ForkBlocPoint.cxx
1// Copyright (C) 2015-2026 CEA, EDF
20#include "ForkBlocPoint.hxx"
21#include "PointVisitor.hxx"
22#include "Exception.hxx"
23
24#include <algorithm>
26using namespace YACS::ENGINE;
27
28ForkBlocPoint::ForkBlocPoint(const std::list<AbstractPoint *>& nodes, AbstractPoint *father):BlocPoint(nodes,father)
29{
30}
31
33{
35 ret->deepCopyFrom(*this);
36 ret->setFather(father);
37 return ret;
38}
39
41{
42}
43
45{
46 if(_nodes.empty())
47 throw Exception("ForkBlocPoint::getFirstNode : error no branches !");
48 return _nodes.front()->getFirstNode();
49}
50
52{
53 if(_nodes.empty())
54 throw Exception("ForkBlocPoint::getLastNode : error no branches !");
55 return _nodes.front()->getLastNode();//not a bug - seen from the outside only first branch exists !
56}
57
59{
60 int ret(0);
61 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
62 ret+=(*it)->getMaxLevelOfParallelism();
63 return ret;
64}
65
67{
68 ComplexWeight localWeight;
69 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
70 {
71 (*it)->getWeightRegardingDPL(&localWeight);
72 weight->addWeight(&localWeight);
73 localWeight.setToZero();
74 }
75}
76
78{
79 std::vector< std::pair<const PartDefinition *, const ComplexWeight *> > parts;
80 std::vector< int> nbCoresPerShot;
81 std::vector<std::size_t> v;
82 std::vector<ComplexWeight> nodesWeight(_nodes.size());
83 std::size_t ii(0);
84 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
85 {
86 ComplexWeight *w=&nodesWeight[ii];
87 (*it)->getWeightRegardingDPL(w);
88 parts.push_back(std::pair<const PartDefinition *, const ComplexWeight *>(pd,w));
89 nbCoresPerShot.push_back((*it)->getMaxLevelOfParallelism());
90 v.push_back(ii);
91 }
92 std::vector<AbstractPoint *> nodes2(_nodes.begin(),_nodes.end());
93 if(!parts.empty())
94 {
95 const PlayGround *pg(pd->getPlayGround());
96 std::vector< YACS::BASES::AutoRefCnt<PartDefinition> > pds(pg->partition(parts,nbCoresPerShot));
97 ii=0;
98 for(std::vector<std::size_t>::const_iterator iter=v.begin();iter!=v.end();iter++,ii++)
99 nodes2[*iter]->partitionRegardingDPL(pds[ii],zeMap);
100 }
101}
102
103std::string ForkBlocPoint::getRepr() const
104{
105 std::size_t sz(_nodes.size()),ii(0);
106 std::string ret("[");
107 std::vector<std::string> elts(sz);
108 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
109 elts[ii]=(*it)->getRepr();
110 std::sort(elts.begin(),elts.end());
111 ii=0;
112 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
113 {
114 ret+=elts[ii];
115 if(ii!=sz-1)
116 ret+="*";
117 }
118 ret+="]";
119 return ret;
120}
121
123{
124 pv->beginForkBlocPoint(this);
125 for(auto it:_nodes)
126 it->accept(pv);
127 pv->endForkBlocPoint(this);
128}
129
130AbstractPoint *ForkBlocPoint::expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set<Node *>& uncatchedNodes)
131{
132 for(auto& it : _nodes)
133 {
134 AbstractPoint *ret(it->expandNonSimpleCaseOn(pathologicalPt,uncatchedNodes));
135 if(ret!=it)
136 {
137 ret->setFather(this);
138 auto oldIt(it);
139 it = ret;
140 delete oldIt;
141 }
142 }
143 return this;
144}
145
void setFather(AbstractPoint *father)
void deepCopyFrom(const BlocPoint &other)
Definition: BlocPoint.cxx:34
std::list< AbstractPoint * > _nodes
Definition: BlocPoint.hxx:35
void addWeight(const ComplexWeight *other)
Node * getFirstNode() override
std::string getRepr() const
void getWeightRegardingDPL(ComplexWeight *weight)
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
AbstractPoint * deepCopy(AbstractPoint *father) const override
AbstractPoint * expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
void accept(PointVisitor *pv) override
Node * getLastNode() override
Base class for all nodes.
Definition: Node.hxx:70
const PlayGround * getPlayGround() const
Definition: PlayGround.hxx:127
std::vector< YACS::BASES::AutoRefCnt< PartDefinition > > partition(const std::vector< std::pair< const PartDefinition *, const ComplexWeight * > > &parts, const std::vector< int > &nbCoresPerShot) const
Definition: PlayGround.cxx:298
virtual void endForkBlocPoint(ForkBlocPoint *pt)=0
virtual void beginForkBlocPoint(ForkBlocPoint *pt)=0
