YACS::ENGINE::PartDefinition Class Referenceabstract
#include <PlayGround.hxx>
Inheritance diagram for YACS::ENGINE::PartDefinition:
Collaboration diagram for YACS::ENGINE::PartDefinition:
const PlayGround * getPlayGround () const
int getSpaceSize () const
void stashPart (int nbCoresStashed, double weightOfRemain, YACS::BASES::AutoRefCnt< PartDefinition > &pdStashed, YACS::BASES::AutoRefCnt< PartDefinition > &pdRemain) const
std::vector< std::size_t > computeWorkerIdsCovered (int nbCoresPerComp) const
virtual std::string printSelf () const =0
virtual std::vector< bool > getCoresOn () const =0
virtual PartDefinition * copy () const =0
virtual int getNumberOfCoresConsumed () const =0
void incrRef () const
bool decrRef () const
static YACS::BASES::AutoRefCnt< PartDefinition > BuildFrom (const PlayGround *pg, const std::vector< int > &coreIds)
 PartDefinition (const PlayGround *pg)
 PartDefinition (const PartDefinition &other)
virtual ~PartDefinition ()
 RefCounter ()
virtual ~RefCounter ()
YACS::BASES::AutoConstRefCnt< PlayGround > _pg
unsigned int _cnt
Definition at line 118 of file PlayGround.hxx.
◆ PartDefinition() [1/2]
PartDefinition::PartDefinition ( const PlayGround *  pg)
Definition at line 590 of file PlayGround.cxx.
591{
592 _pg.takeRef(pg);
593}
Definition: PlayGround.hxx:136
References _pg.
◆ PartDefinition() [2/2]
PartDefinition::PartDefinition ( const PartDefinition &  other)
Definition at line 595 of file PlayGround.cxx.
595 :_pg(other._pg)
596{
597}
◆ ~PartDefinition()
PartDefinition::~PartDefinition ( )
Definition at line 599 of file PlayGround.cxx.
600{
601}
◆ BuildFrom()
YACS::BASES::AutoRefCnt< PartDefinition > PartDefinition::BuildFrom ( const PlayGround *  pg,
const std::vector< int > &  coreIds
Definition at line 612 of file PlayGround.cxx.
613{
614 int spaceSz(pg->getNumberOfCoresAvailable()),sz(coreIds.size());
615 if(sz>spaceSz)
616 throw Exception("PartDefinition::BuildFrom : error 1 !");
617 if(sz==0)
618 throw Exception("PartDefinition::BuildFrom : error 2 !");
619 int zeStart(coreIds.front()),zeEnd(coreIds.back());
620 if(zeStart<0 || zeEnd<zeStart)
621 throw Exception("PartDefinition::BuildFrom : error ! The content of core Ids is not OK !");
622 for(std::size_t i=0;i<sz-1;i++)
623 if(coreIds[i+1]<coreIds[i])
624 throw Exception("PartDefinition::BuildFrom : error ! The content of core Ids is not OK 2 !");
625 if(zeEnd-zeStart+1!=sz)
626 {
628 return pd;
629 }
630 if(sz==spaceSz)
631 {
633 return pd;
634 }
636 return pd;
637}
int getNumberOfCoresAvailable() const
Definition: PlayGround.cxx:130
References YACS::ENGINE::PlayGround::getNumberOfCoresAvailable(), and yacsorb.CORBAEngineTest::i.
Referenced by YACS::ENGINE::PlayGround::partition(), and stashPart().
◆ computeWorkerIdsCovered()
std::vector< std::size_t > PartDefinition::computeWorkerIdsCovered ( int  nbCoresPerComp) const
you must garantee coherence between PlayGround::deduceMachineFrom, PlayGround::getNumberOfWorkers, and PartDefinition::computeWorkerIdsCovered
Definition at line 677 of file PlayGround.cxx.
678{
679 std::vector<bool> coresOn(getCoresOn());
680 return _pg->getWorkerIdsFullyFetchedBy(nbCoresPerComp,coresOn);
681}
virtual std::vector< bool > getCoresOn() const =0
References _pg, and getCoresOn().
◆ copy()
◆ getCoresOn()
virtual std::vector< bool > YACS::ENGINE::PartDefinition::getCoresOn ( ) const
pure virtual
◆ getNumberOfCoresConsumed()
virtual int YACS::ENGINE::PartDefinition::getNumberOfCoresConsumed ( ) const
pure virtual
◆ getPlayGround()
const PlayGround * YACS::ENGINE::PartDefinition::getPlayGround ( ) const
◆ getSpaceSize()
◆ printSelf()
virtual std::string YACS::ENGINE::PartDefinition::printSelf ( ) const
pure virtual
◆ stashPart()
void PartDefinition::stashPart ( int  nbCoresStashed,
YACS::BASES::AutoRefCnt< PartDefinition > &  pdStashed,
YACS::BASES::AutoRefCnt< PartDefinition > &  pdRemain
Definition at line 639 of file PlayGround.cxx.
640{
641 if(nbCoresStashed<=0)
642 throw Exception("stashPart : Invalid nbCoresStashed value !");
643 if(weightOfRemain<=0.)
644 throw Exception("stashPart : Invalid weight !");
645 std::vector<bool> coresOn(getCoresOn());
646 int nbCoresAvailable(std::count(coresOn.begin(),coresOn.end(),true));
647 std::vector<int> ids(PlayGround::BuildVectOfIdsFromVecBool(coresOn));
648 if(nbCoresAvailable==0)
649 throw Exception("PartDefinition::stashPart : no available cores !");
650 if(nbCoresAvailable<=nbCoresStashed)
651 {
652 int n0((int)(1./(1.+weightOfRemain)*nbCoresAvailable)); n0=std::max(n0,1);
653 int n1(nbCoresAvailable-n0);
654 if(n1<=0)
655 {
658 }
659 else
660 {
661 std::vector<int> ids0(ids.begin(),ids.begin()+n0),ids1(ids.begin()+n0,ids.end());
664 }
665 }
666 else
667 {
668 std::vector<int> ids0(ids.begin(),ids.begin()+nbCoresStashed),ids1(ids.begin()+nbCoresStashed,ids.end());
671 }
672}
static YACS::BASES::AutoRefCnt< PartDefinition > BuildFrom(const PlayGround *pg, const std::vector< int > &coreIds)
Definition: PlayGround.cxx:612
const PlayGround * getPlayGround() const
Definition: PlayGround.hxx:127
static std::vector< int > BuildVectOfIdsFromVecBool(const std::vector< bool > &v)
Definition: PlayGround.cxx:234
References BuildFrom(), YACS::ENGINE::PlayGround::BuildVectOfIdsFromVecBool(), getCoresOn(), and getPlayGround().
◆ _pg
YACS::BASES::AutoConstRefCnt<PlayGround> YACS::ENGINE::PartDefinition::_pg
Definition at line 136 of file PlayGround.hxx.
Referenced by computeWorkerIdsCovered(), and PartDefinition().
