREE_ST
◆ SEP_CHAR_BTW_LEVEL
const char ComposedNode::SEP_CHAR_BTW_LEVEL ="."
