YACS::ENGINE::OutputCppPort Class Reference
#include <CppPorts.hxx>
Inheritance diagram for YACS::ENGINE::OutputCppPort:
Collaboration diagram for YACS::ENGINE::OutputCppPort:
 OutputCppPort (const std::string &name, Node *node, TypeCode *type)
 OutputCppPort (const OutputCppPort &other, Node *newHelder)
 ~OutputCppPort ()
OutputPort * clone (Node *newHelder) const
virtual YACS::ENGINE::Any * get () const
virtual std::string dump ()
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
YACS::ENGINE::Any * _data
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 62 of file CppPorts.hxx.
◆ OutputCppPort() [1/2]
OutputCppPort::OutputCppPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 149 of file CppPorts.cxx.
150 : OutputPort(name, node, type), DataPort(name, node, type), Port(node)
151{
152 _data = NULL;
153}
Definition: DataPort.cxx:41
Definition: CppPorts.hxx:74
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
References _data.
Referenced by clone().
◆ OutputCppPort() [2/2]
OutputCppPort::OutputCppPort ( const OutputCppPort &  other,
Node *  newHelder
Definition at line 164 of file CppPorts.cxx.
164 :OutputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder),
165 _data(NULL)
166{
167}
◆ ~OutputCppPort()
OutputCppPort::~OutputCppPort ( )
Definition at line 155 of file CppPorts.cxx.
156{
157 if(_data)
158 {
159 DEBTRACE("_data ref count: " << _data->getRefCnt());
160 _data->decrRef();
161 }
162}
unsigned int getRefCnt() const
Definition: RefCounter.hxx:32
References _data, DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::RefCounter::getRefCnt().
◆ clone()
OutputPort * OutputCppPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 185 of file CppPorts.cxx.
186{
187 return new OutputCppPort(*this,newHelder);
188}
OutputCppPort(const std::string &name, Node *node, TypeCode *type)
Definition: CppPorts.cxx:149
References OutputCppPort().
◆ dump()
std::string OutputCppPort::dump ( )
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 195 of file CppPorts.cxx.
196{
197 if( _data == NULL)
198 return "<value>None</value>";
199 string xmldump = convertNeutralXml(edGetType(), _data);
200 return xmldump;
201}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string convertNeutralXml(const TypeCode *t, YACS::ENGINE::Any *data)
References _data, YACS::ENGINE::convertNeutralXml(), and YACS::ENGINE::DataPort::edGetType().
◆ get()
YACS::ENGINE::Any * OutputCppPort::get ( ) const
Definition at line 190 of file CppPorts.cxx.
191{
192 return _data;
193}
References _data.
◆ put() [1/2]
void OutputCppPort::put ( const void *  data)
Definition at line 169 of file CppPorts.cxx.
170{
171 put((YACS::ENGINE::Any *)data);
172}
Definition: Any.hxx:79
Definition: CppPorts.cxx:169
References put().
Referenced by put().
◆ put() [2/2]
void OutputCppPort::put ( YACS::ENGINE::Any *  data)
Definition at line 174 of file CppPorts.cxx.
175{
176 InputPort *p;
177 if(_data)
178 _data->decrRef();
179 _data = data;
180 if(_data)
181 _data->incrRef();
182 OutputPort::put(data);
183}
Base class for Input Ports.
Definition: InputPort.hxx:44
Definition: OutputPort.cxx:66
Proc * p
Definition: driver.cxx:216
References _data, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::RefCounter::incrRef(), p, and YACS::ENGINE::OutputPort::put().
◆ _data
YACS::ENGINE::Any* YACS::ENGINE::OutputCppPort::_data
Definition at line 74 of file CppPorts.hxx.
Referenced by dump(), get(), OutputCppPort(), put(), and ~OutputCppPort().
