YACS::ENGINE::ForkBlocPoint Class Reference
#include <ForkBlocPoint.hxx>
Inheritance diagram for YACS::ENGINE::ForkBlocPoint:
Collaboration diagram for YACS::ENGINE::ForkBlocPoint:
 ForkBlocPoint ()=default
 ForkBlocPoint (const std::list< AbstractPoint * > &nodes, AbstractPoint *father)
AbstractPoint * deepCopy (AbstractPoint *father) const override
Node * getFirstNode () override
Node * getLastNode () override
void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
std::string getRepr () const
void accept (PointVisitor *pv) override
AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
virtual ~ForkBlocPoint ()
- Public Member Functions inherited from YACS::ENGINE::BlocPoint
void deepCopyFrom (const BlocPoint &other)
AbstractPoint * findPointWithNode (Node *node)
AbstractPoint * getNodeAfter (Node *node)
AbstractPoint * getNodeB4 (Node *node)
bool contains (Node *node) const override
bool anyOf (const std::set< Node * > &nodes) const override
int getNumberOfNodes () const
const std::list< AbstractPoint * > & getListOfPoints () const
virtual ~BlocPoint ()
bool internalContinueForSimplify () const
bool presenceOfNonSimpleCase () const
AbstractPoint * getUnique ()
const AbstractPoint * getUnique () const
AbstractPoint * getUniqueAndReleaseIt ()
- Public Member Functions inherited from YACS::ENGINE::AbstractPoint
 AbstractPoint ()=default
 AbstractPoint (AbstractPoint *father)
AbstractPoint * getFather () const
AbstractPoint * getGodFather ()
bool amIGod ()
void setFather (AbstractPoint *father)
bool isBegin ()
bool isLast ()
bool isSimplyLinkedBeforeAfter (BlocPoint *sop)
bool isSimplyLinkedAfterNullBefore (BlocPoint *sop)
bool isSimplyLinkedBeforeNullAfter (BlocPoint *sop)
bool isNullBeforeNullAfter (BlocPoint *sop)
LinkedBlocPoint * tryAsLink (BlocPoint *sop)
ForkBlocPoint * tryAsFork (BlocPoint *sop)
ForkBlocPoint * tryAsForkBis (BlocPoint *sop)
ForkBlocPoint * tryAsForkTer (BlocPoint *sop)
ForkBlocPoint * tryAsForkQuatro (BlocPoint *sop)
virtual AbstractPoint * deepCopy (AbstractPoint *father) const =0
virtual Node * getFirstNode ()=0
virtual Node * getLastNode ()=0
virtual AbstractPoint * findPointWithNode (Node *node)=0
virtual bool contains (Node *node) const =0
virtual bool anyOf (const std::set< Node * > &nodes) const =0
virtual int getNumberOfNodes () const =0
virtual void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const =0
virtual std::string getRepr () const =0
virtual void accept (PointVisitor *pv)=0
virtual AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes)=0
virtual ~AbstractPoint ()
bool isSimplyLinkedAfter (BlocPoint *sop, Node *node)
bool isSimplyLinkedBefore (BlocPoint *sop, Node *node)
- Static Public Member Functions inherited from YACS::ENGINE::AbstractPoint
static void TryAsNotSimpleCase (AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)
static bool IsGatherB4Ext (Node *node)
static bool IsSimplyLinkedAfterExt (Node *node)
static bool IsScatterAfterExt (Node *node)
static bool IsSimplyLinkedBeforeExt (Node *node)
static bool IsNoLinksBefore (Node *node)
static bool IsNoLinksAfter (Node *node)
static Node * GetNodeB4 (Node *node)
static Node * GetNodeAfter (Node *node)
static AbstractPoint * GetDirectSonOf (AbstractPoint *refFather, AbstractPoint *sonOrLittleSon)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< OutGate * > &outgs, AbstractPoint *&ret)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< InGate * > &ings, AbstractPoint *&ret)
static void FeedData (AbstractPoint *ptToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void FeedData (const std::list< AbstractPoint * > &ptsToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void Rewire (const std::vector< AbstractPoint * > &ptsToKill, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void UnRewire (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > &m)
static void Display (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
- Protected Member Functions inherited from YACS::ENGINE::BlocPoint
void getOutPoint (AbstractPoint *node)
- Protected Attributes inherited from YACS::ENGINE::BlocPoint
std::list< AbstractPoint * > _nodes
- Protected Attributes inherited from YACS::ENGINE::AbstractPoint
AbstractPoint * _father = nullptr
Definition at line 30 of file ForkBlocPoint.hxx.
◆ ForkBlocPoint() [1/2]
YACS::ENGINE::ForkBlocPoint::ForkBlocPoint ( )
default
◆ ForkBlocPoint() [2/2]
ForkBlocPoint::ForkBlocPoint ( const std::list< AbstractPoint * > &  nodes,
AbstractPoint *  father
Definition at line 28 of file ForkBlocPoint.cxx.
28 :BlocPoint(nodes,father)
29{
30}
◆ ~ForkBlocPoint()
ForkBlocPoint::~ForkBlocPoint ( )
Definition at line 40 of file ForkBlocPoint.cxx.
41{
42}
◆ accept()
void ForkBlocPoint::accept ( PointVisitor *  pv)
overridevirtual
Implements YACS::ENGINE::AbstractPoint.
Definition at line 122 of file ForkBlocPoint.cxx.
