YACS::ENGINE::InputPyPort Class Reference
Class for Python Ports. More...
#include <PythonPorts.hxx>
Inheritance diagram for YACS::ENGINE::InputPyPort:
Collaboration diagram for YACS::ENGINE::InputPyPort:
 InputPyPort (const std::string &name, Node *node, TypeCode *type)
 InputPyPort (const InputPyPort &other, Node *newHelder)
 ~InputPyPort ()
bool edIsManuallyInitialized () const
void edRemoveManInit ()
void releaseData () override
void put (PyObject *data)
virtual PyObj * getPyObj () const
void * get () const
virtual bool isEmpty ()
virtual void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
virtual void exRestoreInit ()
 Restore the saved data value to current data value. More...
virtual std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
PyObject * _data
PyObject * _initData
bool _isEmpty
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
See also
PythonNode
Definition at line 73 of file PythonPorts.hxx.
◆ InputPyPort() [1/2]
InputPyPort::InputPyPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 84 of file PythonPorts.cxx.
85 : InputPort(name, node, type)
86 , DataPort(name, node, type)
87 , Port(node)
88 , _data(Py_None)
89 ,_initData(nullptr)
90 ,_isEmpty(true)
91{
92 Py_INCREF(_data);
93}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
References _data.
Referenced by clone().
◆ InputPyPort() [2/2]
InputPyPort::InputPyPort ( const InputPyPort &  other,
Node *  newHelder
Definition at line 106 of file PythonPorts.cxx.
106 :InputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder)
107{
108 _initData=other._initData;
109 Py_XINCREF(_initData);
110 _data=other._data;
111 Py_INCREF(_data);
112 _isEmpty=other._isEmpty;
113}
References _data, _initData, and _isEmpty.
◆ ~InputPyPort()
InputPyPort::~InputPyPort ( )
Definition at line 94 of file PythonPorts.cxx.
95{
96 PyGILState_STATE gstate = PyGILState_Ensure();
97 DEBTRACE( "_data refcnt: " << (_data ? _data->ob_refcnt : -1) );
98 DEBTRACE( "_initData refcnt: " << (_initData ? _initData->ob_refcnt : -1));
99 // Release or not release : all GenericObj are deleted when the input port is deleted
101 Py_XDECREF(_data);
102 Py_XDECREF(_initData);
103 PyGILState_Release(gstate);
104}
void releasePyObj(PyObject *data)
Definition: PythonPorts.cxx:74
References _data, _initData, DEBTRACE, and releasePyObj().
◆ clone()
InputPort * InputPyPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 161 of file PythonPorts.cxx.
162{
163 return new InputPyPort(*this,newHelder);
164}
InputPyPort(const std::string &name, Node *node, TypeCode *type)
Definition: PythonPorts.cxx:84
References InputPyPort().
◆ dump()
std::string InputPyPort::dump ( )
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 238 of file PythonPorts.cxx.
239{
240 if( _isEmpty)
241 return "<value>None</value>";
242
245}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string convertPyObjectXml(const TypeCode *t, PyObject *data)
References _data, _isEmpty, YACS::ENGINE::convertPyObjectXml(), YACS::ENGINE::DataPort::edGetType(), and testCppPluginInvokation::l.
Referenced by getHumanRepr().
◆ edIsManuallyInitialized()
bool InputPyPort::edIsManuallyInitialized ( ) const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition at line 115 of file PythonPorts.cxx.
116{
117 return _initData!=nullptr;
118}
References _initData.
◆ edRemoveManInit()
void InputPyPort::edRemoveManInit ( )
Removes eventually previous manual initialisation.
Definition at line 120 of file PythonPorts.cxx.
121{
122 Py_XDECREF(_initData);
123 _initData=nullptr;
124 Py_XDECREF(_data);
125 _data=Py_None;
126 Py_INCREF(_data);
127 _isEmpty=true;
129}
virtual void edRemoveManInit()
Definition: InputPort.cxx:140
References _data, _initData, _isEmpty, and YACS::ENGINE::InputPort::edRemoveManInit().
◆ exRestoreInit()
void InputPyPort::exRestoreInit ( )
If no data has been saved (_initData == 0) don't restore
Definition at line 227 of file PythonPorts.cxx.
228{
229 if(!_initData)return;
230 Py_XDECREF(_data);
232 Py_XINCREF(_data);
233 _isEmpty = false;
234 DEBTRACE( "_initData.ob refcnt: " << _initData->ob_refcnt );
235 DEBTRACE( "_data.ob refcnt: " << _data->ob_refcnt );
236}
References _data, _initData, _isEmpty, and DEBTRACE.
◆ exSaveInit()
void InputPyPort::exSaveInit ( )
Definition at line 211 of file PythonPorts.cxx.
