YACS::ENGINE::PythonNode Class Reference
#include <PythonNode.hxx>
Inheritance diagram for YACS::ENGINE::PythonNode:
Collaboration diagram for YACS::ENGINE::PythonNode:
 PythonNode (const PythonNode &other, ComposedNode *father)
 PythonNode (const std::string &name)
virtual ~PythonNode ()
virtual void execute ()
virtual void load ()
virtual void loadRemote ()
virtual void loadLocal ()
virtual void executeRemote ()
virtual void executeLocal ()
void imposeResource (const std::string &resource_name, const std::string &container_name) override
bool canAcceptImposedResource () override
bool hasImposedResource () const override
bool isUsingPythonCache () const
std::string getContainerLog ()
PythonNode * cloneNode (const std::string &name)
 Create a new node of same type with a given name. More...
void applyDPLScope (ComposedNode *gfn)
void setSqueezeStatusWithExceptions (bool sqStatus, const std::vector< std::string > &squeezeExceptions)
void setSqueezeStatus (bool sqStatus)
bool getSqueezeStatus () const
void squeezeMemorySafe ()
- Public Member Functions inherited from YACS::ENGINE::InlineNode
virtual void setScript (const std::string &script)
 Set the script (as a string) to execute. More...
virtual std::string getScript ()
virtual InlineNode * cloneNode (const std::string &name)
 Return a new InlineNode node by making a copy of this node. More...
virtual ~InlineNode ()
virtual void setExecutionMode (const std::string &mode)
virtual std::string getExecutionMode ()
virtual void setContainer (Container *container)
virtual Container * getContainer ()
bool isDeployable () const
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
static void ExecuteLocalInternal (const std::string &codeStr, PyObject *context, std::string &errorDetails)
- Static Public Member Functions inherited from YACS::ENGINE::PythonEntry
static bool IsProxy (PyObject *ob)
static bool GetDestroyStatus (PyObject *ob)
static void DoNotTouchFileIfProxy (PyObject *ob)
static void UnlinkOnDestructorIfProxy (PyObject *ob)
static void IfProxyDoSomething (PyObject *ob, const char *meth)
Static Public Attributes
static const char KIND [] ="Python"
static const char IMPL_NAME [] ="Python"
static const char SCRIPT_FOR_SERIALIZATION []
static const char REMOTE_NAME [] ="remote"
static const char DPL_INFO_NAME [] ="my_dpl_localization"
- Static Public Attributes inherited from YACS::ENGINE::InlineNode
static const char LOCAL_STR [] ="local"
static const char REMOTE_STR [] ="remote"
- Static Public Attributes inherited from YACS::ENGINE::PythonEntry
static const char SCRIPT_FOR_SIMPLE_SERIALIZATION []
Node * simpleClone (ComposedNode *father, bool editionOnly) const
void createRemoteAdaptedPyInterpretor (Engines::Container_ptr objContainer)
 returns an object, you have to deal with (UnRegister) More...
Engines::PyNodeBase_var retrieveDftRemotePyInterpretorIfAny (Engines::Container_ptr objContainer) const
 returns (if any) an object, you have to deal with (UnRegister) More...
void assignRemotePyInterpretor (Engines::PyNodeBase_var remoteInterp)
Engines::PyNodeBase_var getRemoteInterpreterHandle ()
const char * getSerializationScript () const
std::string pythonEntryName () const
void squeezeMemory ()
void squeezeMemoryRemote ()
void freeKernelPynode ()
- Protected Member Functions inherited from YACS::ENGINE::InlineNode
 InlineNode (const InlineNode &other, ComposedNode *father)
 InlineNode (const std::string &name)
template<class PORT >
- Protected Member Functions inherited from YACS::ENGINE::PythonEntry
 PythonEntry ()
 ~PythonEntry ()
virtual void assignRemotePyInterpretor (Engines::PyNodeBase_var remoteInterp)=0
virtual Engines::PyNodeBase_var retrieveDftRemotePyInterpretorIfAny (Engines::Container_ptr objContainer) const =0
virtual void createRemoteAdaptedPyInterpretor (Engines::Container_ptr objContainer)=0
virtual Engines::PyNodeBase_var getRemoteInterpreterHandle ()=0
virtual const char * getSerializationScript () const =0
void commonRemoteLoad (InlineNode *reqNode)
void loadRemoteContainer (InlineNode *reqNode)
Engines::Container_var loadPythonAdapter (InlineNode *reqNode, bool &isInitializeRequested)
void loadRemoteContext (InlineNode *reqNode, Engines::Container_ptr objContainer, bool isInitializeRequested)
bool _autoSqueeze = false
std::set< std::string > _nonSqueezableOutputNodes
 list on output port name excluded from the squeeze mecanism More...
Engines::PyScriptNode_var _pynode
- Protected Attributes inherited from YACS::ENGINE::InlineNode
std::string _script
std::string _mode
Container * _container
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
- Protected Attributes inherited from YACS::ENGINE::PythonEntry
PyObject * _context
PyObject * _pyfuncSer
PyObject * _pyfuncUnser
PyObject * _pyfuncSimpleSer
std::string _imposedResource
std::string _imposedContainer
void executeLocalInternal (const std::string &codeStr)
YACS::Colour _colour
- Static Protected Member Functions inherited from YACS::ENGINE::PythonEntry
static std::string GetContainerLog (const std::string &mode, Container *container, const Task *askingTask)
static int _total = 0
- Static Protected Attributes inherited from YACS::ENGINE::PythonEntry
static PyObject * _pyClsBigObject = nullptr
Definition at line 75 of file PythonNode.hxx.
