YACS::ENGINE::SalomeOptimizerLoop Class Reference
class to build optimization loops More...
#include <SalomeOptimizerLoop.hxx>
Inheritance diagram for YACS::ENGINE::SalomeOptimizerLoop:
Collaboration diagram for YACS::ENGINE::SalomeOptimizerLoop:
 SalomeOptimizerLoop (const std::string &name, const std::string &algLibWthOutExt, const std::string &symbolNameToOptimizerAlgBaseInstanceFactory, bool algInitOnFile, bool initAlgo=true, Proc *procForTypes=NULL)
 SalomeOptimizerLoop (const SalomeOptimizerLoop &other, ComposedNode *father, bool editionOnly)
 ~SalomeOptimizerLoop ()
- Public Member Functions inherited from YACS::ENGINE::OptimizerLoop
 OptimizerLoop (const OptimizerLoop &other, ComposedNode *father, bool editionOnly)
 ~OptimizerLoop ()
void init (bool start=true)
void exUpdateState ()
InputPort * edGetPortForOutPool ()
InputPort * edGetAlgoInitPort ()
OutputPort * edGetAlgoResultPort ()
 Get an input port given its name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
void selectRunnableTasks (std::vector< Task * > &tasks)
YACS::Event updateStateOnFinishedEventFrom (Node *node)
void checkNoCyclePassingThrough (Node *node)
virtual std::string getSymbol () const
virtual std::string getAlgLib () const
 Return the name of the algorithm library. More...
virtual void setAlgorithm (const std::string &alglib, const std::string &symbol, bool checkLinks=true, Proc *procForTypes=NULL)
 Set the algorithm library name and factory name (symbol in library) to create the algorithm and change it if the node is not connected. More...
 Check validity for the node. More...
OutPort * getOutPort (const std::string &name) const
 Get an output port given its name. More...
YACS::Event finalize ()
- Public Member Functions inherited from YACS::ENGINE::DynParaLoop
Node * edRemoveNode ()
Node * edRemoveInitNode ()
Node * edRemoveFinalizeNode ()
Node * edSetNode (Node *DISOWNnode)
Node * edSetInitNode (Node *DISOWNnode)
Node * edSetFinalizeNode (Node *DISOWNnode)
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add control link if necessary. More...
InputPort * edGetNbOfBranchesPort ()
unsigned getNumberOfEltsConsumed () const
int getBranchIDOfNode (Node *node) const
OutputPort * edGetSamplePort ()
bool isPlacementPredictableB4Run () const
 For the moment false is returned : impovement about it coming soon. More...
void edRemoveChild (Node *node)
 Remove a child node. More...
bool isLoop () const override
virtual bool edAddChild (Node *DISOWNnode)
std::list< Node * > edGetDirectDescendants () const
unsigned getNumberOfBranchesCreatedDyn () const
Node * getChildByShortName (const std::string &name) const
Node * getChildByNameExec (const std::string &name, unsigned id) const
std::vector< Node * > getNodes () const
ComplexWeight * getWeight ()
void setWeight (double loopWeight)
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
Node * getInitNode ()
Node * getExecNode ()
Node * getFinalizeNode ()
virtual void cleanDynGraph ()
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
Node * simpleClone (ComposedNode *father, bool editionOnly) const
virtual void loadAlgorithm ()
 Load the algorithm object from a Python module or a dynamic library. More...
- Protected Member Functions inherited from YACS::ENGINE::OptimizerLoop
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
void cleanInterceptors ()
void launchMaxOfSamples (bool first)
bool isFullyLazy () const
bool isFullyBusy (unsigned &branchId) const
void initInterceptors (unsigned nbOfBr)
void pushValueOutOfScopeForCase (unsigned branchId)
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
 Load the algorithm from the dynamic library. More...
- Protected Member Functions inherited from YACS::ENGINE::DynParaLoop
 DynParaLoop (const std::string &name, TypeCode *typeOfDataSplitted, std::unique_ptr< NbBranchesAbstract > &&branchManager)
virtual ~DynParaLoop ()
 DynParaLoop (const DynParaLoop &other, ComposedNode *father, bool editionOnly)
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
void prepareInputsFromOutOfScope (int branchNb)
void putValueOnBranch (Any *val, unsigned branchId, bool first)
TypeOfNode getIdentityOfNotifyerNode (const Node *node, unsigned &id)
InputPort * getDynInputPortByAbsName (int branchNb, const std::string &name, bool initNodeAdmitted)
virtual void forwardExecStateToOriginalBody (Node *execNode)
std::vector< Node * > cloneAndPlaceNodesCoherently (const std::vector< Node * > &origNodes)
 Clone nodes and make their placement consistent with the placement of the original ones. More...
Node * checkConsistencyAndSetNode (Node *&nodeToReplace, Node *DISOWNnode)
 This method is used to factorize methods edSetNode, edSetInitNode and edSetFinalizeNode. More...
