YACS::ENGINE::SalomePythonNode Class Reference
#include <SalomePythonNode.hxx>
Inheritance diagram for YACS::ENGINE::SalomePythonNode:
Collaboration diagram for YACS::ENGINE::SalomePythonNode:
 SalomePythonNode (const SalomePythonNode &other, ComposedNode *father)
 SalomePythonNode (const std::string &name)
virtual void execute ()
virtual void load ()
 Load the component associated to the node. More...
std::string getKind () const
 Return the service node kind. More...
ServiceNode * createNode (const std::string &name)
SalomePythonNode * cloneNode (const std::string &name)
 Create a new node of same type with a given name. More...
- Public Member Functions inherited from YACS::ENGINE::ServiceInlineNode
void setScript (const std::string &script)
std::string getScript () const
- Public Member Functions inherited from YACS::ENGINE::ServiceNode
virtual bool isDeployable () const
 By definition of ServiceNode class. More...
virtual void setComponent (ComponentInstance *compo)
 Associate an existing component instance to this service node AND check the consistency regarding the deployment from root node point of view. More...
virtual ComponentInstance * getComponent ()
 Return the associated component instance. More...
virtual const ComponentInstance * getComponent () const
virtual Container * getContainer ()
 Return the associated container. More...
virtual void setRef (const std::string &ref)
 Associate a new component instance to this service node. More...
virtual std::string getRef ()
virtual void setMethod (const std::string &method)
virtual std::string getMethod ()
virtual ServiceNode * createNode (const std::string &name)=0
virtual ~ServiceNode ()
virtual std::string getKind () const
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char PLACEMENT_VAR_NAME_IN_INTERP [] ="__container__from__YACS__"
- Static Public Attributes inherited from YACS::ENGINE::ServiceNode
static const char KIND [] =""
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::ServiceInlineNode
 ServiceInlineNode (const std::string &name)
 ServiceInlineNode (const ServiceInlineNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ServiceNode
 ServiceNode (const std::string &name)
 ServiceNode (const ServiceNode &other, ComposedNode *father)
template<class PORT >
PyObject * _context
PyObject * _pyfunc
- Protected Attributes inherited from YACS::ENGINE::ServiceInlineNode
std::string _script
- Protected Attributes inherited from YACS::ENGINE::ServiceNode
ComponentInstance * _component
std::string _method
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
static int _total = 0
This class is in charge to deal with python willing to interact with YACS placed container. Typical use is for nodes building GEOM and MESH. The great number of calls needed by this type of application, implies a human impossibility to make the corresponding graph.
Definition at line 35 of file SalomePythonNode.hxx.
◆ SalomePythonNode() [1/2]
SalomePythonNode::SalomePythonNode ( const SalomePythonNode &  other,
ComposedNode *  father
Definition at line 36 of file SalomePythonNode.cxx.
36 :ServiceInlineNode(other,father),_pyfunc(0),_context(0)
37{
38 //Not a bug : just because port point of view this is like PythonNode.
40 PyGILState_STATE gstate = PyGILState_Ensure();
41 _context=PyDict_New();
42 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
43 {
44 stringstream msg;
45 msg << "Not possible to set builtins" << __FILE__ << ":" << __LINE__;
46 PyGILState_Release(gstate);
47 throw Exception(msg.str());
48 }
49 PyGILState_Release(gstate);
50}
Definition: Node.hxx:97
static const char IMPL_NAME[]
Definition: PythonNode.hxx:123
ServiceInlineNode(const std::string &name)
References _context, YACS::ENGINE::Node::_implementation, YACS::ENGINE::getSALOMERuntime(), and YACS::ENGINE::PythonNode::IMPL_NAME.
Referenced by cloneNode(), createNode(), and simpleClone().
◆ SalomePythonNode() [2/2]
SalomePythonNode::SalomePythonNode ( const std::string &  name)
Definition at line 52 of file SalomePythonNode.cxx.
52 : ServiceInlineNode(name),_pyfunc(0)
53{
54
55 //Not a bug : just because port point of view this is like PythonNode.
57 PyGILState_STATE gstate = PyGILState_Ensure();
58 _context=PyDict_New();
59 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
60 {
61 stringstream msg;
62 msg << "Not possible to set builtins" << __FILE__ << ":" << __LINE__;
63 PyGILState_Release(gstate);
64 throw Exception(msg.str());
65 }
66 PyGILState_Release(gstate);
67}
◆ cloneNode()
SalomePythonNode * SalomePythonNode::cloneNode ( const std::string &  name)
Definition at line 214 of file SalomePythonNode.cxx.