◆ PythonNode() [1/2]
PythonNode::PythonNode ( const PythonNode &  other,
ComposedNode *  father
Definition at line 418 of file PythonNode.cxx.
418 :
420{
421 _pynode = Engines::PyScriptNode::_nil();
423 {
424 AutoGIL agil;
425 _context=PyDict_New();
426 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
427 {
428 stringstream msg;
429 msg << "Impossible to set builtins" << __FILE__ << ":" << __LINE__;
430 _errorDetails=msg.str();
431 throw Exception(msg.str());
432 }
433 }
434}
InlineNode(const InlineNode &other, ComposedNode *father)
Definition: InlineNode.hxx:46
Definition: Node.hxx:97
Definition: Node.hxx:93
Definition: PythonNode.hxx:131
static const char IMPL_NAME[]
Definition: PythonNode.hxx:123
Definition: PythonNode.hxx:130
References YACS::ENGINE::PythonEntry::_context, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_implementation, _pynode, YACS::ENGINE::getSALOMERuntime(), and IMPL_NAME.
Referenced by cloneNode(), and simpleClone().
◆ PythonNode() [2/2]
PythonNode::PythonNode ( const std::string &  name)
Definition at line 436 of file PythonNode.cxx.
436 :InlineNode(name)
437{
438 _pynode = Engines::PyScriptNode::_nil();
440 {
441 AutoGIL agil;
442 _context=PyDict_New();
443 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
444 {
445 stringstream msg;
446 msg << "Impossible to set builtins" << __FILE__ << ":" << __LINE__;
447 _errorDetails=msg.str();
448 throw Exception(msg.str());
449 }
450 }
451}
◆ ~PythonNode()
PythonNode::~PythonNode ( )
Definition at line 453 of file PythonNode.cxx.
454{
456}
References freeKernelPynode().
◆ applyDPLScope()
void PythonNode::applyDPLScope ( ComposedNode *  gfn)
Method called by the Executor only if the executor is sensitive of scope of DynParaLoop. This method is virtual and empty because by default nothing is done.
Reimplemented from YACS::ENGINE::Node.
Definition at line 1050 of file PythonNode.cxx.
1051{
1052 std::vector< std::pair<std::string,int> > ret(getDPLScopeInfo(gfn));
1053 if(ret.empty())
1054 return ;
1055 //
1056 PyObject *ob(0);
1057 {
1058 AutoGIL agil;
1059 std::size_t sz(ret.size());
1060 ob=PyList_New(sz);
1061 for(std::size_t i=0;i<sz;i++)
1062 {
1063 const std::pair<std::string,int>& p(ret[i]);
1064 PyObject *elt(PyTuple_New(2));
1065 PyTuple_SetItem(elt,0,PyUnicode_FromString(p.first.c_str()));
1066 PyTuple_SetItem(elt,1,PyLong_FromLong(p.second));
1067 PyList_SetItem(ob,i,elt);
1068 }
1069 }
1070 if(_mode==REMOTE_NAME)
1071 {
1072 Engines::pickledArgs_var serializationInputCorba(new Engines::pickledArgs);
1073 {
1074 AutoGIL agil;
1075 PyObject *serializationInput(PyObject_CallFunctionObjArgs(_pyfuncSimpleSer,ob,NULL));
1076 Py_XDECREF(ob);
1077 char *serializationInputC(0);
1078 Py_ssize_t len;
1079 if (PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len))
1080 throw Exception("DistributedPythonNode problem in python pickle");
1081 serializationInputCorba->length(len);
1082 for(int i=0; i < len ; i++)
1083 serializationInputCorba[i]=serializationInputC[i];
1084 Py_XDECREF(serializationInput);
1085 }
1086 _pynode->defineNewCustomVar(DPL_INFO_NAME,serializationInputCorba);
1087 }
1088 else
1089 {
1090 AutoGIL agil;
1091 PyDict_SetItemString(_context,DPL_INFO_NAME,ob);
1092 Py_XDECREF(ob);
1093 }
1094}
int Py_ssize_t
Definition: PythonNode.cxx:45
std::vector< std::pair< std::string, int > > getDPLScopeInfo(ComposedNode *gfn)
Definition: Node.cxx:660
static const char REMOTE_NAME[]
Definition: PythonNode.hxx:125
static const char DPL_INFO_NAME[]
Definition: PythonNode.hxx:126
Proc * p
Definition: driver.cxx:216
References YACS::ENGINE::PythonEntry::_context, YACS::ENGINE::InlineNode::_mode, YACS::ENGINE::PythonEntry::_pyfuncSimpleSer, _pynode, DPL_INFO_NAME, YACS::ENGINE::Node::getDPLScopeInfo(), yacsorb.CORBAEngineTest::i, p, and REMOTE_NAME.
◆ assignRemotePyInterpretor()
void PythonNode::assignRemotePyInterpretor ( Engines::PyNodeBase_var  remoteInterp)
Implements YACS::ENGINE::PythonEntry.
Definition at line 1005 of file PythonNode.cxx.
