YACS::ENGINE::OutNode Class Reference
Class for data out node. More...
#include <OutNode.hxx>
Inheritance diagram for YACS::ENGINE::OutNode:
Collaboration diagram for YACS::ENGINE::OutNode:
 OutNode (const std::string &name)
 OutNode (const OutNode &other, ComposedNode *father)
virtual void execute ()
virtual void setData (InputPort *port, const std::string &data)
virtual void dump (std::ostream &os)
- Public Member Functions inherited from YACS::ENGINE::DataNode
virtual void setData (OutputPort *port, const std::string &data)
virtual void setRef (const std::string &ref)
virtual std::string getRef ()
virtual ~DataNode ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char IMPL_NAME [] ="XML"
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::DataNode
 DataNode (const DataNode &other, ComposedNode *father)
 DataNode (const std::string &name)
template<class PORT >
YACS::Colour _colour
- Protected Attributes inherited from YACS::ENGINE::DataNode
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 29 of file OutNode.hxx.
◆ OutNode() [1/2]
YACS::ENGINE::OutNode::OutNode ( const std::string &  name)
Definition at line 47 of file OutNode.cxx.
48 : DataNode(name)
49{
51}
DataNode(const DataNode &other, ComposedNode *father)
Definition: DataNode.hxx:40
Definition: Node.hxx:97
static const char IMPL_NAME[]
Definition: OutNode.hxx:43
References YACS::ENGINE::Node::_implementation, and IMPL_NAME.
Referenced by simpleClone().
◆ OutNode() [2/2]
YACS::ENGINE::OutNode::OutNode ( const OutNode &  other,
ComposedNode *  father
Definition at line 53 of file OutNode.cxx.
54 : DataNode(other, father)
55{
56}
◆ accept()
void YACS::ENGINE::OutNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 99 of file OutNode.cxx.
100{
101 visitor->visitOutNode(this);
102}
References YACS::ENGINE::Visitor::visitOutNode().
◆ checkBasicConsistency()
void YACS::ENGINE::OutNode::checkBasicConsistency ( ) const
Definition at line 110 of file OutNode.cxx.
111{
112 DEBTRACE("OutNode::checkBasicConsistency");
113 if (! _setOfOutputPort.empty())
114 {
115 string what = "OutNode ";
116 what += getName();
117 what += " only accepts InputPorts, no OutputPorts";
118 throw Exception(what);
119 }
120 list<InputPort *>::const_iterator iter;
121 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
122 {
123 InputPresetPort *preset = dynamic_cast<InputPresetPort*>(*iter);
124 if (!preset)
125 {
126 string what("Input port: ");
127 what += (*iter)->getName();
128 what += " is not an InputPresetPort. PresetNode ";
129 what += getName();
130 what += " only accepts InputPresetPorts";
131 throw Exception(what);
132 }
133 preset->checkBasicConsistency();
134 }
135
136}
Definition: Node.hxx:125
References YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::InputPort::checkBasicConsistency(), DEBTRACE, and YACS::ENGINE::Node::getName().
◆ createInputPort()
InputPort * YACS::ENGINE::OutNode::createInputPort ( const std::string &  inputPortName,
TypeCode *  type
Definition at line 58 of file OutNode.cxx.
59{
60 return new InputPresetPort(inputPortName, this, type);
61}
◆ dump()
void YACS::ENGINE::OutNode::dump ( std::ostream &  os)
Definition at line 63 of file OutNode.cxx.
64{
65 std::list<InputPort *>::const_iterator iter;
66 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
67 {
68 InputPresetPort *inp = dynamic_cast<InputPresetPort *>(*iter);
69 if(inp->getData() != "")
70 {
71 //save the file in the given reference
72 std::string xmlValue=inp->dump();
73 std::string::size_type i=xmlValue.find_first_of('/',0);
74 xmlValue=xmlValue.substr(i);
75 i=xmlValue.find_first_of('<',0);
76 std::ifstream fin(xmlValue.substr(0,i).c_str());
77 std::ofstream fout(inp->getData().c_str());
78 fout << fin.rdbuf(); // Dumps file contents to file
79 out << "<value><objref>" << inp->getData() << "</objref></value>" << std::endl;
80 }
81 else
82 out << inp->dump() << std::endl;
83 }
84}
References YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::InputPresetPort::dump(), YACS::ENGINE::InputPresetPort::getData(), and yacsorb.CORBAEngineTest::i.
Referenced by execute().
◆ execute()
void YACS::ENGINE::OutNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 86 of file OutNode.cxx.
87{
88 DEBTRACE("+++++++ OutNode::execute +++++++++++");
89 if(_ref != "")
90 {
91 std::ofstream out(_ref.c_str());
92 dump(out);
93 }
94 else
95 dump(std::cout);
96 DEBTRACE("+++++++ end OutNode::execute +++++++++++" );
97}
virtual void dump(std::ostream &os)
Definition: OutNode.cxx:63
References YACS::ENGINE::DataNode::_ref, DEBTRACE, and dump().
◆ setData()
void YACS::ENGINE::OutNode::setData ( InputPort *  port,
const std::string &  data
Reimplemented from YACS::ENGINE::DataNode.
Definition at line 104 of file OutNode.cxx.
105{
106 InputPresetPort *inp = dynamic_cast<InputPresetPort *>(port);
107 inp->setData(data);
108}
References YACS::ENGINE::InputPresetPort::setData().
◆ simpleClone()
Node * YACS::ENGINE::OutNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 138 of file OutNode.cxx.
139{
140 return new OutNode(*this,father);
141}
OutNode(const std::string &name)
Definition: OutNode.cxx:47
References OutNode().
◆ IMPL_NAME
const char YACS::ENGINE::OutNode::IMPL_NAME ="XML"
Definition at line 43 of file OutNode.hxx.
Referenced by OutNode().
