YACS::ENGINE::NonContigPartDefinition Class Reference
#include <PlayGround.hxx>
Inheritance diagram for YACS::ENGINE::NonContigPartDefinition:
Collaboration diagram for YACS::ENGINE::NonContigPartDefinition:
 NonContigPartDefinition (const PlayGround *pg, const std::vector< int > &ids)
 NonContigPartDefinition (const ContigPartDefinition &other)
std::string printSelf () const
std::vector< bool > getCoresOn () const
std::vector< int > getIDs () const
NonContigPartDefinition * copy () const
int getNumberOfCoresConsumed () const
- Public Member Functions inherited from YACS::ENGINE::PartDefinition
const PlayGround * getPlayGround () const
int getSpaceSize () const
void stashPart (int nbCoresStashed, double weightOfRemain, YACS::BASES::AutoRefCnt< PartDefinition > &pdStashed, YACS::BASES::AutoRefCnt< PartDefinition > &pdRemain) const
std::vector< std::size_t > computeWorkerIdsCovered (int nbCoresPerComp) const
virtual std::string printSelf () const =0
virtual std::vector< bool > getCoresOn () const =0
virtual PartDefinition * copy () const =0
virtual int getNumberOfCoresConsumed () const =0
void incrRef () const
bool decrRef () const
void checkOKIds () const
 ~NonContigPartDefinition ()
std::vector< int > _ids
- Static Public Member Functions inherited from YACS::ENGINE::PartDefinition
static YACS::BASES::AutoRefCnt< PartDefinition > BuildFrom (const PlayGround *pg, const std::vector< int > &coreIds)
- Protected Member Functions inherited from YACS::ENGINE::PartDefinition
 PartDefinition (const PlayGround *pg)
 PartDefinition (const PartDefinition &other)
virtual ~PartDefinition ()
 RefCounter ()
virtual ~RefCounter ()
unsigned int _cnt
Definition at line 157 of file PlayGround.hxx.
◆ NonContigPartDefinition() [1/2]
NonContigPartDefinition::NonContigPartDefinition ( const PlayGround *  pg,
const std::vector< int > &  ids
Definition at line 722 of file PlayGround.cxx.
722 :PartDefinition(pg),_ids(ids)
723{
724 checkOKIds();
725}
PartDefinition(const PlayGround *pg)
Definition: PlayGround.cxx:590
References checkOKIds().
Referenced by copy().
◆ NonContigPartDefinition() [2/2]
NonContigPartDefinition::NonContigPartDefinition ( const ContigPartDefinition &  other)
Definition at line 727 of file PlayGround.cxx.
727 :PartDefinition(other)
728{
729}
◆ ~NonContigPartDefinition()
YACS::ENGINE::NonContigPartDefinition::~NonContigPartDefinition ( )
inlineprivate
Definition at line 169 of file PlayGround.hxx.
169{ }
◆ checkOKIds()
void NonContigPartDefinition::checkOKIds ( ) const
Definition at line 758 of file PlayGround.cxx.
759{
760 int maxVal(getSpaceSize());
761 if(_ids.empty())
762 return;
763 int val(_ids.front());
764 if(val<0 || val>=maxVal)
765 throw Exception("checkOKIds : error 2 !");
766 std::size_t sz(_ids.size());
767 for(std::size_t i=0;i<sz-1;i++)
768 {
769 if(_ids[i+1]<=_ids[i])
770 throw Exception("checkOKIds : error 1 !");
771 if(_ids[i+1]>=maxVal)
772 throw Exception("checkOKIds : error 3 !");
773 }
774}
References _ids, YACS::ENGINE::PartDefinition::getSpaceSize(), and yacsorb.CORBAEngineTest::i.
Referenced by NonContigPartDefinition().
◆ copy()
NonContigPartDefinition * NonContigPartDefinition::copy ( ) const
Implements YACS::ENGINE::PartDefinition.
Definition at line 748 of file PlayGround.cxx.
749{
750 return new NonContigPartDefinition(*this);
751}
NonContigPartDefinition(const PlayGround *pg, const std::vector< int > &ids)
Definition: PlayGround.cxx:722
References NonContigPartDefinition().
◆ getCoresOn()
std::vector< bool > NonContigPartDefinition::getCoresOn ( ) const
Definition at line 740 of file PlayGround.cxx.
741{
742 std::vector<bool> ret(getSpaceSize(),false);
743 for(std::vector<int>::const_iterator it=_ids.begin();it!=_ids.end();it++)
744 ret[*it]=true;
745 return ret;
746}
References _ids, and YACS::ENGINE::PartDefinition::getSpaceSize().
◆ getIDs()
std::vector< int > YACS::ENGINE::NonContigPartDefinition::getIDs ( ) const
Definition at line 164 of file PlayGround.hxx.
164{ return _ids; }
◆ getNumberOfCoresConsumed()
int NonContigPartDefinition::getNumberOfCoresConsumed ( ) const
Definition at line 753 of file PlayGround.cxx.
754{
755 return _ids.size();
756}
References _ids.
◆ printSelf()
std::string NonContigPartDefinition::printSelf ( ) const
Definition at line 731 of file PlayGround.cxx.
732{
733 std::ostringstream oss;
734 oss << "Non contiguous : ";
735 for(std::vector<int>::const_iterator it=_ids.begin();it!=_ids.end();it++)
736 oss << *it << ", ";
737 return oss.str();
738}
References _ids.
◆ _ids
std::vector<int> YACS::ENGINE::NonContigPartDefinition::_ids
Definition at line 171 of file PlayGround.hxx.
Referenced by checkOKIds(), getCoresOn(), getNumberOfCoresConsumed(), and printSelf().