1006{
1007 if(CORBA::is_nil(_pynode))
1008 _pynode=Engines::PyScriptNode::_narrow(remoteInterp);
1009 else
1010 {
1011 Engines::PyScriptNode_var tmpp(Engines::PyScriptNode::_narrow(remoteInterp));
1012 if(!_pynode->_is_equivalent(tmpp))
1013 {
1015 _pynode=Engines::PyScriptNode::_narrow(remoteInterp);
1016 }
1017 }
1018 _pynode->assignNewCompiledCode(getScript().c_str());
1019}
virtual std::string getScript()
Definition: InlineNode.hxx:51
References _pynode, freeKernelPynode(), and YACS::ENGINE::InlineNode::getScript().
◆ canAcceptImposedResource()
bool PythonNode::canAcceptImposedResource ( )
overridevirtual
Reimplemented from YACS::ENGINE::Task.
Definition at line 941 of file PythonNode.cxx.
942{
943 return _container != nullptr && _container->canAcceptImposedResource();
944}
virtual bool canAcceptImposedResource()
Definition: Container.cxx:59
References YACS::ENGINE::InlineNode::_container, and YACS::ENGINE::Container::canAcceptImposedResource().
◆ checkBasicConsistency()
void PythonNode::checkBasicConsistency ( ) const
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 458 of file PythonNode.cxx.
459{
460 DEBTRACE("checkBasicConsistency");
462 {
463 AutoGIL agil;
464 PyObject* res;
465 res=Py_CompileString(_script.c_str(),getName().c_str(),Py_file_input);
466 if(res == NULL)
467 {
468 std::string error="";
469 PyObject* new_stderr = newPyStdOut(error);
470 PySys_SetObject((char*)"stderr", new_stderr);
471 PyErr_Print();
472 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
473 Py_DECREF(new_stderr);
474 throw Exception(error);
475 }
476 else
477 Py_XDECREF(res);
478 }
479}
Definition: Node.hxx:125
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
References YACS::ENGINE::InlineNode::_script, YACS::ENGINE::ElementaryNode::checkBasicConsistency(), DEBTRACE, YACS::ENGINE::Node::getName(), and YACS::ENGINE::newPyStdOut().
◆ cloneNode()
PythonNode * PythonNode::cloneNode ( const std::string &  name)
Reimplemented from YACS::ENGINE::InlineNode.
Definition at line 1027 of file PythonNode.cxx.
1028{
1029 PythonNode* n=new PythonNode(name);
1030 n->setScript(_script);
1031 list<InputPort *>::iterator iter;
1032 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
1033 {
1034 InputPyPort *p=(InputPyPort *)*iter;
1035 DEBTRACE( "port name: " << p->getName() );
1036 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1037 n->edAddInputPort(p->getName(),p->edGetType());
1038 }
1039 list<OutputPort *>::iterator iter2;
1040 for(iter2 = _setOfOutputPort.begin(); iter2 != _setOfOutputPort.end(); iter2++)
1041 {
1042 OutputPyPort *p=(OutputPyPort *)*iter2;
1043 DEBTRACE( "port name: " << p->getName() );
1044 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1045 n->edAddOutputPort(p->getName(),p->edGetType());
1046 }
1047 return n;
1048}
std::string getName() const
Class for Python Ports.
Definition: PythonPorts.hxx:74
PythonNode(const PythonNode &other, ComposedNode *father)
Definition: PythonNode.cxx:418
References YACS::ENGINE::InlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, YACS::ENGINE::ComposedNode::getName(), gui.Appli::n, p, and PythonNode().
◆ createRemoteAdaptedPyInterpretor()
void PythonNode::createRemoteAdaptedPyInterpretor ( Engines::Container_ptr  objContainer)
Definition at line 988 of file PythonNode.cxx.
989{
991 _pynode=objContainer->createPyScriptNode(pythonEntryName().c_str(),getScript().c_str());
992 _pynode->Register();
993}
std::string pythonEntryName() const
Definition: PythonNode.cxx:951
References _pynode, freeKernelPynode(), YACS::ENGINE::InlineNode::getScript(), and pythonEntryName().
◆ execute()
void PythonNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 501 of file PythonNode.cxx.
502{
505 else
506 executeLocal();
507}
virtual void executeRemote()
Definition: PythonNode.cxx:509
virtual void executeLocal()
Definition: PythonNode.cxx:778
References YACS::ENGINE::InlineNode::_mode, executeLocal(), executeRemote(), and REMOTE_NAME.
◆ executeLocal()
void PythonNode::executeLocal ( )
Definition at line 778 of file PythonNode.cxx.
