SalomeOptimizerLoop.cxx
21
22// rnv: avoid compilation warning on Linux : "_POSIX_C_SOURCE" and "_XOPEN_SOURCE" are redefined
23#ifdef _POSIX_C_SOURCE
24#undef _POSIX_C_SOURCE
25#endif
26
27#ifdef _XOPEN_SOURCE
28#undef _XOPEN_SOURCE
29#endif
30#include <Python.h>
31#include "TypeCode.hxx"
32#include "PyStdout.hxx"
33
34//#define _DEVDEBUG_
35#include "YacsTrace.hxx"
36
37using namespace YACS::ENGINE;
38using namespace std;
39
40
47SalomeOptimizerLoop::SalomeOptimizerLoop(const std::string& name, const std::string& algLibWthOutExt,
48 const std::string& symbolNameToOptimizerAlgBaseInstanceFactory,
49 bool algInitOnFile,bool initAlgo, Proc * procForTypes):
50 OptimizerLoop(name,algLibWthOutExt,symbolNameToOptimizerAlgBaseInstanceFactory,algInitOnFile,false)
51{
52 if(initAlgo)
53 {
54 //try
55 // {
56 setAlgorithm(algLibWthOutExt, symbolNameToOptimizerAlgBaseInstanceFactory, true, procForTypes);
57 // }
58 //catch(YACS::Exception& e)
59 // {
60 //ignore it
61 // }
62 }
63}
64
66 OptimizerLoop(other,father,editionOnly)
67{
68}
69
71{
72 Py_XDECREF(_pyAlgo);
73}
74
75Node *SalomeOptimizerLoop::simpleClone(ComposedNode *father, bool editionOnly) const
76{
77 SalomeOptimizerLoop* sol=new SalomeOptimizerLoop(*this,father,editionOnly);
78 // TODO: Remove this const_cast (find a better design to get the type codes from the original node)
79 Proc * procForTypes = sol->getProc();
80 if (procForTypes == NULL) {
81 const Proc * origProc = getProc();
82 procForTypes = const_cast<Proc *>(origProc);
83 }
84 sol->setAlgorithm(_alglib, _symbol, false, procForTypes);
85 return sol;
86}
87
89
95{
96 YASSERT(_alg == NULL)
97
98 if(_alglib.size() > 3 && _alglib.substr(_alglib.size()-3,3)==".py")
99 {
100 //if alglib extension is .py try to import the corresponding python module
101 PyGILState_STATE gstate=PyGILState_Ensure();
102
103 PyObject* mainmod = PyImport_AddModule("__main__");
104 PyObject* globals = PyModule_GetDict(mainmod);
105
106 std::string pyscript;
107 pyscript="import sys\n"
108 "import SALOMERuntime\n"
109 "filename='";
110 pyscript=pyscript+_alglib+"'\nentry='"+_symbol+"'\n";
111 pyscript=pyscript+"import os\n"
112 "import pilot\n"
113 "rep,mod=os.path.split(os.path.splitext(filename)[0])\n"
114 "if rep != '':\n"
115 " sys.path.insert(0,rep)\n"
116 "algomodule=__import__(mod)\n"
117 "if rep != '':\n"
118 " del sys.path[0]\n"
119 "algoclass= getattr(algomodule,entry)\n"
120 "algo= algoclass()\n"
121 "swigalgo= algo.this\n"
122 "\n";
123
124 PyObject* res=PyRun_String(pyscript.c_str(), Py_file_input, globals, globals );
125
126 if(res == NULL)
127 {
128 //error during import
129 _errorDetails="";
130 PyObject* new_stderr = newPyStdOut(_errorDetails);
131 PySys_SetObject((char*)"stderr", new_stderr);
132 PyErr_Print();
133 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
134 Py_DECREF(new_stderr);
135 modified();
136 PyGILState_Release(gstate);
138 }
139 else
140 {
141 Py_DECREF(res);
142
143 typedef struct {
144 PyObject_HEAD
145 void *ptr;
146 void *ty;
147 int own;
148 PyObject *next;
149 } SwigPyObject;
150
151 PyObject * _pyAlgo = PyDict_GetItemString(globals, "algo");
152 Py_XINCREF(_pyAlgo);
153 SwigPyObject* pyalgo = (SwigPyObject*)PyDict_GetItemString(globals, "swigalgo");
154 _alg=(OptimizerAlgBase*)pyalgo->ptr;
156 }
157 PyGILState_Release(gstate);
158 }
159 else
160 {
161 //else try to load a dynamic library
163 }
164}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Base class for all nodes.
Definition: Node.hxx:70
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
std::string _errorDetails
Definition: Node.hxx:93
virtual Proc * getProc()
Definition: Node.cxx:401
Base class factorizing common methods for all algorithms interfaces.
virtual void setPool(Pool *pool)
virtual void setAlgorithm(const std::string &alglib, const std::string &symbol, bool checkLinks=true, Proc *procForTypes=NULL)
Set the algorithm library name and factory name (symbol in library) to create the algorithm and chang...
virtual void loadAlgorithm()
Load the algorithm from the dynamic library.
Definition: Proc.hxx:44
SalomeOptimizerLoop(const std::string &name, const std::string &algLibWthOutExt, const std::string &symbolNameToOptimizerAlgBaseInstanceFactory, bool algInitOnFile, bool initAlgo=true, Proc *procForTypes=NULL)
Node * simpleClone(ComposedNode *father, bool editionOnly) const
Load the algorithm object from a Python module or a dynamic library.
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
