YACS::ENGINE::InputCppPort Class Reference
Class for C++ Ports. More...
#include <CppPorts.hxx>
Inheritance diagram for YACS::ENGINE::InputCppPort:
Collaboration diagram for YACS::ENGINE::InputCppPort:
 InputCppPort (const std::string &name, Node *node, TypeCode *type)
 InputCppPort (const InputCppPort &other, Node *newHelder)
 ~InputCppPort ()
bool edIsManuallyInitialized () const
void edRemoveManInit ()
void releaseData () override
virtual YACS::ENGINE::Any * getCppObj () const
void * get () const
virtual bool isEmpty ()
virtual void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
virtual void exRestoreInit ()
 Restore the saved data value to current data value. More...
virtual std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
YACS::ENGINE::Any * _data
YACS::ENGINE::Any * _initData
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
CppNode
Definition at line 39 of file CppPorts.hxx.
◆ InputCppPort() [1/2]
InputCppPort::InputCppPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 34 of file CppPorts.cxx.
35 : InputPort(name, node, type), DataPort(name, node, type), Port(node), _data(NULL),_initData(NULL)
36{
37}
Definition: DataPort.cxx:41
Definition: CppPorts.hxx:59
Definition: CppPorts.hxx:58
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InputCppPort() [2/2]
InputCppPort::InputCppPort ( const InputCppPort &  other,
Node *  newHelder
Definition at line 48 of file CppPorts.cxx.
48 :InputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder)
49{
50 _initData=other._initData;
51 _data=other._data;
52}
References _data, and _initData.
◆ ~InputCppPort()
InputCppPort::~InputCppPort ( )
Definition at line 39 of file CppPorts.cxx.
40{
41 if(_data)
42 {
43 DEBTRACE("_data ref count: " << _data->getRefCnt());
44 _data->decrRef();
45 }
46}
unsigned int getRefCnt() const
Definition: RefCounter.hxx:32
References _data, DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::RefCounter::getRefCnt().
◆ clone()
InputPort * InputCppPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 85 of file CppPorts.cxx.
86{
87 return new InputCppPort(*this,newHelder);
88}
InputCppPort(const std::string &name, Node *node, TypeCode *type)
Definition: CppPorts.cxx:34
References InputCppPort().
◆ dump()
std::string InputCppPort::dump ( )
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 128 of file CppPorts.cxx.
129{
130 if( _data == NULL)
131 return "<value>None</value>";
132
133 if (edGetType()->kind() != YACS::ENGINE::Objref)
135 //return convertCppXml(edGetType(), _data);
136 if (! _stringRef.empty())
137 return _stringRef;
138 else
140// {
141// stringstream msg;
142// msg << "Cannot retreive init reference string for port " << _name
143// << " on node " << _node->getName();
144// throw Exception(msg.str());
145// }
146}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: InputPort.hxx:90
std::string convertNeutralXml(const TypeCode *t, YACS::ENGINE::Any *data)
References _data, YACS::ENGINE::InputPort::_stringRef, YACS::ENGINE::convertNeutralXml(), YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::Objref.
◆ edIsManuallyInitialized()
bool InputCppPort::edIsManuallyInitialized ( ) const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition at line 54 of file CppPorts.cxx.
55{
56 return _initData!= NULL;
57}
References _initData.
◆ edRemoveManInit()
void InputCppPort::edRemoveManInit ( )
Removes eventually previous manual initialisation.
Definition at line 59 of file CppPorts.cxx.
60{
61 _initData=NULL;
63}
virtual void edRemoveManInit()
Definition: InputPort.cxx:140
References _initData, and YACS::ENGINE::InputPort::edRemoveManInit().
◆ exRestoreInit()
void InputCppPort::exRestoreInit ( )
If no data has been saved (_initData == 0) don't restore
Definition at line 120 of file CppPorts.cxx.
121{
122 if(!_initData)return;
124 //DEBTRACE("_initData.ob refcnt: " << _initData->ob_refcnt);
125 //DEBTRACE("_data.ob refcnt: " << _data->ob_refcnt);
126}
◆ exSaveInit()
void InputCppPort::exSaveInit ( )
Definition at line 109 of file CppPorts.cxx.
110{
112 //DEBTRACE("_initData.ob refcnt: " << _initData->ob_refcnt);
113 //DEBTRACE("_data.ob refcnt: " << _data->ob_refcnt);
114}
◆ get()
void * InputCppPort::get ( ) const
Definition at line 95 of file CppPorts.cxx.
96{
97 return (void*) _data;
98}
References _data.
◆ getCppObj()
YACS::ENGINE::Any * InputCppPort::getCppObj ( ) const
Definition at line 90 of file CppPorts.cxx.
91{
92 return _data;
93}
References _data.
◆ isEmpty()
bool InputCppPort::isEmpty ( )
Definition at line 100 of file CppPorts.cxx.
101{
102 return _data == NULL;
103}
References _data.
◆ put() [1/2]
void InputCppPort::put ( const void *  data)
Definition at line 65 of file CppPorts.cxx.
66{
67 put((YACS::ENGINE::Any *)data);
68}
Definition: Any.hxx:79
Definition: CppPorts.cxx:65
References put().
Referenced by put().
◆ put() [2/2]
void InputCppPort::put ( YACS::ENGINE::Any *  data)
Definition at line 77 of file CppPorts.cxx.
78{
80 _data=data;
81 _data->incrRef();
82 DEBTRACE("value ref count: " << _data->getRefCnt());
83}
void releaseData() override
Definition: CppPorts.cxx:70
References _data, DEBTRACE, YACS::ENGINE::RefCounter::getRefCnt(), YACS::ENGINE::RefCounter::incrRef(), and releaseData().
◆ releaseData()
void InputCppPort::releaseData ( )
overridevirtual
Definition at line 70 of file CppPorts.cxx.
71{
72 if(_data)
73 _data->decrRef();
74 _data=nullptr;
75}
References _data, and YACS::ENGINE::RefCounter::decrRef().
◆ _data
YACS::ENGINE::Any* YACS::ENGINE::InputCppPort::_data
◆ _initData
YACS::ENGINE::Any* YACS::ENGINE::InputCppPort::_initData