779{
780 DEBTRACE( "++++++++++++++ PyNode::executeLocal: " << getName() << " ++++++++++++++++++++" );
781 {
782 AutoGIL agil;
783 std::ostringstream unpxy; unpxy << "from SALOME_PyNode import UnProxyObjectSimpleLocal" << std::endl;
784 DEBTRACE( "---------------PyNode::inputs---------------" );
785 list<InputPort *>::iterator iter2;
786 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
787 {
788 InputPyPort *p=(InputPyPort *)*iter2;
789 DEBTRACE( "port name: " << p->getName() );
790 DEBTRACE( "port kind: " << p->edGetType()->kind() );
791 PyObject* ob=p->getPyObj();
792 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
793 unpxy << p->getName() << " = UnProxyObjectSimpleLocal( " << p->getName() << " )" << std::endl;
794#ifdef _DEVDEBUG_
795 PyObject_Print(ob,stderr,Py_PRINT_RAW);
796 cerr << endl;
797#endif
798 int ier=PyDict_SetItemString(_context,p->getName().c_str(),ob);
799 DEBTRACE( "after PyDict_SetItemString:ob refcnt: " << ob->ob_refcnt );
800 }
801
802 DEBTRACE( "---------------End PyNode::inputs---------------" );
803
804 //calculation
805 DEBTRACE( "----------------PyNode::calculation---------------" );
806
807 if( ! getSqueezeStatus() )
808 executeLocalInternal( unpxy.str() );
809
811
812 DEBTRACE( "-----------------PyNode::outputs-----------------" );
813 list<OutputPort *>::iterator iter;
814 try
815 {
816 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
817 {
818 OutputPyPort *p=(OutputPyPort *)*iter;
819 DEBTRACE( "port name: " << p->getName() );
820 DEBTRACE( "port kind: " << p->edGetType()->kind() );
821 PyObject *ob=PyDict_GetItemString(_context,p->getName().c_str());
822 if(ob==NULL)
823 {
824 std::string msg="Error during execution: there is no variable ";
825 msg=msg+p->getName()+" in node context";
826 _errorDetails=msg;
827 throw Exception(msg);
828 }
829 DEBTRACE( "PyNode::outputs::ob refcnt: " << ob->ob_refcnt );
830#ifdef _DEVDEBUG_
831 PyObject_Print(ob,stderr,Py_PRINT_RAW);
832 cerr << endl;
833#endif
834 p->put(ob);
835 if(!isUsingPythonCache())
836 PyDict_DelItemString(_context,p->getName().c_str());
837 }
838 }
839 catch(ConversionException& ex)
840 {
841 _errorDetails=ex.what();
842 throw;
843 }
844 if(_autoSqueeze)
846 DEBTRACE( "-----------------End PyNode::outputs-----------------" );
847 if(!isUsingPythonCache())
848 {
849 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
850 {
851 AutoPyRef pStr = PyUnicode_FromString( (*iter2)->getName().c_str() );
852 if( PyDict_Contains(_context,pStr) == 1 )
853 { PyDict_DelItem(_context,pStr); }
854 }
855 }
856 }
857 DEBTRACE( "++++++++++++++ End PyNode::execute: " << getName() << " ++++++++++++++++++++" );
858}
bool isUsingPythonCache() const
Definition: PythonNode.cxx:959
void executeLocalInternal(const std::string &codeStr)
Definition: PythonNode.cxx:773
bool getSqueezeStatus() const
Definition: PythonNode.hxx:112
References _autoSqueeze, YACS::ENGINE::PythonEntry::_context, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::InlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, testCppPluginInvokation::ex, executeLocalInternal(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), getSqueezeStatus(), isUsingPythonCache(), p, and squeezeMemory().
Referenced by execute().
◆ executeLocalInternal()
void PythonNode::executeLocalInternal ( const std::string &  codeStr)
Definition at line 773 of file PythonNode.cxx.
774{
776}
static void ExecuteLocalInternal(const std::string &codeStr, PyObject *context, std::string &errorDetails)
Definition: PythonNode.cxx:733
References YACS::ENGINE::PythonEntry::_context, YACS::ENGINE::Node::_errorDetails, and ExecuteLocalInternal().
Referenced by executeLocal().
◆ ExecuteLocalInternal()
void PythonNode::ExecuteLocalInternal ( const std::string &  codeStr,
PyObject *  context,
std::string &  errorDetails
Definition at line 733 of file PythonNode.cxx.
734{
735 DEBTRACE( code );
736 DEBTRACE( "context refcnt: " << context->ob_refcnt );
737 std::ostringstream stream;
738 stream << "/tmp/PythonNode_";
739 stream << getpid();
740 AutoPyRef code=Py_CompileString(codeStr.c_str(), stream.str().c_str(), Py_file_input);
741 if(code == NULL)
742 {
743 errorDetails="";
744 AutoPyRef new_stderr = newPyStdOut(errorDetails);
745 PySys_SetObject((char*)"stderr", new_stderr);
746 PyErr_Print();
747 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
748 throw YACS::Exception("Error during execution");
749 }
750 {
751 AutoPyRef res = PyEval_EvalCode( code, context, context);
752 }
753 DEBTRACE( "context refcnt: " << context->ob_refcnt );
754 fflush(stdout);
755 fflush(stderr);
756 if(PyErr_Occurred ())
757 {
758 errorDetails="";
759 AutoPyRef new_stderr = newPyStdOut(errorDetails);
760 PySys_SetObject((char*)"stderr", new_stderr);
761 ofstream errorfile(stream.str().c_str());
762 if (errorfile.is_open())
763 {
764 errorfile << codeStr;
765 errorfile.close();
766 }
767 PyErr_Print();
768 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
769 throw YACS::Exception("Error during execution");
770 }
771}
References DEBTRACE, and YACS::ENGINE::newPyStdOut().
Referenced by executeLocalInternal(), and YACS::ENGINE::RuntimeSALOME::launchSubProcess().
◆ executeRemote()
void PythonNode::executeRemote ( )
Definition at line 509 of file PythonNode.cxx.
510{
511 DEBTRACE( "++++++++++++++ PyNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
512 if(!_pyfuncSer)
513 throw Exception("PythonNode badly loaded");
514 //
515 if(dynamic_cast<HomogeneousPoolContainer *>(getContainer()))
516 {
517 bool dummy;
518 loadPythonAdapter(this,dummy);
519 _pynode->assignNewCompiledCode(getScript().c_str());
520 }
521 // not managed by unique_ptr here because destructed by the order of client.
