ElementaryPoint.cxx
1// Copyright (C) 2015-2026 CEA, EDF
20#include "ElementaryPoint.hxx"
21#include "PointVisitor.hxx"
23#include "ForkBlocPoint.hxx"
24#include "Node.hxx"
26using namespace YACS::ENGINE;
27
28ElementaryPoint::~ElementaryPoint()
29{
30}
31
33{
34 if(node==_node)
35 return this;
36 else
37 return nullptr;
38}
39
41{
42 return _node==node;
43}
44
45bool ElementaryPoint::anyOf(const std::set<Node *>& nodes) const
46{
47 return nodes.find(_node)!=nodes.end();
48}
49
51{
53 ret->setFather(father);
54 return ret;
55}
56
58{
59 return _node;
60}
61
63{
64 return _node;
65}
66
68{
69 return 1;
70}
71
73{
75}
76
78{
80}
81
83{
85}
86
87std::string ElementaryPoint::getRepr() const
88{
89 return _node->getName();
90}
91
93{
94 pv->beginElementaryPoint(this);
95 pv->endElementaryPoint(this);
96}
97
98AbstractPoint *ElementaryPoint::expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set<Node *>& uncatchedNodes)
99{
100 if(uncatchedNodes.find(_node)!=uncatchedNodes.end())
101 return this;
102 else
103 {
104 std::list<AbstractPoint *> l;
105 AbstractPoint *p0(this->deepCopy(getFather())),*p1(pathologicalPt->getUnique()->deepCopy(getFather()));
106 l.push_back(p0);
107 l.push_back(p1);
109 p0->setFather(ret); p1->setFather(ret);
110 return ret;
111 }
112}
113
115{
116 return _node->getName();
117}
virtual AbstractPoint * deepCopy(AbstractPoint *father) const =0
AbstractPoint * getFather() const
void setFather(AbstractPoint *father)
AbstractPoint * getUnique()
Definition: BlocPoint.cxx:111
AbstractPoint * findPointWithNode(Node *node)
void getWeightRegardingDPL(ComplexWeight *weight)
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
void accept(PointVisitor *pv) override
AbstractPoint * expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
AbstractPoint * deepCopy(AbstractPoint *father) const override
bool contains(Node *node) const override
bool anyOf(const std::set< Node * > &nodes) const override
Base class for all nodes.
Definition: Node.hxx:70
virtual int getMaxLevelOfParallelism() const =0
Definition: Node.hxx:125
virtual void getWeightRegardingDPL(ComplexWeight *weight)=0
virtual void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)=0
virtual void beginElementaryPoint(ElementaryPoint *pt)=0
virtual void endElementaryPoint(ElementaryPoint *pt)=0
