NotSimpleCasePoint.cxx
1// Copyright (C) 2019-2026 CEA, EDF
21#include "PointVisitor.hxx"
22#include "Exception.hxx"
23
24#include <algorithm>
26
27using namespace YACS::ENGINE;
28
29NotSimpleCasePoint::NotSimpleCasePoint(const std::list<AbstractPoint *>& nodes, AbstractPoint *father):BlocPoint(nodes,father)
30{
31}
32
34{
36 ret->deepCopyFrom(*this);
37 ret->setFather(father);
38 return ret;
39}
40
42{
43 if(_nodes.empty())
44 throw Exception("NotSimpleCasePoint::getFirstNode : error no branches !");
45 return _nodes.front()->getFirstNode();
46}
47
49{
50 if(_nodes.empty())
51 throw Exception("NotSimpleCasePoint::getFirstNode : error no branches !");
52 return _nodes.back()->getLastNode();
53}
54
56{
57 int ret(0);
58 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
59 ret=std::max(ret,(*it)->getMaxLevelOfParallelism());
60 return ret;
61}
62
64{
65 ComplexWeight localWeight;
66 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
67 {
68 (*it)->getWeightRegardingDPL(&localWeight);
69 weight->addWeight(&localWeight);
70 localWeight.setToZero();
71 }
72}
73
75{
76 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
77 (*it)->partitionRegardingDPL(pd,zeMap);
78}
79
80std::string NotSimpleCasePoint::getRepr() const
81{
82 std::size_t sz(_nodes.size()),ii(0);
83 std::string ret("|");
84 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
85 {
86 ret+=(*it)->getRepr();
87 if(ii!=sz-1)
88 ret+="^";
89 }
90 ret+="|";
91 return ret;
92}
93
95{
97 for(auto it:_nodes)
98 it->accept(pv);
99 pv->endNotSimpleCasePoint(this);
100}
101
102AbstractPoint *NotSimpleCasePoint::expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set<Node *>& uncatchedNodes)
103{
104 throw YACS::Exception("NotSimpleCasePoint::expandNonSimpleCaseOn : ooops !");
105}
void setFather(AbstractPoint *father)
void deepCopyFrom(const BlocPoint &other)
Definition: BlocPoint.cxx:34
std::list< AbstractPoint * > _nodes
Definition: BlocPoint.hxx:35
void addWeight(const ComplexWeight *other)
Base class for all nodes.
Definition: Node.hxx:70
int getMaxLevelOfParallelism() const override
void getWeightRegardingDPL(ComplexWeight *weight) override
AbstractPoint * expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
void accept(PointVisitor *pv) override
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const override
std::string getRepr() const override
AbstractPoint * deepCopy(AbstractPoint *father) const override
virtual void endNotSimpleCasePoint(NotSimpleCasePoint *pt)=0
virtual void beginNotSimpleCasePoint(NotSimpleCasePoint *pt)=0