215{
217 n->setScript(_script);
218 n->setMethod(_method);
219 list<InputPort *>::iterator iter;
220 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
221 {
222 InputPyPort *p=(InputPyPort *)*iter;
223 n->edAddInputPort(p->getName(),p->edGetType());
224 }
225 list<OutputPort *>::iterator iter2;
226 for(iter2 = _setOfOutputPort.begin(); iter2 != _setOfOutputPort.end(); iter2++)
227 {
228 OutputPyPort *p=(OutputPyPort *)*iter2;
229 n->edAddOutputPort(p->getName(),p->edGetType());
230 }
231 return n;
232}
std::string getName() const
Class for Python Ports.
Definition: PythonPorts.hxx:74
SalomePythonNode(const SalomePythonNode &other, ComposedNode *father)
Proc * p
Definition: driver.cxx:216
References YACS::ENGINE::ServiceNode::_method, YACS::ENGINE::ServiceInlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::ComposedNode::getName(), gui.Appli::n, p, and SalomePythonNode().
◆ createNode()
ServiceNode * SalomePythonNode::createNode ( const std::string &  name)
Implements YACS::ENGINE::ServiceNode.
Definition at line 206 of file SalomePythonNode.cxx.
207{
208 ServiceNode* node=new SalomePythonNode(name);
210 return node;
211}
Definition: ServiceNode.hxx:60
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
References YACS::ENGINE::ServiceNode::_component, SalomePythonNode(), and YACS::ENGINE::ServiceNode::setComponent().
◆ execute()
void SalomePythonNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 105 of file SalomePythonNode.cxx.
106{
107 cerr << "++++++++++++++ SalomePythonNode::execute: " << getName() << " ++++++++++++++++++++" << endl;
108 int pos=0;
109 PyObject* ob;
110 if(!_pyfunc)throw Exception("SalomePythonNode badly loaded");
111 PyGILState_STATE gstate = PyGILState_Ensure();
112
113 cerr << "---------------SalomePythonNode::inputs---------------" << endl;
114 PyObject* args = PyTuple_New(getNumberOfInputPorts()) ;
115 list<InputPort *>::iterator iter2;
116 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
117 {
118 InputPyPort *p=(InputPyPort *)*iter2;
119 cerr << "port name: " << p->getName() << endl;
120 cerr << "port kind: " << p->edGetType()->kind() << endl;
121 ob=p->getPyObj();
122 PyObject_Print(ob,stderr,Py_PRINT_RAW);
123 cerr << endl;
124 cerr << "ob refcnt: " << ob->ob_refcnt << endl;
125 Py_INCREF(ob);
126 PyTuple_SetItem(args,pos,ob);
127 cerr << "ob refcnt: " << ob->ob_refcnt << endl;
128 pos++;
129 }
130 cerr << "---------------End SalomePythonNode::inputs---------------" << endl;
131
132 cerr << "----------------SalomePythonNode::calculation---------------" << endl;
133 PyObject_Print(_pyfunc,stderr,Py_PRINT_RAW);
134 cerr << endl;
135 PyObject_Print(args,stderr,Py_PRINT_RAW);
136 cerr << endl;
137 PyObject* result = PyObject_CallObject( _pyfunc , args ) ;
138 Py_DECREF(args);
139 if(result == NULL)
140 {
141 PyErr_Print();
142 PyGILState_Release(gstate);
143 throw Exception("Error during execution");
144 }
145 cerr << "----------------End SalomePythonNode::calculation---------------" << endl;
146
147 cerr << "-----------------SalomePythonNode::outputs-----------------" << endl;
148 int nres=1;
149 if(result == Py_None)
150 nres=0;
151 else if(PyTuple_Check(result))
152 nres=PyTuple_Size(result);
153
154 if(getNumberOfOutputPorts() != nres)
155 {
156 Py_DECREF(result);
157 PyGILState_Release(gstate);
158 throw Exception("Number of output arguments : Mismatch between definition and execution");
159 }
160
161 pos=0;
162 PyObject_Print(result,stderr,Py_PRINT_RAW);
163 cerr << endl;
164 list<OutputPort *>::iterator iter;
165 try
166 {
167 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
168 {
169 OutputPyPort *p=(OutputPyPort *)*iter;
170 cerr << "port name: " << p->getName() << endl;
171 cerr << "port kind: " << p->edGetType()->kind() << endl;
172 cerr << "port pos : " << pos << endl;
173 if(PyTuple_Check(result))ob=PyTuple_GetItem(result,pos) ;
174 else ob=result;
175 cerr << "ob refcnt: " << ob->ob_refcnt << endl;
176 PyObject_Print(ob,stderr,Py_PRINT_RAW);
177 cerr << endl;
178 p->put(ob);
179 pos++;
180 }
181 }
183 {
184 Py_DECREF(result);
185 PyGILState_Release(gstate);
186 throw;
187 }
188 cerr << "-----------------End SalomePythonNode::outputs-----------------" << endl;
189
190 Py_DECREF(result);
191 PyGILState_Release(gstate);
192 cerr << "++++++++++++++ End SalomePythonNode::execute: " << getName() << " ++++++++++++++++++++" << endl;
193}
Definition: Node.hxx:125
References _pyfunc, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, driver_internal::args, YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ElementaryNode::getNumberOfInputPorts(), YACS::ENGINE::ElementaryNode::getNumberOfOutputPorts(), and p.