Node * removeNode (Node *&nodeToRemove)
 This method is used to factorize methods edRemoveNode, edRemoveInitNode and edRemoveFinalizeNode. More...
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const std::string &name)
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
PyObject * _pyAlgo = nullptr
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Protected Types inherited from YACS::ENGINE::DynParaLoop
enum  TypeOfNode { INIT_NODE = 5 , WORK_NODE = 6 , FINALIZE_NODE = 7 }
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
- Protected Attributes inherited from YACS::ENGINE::OptimizerLoop
Pool _myPool
bool _algInitOnFile
std::string _symbol
std::string _alglib
AnyInputPort _algoInitPort
::YACS::BASES::DynLibLoader * _loader
OptimizerAlgBase * _alg
AnyInputPort _retPortForOutPool
std::vector< bool > _initNodeUpdated
bool _convergenceReachedWithOtherCalc
FakeNodeForOptimizerLoop * _nodeForSpecialCases
std::vector< AnyInputPort * > _interceptorsForOutPool
std::map< InputPort *, std::vector< InputPort * > > _interceptors
 outputports interceptors leaving current scope. More...
AnyOutputPort _algoResultPort
- Protected Attributes inherited from YACS::ENGINE::DynParaLoop
Node * _node
Node * _initNode
Node * _finalizeNode
unsigned _nbOfEltConsumed
std::vector< int > _execIds
std::unique_ptr< NbBranchesAbstract > _nbOfBranches
AnyOutputPort _splittedPort
std::vector< Node * > _execNodes
std::vector< Node * > _execInitNodes
std::vector< Node * > _execFinalizeNodes
int _initializingCounter
int _unfinishedCounter
int _failedCounter
ComplexWeight _weight
double _loopWeight
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
- Static Protected Attributes inherited from YACS::ENGINE::OptimizerLoop
static const int NOT_RUNNING_BRANCH_ID =-1973012217
static const int NOT_INITIALIZED_BRANCH_ID =-1973
static const char NAME_OF_ALGO_INIT_PORT [] = "algoInit"
static const char NAME_OF_OUT_POOL_INPUT [] = "evalResults"
static const char NAME_OF_ALGO_RESULT_PORT [] = "algoResults"
- Static Protected Attributes inherited from YACS::ENGINE::DynParaLoop
static const char NAME_OF_SPLITTED_SEQ_OUT [] = "evalSamples"
static const char OLD_NAME_OF_SPLITTED_SEQ_OUT [] = "SmplPrt"
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
Definition at line 31 of file SalomeOptimizerLoop.hxx.
◆ SalomeOptimizerLoop() [1/2]
SalomeOptimizerLoop::SalomeOptimizerLoop ( const std::string &  name,
const std::string &  algLibWthOutExt,
const std::string &  symbolNameToOptimizerAlgBaseInstanceFactory,
bool  algInitOnFile,
bool  initAlgo = true,
Proc *  procForTypes = NULL
Definition at line 47 of file SalomeOptimizerLoop.cxx.
49 :
50 OptimizerLoop(name,algLibWthOutExt,symbolNameToOptimizerAlgBaseInstanceFactory,algInitOnFile,false)
51{
52 if(initAlgo)
53 {
54 //try
55 // {
56 setAlgorithm(algLibWthOutExt, symbolNameToOptimizerAlgBaseInstanceFactory, true, procForTypes);
57 // }
58 //catch(YACS::Exception& e)
59 // {
60 //ignore it
61 // }
62 }
63}
virtual void setAlgorithm(const std::string &alglib, const std::string &symbol, bool checkLinks=true, Proc *procForTypes=NULL)
Set the algorithm library name and factory name (symbol in library) to create the algorithm and chang...
OptimizerLoop(const std::string &name, const std::string &algLibWthOutExt, const std::string &symbolNameToOptimizerAlgBaseInstanceFactory, bool algInitOnFile, bool initAlgo=true, Proc *procForTypes=NULL)
References YACS::ENGINE::OptimizerLoop::setAlgorithm().
Referenced by simpleClone().
◆ SalomeOptimizerLoop() [2/2]
SalomeOptimizerLoop::SalomeOptimizerLoop ( const SalomeOptimizerLoop &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 65 of file SalomeOptimizerLoop.cxx.
65 :
66 OptimizerLoop(other,father,editionOnly)
67{
68}
◆ ~SalomeOptimizerLoop()
SalomeOptimizerLoop::~SalomeOptimizerLoop ( )
Definition at line 70 of file SalomeOptimizerLoop.cxx.
71{
72 Py_XDECREF(_pyAlgo);
73}
References _pyAlgo.
◆ loadAlgorithm()
void SalomeOptimizerLoop::loadAlgorithm ( )
Member _alglib is the library name (shared library WITHOUT extension .so or python module WITH extension .py). Member _symbol is a symbol name in the library to use as an algorithm factory.