522 SenderByteImpl *serializationInputCorba = nullptr;
523 AutoPyRef serializationInput;
524 {
525#if PY_VERSION_HEX < 0x03070000
526 std::unique_lock<std::mutex> lock(data_mutex);
527#endif
528 AutoGIL agil;
529 PyObject *args(0),*ob(0);
530 //===========================================================================
531 // Get inputs in input ports, build a Python dict and pickle it
532 //===========================================================================
533 args = PyDict_New();
534 std::list<InputPort *>::iterator iter2;
535 int pos(0);
536 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); ++iter2)
537 {
538 InputPyPort *p=(InputPyPort *)*iter2;
539 ob=p->getPyObj();
540 PyDict_SetItemString(args,p->getName().c_str(),ob);
541 pos++;
542 }
543#ifdef _DEVDEBUG_
544 PyObject_Print(args,stderr,Py_PRINT_RAW);
545 std::cerr << endl;
546#endif
547 serializationInput.set(PyObject_CallFunctionObjArgs(_pyfuncSer,args,nullptr));
548 Py_DECREF(args);
549 //The pickled string may contain NULL characters so use PyString_AsStringAndSize
550 char *serializationInputC(nullptr);
551 Py_ssize_t len;
552 if (PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len))
553 throw Exception("DistributedPythonNode problem in python pickle");
554 // no copy here. The C byte array of Python is taken as this into CORBA sequence to avoid copy
555 serializationInputCorba = new SenderByteImpl(serializationInputC,len);
556 }
557
558 //get the list of output argument names
559 std::list<OutputPort *>::iterator iter;
560 Engines::listofstring myseq;
561 myseq.length(getNumberOfOutputPorts());
562 int pos=0;
563 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); ++iter)
564 {
565 OutputPyPort *p=(OutputPyPort *)*iter;
566 myseq[pos]=p->getName().c_str();
567 DEBTRACE( "port name: " << p->getName() );
568 DEBTRACE( "port kind: " << p->edGetType()->kind() );
569 DEBTRACE( "port pos : " << pos );
570 pos++;
571 }
572 //===========================================================================
573 // Execute in remote Python node
574 //===========================================================================
575 DEBTRACE( "-----------------starting remote python invocation-----------------" );
576 std::unique_ptr<SALOME::SenderByteSeq> resultCorba;
577 try
578 {
579 //pass outargsname and dict serialized
580 SALOME::SenderByte_var serializationInputRef = serializationInputCorba->_this();
581 DEBUG_YACSTRACE("Before execute first of " << getId());
582 _pynode->executeFirst(serializationInputRef);
583 //serializationInput and serializationInputCorba are no more needed for server. Release it.
584 {
585 AutoGIL agil;
586 serializationInput.set(nullptr);
587 }
588 resultCorba.reset( _pynode->executeSecond(myseq) );
589 DEBUG_YACSTRACE("After execute second of " << getId());
590 }
591 catch( const SALOME::SALOME_Exception& ex )
592 {
593 std::ostringstream msg; msg << "Exception on remote python invocation" << std::endl << ex.details.text.in() << std::endl;
594 msg << "PyScriptNode CORBA ref : ";
595 {
596 CORBA::ORB_ptr orb(getSALOMERuntime()->getOrb());
597 if(!CORBA::is_nil(orb))
598 {
599 CORBA::String_var IOR(orb->object_to_string(_pynode));
600 msg << IOR;
601 }
602 }
603 msg << std::endl;
604 _errorDetails=msg.str();
605 throw Exception(msg.str());
606 }
607 catch(CORBA::COMM_FAILURE& ex)
608 {
609 std::ostringstream msg;
610 msg << "Exception on remote python invocation." << std::endl ;
611 msg << "Caught system exception COMM_FAILURE -- unable to contact the "
612 << "object." << std::endl;
613 _errorDetails=msg.str();
614 throw Exception(msg.str());
615 }
616 catch(CORBA::SystemException& ex)
617 {
618 std::ostringstream msg;
619 msg << "Exception on remote python invocation." << std::endl ;
620 msg << "Caught a CORBA::SystemException." ;
621 CORBA::Any tmp;
622 tmp <<= ex;
623 CORBA::TypeCode_var tc = tmp.type();
624 const char *p = tc->name();
625 if ( *p != '\0' )
626 msg <<p;
627 else
628 msg << tc->id();
629 msg << std::endl;
630 _errorDetails=msg.str();
631 throw Exception(msg.str());
632 }
633 catch(CORBA::Exception& ex)
634 {
635 std::ostringstream msg;
636 msg << "Exception on remote python invocation." << std::endl ;
637 msg << "Caught CORBA::Exception. " ;
638 CORBA::Any tmp;
639 tmp <<= ex;
640 CORBA::TypeCode_var tc = tmp.type();
641 const char *p = tc->name();
642 if ( *p != '\0' )
643 msg <<p;
644 else
645 msg << tc->id();
646 msg << std::endl;
647 _errorDetails=msg.str();
648 throw Exception(msg.str());
649 }
650 catch(omniORB::fatalException& fe)
651 {
652 std::ostringstream msg;
653 msg << "Exception on remote python invocation." << std::endl ;