212{
213 // Interpreter lock seems necessary when deleting lists in Python 2.7
214 PyGILState_STATE gstate = PyGILState_Ensure();
215 Py_XDECREF(_initData);
217 Py_INCREF(_initData);
218 PyGILState_Release(gstate);
219 DEBTRACE( "_initData.ob refcnt: " << (_initData ? _initData->ob_refcnt : -1));
220 DEBTRACE( "_data.ob refcnt: " << _data->ob_refcnt );
221}
References _data, _initData, and DEBTRACE.
◆ get()
void * InputPyPort::get ( ) const
Definition at line 171 of file PythonPorts.cxx.
172{
173 return (void*) _data;
174}
References _data.
◆ getAsString()
std::string InputPyPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 176 of file PythonPorts.cxx.
177{
178 std::string ret;
179 //protect _data against modification or delete in another thread
180 PyObject* data=_data;
181 Py_INCREF(data);
182 ret = convertPyObjectToString(data);
183 Py_XDECREF(data);
184 return ret;
185}
std::string convertPyObjectToString(PyObject *ob)
References _data, and YACS::ENGINE::convertPyObjectToString().
◆ getHumanRepr()
std::string InputPyPort::getHumanRepr ( )
Definition at line 187 of file PythonPorts.cxx.
188{
189 if(!_data)
190 return dump();
191 PyObject *ret(PyObject_Str(_data));
192 if(!ret)
193 return dump();
194 std::string retCpp;
195 char *val(PyBytes_AsString(ret));
196 if(val)
197 retCpp=val;
198 Py_XDECREF(ret);
199 return retCpp;
200}
virtual std::string dump()
References _data, and dump().
◆ getPyObj()
PyObject * InputPyPort::getPyObj ( ) const
Definition at line 166 of file PythonPorts.cxx.
167{
168 return _data;
169}
References _data.
Referenced by valToStr().
◆ isEmpty()
bool InputPyPort::isEmpty ( )
Definition at line 202 of file PythonPorts.cxx.
203{
204 return _isEmpty;
205}
References _isEmpty.
◆ put() [1/2]
void InputPyPort::put ( const void *  data)
Definition at line 131 of file PythonPorts.cxx.
132{
133 put((PyObject *)data);
134}
References put().
Referenced by put(), YACS::ENGINE::PythonNode::squeezeMemory(), and YACS::ENGINE::PythonNode::squeezeMemoryRemote().
◆ put() [2/2]
void InputPyPort::put ( PyObject *  data)
Definition at line 149 of file PythonPorts.cxx.
150{
153 _data = data;
154 _stringRef="";
155 Py_INCREF(_data);
157 _isEmpty=false;
158 DEBTRACE( "_data refcnt: " << _data->ob_refcnt );
159}
void registerPyObj(PyObject *data)
Definition: PythonPorts.cxx:79
Definition: InputPort.hxx:90
References _data, _isEmpty, YACS::ENGINE::InputPort::_stringRef, DEBTRACE, testCppPluginInvokation::l, registerPyObj(), and releaseDataUnsafe().
◆ releaseData()
void InputPyPort::releaseData ( )
overridevirtual
◆ releaseDataUnsafe()
void InputPyPort::releaseDataUnsafe ( )
Definition at line 136 of file PythonPorts.cxx.
137{
139 Py_XDECREF(_data);
140 _data = nullptr;
141}
References _data, and releasePyObj().
Referenced by put(), and releaseData().
◆ typeName()
virtual std::string YACS::ENGINE::InputPyPort::typeName ( )
Definition at line 94 of file PythonPorts.hxx.
94{return "YACS__ENGINE__InputPyPort";}
◆ valFromStr()
void InputPyPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 261 of file PythonPorts.cxx.
262{
263}
◆ valToStr()
std::string InputPyPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 247 of file PythonPorts.cxx.
248{
249 int isString = PyBytes_Check(getPyObj());
250 //DEBTRACE("isString=" << isString);
251 PyObject *strPyObj = PyObject_Str(getPyObj());
252 //DEBTRACE(PyString_Size(strPyObj));
253 string val = PyBytes_AsString(strPyObj);
254 if (isString)
255 val = "\"" + val + "\"";
256 //DEBTRACE(val);
257 Py_DECREF(strPyObj);
258 return val;
259}
virtual PyObj * getPyObj() const
References getPyObj().
◆ _data
PyObject* YACS::ENGINE::InputPyPort::_data
◆ _initData
PyObject* YACS::ENGINE::InputPyPort::_initData
◆ _isEmpty
bool YACS::ENGINE::InputPyPort::_isEmpty
Definition at line 102 of file PythonPorts.hxx.
Referenced by dump(), edRemoveManInit(), exRestoreInit(), InputPyPort(), isEmpty(), and put().
