YACS::ENGINE::ServiceNode Class Referenceabstract
Class for calculation node associated with a component service. More...
#include <ServiceNode.hxx>
Inheritance diagram for YACS::ENGINE::ServiceNode:
Collaboration diagram for YACS::ENGINE::ServiceNode:
virtual void load ()
 Load the component associated to the node. More...
virtual bool isDeployable () const
 By definition of ServiceNode class. More...
virtual void setComponent (ComponentInstance *compo)
 Associate an existing component instance to this service node AND check the consistency regarding the deployment from root node point of view. More...
virtual ComponentInstance * getComponent ()
 Return the associated component instance. More...
virtual const ComponentInstance * getComponent () const
virtual Container * getContainer ()
 Return the associated container. More...
virtual void setRef (const std::string &ref)
 Associate a new component instance to this service node. More...
virtual std::string getRef ()
virtual void setMethod (const std::string &method)
virtual std::string getMethod ()
virtual ServiceNode * createNode (const std::string &name)=0
virtual ~ServiceNode ()
virtual std::string getKind () const
 Return the service node kind. More...
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char KIND [] =""
 ServiceNode (const std::string &name)
 ServiceNode (const ServiceNode &other, ComposedNode *father)
template<class PORT >
ComponentInstance * _component
std::string _method
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
static int _total = 0
See also
InlineNode
ElementaryNode
Definition at line 34 of file ServiceNode.hxx.
◆ ServiceNode() [1/2]
ServiceNode::ServiceNode ( const std::string &  name)
Definition at line 55 of file ServiceNode.cxx.
56{
57}
friend class ElementaryNode
Definition: Node.hxx:80
Definition: ServiceNode.hxx:60
◆ ServiceNode() [2/2]
ServiceNode::ServiceNode ( const ServiceNode &  other,
ComposedNode *  father
Definition at line 59 of file ServiceNode.cxx.
60 :ElementaryNode(other,father),_method(other._method),_component(0)
61{
62}
◆ ~ServiceNode()
ServiceNode::~ServiceNode ( )
Definition at line 83 of file ServiceNode.cxx.
84{
85 if(_component)
87}
References _component, and YACS::ENGINE::RefCounter::decrRef().
◆ accept()
void ServiceNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ElementaryNode.
Reimplemented in YACS::ENGINE::ServiceInlineNode.
Definition at line 116 of file ServiceNode.cxx.
117{
118 visitor->visitServiceNode(this);
119}
virtual void visitServiceNode(ServiceNode *node)=0
References YACS::ENGINE::Visitor::visitServiceNode().
◆ createNode()
virtual ServiceNode * YACS::ENGINE::ServiceNode::createNode ( const std::string &  name)
pure virtual
◆ getComponent() [1/2]
◆ getComponent() [2/2]
const ComponentInstance * ServiceNode::getComponent ( ) const
Definition at line 127 of file ServiceNode.cxx.
128{
129 return _component;
130}
References _component.
◆ getContainer()
Container * ServiceNode::getContainer ( )
Definition at line 133 of file ServiceNode.cxx.
134{
136 return 0;
137}
References _component, and YACS::ENGINE::ComponentInstance::getContainer().
Referenced by YACS::HMI::EditionSalomeNode::EditionSalomeNode().
◆ getKind()
std::string ServiceNode::getKind ( ) const
A runtime can provide several implementations of a service node. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode with the same kind.
Reimplemented in YACS::ENGINE::CORBANode, YACS::ENGINE::SalomeNode, YACS::ENGINE::CppNode, YACS::ENGINE::SalomePythonNode, and YACS::ENGINE::XmlNode.
Definition at line 50 of file ServiceNode.cxx.
51{
52 return KIND;
53}
static const char KIND[]
Definition: ServiceNode.hxx:58
References KIND.
Referenced by YACS::servicetypeParser< T >::component(), setRef(), and YACS::ENGINE::VisitorSaveSchema::visitServiceNode().
◆ getMethod()
virtual std::string YACS::ENGINE::ServiceNode::getMethod ( )
◆ getRef()
std::string ServiceNode::getRef ( )
Definition at line 206 of file ServiceNode.cxx.
207{
208 return _ref;
209}
References _ref.
Referenced by YACS::ENGINE::VisitorSaveSchema::visitServiceNode().
◆ isDeployable()
bool ServiceNode::isDeployable ( ) const
Definition at line 140 of file ServiceNode.cxx.
141{
142 return true;
143}
◆ load()
void ServiceNode::load ( )
Reimplemented in YACS::ENGINE::CppNode, YACS::ENGINE::SalomePythonNode, and YACS::ENGINE::XmlNode.
Definition at line 90 of file ServiceNode.cxx.
91{
92 if(_component)
93 {
94 if(!_component->isLoaded(this))
95 {
96 try
97 {
98 _component->load(this);
99 }
100 catch(Exception& e)
101 {
102 _errorDetails=e.what();
103 throw e;
104 }
105 }
106 }
107 else
108 {
109 std::string what("ServiceNode::load : a load operation requested on ServiceNode called \"");
110 what+=_name; what+="\" with no component specified.";
111 _errorDetails=what;
112 throw Exception(what);
113 }
114}
virtual bool isLoaded(Task *askingNode) const =0
Indicate if the component instance is loaded (true) or not.
virtual void load(Task *askingNode)=0
Load the component instance.
std::string _name
Definition: Node.hxx:89
Definition: Node.hxx:93
References _component, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_name, YACS::ENGINE::ComponentInstance::isLoaded(), YACS::ENGINE::ComponentInstance::load(), and YACS::Exception::what().
