42const char ServiceNode::KIND[]=
50std::string ServiceNode::getKind()
const
109 std::string what(
"ServiceNode::load : a load operation requested on ServiceNode called \"");
110 what+=
_name; what+=
"\" with no component specified.";
148 DEBTRACE(
"ServiceNode::setComponent " << compo);
155 std::string what(
"ServiceNode::setComponent : component instance kind not allowed ");
161 std::string oldref=
_ref;
#define YASSERT(val)
Container * getContainer() const
virtual std::string getKindForNode() const
const std::string & getInstanceName() const
virtual bool isLoaded(Task *askingNode) const =0
Indicate if the component instance is loaded (true) or not.
virtual ComponentInstance * clone() const =0
virtual void load(Task *askingNode)=0
Load the component instance.
DeploymentTree checkDeploymentTree(bool deep) const
Perform check of deployment consistency of the current graph.
Base class for all nodes.
virtual ComposedNode * getRootNode() const
std::string _errorDetails
virtual ComponentInstance * createComponentInstance(const std::string &name, const std::string &kind="")
Return the service node kind.
virtual void setRef(const std::string &ref)
Associate a new component instance to this service node.
ServiceNode(const std::string &name)
virtual Container * getContainer()
Return the associated container.
void performDuplicationOfPlacement(const Node &other)
performs a duplication of placement using clone method of containers and components....
virtual void load()
Load the component associated to the node.
ComponentInstance * _component
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
virtual std::string getRef()
virtual ComponentInstance * getComponent()
Return the associated component instance.
virtual void accept(Visitor *visitor)
void performShallowDuplicationOfPlacement(const Node &other)
performs a also duplication of placement but here containers and components are not copied at all wha...
virtual bool isDeployable() const
By definition of ServiceNode class.
virtual void visitServiceNode(ServiceNode *node)=0
const char * what(void) const noexcept
