YACS::ENGINE::NotSimpleCasePoint Class Reference
#include <NotSimpleCasePoint.hxx>
Inheritance diagram for YACS::ENGINE::NotSimpleCasePoint:
Collaboration diagram for YACS::ENGINE::NotSimpleCasePoint:
 NotSimpleCasePoint ()=default
 NotSimpleCasePoint (const std::list< AbstractPoint * > &nodes, AbstractPoint *father)
 ~NotSimpleCasePoint ()=default
AbstractPoint * deepCopy (AbstractPoint *father) const override
Node * getFirstNode () override
Node * getLastNode () override
int getMaxLevelOfParallelism () const override
void getWeightRegardingDPL (ComplexWeight *weight) override
void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const override
std::string getRepr () const override
void accept (PointVisitor *pv) override
AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
- Public Member Functions inherited from YACS::ENGINE::BlocPoint
 BlocPoint ()=default
 BlocPoint (const std::list< AbstractPoint * > &nodes, AbstractPoint *father)
void deepCopyFrom (const BlocPoint &other)
AbstractPoint * findPointWithNode (Node *node)
AbstractPoint * getNodeAfter (Node *node)
AbstractPoint * getNodeB4 (Node *node)
bool contains (Node *node) const override
bool anyOf (const std::set< Node * > &nodes) const override
int getNumberOfNodes () const
const std::list< AbstractPoint * > & getListOfPoints () const
virtual ~BlocPoint ()
bool internalContinueForSimplify () const
bool presenceOfNonSimpleCase () const
AbstractPoint * getUnique ()
const AbstractPoint * getUnique () const
AbstractPoint * getUniqueAndReleaseIt ()
- Public Member Functions inherited from YACS::ENGINE::AbstractPoint
 AbstractPoint ()=default
 AbstractPoint (AbstractPoint *father)
AbstractPoint * getFather () const
AbstractPoint * getGodFather ()
bool amIGod ()
void setFather (AbstractPoint *father)
bool isBegin ()
bool isLast ()
bool isSimplyLinkedBeforeAfter (BlocPoint *sop)
bool isSimplyLinkedAfterNullBefore (BlocPoint *sop)
bool isSimplyLinkedBeforeNullAfter (BlocPoint *sop)
bool isNullBeforeNullAfter (BlocPoint *sop)
LinkedBlocPoint * tryAsLink (BlocPoint *sop)
ForkBlocPoint * tryAsFork (BlocPoint *sop)
ForkBlocPoint * tryAsForkBis (BlocPoint *sop)
ForkBlocPoint * tryAsForkTer (BlocPoint *sop)
ForkBlocPoint * tryAsForkQuatro (BlocPoint *sop)
virtual AbstractPoint * deepCopy (AbstractPoint *father) const =0
virtual Node * getFirstNode ()=0
virtual Node * getLastNode ()=0
virtual AbstractPoint * findPointWithNode (Node *node)=0
virtual bool contains (Node *node) const =0
virtual bool anyOf (const std::set< Node * > &nodes) const =0
virtual int getNumberOfNodes () const =0
virtual void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const =0
virtual std::string getRepr () const =0
virtual void accept (PointVisitor *pv)=0
virtual AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes)=0
virtual ~AbstractPoint ()
bool isSimplyLinkedAfter (BlocPoint *sop, Node *node)
bool isSimplyLinkedBefore (BlocPoint *sop, Node *node)
- Static Public Member Functions inherited from YACS::ENGINE::AbstractPoint
static void TryAsNotSimpleCase (AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)
static bool IsGatherB4Ext (Node *node)
static bool IsSimplyLinkedAfterExt (Node *node)
static bool IsScatterAfterExt (Node *node)
static bool IsSimplyLinkedBeforeExt (Node *node)
static bool IsNoLinksBefore (Node *node)
static bool IsNoLinksAfter (Node *node)
static Node * GetNodeB4 (Node *node)
static Node * GetNodeAfter (Node *node)
static AbstractPoint * GetDirectSonOf (AbstractPoint *refFather, AbstractPoint *sonOrLittleSon)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< OutGate * > &outgs, AbstractPoint *&ret)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< InGate * > &ings, AbstractPoint *&ret)
static void FeedData (AbstractPoint *ptToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void FeedData (const std::list< AbstractPoint * > &ptsToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void Rewire (const std::vector< AbstractPoint * > &ptsToKill, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void UnRewire (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > &m)
static void Display (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
- Protected Member Functions inherited from YACS::ENGINE::BlocPoint
void getOutPoint (AbstractPoint *node)
- Protected Attributes inherited from YACS::ENGINE::BlocPoint
std::list< AbstractPoint * > _nodes
- Protected Attributes inherited from YACS::ENGINE::AbstractPoint
AbstractPoint * _father = nullptr
Definition at line 29 of file NotSimpleCasePoint.hxx.
