YACS::ENGINE::HomogeneousPoolContainer Class Referenceabstract
#include <HomogeneousPoolContainer.hxx>
Inheritance diagram for YACS::ENGINE::HomogeneousPoolContainer:
Collaboration diagram for YACS::ENGINE::HomogeneousPoolContainer:
void attachOnCloning () const
void dettachOnCloning () const
bool isAttachedOnCloning () const
void setAttachOnCloningStatus (bool val) const
virtual void assignPG (const PlayGround *pg)
std::mutex & getLocker () const
virtual void setSizeOfPool (int sz)=0
virtual int getSizeOfPool () const =0
virtual std::size_t getNumberOfFreePlace () const =0
virtual void allocateFor (const std::vector< const Task * > &nodes)=0
virtual void release (const Task *node)=0
virtual int getNumberOfCoresPerWorker () const =0
- Public Member Functions inherited from YACS::ENGINE::Container
virtual std::string getKind () const =0
virtual std::string getDiscreminantStrOfThis (const Task *askingNode) const
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void start (const Task *askingNode)=0
virtual void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name)
virtual bool isUsingPythonCache ()
virtual void usePythonCache (bool v)
virtual std::string getPlacementId (const Task *askingNode) const =0
virtual std::string getFullPlacementId (const Task *askingNode) const =0
virtual void setAttachOnCloningStatus (bool val) const
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
virtual bool isAttachedOnCloning () const
virtual void lock ()=0
virtual void unLock ()=0
virtual Container * clone () const =0
 WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method More...
virtual Container * cloneAlways () const =0
virtual bool isSupportingRTODefNbOfComp () const
virtual void checkCapabilityToDealWith (const ComponentInstance *inst) const =0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name) const =0
virtual void clearProperties ()=0
virtual void addComponentName (const std::string &name)=0
virtual std::map< std::string, std::string > getProperties () const =0
virtual std::map< std::string, std::string > getResourceProperties (const std::string &name) const =0
virtual void setProperties (const std::map< std::string, std::string > &properties)
virtual std::string getName () const
void setName (std::string name)
 WARNING ! name is used in edition to identify different containers, it is not the runtime name of the container More...
void setProc (Proc *proc)
Proc * getProc ()
virtual void shutdown (int level)=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char SIZE_OF_POOL_KEY [] ="SizeOfPool"
static const char INITIALIZE_SCRIPT_KEY [] ="InitializeScriptKey"
- Static Public Attributes inherited from YACS::ENGINE::Container
static const char KIND_ENTRY [] ="container_kind"
static const char AOC_ENTRY [] ="attached_on_cloning"
static const char USE_PYCACHE_PROPERTY [] ="use_py_cache"
 HomogeneousPoolContainer ()
virtual ~HomogeneousPoolContainer ()
const PlayGround * getPG () const
- Protected Member Functions inherited from YACS::ENGINE::Container
 Container ()
virtual ~Container ()
 RefCounter ()
virtual ~RefCounter ()
YACS::BASES::AutoConstRefCnt< PlayGround > _pg
- Protected Attributes inherited from YACS::ENGINE::Container
bool _isAttachedOnCloning
Proc * _proc
unsigned int _cnt
This is an abstract class, that represents a set of fixed number of worker "kernelcontainers" homegenous in the sense that can be used indifferently each other. But each of those worker pool can be used once at a time.
Definition at line 39 of file HomogeneousPoolContainer.hxx.
◆ HomogeneousPoolContainer()
HomogeneousPoolContainer::HomogeneousPoolContainer ( )
◆ ~HomogeneousPoolContainer()
HomogeneousPoolContainer::~HomogeneousPoolContainer ( )
Definition at line 67 of file HomogeneousPoolContainer.cxx.
68{
69}
◆ allocateFor()
virtual void YACS::ENGINE::HomogeneousPoolContainer::allocateFor ( const std::vector< const Task * > &  nodes)
pure virtual
◆ assignPG()
void HomogeneousPoolContainer::assignPG ( const PlayGround *  pg)
Reimplemented in YACS::ENGINE::SalomeHPContainer.
Definition at line 43 of file HomogeneousPoolContainer.cxx.
44{
45 _pg.takeRef(pg);
46}
References _pg.
Referenced by YACS::ENGINE::SalomeHPContainer::assignPG().
◆ attachOnCloning()
void HomogeneousPoolContainer::attachOnCloning ( ) const
By calling this method the current container 'this' is not destined to be deeply copied on clone call.
Reimplemented from YACS::ENGINE::Container.
Definition at line 29 of file HomogeneousPoolContainer.cxx.
30{
32}
References YACS::ENGINE::Container::_isAttachedOnCloning.
◆ dettachOnCloning()
void HomogeneousPoolContainer::dettachOnCloning ( ) const
By calling this method the current container 'this' will be deeply copied on clone call.
Definition at line 48 of file HomogeneousPoolContainer.cxx.
49{
51 throw Exception("An HomogeneousPoolContainer cannot be detached on cloning !");
52}
◆ getLocker()
◆ getNumberOfCoresPerWorker()
virtual int YACS::ENGINE::HomogeneousPoolContainer::getNumberOfCoresPerWorker ( ) const
pure virtual
◆ getNumberOfFreePlace()
virtual std::size_t YACS::ENGINE::HomogeneousPoolContainer::getNumberOfFreePlace ( ) const
pure virtual
◆ getPG()
◆ getSizeOfPool()
virtual int YACS::ENGINE::HomogeneousPoolContainer::getSizeOfPool ( ) const
pure virtual
◆ isAttachedOnCloning()
bool HomogeneousPoolContainer::isAttachedOnCloning ( ) const
By definition an HomogeneousPoolContainer instance is attached on cloning.
Definition at line 57 of file HomogeneousPoolContainer.cxx.
58{
59 return true;
60}
◆ release()
virtual void YACS::ENGINE::HomogeneousPoolContainer::release ( const Task *  node)
pure virtual
◆ setAttachOnCloningStatus()
void HomogeneousPoolContainer::setAttachOnCloningStatus ( bool  val) const
If val is equal to true the current container 'this' is not destined to be deeply copied on clone call. If val is equal to false the current container 'this' is destined to be deeply copied on clone call.
Definition at line 34 of file HomogeneousPoolContainer.cxx.
35{
37 if(val)
38 return ;
39 else
40 throw Exception("An HomogeneousPoolContainer cannot be detached on cloning #2 !");
41}
◆ setSizeOfPool()
virtual void YACS::ENGINE::HomogeneousPoolContainer::setSizeOfPool ( int  sz)
pure virtual
◆ _pg
YACS::BASES::AutoConstRefCnt<PlayGround> YACS::ENGINE::HomogeneousPoolContainer::_pg
Definition at line 65 of file HomogeneousPoolContainer.hxx.
Referenced by assignPG(), and getPG().
◆ INITIALIZE_SCRIPT_KEY
◆ SIZE_OF_POOL_KEY
