CppPorts.hxx
20#ifndef _CPPPORTS_HXX_
21#define _CPPPORTS_HXX_
23
24#include "InputPort.hxx"
25#include "OutputPort.hxx"
26
27namespace YACS
28{
29 namespace ENGINE
30 {
31 class Any;
32
39 class InputCppPort : public InputPort
40 {
41 public:
42 InputCppPort(const std::string& name, Node * node, TypeCode * type);
43 InputCppPort(const InputCppPort& other, Node *newHelder);
45 bool edIsManuallyInitialized() const;
46 void edRemoveManInit();
47 virtual void put(const void *data);
48 void put(YACS::ENGINE::Any *data);
49 void releaseData() override;
50 InputPort *clone(Node *newHelder) const;
51 virtual YACS::ENGINE::Any * getCppObj() const;
52 void *get() const ;
53 virtual bool isEmpty();
54 virtual void exSaveInit();
55 virtual void exRestoreInit();
56 virtual std::string dump();
57 protected:
60 };
61
63 {
64 public:
65 OutputCppPort(const std::string& name, Node * node, TypeCode * type);
66 OutputCppPort(const OutputCppPort& other, Node *newHelder);
68 virtual void put(const void *data);
69 void put(YACS::ENGINE::Any *data);
70 OutputPort *clone(Node *newHelder) const;
71 virtual YACS::ENGINE::Any * get() const;
72 virtual std::string dump();
73 protected:
75 };
76
77
78
79 }
80}
81
82#endif
Definition: Any.hxx:79
Class for C++ Ports.
Definition: CppPorts.hxx:40
Definition: CppPorts.cxx:90
InputPort * clone(Node *newHelder) const
Definition: CppPorts.cxx:85
InputCppPort(const std::string &name, Node *node, TypeCode *type)
Definition: CppPorts.cxx:34
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition: CppPorts.cxx:54
Restore the saved data value to current data value.
Definition: CppPorts.cxx:120
Removes eventually previous manual initialisation.
Definition: CppPorts.cxx:59
Definition: CppPorts.cxx:100
Save the current data value for further reinitialization of the port.
Definition: CppPorts.cxx:109
YACS::ENGINE::Any * _initData
Definition: CppPorts.hxx:59
Definition: CppPorts.cxx:70
Definition: CppPorts.cxx:128
Definition: CppPorts.cxx:65
YACS::ENGINE::Any * _data
Definition: CppPorts.hxx:58
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
OutputPort * clone(Node *newHelder) const
Definition: CppPorts.cxx:185
Definition: CppPorts.cxx:195
Definition: CppPorts.cxx:190
Definition: CppPorts.hxx:74
Definition: CppPorts.cxx:169
OutputCppPort(const std::string &name, Node *node, TypeCode *type)
Definition: CppPorts.cxx:149
Definition: TypeCode.hxx:68