◆ getKind()
std::string SalomePythonNode::getKind ( ) const
A runtime can provide several implementations of a service node. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode with the same kind.
Reimplemented from YACS::ENGINE::ServiceNode.
Definition at line 195 of file SalomePythonNode.cxx.
196{
197 static const char LOC_KIND[]="";
198 return LOC_KIND;
199}
◆ load()
void SalomePythonNode::load ( )
Definition at line 69 of file SalomePythonNode.cxx.
70{
72 cerr << "---------------SalomePythonNode::load function---------------" << endl;
73 list<OutputPort *>::iterator iter;
74 string value2Export=((SalomePythonComponent*)_component)->getStringValueToExportInInterp(this);
75 PyObject* ob=PyBytes_FromString(value2Export.c_str());
76 PyDict_SetItemString(_context,PLACEMENT_VAR_NAME_IN_INTERP,ob);
77 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
78 {
79 OutputPyPort *p=(OutputPyPort *)*iter;
80 cerr << "port name: " << p->getName() << endl;
81 cerr << "port kind: " << p->edGetType()->kind() << endl;
82 }
83 cerr << _script << endl;
84 PyGILState_STATE gstate = PyGILState_Ensure();
85 PyObject *res=PyRun_String(_script.c_str(),Py_file_input,_context,_context);
86 if(res == NULL)
87 {
88 PyErr_Print();
89 PyGILState_Release(gstate);
90 throw Exception("Error during execution");
91 return;
92 }
93 Py_DECREF(res);
94 _pyfunc=PyDict_GetItemString(_context,_method.c_str());
95 if(_pyfunc == NULL)
96 {
97 PyErr_Print();
98 PyGILState_Release(gstate);
99 throw Exception("Error during execution");
100 }
101 cerr << "---------------End SalomePythonNode::load function---------------" << endl;
102 PyGILState_Release(gstate);
103}
static const char PLACEMENT_VAR_NAME_IN_INTERP[]
virtual void load()
Definition: ServiceNode.cxx:90
References YACS::ENGINE::ServiceNode::_component, _context, YACS::ENGINE::ServiceNode::_method, _pyfunc, YACS::ENGINE::ServiceInlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::ServiceNode::load(), p, and PLACEMENT_VAR_NAME_IN_INTERP.
◆ simpleClone()
Node * SalomePythonNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 201 of file SalomePythonNode.cxx.
202{
203 return new SalomePythonNode(*this,father);
204}
References SalomePythonNode().
◆ _context
PyObject* YACS::ENGINE::SalomePythonNode::_context
Definition at line 48 of file SalomePythonNode.hxx.
Referenced by load(), and SalomePythonNode().
◆ _pyfunc
PyObject* YACS::ENGINE::SalomePythonNode::_pyfunc
Definition at line 49 of file SalomePythonNode.hxx.
Referenced by execute(), and load().
◆ PLACEMENT_VAR_NAME_IN_INTERP
const char SalomePythonNode::PLACEMENT_VAR_NAME_IN_INTERP ="__container__from__YACS__"
Definition at line 51 of file SalomePythonNode.hxx.
Referenced by load().