Referenced by YACS::ENGINE::CppNode::load(), and YACS::ENGINE::SalomePythonNode::load().
◆ performDuplicationOfPlacement()
void ServiceNode::performDuplicationOfPlacement ( const Node &  other)
performs a duplication of placement using clone method of containers and components. clone behaviour is driven by attachOnCloning attribute.
Definition at line 64 of file ServiceNode.cxx.
65{
66 const ServiceNode &otherC=*(dynamic_cast<const ServiceNode *>(&other));
67 //if other has no component don't clone: this will not have one
68 if(otherC._component)
69 _component=otherC._component->clone();
70}
virtual ComponentInstance * clone() const =0
References _component, and YACS::ENGINE::ComponentInstance::clone().
◆ performShallowDuplicationOfPlacement()
void ServiceNode::performShallowDuplicationOfPlacement ( const Node &  other)
performs a also duplication of placement but here containers and components are not copied at all whatever the value of attachedOnCloning.
Definition at line 72 of file ServiceNode.cxx.
73{
74 const ServiceNode &otherC=*(dynamic_cast<const ServiceNode *>(&other));
75 //if other has no component don't clone: this will not have one
76 if(otherC._component)
77 {
80 }
81}
References _component, and YACS::ENGINE::RefCounter::incrRef().
◆ setComponent()
void ServiceNode::setComponent ( ComponentInstance *  compo)
Definition at line 146 of file ServiceNode.cxx.
147{
148 DEBTRACE("ServiceNode::setComponent " << compo);
149 if(compo)
150 {
151 DEBTRACE(compo->getInstanceName());
152 if(compo->getKindForNode() != this->getKind())
153 {
154 //Not allowed
155 std::string what("ServiceNode::setComponent : component instance kind not allowed ");
156 throw Exception(what);
157 }
158 }
159
161 std::string oldref=_ref;
162
163 _component=compo;
164 _ref=compo->getCompoName();
166 if(_component)
167 {
168 if(_father)
169 try
170 {
172 }
173 catch(Exception& e)
174 {
175 // Impossible to associate compo to this node. Keep the old component instance and throws exception
176 _component=oldcompo;
177 _ref=oldref;
178 throw e;
179 }
181 }
182
183 if(oldcompo)
184 oldcompo->decrRef();
185}
virtual std::string getKindForNode() const
const std::string & getInstanceName() const
DeploymentTree checkDeploymentTree(bool deep) const
Perform check of deployment consistency of the current graph.
virtual ComposedNode * getRootNode() const
Definition: Node.cxx:431
Definition: Node.hxx:90
References _component, YACS::ENGINE::Node::_father, _ref, YACS::ENGINE::ComposedNode::checkDeploymentTree(), DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::ENGINE::ComponentInstance::getKindForNode(), YACS::ENGINE::Node::getRootNode(), and YACS::ENGINE::RefCounter::incrRef().
Referenced by YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), YACS::servicetypeParser< T >::component(), YACS::servicetypeParser< T >::componentinstance(), YACS::ENGINE::CORBAComponent::createNode(), YACS::ENGINE::CORBANode::createNode(), YACS::ENGINE::SalomeNode::createNode(), YACS::ENGINE::CppComponent::createNode(), YACS::ENGINE::CppNode::createNode(), YACS::ENGINE::SalomeComponent::createNode(), YACS::ENGINE::SalomeHPComponent::createNode(), YACS::ENGINE::SalomePythonComponent::createNode(), YACS::ENGINE::SalomePythonNode::createNode(), YACS::inlinetypeParser< T >::function(), YACS::HMI::CommandAddNodeFromCatalog::localExecute(), YACS::ENGINE::ComposedNode::performDuplicationOfPlacement(), and YACS::ENGINE::ComposedNode::performShallowDuplicationOfPlacement().
◆ setMethod()
virtual void YACS::ENGINE::ServiceNode::setMethod ( const std::string &  method)
◆ setRef()
void ServiceNode::setRef ( const std::string &  ref)
A new component instance with type name ref is created (from runtime factory createComponentInstance) and associated to the node.
Reimplemented in YACS::ENGINE::XmlNode.
Definition at line 193 of file ServiceNode.cxx.
194{
195 _ref = ref;
196 if(_component)
197 {
198 //The node is already associated with a component instance
200 //Don't forget to unassociate
201 }
204}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual ComponentInstance * createComponentInstance(const std::string &name, const std::string &kind="")
Definition: Runtime.cxx:215
Definition: ServiceNode.cxx:50
Definition: Runtime.cxx:61
Definition: CONNECTOR.py:120
References _component, _ref, YACS::ENGINE::Runtime::createComponentInstance(), YACS::ENGINE::RefCounter::decrRef(), getKind(), YACS::ENGINE::getRuntime(), gui.CONNECTOR::ref(), and YASSERT.
Referenced by YACS::ENGINE::SessionCataLoader::importComponent(), YACS::ENGINE::CppNode::load(), and YACS::servicetypeParser< T >::ref().
◆ typeName()
virtual std::string YACS::ENGINE::ServiceNode::typeName ( )
Reimplemented in YACS::ENGINE::ServiceInlineNode, YACS::ENGINE::CORBANode, and YACS::ENGINE::SalomeNode.
Definition at line 56 of file ServiceNode.hxx.
56{ return "YACS__ENGINE__ServiceNode"; }
◆ _component
◆ _method
◆ _ref
◆ KIND
const char ServiceNode::KIND =""
Definition at line 58 of file ServiceNode.hxx.
Referenced by getKind().