654 msg << "Caught omniORB::fatalException:" << std::endl;
655 msg << " file: " << fe.file() << std::endl;
656 msg << " line: " << fe.line() << std::endl;
657 msg << " mesg: " << fe.errmsg() << std::endl;
658 _errorDetails=msg.str();
659 throw Exception(msg.str());
660 }
661 DEBTRACE( "-----------------end of remote python invocation-----------------" );
662 //===========================================================================
663 // Get results, unpickle and put them in output ports
664 //===========================================================================
665 {
666#if PY_VERSION_HEX < 0x03070000
667 std::unique_lock<std::mutex> lock(data_mutex);
668#endif
669 AutoGIL agil;
670 DEBTRACE( "-----------------PythonNode::outputs-----------------" );
671 int nres( resultCorba->length() );
672
673 if(getNumberOfOutputPorts() != nres)
674 {
675 std::string msg="Number of output arguments : Mismatch between definition and execution";
676 _errorDetails=msg;
677 throw Exception(msg);
678 }
679 pos=0;
680 try
681 {
682 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); ++iter)
683 {
684 OutputPyPort *p=(OutputPyPort *)*iter;
685 DEBUG_YACSTRACE("Start of dealing with output " << p->getName() << " of "<< getId());
686 DEBTRACE( "port name: " << p->getName() );
687 DEBTRACE( "port kind: " << p->edGetType()->kind() );
688 DEBTRACE( "port pos : " << pos );
689 SALOME::SenderByte_var elt = (*resultCorba)[pos];
690 SeqByteReceiver recv(elt);
691 unsigned long length = 0;
692 char *resultCorbaC = recv.data(length);
693 {
694 AutoPyRef resultPython=PyMemoryView_FromMemory(resultCorbaC,length,PyBUF_READ);
695 AutoPyRef args = PyTuple_New(1);
696 PyTuple_SetItem(args,0,resultPython.retn());
697 AutoPyRef ob = PyObject_CallObject(_pyfuncUnser,args);
698 if (!ob)
699 {
700 std::stringstream msg;
701 msg << "Conversion with pickle of output ports failed !";
702 msg << " : " << __FILE__ << ":" << __LINE__;
703 _errorDetails=msg.str();
704 throw YACS::ENGINE::ConversionException(msg.str());
705 }
707 DEBUG_YACSTRACE("Assign PyObj output " << p->getName() << " of "<< getId());
708 p->put( ob );
709 DEBUG_YACSTRACE("End of assign PyObj output " << p->getName() << " of "<< getId());
710 }
711 pos++;
712 }
713 }
714 catch(ConversionException& ex)
715 {
716 _errorDetails=ex.what();
717 throw;
718 }
719 if(_autoSqueeze)
721 }
722 //
723 if(!isUsingPythonCache())
724 {
726 bool dummy;
727 Engines::Container_var cont(GetContainerObj(this,dummy));
728 cont->removePyScriptNode(getId().c_str());
729 }
730 DEBTRACE( "++++++++++++++ ENDOF PyNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
731}
static std::mutex data_mutex
Definition: PythonNode.cxx:90
Engines::Container_var GetContainerObj(InlineNode *reqNode, bool &isStandardCont)
Definition: PythonNode.cxx:139
#define DEBUG_YACSTRACE(msg)
Definition: YacsTrace.hxx:53
virtual Container * getContainer()
Definition: InlineNode.cxx:100
const std::string getId() const
Definition: Node.cxx:478
static void UnlinkOnDestructorIfProxy(PyObject *ob)
Definition: PythonNode.cxx:413
Engines::Container_var loadPythonAdapter(InlineNode *reqNode, bool &isInitializeRequested)
Definition: PythonNode.cxx:165
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
References _autoSqueeze, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::PythonEntry::_pyfuncSer, YACS::ENGINE::PythonEntry::_pyfuncUnser, _pynode, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, driver_internal::args, data_mutex, DEBTRACE, DEBUG_YACSTRACE, testCppPluginInvokation::ex, freeKernelPynode(), YACS::ENGINE::InlineNode::getContainer(), GetContainerObj(), YACS::ENGINE::Node::getId(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ElementaryNode::getNumberOfOutputPorts(), YACS::ENGINE::getSALOMERuntime(), YACS::ENGINE::InlineNode::getScript(), isUsingPythonCache(), YACS::ENGINE::PythonEntry::loadPythonAdapter(), orb, p, squeezeMemoryRemote(), and YACS::ENGINE::PythonEntry::UnlinkOnDestructorIfProxy().
◆ freeKernelPynode()
void PythonNode::freeKernelPynode ( )
Definition at line 967 of file PythonNode.cxx.
968{
969 if(!CORBA::is_nil(_pynode))
970 {
971 try
972 {
973 _pynode->UnRegister();
974 }
975 catch(...)
976 {
977 DEBTRACE("Trouble when pynode->UnRegister!")
978 }
979 _pynode = Engines::PyScriptNode::_nil();
980 }
981}
References _pynode, and DEBTRACE.
Referenced by assignRemotePyInterpretor(), createRemoteAdaptedPyInterpretor(), executeRemote(), shutdown(), and ~PythonNode().
◆ getContainerLog()
std::string PythonNode::getContainerLog ( )
returns a string that contains the name of the container log file if it exists
Do nothing here. To subclass
Definition at line 915 of file PythonNode.cxx.
