Nodes
class  YACS::ENGINE::DataNode
 Class for data parameters specification. More...
class  YACS::ENGINE::DynParaLoop
 Base class for dynamically (fully or semifully) built graphs. More...
class  YACS::ENGINE::InlineNode
 Class for calculation node (script) inlined (and executed) in the schema. More...
class  YACS::ENGINE::InlineFuncNode
 Class for calculation node (function) inlined (and executed) in the schema. More...
class  YACS::ENGINE::Loop
 Base class for loop node. More...
class  YACS::ENGINE::WhileLoop
 Class for a while loop. More...
class  YACS::ENGINE::CORBANode
 Class for CORBA Service Node. More...
class  YACS::ENGINE::SalomeNode
 Class for Salome component Service Node. More...
class  YACS::ENGINE::CppNode
 Class for C++ Nodes (in process component) More...
class  YACS::ENGINE::Bloc
 Composed node to group elementary and composed nodes. More...
class  YACS::ENGINE::ComposedNode
 Base class for all composed nodes. More...
class  YACS::ENGINE::ElementaryNode
 Base class for all calculation nodes. More...
class  YACS::ENGINE::ForEachLoop
 Loop node for parametric calculation. More...
class  YACS::ENGINE::ForLoop
 Class for for loop node. More...
class  YACS::ENGINE::Node
 Base class for all nodes. More...
class  YACS::ENGINE::Proc
 Base class for all schema objects. More...
class  YACS::ENGINE::ServiceNode
 Class for calculation node associated with a component service. More...
class  YACS::ENGINE::Switch
 Control node that emulates the C switch. More...
class  YACS::ENGINE::OutNode
 Class for data out node. More...
class  YACS::ENGINE::PresetNode
 Class for data in node. More...
class  YACS::ENGINE::SalomeOptimizerLoop
 class to build optimization loops More...
