YACS::ENGINE::ElementaryPoint Class Reference
#include <ElementaryPoint.hxx>
Inheritance diagram for YACS::ENGINE::ElementaryPoint:
Collaboration diagram for YACS::ENGINE::ElementaryPoint:
 ElementaryPoint (Node *node)
AbstractPoint * findPointWithNode (Node *node)
bool contains (Node *node) const override
bool anyOf (const std::set< Node * > &nodes) const override
AbstractPoint * deepCopy (AbstractPoint *father) const override
Node * getFirstNode () override
Node * getLastNode () override
int getNumberOfNodes () const
void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
std::string getRepr () const
void accept (PointVisitor *pv) override
AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
virtual ~ElementaryPoint ()
void setNode (Node *node)
Node * getNode () const
std::string getNodeName () const
- Public Member Functions inherited from YACS::ENGINE::AbstractPoint
 AbstractPoint ()=default
 AbstractPoint (AbstractPoint *father)
AbstractPoint * getFather () const
AbstractPoint * getGodFather ()
bool amIGod ()
void setFather (AbstractPoint *father)
bool isBegin ()
bool isLast ()
bool isSimplyLinkedBeforeAfter (BlocPoint *sop)
bool isSimplyLinkedAfterNullBefore (BlocPoint *sop)
bool isSimplyLinkedBeforeNullAfter (BlocPoint *sop)
bool isNullBeforeNullAfter (BlocPoint *sop)
LinkedBlocPoint * tryAsLink (BlocPoint *sop)
ForkBlocPoint * tryAsFork (BlocPoint *sop)
ForkBlocPoint * tryAsForkBis (BlocPoint *sop)
ForkBlocPoint * tryAsForkTer (BlocPoint *sop)
ForkBlocPoint * tryAsForkQuatro (BlocPoint *sop)
virtual AbstractPoint * deepCopy (AbstractPoint *father) const =0
virtual Node * getFirstNode ()=0
virtual Node * getLastNode ()=0
virtual AbstractPoint * findPointWithNode (Node *node)=0
virtual bool contains (Node *node) const =0
virtual bool anyOf (const std::set< Node * > &nodes) const =0
virtual int getNumberOfNodes () const =0
virtual void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const =0
virtual std::string getRepr () const =0
virtual void accept (PointVisitor *pv)=0
virtual AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes)=0
virtual ~AbstractPoint ()
bool isSimplyLinkedAfter (BlocPoint *sop, Node *node)
bool isSimplyLinkedBefore (BlocPoint *sop, Node *node)
Node * _node
- Static Public Member Functions inherited from YACS::ENGINE::AbstractPoint
static void TryAsNotSimpleCase (AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)
static bool IsGatherB4Ext (Node *node)
static bool IsSimplyLinkedAfterExt (Node *node)
static bool IsScatterAfterExt (Node *node)
static bool IsSimplyLinkedBeforeExt (Node *node)
static bool IsNoLinksBefore (Node *node)
static bool IsNoLinksAfter (Node *node)
static Node * GetNodeB4 (Node *node)
static Node * GetNodeAfter (Node *node)
static AbstractPoint * GetDirectSonOf (AbstractPoint *refFather, AbstractPoint *sonOrLittleSon)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< OutGate * > &outgs, AbstractPoint *&ret)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< InGate * > &ings, AbstractPoint *&ret)
static void FeedData (AbstractPoint *ptToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void FeedData (const std::list< AbstractPoint * > &ptsToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void Rewire (const std::vector< AbstractPoint * > &ptsToKill, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void UnRewire (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > &m)
static void Display (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
- Protected Attributes inherited from YACS::ENGINE::AbstractPoint
AbstractPoint * _father = nullptr
Definition at line 34 of file ElementaryPoint.hxx.
◆ ElementaryPoint()
YACS::ENGINE::ElementaryPoint::ElementaryPoint ( Node *  node)
Definition at line 39 of file ElementaryPoint.hxx.
Referenced by deepCopy().
◆ ~ElementaryPoint()
ElementaryPoint::~ElementaryPoint ( )
Definition at line 28 of file ElementaryPoint.cxx.
29{
30}
◆ accept()
void ElementaryPoint::accept ( PointVisitor *  pv)
overridevirtual
Implements YACS::ENGINE::AbstractPoint.
Definition at line 92 of file ElementaryPoint.cxx.
93{
94 pv->beginElementaryPoint(this);
95 pv->endElementaryPoint(this);
96}
virtual void beginElementaryPoint(ElementaryPoint *pt)=0
virtual void endElementaryPoint(ElementaryPoint *pt)=0
References YACS::ENGINE::PointVisitor::beginElementaryPoint(), and YACS::ENGINE::PointVisitor::endElementaryPoint().