916{
918}
static std::string GetContainerLog(const std::string &mode, Container *container, const Task *askingTask)
Definition: PythonNode.cxx:283
References YACS::ENGINE::InlineNode::_container, YACS::ENGINE::InlineNode::_mode, and YACS::ENGINE::PythonEntry::GetContainerLog().
◆ getRemoteInterpreterHandle()
Engines::PyNodeBase_var PythonNode::getRemoteInterpreterHandle ( )
Definition at line 1021 of file PythonNode.cxx.
1022{
1023 return Engines::PyNodeBase::_narrow(_pynode);
1024}
References _pynode.
◆ getSerializationScript()
const char * YACS::ENGINE::PythonNode::getSerializationScript ( ) const
inlineprotectedvirtual
Definition at line 84 of file PythonNode.hxx.
static const char SCRIPT_FOR_SERIALIZATION[]
Definition: PythonNode.hxx:124
◆ getSqueezeStatus()
bool YACS::ENGINE::PythonNode::getSqueezeStatus ( ) const
Definition at line 112 of file PythonNode.hxx.
112{ return _autoSqueeze; }
◆ hasImposedResource()
bool PythonNode::hasImposedResource ( ) const
overridevirtual
Reimplemented from YACS::ENGINE::PythonEntry.
Definition at line 946 of file PythonNode.cxx.
947{
949}
virtual bool hasImposedResource() const
Definition: PythonNode.cxx:326
References YACS::ENGINE::PythonEntry::hasImposedResource().
◆ imposeResource()
void PythonNode::imposeResource ( const std::string &  resource_name,
const std::string &  container_name
overridevirtual
Definition at line 931 of file PythonNode.cxx.
933{
934 if(!resource_name.empty() && !container_name.empty())
935 {
936 _imposedResource = resource_name;
937 _imposedContainer = container_name;
938 }
939}
Definition: PythonNode.hxx:69
Definition: PythonNode.hxx:70
References YACS::ENGINE::PythonEntry::_imposedContainer, and YACS::ENGINE::PythonEntry::_imposedResource.
◆ isUsingPythonCache()
bool PythonNode::isUsingPythonCache ( ) const
Definition at line 959 of file PythonNode.cxx.
960{
961 bool found = false;
962 if(_container)
964 return found;
965}
virtual bool isUsingPythonCache()
Definition: Container.cxx:109
References YACS::ENGINE::InlineNode::_container, and YACS::ENGINE::Container::isUsingPythonCache().
Referenced by executeLocal(), executeRemote(), and pythonEntryName().
◆ load()
void PythonNode::load ( )
Definition at line 481 of file PythonNode.cxx.
482{
483 DEBTRACE( "---------------PyNode::load function---------------" );
485 loadRemote();
486 else
487 loadLocal();
488}
virtual void loadLocal()
Definition: PythonNode.cxx:490
virtual void loadRemote()
Definition: PythonNode.cxx:496
References YACS::ENGINE::InlineNode::_mode, DEBTRACE, loadLocal(), loadRemote(), and REMOTE_NAME.
◆ loadLocal()
void PythonNode::loadLocal ( )
Definition at line 490 of file PythonNode.cxx.
491{
492 DEBTRACE( "---------------PyNode::loadLocal function---------------" );
493 // do nothing
494}
References DEBTRACE.
Referenced by load().
◆ loadRemote()
void PythonNode::loadRemote ( )
Definition at line 496 of file PythonNode.cxx.
497{
498 commonRemoteLoad(this);
499}
void commonRemoteLoad(InlineNode *reqNode)
Definition: PythonNode.cxx:318
References YACS::ENGINE::PythonEntry::commonRemoteLoad().
◆ pythonEntryName()
std::string PythonNode::pythonEntryName ( ) const
Definition at line 951 of file PythonNode.cxx.
952{
954 return "DEFAULT_NAME_FOR_UNIQUE_PYTHON_NODE_ENTRY";
955 else
956 return getId();
957}
References YACS::ENGINE::Node::getId(), and isUsingPythonCache().
Referenced by createRemoteAdaptedPyInterpretor(), and retrieveDftRemotePyInterpretorIfAny().
◆ retrieveDftRemotePyInterpretorIfAny()
Engines::PyNodeBase_var PythonNode::retrieveDftRemotePyInterpretorIfAny ( Engines::Container_ptr  objContainer) const
Definition at line 995 of file PythonNode.cxx.
996{
997 Engines::PyScriptNode_var ret(objContainer->getDefaultPyScriptNode(pythonEntryName().c_str()));
998 if(!CORBA::is_nil(ret))
999 {
1000 ret->Register();
1001 }
1002 return Engines::PyNodeBase::_narrow(ret);
1003}
References pythonEntryName().
◆ setSqueezeStatus()
void YACS::ENGINE::PythonNode::setSqueezeStatus ( bool  sqStatus)
Definition at line 111 of file PythonNode.hxx.
111{ _autoSqueeze=sqStatus; }
Referenced by main(), and setSqueezeStatusWithExceptions().
◆ setSqueezeStatusWithExceptions()
void PythonNode::setSqueezeStatusWithExceptions ( bool  sqStatus,
const std::vector< std::string > &  squeezeExceptions
[EDF28562]
insqueezeExceptions list on output port name excluded from the squeeze mecanism
Definition at line 864 of file PythonNode.cxx.