123{
124 pv->beginForkBlocPoint(this);
125 for(auto it:_nodes)
126 it->accept(pv);
127 pv->endForkBlocPoint(this);
128}
Definition: BlocPoint.hxx:35
virtual void endForkBlocPoint(ForkBlocPoint *pt)=0
virtual void beginForkBlocPoint(ForkBlocPoint *pt)=0
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::PointVisitor::beginForkBlocPoint(), and YACS::ENGINE::PointVisitor::endForkBlocPoint().
◆ deepCopy()
AbstractPoint * ForkBlocPoint::deepCopy ( AbstractPoint *  father) const
overridevirtual
Definition at line 32 of file ForkBlocPoint.cxx.
33{
35 ret->deepCopyFrom(*this);
36 ret->setFather(father);
37 return ret;
38}
References YACS::ENGINE::BlocPoint::deepCopyFrom(), and YACS::ENGINE::AbstractPoint::setFather().
◆ expandNonSimpleCaseOn()
AbstractPoint * ForkBlocPoint::expandNonSimpleCaseOn ( NotSimpleCasePoint *  pathologicalPt,
const std::set< Node * > &  uncatchedNodes
overridevirtual
Definition at line 130 of file ForkBlocPoint.cxx.
131{
132 for(auto& it : _nodes)
133 {
134 AbstractPoint *ret(it->expandNonSimpleCaseOn(pathologicalPt,uncatchedNodes));
135 if(ret!=it)
136 {
137 ret->setFather(this);
138 auto oldIt(it);
139 it = ret;
140 delete oldIt;
141 }
142 }
143 return this;
144}
References YACS::ENGINE::BlocPoint::_nodes, and YACS::ENGINE::AbstractPoint::setFather().
◆ getFirstNode()
Node * ForkBlocPoint::getFirstNode ( )
overridevirtual
Definition at line 44 of file ForkBlocPoint.cxx.
45{
46 if(_nodes.empty())
47 throw Exception("ForkBlocPoint::getFirstNode : error no branches !");
48 return _nodes.front()->getFirstNode();
49}
References YACS::ENGINE::BlocPoint::_nodes.
◆ getLastNode()
Node * ForkBlocPoint::getLastNode ( )
overridevirtual
Definition at line 51 of file ForkBlocPoint.cxx.
52{
53 if(_nodes.empty())
54 throw Exception("ForkBlocPoint::getLastNode : error no branches !");
55 return _nodes.front()->getLastNode();//not a bug - seen from the outside only first branch exists !
56}
◆ getMaxLevelOfParallelism()
int ForkBlocPoint::getMaxLevelOfParallelism ( ) const
Definition at line 58 of file ForkBlocPoint.cxx.
59{
60 int ret(0);
61 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
62 ret+=(*it)->getMaxLevelOfParallelism();
63 return ret;
64}
Referenced by YACS::ENGINE::Bloc::getMaxLevelOfParallelism().
◆ getRepr()
std::string ForkBlocPoint::getRepr ( ) const
Definition at line 103 of file ForkBlocPoint.cxx.
104{
105 std::size_t sz(_nodes.size()),ii(0);
106 std::string ret("[");
107 std::vector<std::string> elts(sz);
108 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
109 elts[ii]=(*it)->getRepr();
110 std::sort(elts.begin(),elts.end());
111 ii=0;
112 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
113 {
114 ret+=elts[ii];
115 if(ii!=sz-1)
116 ret+="*";
117 }
118 ret+="]";
119 return ret;
120}
◆ getWeightRegardingDPL()
void ForkBlocPoint::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 66 of file ForkBlocPoint.cxx.
67{
68 ComplexWeight localWeight;
69 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
70 {
71 (*it)->getWeightRegardingDPL(&localWeight);
72 weight->addWeight(&localWeight);
73 localWeight.setToZero();
74 }
75}
void addWeight(const ComplexWeight *other)
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::ComplexWeight::addWeight(), and YACS::ENGINE::ComplexWeight::setToZero().
Referenced by YACS::ENGINE::Bloc::getWeightRegardingDPL().
◆ partitionRegardingDPL()
void ForkBlocPoint::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 77 of file ForkBlocPoint.cxx.
78{
79 std::vector< std::pair<const PartDefinition *, const ComplexWeight *> > parts;
80 std::vector< int> nbCoresPerShot;
81 std::vector<std::size_t> v;
82 std::vector<ComplexWeight> nodesWeight(_nodes.size());
83 std::size_t ii(0);
84 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
85 {
86 ComplexWeight *w=&nodesWeight[ii];
87 (*it)->getWeightRegardingDPL(w);
88 parts.push_back(std::pair<const PartDefinition *, const ComplexWeight *>(pd,w));
89 nbCoresPerShot.push_back((*it)->getMaxLevelOfParallelism());
90 v.push_back(ii);
91 }
92 std::vector<AbstractPoint *> nodes2(_nodes.begin(),_nodes.end());
93 if(!parts.empty())
94 {
95 const PlayGround *pg(pd->getPlayGround());
96 std::vector< YACS::BASES::AutoRefCnt<PartDefinition> > pds(pg->partition(parts,nbCoresPerShot));
97 ii=0;
98 for(std::vector<std::size_t>::const_iterator iter=v.begin();iter!=v.end();iter++,ii++)
99 nodes2[*iter]->partitionRegardingDPL(pds[ii],zeMap);
100 }
101}
const PlayGround * getPlayGround() const
Definition: PlayGround.hxx:127
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::PartDefinition::getPlayGround(), YACS::ENGINE::PlayGround::partition(), and gui.logview::w.
Referenced by YACS::ENGINE::Bloc::partitionRegardingDPL().
