YACS::ENGINE::CppNode Class Reference
Class for C++ Nodes (in process component) More...
#include <CppNode.hxx>
Inheritance diagram for YACS::ENGINE::CppNode:
Collaboration diagram for YACS::ENGINE::CppNode:
 CppNode (const CppNode &other, ComposedNode *father)
 CppNode (const std::string &name)
virtual void load ()
 Load the component associated to the node. More...
virtual void execute ()
virtual ServiceNode * createNode (const std::string &name)
CppNode * cloneNode (const std::string &name)
 Create a new node of same type with a given name. More...
void setCode (const std::string &componentName, const std::string &service)
void setFunc (MYRUN fonc)
std::string getKind () const
 Return the service node kind. More...
- Public Member Functions inherited from YACS::ENGINE::ServiceNode
virtual bool isDeployable () const
 By definition of ServiceNode class. More...
virtual void setComponent (ComponentInstance *compo)
 Associate an existing component instance to this service node AND check the consistency regarding the deployment from root node point of view. More...
virtual ComponentInstance * getComponent ()
 Return the associated component instance. More...
virtual const ComponentInstance * getComponent () const
virtual Container * getContainer ()
 Return the associated container. More...
virtual void setRef (const std::string &ref)
 Associate a new component instance to this service node. More...
virtual std::string getRef ()
virtual void setMethod (const std::string &method)
virtual std::string getMethod ()
virtual ServiceNode * createNode (const std::string &name)=0
virtual ~ServiceNode ()
virtual std::string getKind () const
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char IMPL_NAME [] ="Cpp"
static const char KIND [] ="Cpp"
- Static Public Attributes inherited from YACS::ENGINE::ServiceNode
static const char KIND [] =""
Node * simpleClone (ComposedNode *father, bool editionOnly) const
 Clone the node : must also clone the component instance ? More...
- Protected Member Functions inherited from YACS::ENGINE::ServiceNode
 ServiceNode (const std::string &name)
 ServiceNode (const ServiceNode &other, ComposedNode *father)
template<class PORT >
std::string _componentName
MYRUN _run
- Protected Attributes inherited from YACS::ENGINE::ServiceNode
ComponentInstance * _component
std::string _method
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
static int _total = 0
local C++ implementation - single process
Definition at line 46 of file CppNode.hxx.
◆ CppNode() [1/2]
CppNode::CppNode ( const CppNode &  other,
ComposedNode *  father
Definition at line 41 of file CppNode.cxx.
41 :ServiceNode(other,father),
42 _run(other._run),
44{
45 DEBTRACE("CppNode::CppNode");
47}
Definition: CppNode.hxx:65
static const char IMPL_NAME[]
Definition: CppNode.hxx:61
Definition: Node.hxx:97
ServiceNode(const std::string &name)
Definition: ServiceNode.cxx:55
References YACS::ENGINE::Node::_implementation, DEBTRACE, and IMPL_NAME.
Referenced by cloneNode(), createNode(), and simpleClone().
◆ CppNode() [2/2]
CppNode::CppNode ( const std::string &  name)
Definition at line 49 of file CppNode.cxx.
49 : ServiceNode(name), _run(NULL)
50{
52}
References YACS::ENGINE::Node::_implementation, and IMPL_NAME.
◆ cloneNode()
CppNode * CppNode::cloneNode ( const std::string &  name)
Definition at line 149 of file CppNode.cxx.
150{
151 DEBTRACE("CppNode::cloneNode");
152 CppNode* n=new CppNode(name);
153
154 if (_run)
155 n->setFunc(_run);
156
157 if (_component)
158 n->setCode(_componentName, _method);
159
160 list<InputPort *>::iterator iter;
161 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
162 {
163 InputCppPort *p=(InputCppPort *)*iter;
164 DEBTRACE("port name: " << p->getName());
165 DEBTRACE("port kind: " << p->edGetType()->kind());
166 n->edAddInputPort(p->getName(),p->edGetType());
167 }
168 list<OutputPort *>::iterator iter2;
169 for(iter2 = _setOfOutputPort.begin(); iter2 != _setOfOutputPort.end(); iter2++)
170 {
171 OutputCppPort *p=(OutputCppPort *)*iter2;
172 DEBTRACE("port name: " << p->getName());
173 DEBTRACE("port kind: " << p->edGetType()->kind());
174 n->edAddOutputPort(p->getName(),p->edGetType());
175 }
176 return n;
177}
std::string getName() const
Definition: CppNode.hxx:47
CppNode(const CppNode &other, ComposedNode *father)
Definition: CppNode.cxx:41
Class for C++ Ports.
Definition: CppPorts.hxx:40
Definition: ServiceNode.hxx:60
Proc * p
Definition: driver.cxx:216
References YACS::ENGINE::ServiceNode::_component, _componentName, YACS::ENGINE::ServiceNode::_method, _run, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, CppNode(), DEBTRACE, YACS::ENGINE::ComposedNode::getName(), gui.Appli::n, and p.