◆ anyOf()
bool ElementaryPoint::anyOf ( const std::set< Node * > &  nodes) const
overridevirtual
Definition at line 45 of file ElementaryPoint.cxx.
46{
47 return nodes.find(_node)!=nodes.end();
48}
References _node.
◆ contains()
bool ElementaryPoint::contains ( Node *  node) const
overridevirtual
Definition at line 40 of file ElementaryPoint.cxx.
41{
42 return _node==node;
43}
References _node.
◆ deepCopy()
AbstractPoint * ElementaryPoint::deepCopy ( AbstractPoint *  father) const
overridevirtual
Definition at line 50 of file ElementaryPoint.cxx.
51{
53 ret->setFather(father);
54 return ret;
55}
References _node, ElementaryPoint(), and YACS::ENGINE::AbstractPoint::setFather().
Referenced by expandNonSimpleCaseOn().
◆ expandNonSimpleCaseOn()
AbstractPoint * ElementaryPoint::expandNonSimpleCaseOn ( NotSimpleCasePoint *  pathologicalPt,
const std::set< Node * > &  uncatchedNodes
overridevirtual
Definition at line 98 of file ElementaryPoint.cxx.
99{
100 if(uncatchedNodes.find(_node)!=uncatchedNodes.end())
101 return this;
102 else
103 {
104 std::list<AbstractPoint *> l;
105 AbstractPoint *p0(this->deepCopy(getFather())),*p1(pathologicalPt->getUnique()->deepCopy(getFather()));
106 l.push_back(p0);
107 l.push_back(p1);
109 p0->setFather(ret); p1->setFather(ret);
110 return ret;
111 }
112}
virtual AbstractPoint * deepCopy(AbstractPoint *father) const =0
AbstractPoint * getFather() const
AbstractPoint * getUnique()
Definition: BlocPoint.cxx:111
AbstractPoint * deepCopy(AbstractPoint *father) const override
References _node, YACS::ENGINE::AbstractPoint::deepCopy(), deepCopy(), YACS::ENGINE::AbstractPoint::getFather(), YACS::ENGINE::BlocPoint::getUnique(), testCppPluginInvokation::l, and YACS::ENGINE::AbstractPoint::setFather().
◆ findPointWithNode()
AbstractPoint * ElementaryPoint::findPointWithNode ( Node *  node)
Definition at line 32 of file ElementaryPoint.cxx.
33{
34 if(node==_node)
35 return this;
36 else
37 return nullptr;
38}
References _node.
◆ getFirstNode()
Node * ElementaryPoint::getFirstNode ( )
overridevirtual
Definition at line 57 of file ElementaryPoint.cxx.
58{
59 return _node;
60}
References _node.
◆ getLastNode()
Node * ElementaryPoint::getLastNode ( )
overridevirtual
Definition at line 62 of file ElementaryPoint.cxx.
63{
64 return _node;
65}
References _node.
◆ getMaxLevelOfParallelism()
int ElementaryPoint::getMaxLevelOfParallelism ( ) const
Definition at line 72 of file ElementaryPoint.cxx.
73{
75}
virtual int getMaxLevelOfParallelism() const =0
References _node, and YACS::ENGINE::Node::getMaxLevelOfParallelism().
◆ getNode()
Node * YACS::ENGINE::ElementaryPoint::getNode ( ) const
Definition at line 56 of file ElementaryPoint.hxx.
56{ return _node; }
Referenced by Visitor1::beginElementaryPoint(), and YACS::ENGINE::AbstractPoint::Display().
◆ getNodeName()
std::string ElementaryPoint::getNodeName ( ) const
Definition at line 114 of file ElementaryPoint.cxx.
115{
116 return _node->getName();
117}
Definition: Node.hxx:125
References _node, and YACS::ENGINE::Node::getName().
◆ getNumberOfNodes()
int ElementaryPoint::getNumberOfNodes ( ) const
Definition at line 67 of file ElementaryPoint.cxx.
68{
69 return 1;
70}
◆ getRepr()
std::string ElementaryPoint::getRepr ( ) const
Definition at line 87 of file ElementaryPoint.cxx.
88{
89 return _node->getName();
90}
◆ getWeightRegardingDPL()
void ElementaryPoint::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 77 of file ElementaryPoint.cxx.
78{
80}
virtual void getWeightRegardingDPL(ComplexWeight *weight)=0
References _node, and YACS::ENGINE::Node::getWeightRegardingDPL().
◆ partitionRegardingDPL()
void ElementaryPoint::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 82 of file ElementaryPoint.cxx.
83{
85}
virtual void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)=0
References _node, and YACS::ENGINE::Node::partitionRegardingDPL().
◆ setNode()
void YACS::ENGINE::ElementaryPoint::setNode ( Node *  node)
◆ _node