Reimplemented from YACS::ENGINE::OptimizerLoop.
Definition at line 94 of file SalomeOptimizerLoop.cxx.
95{
96 YASSERT(_alg == NULL)
97
98 if(_alglib.size() > 3 && _alglib.substr(_alglib.size()-3,3)==".py")
99 {
100 //if alglib extension is .py try to import the corresponding python module
101 PyGILState_STATE gstate=PyGILState_Ensure();
102
103 PyObject* mainmod = PyImport_AddModule("__main__");
104 PyObject* globals = PyModule_GetDict(mainmod);
105
106 std::string pyscript;
107 pyscript="import sys\n"
108 "import SALOMERuntime\n"
109 "filename='";
110 pyscript=pyscript+_alglib+"'\nentry='"+_symbol+"'\n";
111 pyscript=pyscript+"import os\n"
112 "import pilot\n"
113 "rep,mod=os.path.split(os.path.splitext(filename)[0])\n"
114 "if rep != '':\n"
115 " sys.path.insert(0,rep)\n"
116 "algomodule=__import__(mod)\n"
117 "if rep != '':\n"
118 " del sys.path[0]\n"
119 "algoclass= getattr(algomodule,entry)\n"
120 "algo= algoclass()\n"
121 "swigalgo= algo.this\n"
122 "\n";
123
124 PyObject* res=PyRun_String(pyscript.c_str(), Py_file_input, globals, globals );
125
126 if(res == NULL)
127 {
128 //error during import
129 _errorDetails="";
130 PyObject* new_stderr = newPyStdOut(_errorDetails);
131 PySys_SetObject((char*)"stderr", new_stderr);
132 PyErr_Print();
133 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
134 Py_DECREF(new_stderr);
135 modified();
136 PyGILState_Release(gstate);
138 }
139 else
140 {
141 Py_DECREF(res);
142
143 typedef struct {
144 PyObject_HEAD
145 void *ptr;
146 void *ty;
147 int own;
148 PyObject *next;
149 } SwigPyObject;
150
151 PyObject * _pyAlgo = PyDict_GetItemString(globals, "algo");
152 Py_XINCREF(_pyAlgo);
153 SwigPyObject* pyalgo = (SwigPyObject*)PyDict_GetItemString(globals, "swigalgo");
154 _alg=(OptimizerAlgBase*)pyalgo->ptr;
156 }
157 PyGILState_Release(gstate);
158 }
159 else
160 {
161 //else try to load a dynamic library
163 }
164}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
Definition: Node.hxx:93
Base class factorizing common methods for all algorithms interfaces.
virtual void setPool(Pool *pool)
virtual void loadAlgorithm()
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
References YACS::ENGINE::OptimizerLoop::_alg, YACS::ENGINE::OptimizerLoop::_alglib, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::OptimizerLoop::_myPool, _pyAlgo, YACS::ENGINE::OptimizerLoop::_symbol, YACS::ENGINE::OptimizerLoop::loadAlgorithm(), YACS::ENGINE::Node::modified(), YACS::ENGINE::newPyStdOut(), YACS::ENGINE::OptimizerAlgBase::setPool(), and YASSERT.
◆ simpleClone()
Node * SalomeOptimizerLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 75 of file SalomeOptimizerLoop.cxx.
76{
77 SalomeOptimizerLoop* sol=new SalomeOptimizerLoop(*this,father,editionOnly);
78 // TODO: Remove this const_cast (find a better design to get the type codes from the original node)
79 Proc * procForTypes = sol->getProc();
80 if (procForTypes == NULL) {
81 const Proc * origProc = getProc();
82 procForTypes = const_cast<Proc *>(origProc);
83 }
84 sol->setAlgorithm(_alglib, _symbol, false, procForTypes);
85 return sol;
86}
virtual Proc * getProc()
Definition: Node.cxx:401
Definition: Proc.hxx:44
SalomeOptimizerLoop(const std::string &name, const std::string &algLibWthOutExt, const std::string &symbolNameToOptimizerAlgBaseInstanceFactory, bool algInitOnFile, bool initAlgo=true, Proc *procForTypes=NULL)
References YACS::ENGINE::OptimizerLoop::_alglib, YACS::ENGINE::OptimizerLoop::_symbol, YACS::ENGINE::Node::getProc(), SalomeOptimizerLoop(), and YACS::ENGINE::OptimizerLoop::setAlgorithm().
◆ typeName()
virtual std::string YACS::ENGINE::SalomeOptimizerLoop::typeName ( )
Definition at line 42 of file SalomeOptimizerLoop.hxx.
42{return "YACS__ENGINE__SalomeOptimizerLoop";}
◆ _pyAlgo
PyObject* YACS::ENGINE::SalomeOptimizerLoop::_pyAlgo = nullptr
Definition at line 44 of file SalomeOptimizerLoop.hxx.
Referenced by loadAlgorithm(), and ~SalomeOptimizerLoop().