◆ NotSimpleCasePoint() [1/2]
YACS::ENGINE::NotSimpleCasePoint::NotSimpleCasePoint ( )
default
◆ NotSimpleCasePoint() [2/2]
NotSimpleCasePoint::NotSimpleCasePoint ( const std::list< AbstractPoint * > &  nodes,
AbstractPoint *  father
Definition at line 29 of file NotSimpleCasePoint.cxx.
29 :BlocPoint(nodes,father)
30{
31}
◆ ~NotSimpleCasePoint()
YACS::ENGINE::NotSimpleCasePoint::~NotSimpleCasePoint ( )
default
◆ accept()
void NotSimpleCasePoint::accept ( PointVisitor *  pv)
overridevirtual
Implements YACS::ENGINE::AbstractPoint.
Definition at line 94 of file NotSimpleCasePoint.cxx.
95{
97 for(auto it:_nodes)
98 it->accept(pv);
99 pv->endNotSimpleCasePoint(this);
100}
Definition: BlocPoint.hxx:35
virtual void endNotSimpleCasePoint(NotSimpleCasePoint *pt)=0
virtual void beginNotSimpleCasePoint(NotSimpleCasePoint *pt)=0
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::PointVisitor::beginNotSimpleCasePoint(), and YACS::ENGINE::PointVisitor::endNotSimpleCasePoint().
◆ deepCopy()
AbstractPoint * NotSimpleCasePoint::deepCopy ( AbstractPoint *  father) const
overridevirtual
Definition at line 33 of file NotSimpleCasePoint.cxx.
34{
36 ret->deepCopyFrom(*this);
37 ret->setFather(father);
38 return ret;
39}
References YACS::ENGINE::BlocPoint::deepCopyFrom(), and YACS::ENGINE::AbstractPoint::setFather().
◆ expandNonSimpleCaseOn()
AbstractPoint * NotSimpleCasePoint::expandNonSimpleCaseOn ( NotSimpleCasePoint *  pathologicalPt,
const std::set< Node * > &  uncatchedNodes
overridevirtual
Definition at line 102 of file NotSimpleCasePoint.cxx.
103{
104 throw YACS::Exception("NotSimpleCasePoint::expandNonSimpleCaseOn : ooops !");
105}
◆ getFirstNode()
Node * NotSimpleCasePoint::getFirstNode ( )
overridevirtual
Definition at line 41 of file NotSimpleCasePoint.cxx.
42{
43 if(_nodes.empty())
44 throw Exception("NotSimpleCasePoint::getFirstNode : error no branches !");
45 return _nodes.front()->getFirstNode();
46}
References YACS::ENGINE::BlocPoint::_nodes.
◆ getLastNode()
Node * NotSimpleCasePoint::getLastNode ( )
overridevirtual
Definition at line 48 of file NotSimpleCasePoint.cxx.
49{
50 if(_nodes.empty())
51 throw Exception("NotSimpleCasePoint::getFirstNode : error no branches !");
52 return _nodes.back()->getLastNode();
53}
◆ getMaxLevelOfParallelism()
int NotSimpleCasePoint::getMaxLevelOfParallelism ( ) const
overridevirtual
Definition at line 55 of file NotSimpleCasePoint.cxx.
56{
57 int ret(0);
58 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
59 ret=std::max(ret,(*it)->getMaxLevelOfParallelism());
60 return ret;
61}
◆ getRepr()
std::string NotSimpleCasePoint::getRepr ( ) const
overridevirtual
Definition at line 80 of file NotSimpleCasePoint.cxx.
81{
82 std::size_t sz(_nodes.size()),ii(0);
83 std::string ret("|");
84 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
85 {
86 ret+=(*it)->getRepr();
87 if(ii!=sz-1)
88 ret+="^";
89 }
90 ret+="|";
91 return ret;
92}
◆ getWeightRegardingDPL()
void NotSimpleCasePoint::getWeightRegardingDPL ( ComplexWeight *  weight)
overridevirtual
Definition at line 63 of file NotSimpleCasePoint.cxx.
64{
65 ComplexWeight localWeight;
66 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
67 {
68 (*it)->getWeightRegardingDPL(&localWeight);
69 weight->addWeight(&localWeight);
70 localWeight.setToZero();
71 }
72}
void addWeight(const ComplexWeight *other)
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::ComplexWeight::addWeight(), and YACS::ENGINE::ComplexWeight::setToZero().
◆ partitionRegardingDPL()
void NotSimpleCasePoint::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
overridevirtual
Definition at line 74 of file NotSimpleCasePoint.cxx.
75{
76 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
77 (*it)->partitionRegardingDPL(pd,zeMap);
78}