865{
866 this->setSqueezeStatus(sqStatus);
867 this->_nonSqueezableOutputNodes = std::set<std::string>(squeezeExceptions.begin(), squeezeExceptions.end());
868}
void setSqueezeStatus(bool sqStatus)
Definition: PythonNode.hxx:111
References _nonSqueezableOutputNodes, and setSqueezeStatus().
◆ shutdown()
void PythonNode::shutdown ( int  level)
Stop all pending activities of the node.
This method should be called when a Proc is finished and must be deleted from the YACS server
Definition at line 920 of file PythonNode.cxx.
921{
922 DEBTRACE("PythonNode::shutdown " << level);
923 if(_mode=="local")return;
924 if(_container)
925 {
927 _container->shutdown(level);
928 }
929}
virtual void shutdown(int level)=0
References YACS::ENGINE::InlineNode::_container, YACS::ENGINE::InlineNode::_mode, DEBTRACE, freeKernelPynode(), and YACS::ENGINE::Container::shutdown().
◆ simpleClone()
Node * PythonNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 983 of file PythonNode.cxx.
984{
985 return new PythonNode(*this,father);
986}
References PythonNode().
◆ squeezeMemory()
void PythonNode::squeezeMemory ( )
Definition at line 879 of file PythonNode.cxx.
880{
881 for(auto p : _setOfInputPort)
882 {
883 PyDict_DelItemString(_context,p->getName().c_str());
884 InputPyPort *p2(static_cast<InputPyPort *>(p));
885 if(p2->canSafelySqueezeMemory())
886 p2->put(Py_None);
887 }
888 for(auto p : _setOfOutputPort)
889 {
890 if (!this->_nonSqueezableOutputNodes.empty() && this->_nonSqueezableOutputNodes.find(p->getName()) != this->_nonSqueezableOutputNodes.end())
891 continue;
892 PyDict_DelItemString(_context,p->getName().c_str());
893 OutputPyPort *p2(static_cast<OutputPyPort *>(p));
894 p2->putWithoutForward(Py_None);
895 }
896}
References YACS::ENGINE::PythonEntry::_context, _nonSqueezableOutputNodes, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::InPort::canSafelySqueezeMemory(), YACS::ENGINE::ComposedNode::getName(), p, YACS::ENGINE::InputPyPort::put(), and YACS::ENGINE::OutputPyPort::putWithoutForward().
Referenced by executeLocal(), and squeezeMemorySafe().
◆ squeezeMemoryRemote()
void PythonNode::squeezeMemoryRemote ( )
Definition at line 898 of file PythonNode.cxx.
899{
900 for(auto p : _setOfInputPort)
901 {
902 InputPyPort *p2(static_cast<InputPyPort *>(p));
903 if(p2->canSafelySqueezeMemory())
904 p2->put(Py_None);
905 }
906 for(auto p : _setOfOutputPort)
907 {
908 if (!this->_nonSqueezableOutputNodes.empty() && this->_nonSqueezableOutputNodes.find(p->getName()) != this->_nonSqueezableOutputNodes.end())
909 continue;
910 OutputPyPort *p2(static_cast<OutputPyPort *>(p));
911 p2->putWithoutForward(Py_None);
912 }
913}
References _nonSqueezableOutputNodes, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::InPort::canSafelySqueezeMemory(), YACS::ENGINE::ComposedNode::getName(), p, YACS::ENGINE::InputPyPort::put(), and YACS::ENGINE::OutputPyPort::putWithoutForward().
Referenced by executeRemote(), and squeezeMemorySafe().
◆ squeezeMemorySafe()
void PythonNode::squeezeMemorySafe ( )
Definition at line 870 of file PythonNode.cxx.
871{
872 AutoGIL agil;
874 this->squeezeMemoryRemote();
875 else
876 this->squeezeMemory();
877}
References YACS::ENGINE::InlineNode::_mode, REMOTE_NAME, squeezeMemory(), and squeezeMemoryRemote().
◆ typeName()
virtual std::string YACS::ENGINE::PythonNode::typeName ( )
Definition at line 108 of file PythonNode.hxx.
108{ return "YACS__ENGINE__PythonNode"; }
◆ _autoSqueeze
bool YACS::ENGINE::PythonNode::_autoSqueeze = false
Definition at line 128 of file PythonNode.hxx.
Referenced by executeLocal(), and executeRemote().
◆ _nonSqueezableOutputNodes
std::set<std::string> YACS::ENGINE::PythonNode::_nonSqueezableOutputNodes
Definition at line 130 of file PythonNode.hxx.
Referenced by setSqueezeStatusWithExceptions(), squeezeMemory(), and squeezeMemoryRemote().
◆ _pynode
Engines::PyScriptNode_var YACS::ENGINE::PythonNode::_pynode
◆ DPL_INFO_NAME
const char PythonNode::DPL_INFO_NAME ="my_dpl_localization"
Definition at line 126 of file PythonNode.hxx.
Referenced by applyDPLScope().
◆ IMPL_NAME
◆ KIND
◆ REMOTE_NAME
const char PythonNode::REMOTE_NAME ="remote"
◆ SCRIPT_FOR_SERIALIZATION
const char PythonNode::SCRIPT_FOR_SERIALIZATION
Initial value:
="import pickle\n"
"def pickleForDistPyth2009(kws):\n"
" return pickle.dumps(((),kws),-1)\n"
"\n"
"def unPickleForDistPyth2009(st):\n"
" args=pickle.loads(st)\n"
" return args\n"
Definition at line 124 of file PythonNode.hxx.