◆ createNode()
ServiceNode * CppNode::createNode ( const std::string &  name)
Implements YACS::ENGINE::ServiceNode.
Definition at line 135 of file CppNode.cxx.
136{
137 CppNode* node= new CppNode(name);
139 return node;
140}
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
References YACS::ENGINE::ServiceNode::_component, CppNode(), and YACS::ENGINE::ServiceNode::setComponent().
◆ execute()
void CppNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 84 of file CppNode.cxx.
85{
86 std::list<InputPort *>::iterator iter1;
87 int nIn, nOut, it;
88
89 nIn = _setOfInputPort.size();
90 nOut = _setOfOutputPort.size();
91
92 Any ** In = new Any * [nIn], ** Out = new Any * [nOut];
93
94 try
95 {
96
97 for(iter1 = _setOfInputPort.begin(), it = 0; iter1 != _setOfInputPort.end();
98 iter1++, it++)
99 {
100 InputCppPort *p = dynamic_cast<InputCppPort *> (*iter1);
101 In[it] = p->getCppObj();
102 }
103
104 if (_component)
105 {
106 CppComponent * _componentC = dynamic_cast<CppComponent *>(_component);
107 if (!_componentC)
108 throw YACS::Exception("CppNode::execute : bad type of component");
109 _componentC->run(_method.c_str(), nIn, nOut, In, Out);
110 }
111 else if (_run)
112 _run(nIn, nOut, In, Out);
113
114 //output parameters
115 std::list<OutputPort *>::iterator iter2;
116 for(iter2 = _setOfOutputPort.begin(), it=0; iter2 != _setOfOutputPort.end(); iter2++, it++)
117 {
118 OutputCppPort *p = dynamic_cast<OutputCppPort *> (*iter2);
119 p->put(Out[it]);
120 //decref it, we don't need it more
121 Out[it]->decrRef();
122 DEBTRACE("ref count: " << Out[it]->getRefCnt());
123 }
124 }
125 catch (YACS::Exception & e) {
126 delete [] In;
127 delete [] Out;
128 throw e;
129 }
130
131 delete [] In;
132 delete [] Out;
133}
Definition: Any.hxx:79
void run(const char *service, int nbIn, int nbOut, Any **argIn, Any **argOut)
References YACS::ENGINE::ServiceNode::_component, YACS::ENGINE::ServiceNode::_method, _run, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), p, and YACS::ENGINE::CppComponent::run().
◆ getKind()
std::string YACS::ENGINE::CppNode::getKind ( ) const
A runtime can provide several implementations of a service node. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode with the same kind.
Reimplemented from YACS::ENGINE::ServiceNode.
Definition at line 63 of file CppNode.hxx.
63{ return CppNode::KIND; }
static const char KIND[]
Definition: CppNode.hxx:62
References KIND.
◆ load()
void CppNode::load ( )
Definition at line 74 of file CppNode.cxx.
75{
76 if (_run) return;
77
78 if (!_component) {
80 }
82}
virtual void setRef(const std::string &ref)
virtual void load()
Definition: ServiceNode.cxx:90
References YACS::ENGINE::ServiceNode::_component, _componentName, _run, YACS::ENGINE::ServiceNode::load(), and YACS::ENGINE::ServiceNode::setRef().
◆ setCode()
void CppNode::setCode ( const std::string &  componentName,
const std::string &  service
Definition at line 54 of file CppNode.cxx.
55{
56 _method = method;
57 _componentName = componentName;
58 _run = NULL;
59}
References _componentName, YACS::ENGINE::ServiceNode::_method, and _run.
◆ setFunc()
void CppNode::setFunc ( MYRUN  fonc)
Definition at line 61 of file CppNode.cxx.
61 {
62
63 if (_component)
64 {
66 _component = NULL;
67 _componentName = "";
68 _method = "";
69 _component = NULL;
70 }
71 _run = fonc;
72}
References YACS::ENGINE::ServiceNode::_component, _componentName, YACS::ENGINE::ServiceNode::_method, _run, and YACS::ENGINE::RefCounter::decrRef().
◆ simpleClone()
Node * CppNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 143 of file CppNode.cxx.
144{
145 return new CppNode(*this,father);
146}
References CppNode().
◆ _componentName
std::string YACS::ENGINE::CppNode::_componentName
Definition at line 65 of file CppNode.hxx.
Referenced by cloneNode(), load(), setCode(), and setFunc().
◆ _run
MYRUN YACS::ENGINE::CppNode::_run
Definition at line 66 of file CppNode.hxx.
Referenced by cloneNode(), execute(), load(), setCode(), and setFunc().
◆ IMPL_NAME
◆ KIND
const char CppNode::KIND ="Cpp"
